Wingrider
Joined: 22 Nov 2006 Posts: 34 Location: Tullahoma, TN
Posted: Thu Nov 30, 2006 6:06 am Post subject: Alternator Recommendations |
Hi, I am new to the Matronics newsgroups although I have been reading the post for a while this is my first time writing in.
I'm building a Zenith 601HDS and will probably go with William Wynne's Corvair conversion. I'm trying to figure my electrical loads before installing the landing lights and closing up the wings and don't believe the typical JD garden tractor alternator is sufficient for my application; I expect a full load amp draw of between 35 and 40 amps. Maybe I'm way off base and maybe I shouldn't use a pair of 100 watt off road lights for landing lights.
I'd like your recommendations for a small lightweight automotive alternator. From what I’ve read it sounds like I should stick with the three wire alternators and shy away from the one wire versions but are there recommendations for specific alternators?
There seems to be differing opinions on the whether the load dump issue is a real concern or not. I understand Bob Nuckolls is working on a product to nullify the concern with using internally regulated alternators. Is there any news on this product at this time?
Attached is my initial swag at my electrical loads.
Description: |
 Download |
Filename: |
CH601HDS Electrical Loads Analysis1.xls |
Filesize: |
16 KB |
Downloaded: |
526 Time(s) |
_________________ Rich Whittington
Tullahoma, TN
Zenith 601HDS
Corvair 3 Liter 120HP |
frank.hinde(at)hp.com Guest
Posted: Thu Nov 30, 2006 7:32 am Post subject: Alternator Recommendations |
Personally I don't have an issue with one wire alternators, I ran one in my Zodiac for over 400 hours and it worked flawlessly. This is assuming you don't have hugely expensive avionics stack either...In my IFR RV7 I still run a one wire but have an Overvolt circuit and contactor...But I still don't expect any real issues.
Bob will point out that many doggy old spam cans are running alternators that came out of the Ark!
Anyway, the homebuilders choice for many years has been the 1987 Suzuki Samuri Alternator..Its a real gem, lightwieght, powerful (55amps in theory) and extremely reliable...The only time mine acted up was when the back of the alt was continually sprayed with oil that worked itsway to the brushes, then it became intermittent.
Replaced the brushes and it was fine.
As to your loads, you really don't need to assume your landing lights are part of your running loads as these should only be used intermittently...Having said that, if your running electric fuel pumps only then there is a risk of leaving your LL on and pulling down the battery voltage...I would use a small LED as a warning that you have your lights on.
The Suzuki alternator will fit your requirements very nicely however.
Frank
nuckollsr(at)cox.net Guest
Posted: Thu Nov 30, 2006 8:20 am Post subject: Alternator Recommendations |
landing lights.
I've acquired an alternator drive stand and hope
to spend some time getting it wired up over the
xmas holidays. In any case, the internally regulated
automotive alternator is the wave of the future and
certainly the better value. Drive ahead with any
alternator choice that meets your power requirements
knowing that any enhancements to the alternator's
operability are easily added on at a later time.
klehman(at)albedo.net Guest
Posted: Thu Nov 30, 2006 10:11 am Post subject: Alternator Recommendations |
Hi Rich
FWIW I run an electonic ignition, EFI, and two 38 watt halogen projector
lights wig wagging, but not much in the way of avionics and I typically
see just over 20 amps daytime and about 26 amps when I add the nav
lights. Even at night with the two 38 watt lights on continuously plus
two 50 watt landing lights for approach, my wee 40 amp nippondenso (with
a homemade large pulley to slow it) still seems to maintain voltage.
I've never seen the low voltage warning on the ground either although I
usually kill the two 50 watt landing lights while taxiing. While in
theory it is fine if the landing lights draw down the battery a tiny bit
on approach, it would be a distraction to get a low voltage warning on
final. You would either learn to ignore the warning (not good) or
disable it when the lights are on which is also not good. My 88 watts
per wing of halogen landing and taxi lights is perhaps more than needed
but it is appreciated on black nights on runways with no approach lights.
Now I also run a 20 amp John Deere PM alternator on a separate system
which drives backup EFI, ignition, and strobe lights. It really does put
out 20 amps in flight but its output falls off rapidly such that it will
not maintain voltage with all those things running during normal ground
handling. So while a single John Deere is adequate for daytime operation
without exterior lights, you are correct that it would not be very
satisfactory for ground running at night for me. With a carb and no EFI
electric fuel pumps the 20 amps would be fine I think but exterior
lighting would have to be watched on the ground at night and I'd also be
looking for LED nav lights. I don't know what your Fujitsu thing is but
my conventional nav lights draw a lot more than the 1 amp on your
spreadsheet. My ignition also draws a couple of amps. One amp seems a
bit low for ignition. Electronic ignition may draw considerably more at
high rpm than at idle. The corvair would likely spin the John Deere
faster than I am though so that might help.
BTW I don't see any real difference between a "one wire" alternator and
a automotive internally regulated alternator. The warning light function
usually doesn't make a good low voltage warning. The ability to remote
sense the voltage that some regulators have doesn't make much difference
to us. The ability to delay turnng on the alternator until after engine
start also has little value and is not normally used. We know that some
of the oem alternators can be turned off but many of us don't believe
one can count on that function either once a regulator has failed - so
again not much value to that.
Ken
I'd like your recommendations for a small lightweight automotive alternator. From what Iâ¬"ve read it sounds like I should stick with the three wire alternators and shy away from the one wire versions but are there recommendations for specific alternators?
Rich Whittington
Tullahoma, TN
Zenith 601HDS Under Construction
Wingrider
Posted: Thu Nov 30, 2006 5:31 pm Post subject: Re: Alternator Recommendations |
Thanks for the information, I'll research the Suzuki alternator. The Fujitsu is a Tablet PC I plan to attach to the panel for gps navigation using PocketFMS and Voyager.
My nav lights are LED's that's why the amp draw is so low. Now I just have to figure out how to mount an alternator to the rear of the Corvair.
Tullahoma, TN
Zenith 601HDS
mwcreek(at)frontiernet.ne Guest
Posted: Thu Nov 30, 2006 5:56 pm Post subject: Alternator Recommendations |
Rich,
I just went through this for my Bearhawk. I spent a lot of time trying to
find a Samurai alternator; they are no longer available new. Niagra Airparts
no longer carries the ND, either. I did find and ND 45 amp internally
regulated alternator for $175 at:
http://www.litechracesystems.com/Products.html
It arrived this week and is a new ND part no. 18504-6220.
Good luck,
Mike C.
Posted: Fri Dec 01, 2006 8:20 am Post subject: Alternator Recommendations |
When alternator shopping based on the recommendations
of others, it's useful to know that there's no such
thing as a "Honda" or "GEO_Metro" alternator. 95% of
the world's supply of alternators is manufactured
by a handful of companies of which folks like Bosch
and Nipon Denso are major players.
It's unfortunate that so many different versions of
electrically identical alternators are offered in so
many mechanical variations. But this is like choosing and/or
attempting to mandate the language of measurement. It's
an attractive idea but fruitless to suggest that all
auto manufacturers get together and pick a suite of say 25 parts
around which everyone will design their electrical
systems. Certainly the parts jobbers and dealers
would be delighted . . . as perhaps customers. They'd
certainly cost less.
Bottom line is that on the shelves of any well
stock parts supplier, there are dozens of alternators
that will perform just fine in your airplane. The
value in selecting a "Honda" alternator may come from
the fact that somebody has published drawings for
the mechanical interface between THAT particular
alternator and YOUR engine.
Just keep in mind that electrical and quality issues
are tiny considerations compared to size, weight
and ease of integration into your airframe . . . and
that the number of choices open to you run far beyond
anyone's particular preferences or recommendations.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Fri Dec 01, 2006 8:51 am Post subject: Alternator Recommendations |
Yes Bob I agree, but there are alternators that have less than a stella
reputation, the Van 35A "Honda" alternator being a case in point.
The "Suzuki Samurai" is a ND unit and for the life of me I can't find
the ND part number. It was indeed used on many cars the biggest
difference being whether it was fitted with a V belt pully or a
serpentine. When I found my 80A "Toyota Camry" alt for my IFR RV it cam
with a serp pulley, An alternator rebuilder kindly found me a v pulley
that fitted. Once you get past the pulley the rest is just fabricating
suitable brackets to suit.
I would post a note to the "Stratus group" as someone on there will have
the part number handy. I would be very surprised if this alt was no
longer available.
Cheers
Frank
robh(at)hyperion-ef.us Guest
Posted: Fri Dec 01, 2006 10:30 am Post subject: Alternator Recommendations |
That's the one!...I had to shorten the link to make it work by removing
the "wizrd.js" part then I could step thru to 1987 Suz samurai.
$130 for a new alt...Can't beat that with a stick!
Frank
Wingrider
