Posted: Thu Nov 30, 2006 7:05 am Post subject: Control Cable |
Morning Bob B:
Took the liberty of changing the subject line to something a little
more appropriate.
Don't know if a dab of grease would help or not. Probably would, if
it did not also attract dirt and grit.
Not a big problem, but something to keep you eye on if you put a lot
of hours on your mkIII.
I can't remember how many times I have changed out the rudder and
elevator cables over the 2500 hours my mkIII has been flying, but not
that often.
_________________ John Hauck
Titus, Alabama |
Posted: Thu Nov 30, 2006 7:21 am Post subject: Control Cable |
| Another serious elevator issue that I have seem on some kolbs is
with
| cable turnbuckles. Where turnbuckles are bolted directly to the
| control horn on the stick sometimes there is not enough clearance
| for full stick movement in the yoke of the turnbuckle causing the
| yoke of the turnbuckle to bottom out on the horn causing bending
| side pressure on the stem of the turnbuckle. This condition will
| eventually cause the turnbuckle to fail. The solution is to file or
| grind the control horn to allow for full stick movement without the
| yoke of the turnbuckle bottoming out on the horn.
| Gene
Gene Z:
I have also seen this turn buckle clearance problem on Kolbs. You are
absolutely right. It will eventually cause the turn buckle to fail.
I remember Old Kolb sending out a supplemental change to grind out
clearance on a Firestar control stick to prevent this from happening.
Another place that a cable gets bent with a hard side load is the
forward end of the throttle cable, where it is attached to the clevis.
If it bends enough it will eventually break.
These are areas that need to be checked and corrected before they
break.
Thanks for the turn buckle problem. I had forgotten about that one.
I changed the subject line to reflect what we are discussing.
Titus, Alabama |
ul15rhb(at)juno.com Guest
Posted: Thu Nov 30, 2006 10:57 am Post subject: Control Cable |
John and all, I've never changed elevator or rudder cables in the 20
years of flying my Kolb. I've inspected them many times and they are
still good.
Ralph
Original Firestar
20 years flying it
-- "John Hauck" <jhauck(at)elmore.rr.com> wrote:
Morning Bob B:
more appropriate.
that often.
Posted: Thu Nov 30, 2006 12:58 pm Post subject: Control Cable |
20
| still good.
| Ralph
Hi Ralph:
That is great!
Now, how does 20 years flying equate to hours flown?
Flight hours gives us a better idea of how much use/wear has been
placed on a piece of equipment. Most Kolb owners don't fly 50 hours a
year, and many of them do not log their flight time.
Guess you are getting geared up to start flying off the ice.
I change mine out about every 1,000 hours.
Titus, Alabama |
Posted: Thu Nov 30, 2006 7:07 pm Post subject: Control Cable |
John, sorry about not posting the hours. I have 810 hours on the
Firestar in 20 years. I'm a weekend flyer.
Ralph
Original Firestar
20
| still good.
| Ralph
Hi Ralph:
That is great!
Thom Riddle
Posted: Fri Dec 01, 2006 6:54 am Post subject: Re: Control Cable |
For those of you who do not have your very own AC 43.13, here is a link to the section about aircraft cables. Very informative.
http://www2.tech.purdue.edu/at/courses/at308/Technical_Links/Ac43-13-1B/CH7_8.pdf
Here it is in as a Tiny URL, in case the previous one line wraps.
http://tinyurl.com/ymlu68
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Fri Dec 01, 2006 12:32 pm Post subject: Control Cable |
I have two nicros at each end of the cable. The ends of the cable are
just inside the end of the last nicro in the uncompressed part.
Testing? Is 20 years 810 hours long enough?
I've noticed the cables have stretched. I will replace them in a
couple of years. There are no broken strands under the pulleys even
when they are twisted backwards. The cables have lasted a long time
due to the light load and the small angle around the pulleys.
Ralph
Original Firestar
20 years flying it
Ralph
Original Firestar
20
| still good.
| Ralph
Hi Ralph:
That is great!
a
__
WhiskeyVictor36(at)aol.co Guest
Posted: Fri Dec 01, 2006 6:33 pm Post subject: Control Cable |
In a message dated 12/1/2006 3:35:09 P.M. Eastern Standard Time, ul15rhb(at)juno.com writes:
| Quote: | | Testing? Is 20 years 810 hours long enough? |
Hi there Ralph,
I see that you are heeding John Haucks advice and including testing data now. hehehe
Bill Varnes
Original Kolb FireStar
Audubon NJ
