jfogarty(at)tds.net Guest
Posted: Wed Nov 29, 2006 10:26 am Post subject: Bell Crank Brass Bushing |
What is the best way to size the bushing to 1/4" to receive the AN4 bolt on the RV9 bell crank for the aileron. I think this should be done with my drill press, however, it is hard to keep the bushing straight, please let me know what you think and how you did it. Thanks.
Jim
dale1rv6(at)comcast.net Guest
Posted: Wed Nov 29, 2006 11:13 am Post subject: Bell Crank Brass Bushing |
I would use a lathe. There should be someone nearby that would be glad to help you, does not have to be an airplane builder. Or a machine shop would not charge much.
Dale
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Jim Fogarty at Lakes & Leisure Realty
Sent: Wednesday, November 29, 2006 1:25 PM
To: rv-list(at)matronics.com
Subject: Bell Crank Brass Bushing
Jim
| Quote: | | www.aeroelectric.com | 0123456789012345
bicyclop(at)pacbell.net Guest
Posted: Wed Nov 29, 2006 11:44 am Post subject: Bell Crank Brass Bushing |
Use a reamer in a hand held drill, with lubricant at very low speed. You can clamp it in a vise with padded jaws. Reams are available at Cleaveland, Brown, Avery and machine tool dealers.
Pax,
Ed Holyoke
Michael Wynn
Joined: 10 Jan 2006 Posts: 148 Location: San Ramon, CA
Posted: Wed Nov 29, 2006 9:30 pm Post subject: Bell Crank Brass Bushing |
Hi Jim
I tried using a reamer in my drill press. Mucked it up pretty well. I went to my riveting buddy who is an amateur machinist. We used the reamer on a metal lath. Very slick and perfectly round. However, that was sort of overkill. The bolt really just needs to be down the bushing, fairly centrally. The actual bearing surface is the outside of the bushing against the inside of the bellcrank. So, having a perfectly reamed interior is not really crucial. What is crucial is that you don't scrape up the exterior of the bushing while trying to hold it still to ream the interior.
Michael Wynn
RV-8, Fuselage
San Ramon, California
_________________ Michael Wynn
RV 8
San Ramon, CA |
Vanremog(at)aol.com Guest
Posted: Wed Nov 29, 2006 9:36 pm Post subject: Bell Crank Brass Bushing |
I've used a standard reamer backing it thru the bushing, shaft end first, then chuck up to something you can turn at hand speed as you back ream the bushing.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 822hrs, Silicon Valley, CA)
jconnell(at)rconnect.com Guest
Posted: Thu Nov 30, 2006 9:39 am Post subject: Bell Crank Brass Bushing |
Hi Jim,
When I did mine (it's been a few years) I initially put
the bushing material in the drill press (hand tighten only.)
I had marked the approximate length with the Sharpie pen.
The drill was run at a slow speed and the Sharpie mark
was visible as it turned. I used a Dremel tool with a cut-off
wheel (one of those with a fiberglass mesh imbedded to keep
the wheel from coming apart. Once this was done I lowered
the bushing onto some emery paper to square and polish the
end.
If the bolt would not fit in the bushing I would use a de-burring tool
to make sure there was no ridge at either end. The bushing was placed
in a padded vise and a reamer was slowly run through the bushing.
I used a reamer on the bellcrank to insure the hole was true
after is was welded and powder-coated. If the bronze bushing
was tight I would put a bolt through the bushing and mount
the bolt in the drill press chuck (hand tighten.) I'd run the
drill a little faster and use some emery paper to as a tool to
remove a bit from the gushing. I could do a trial fit with the bellcrank
while the bushing was still in the drill press...
Joe Connell
Stewartville, MN
RV-9A FAB and carb fitting
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Thu Nov 30, 2006 12:13 pm Post subject: Re: Bell Crank Brass Bushing |
I probably shouldn't admit this but I just used a hand drill to ream out the bushing. And I held it with a pair of pliars after wrapping it with a cloth. I don't think I got it perfectly centered.. it took a little work to get the bolt to slip in nicely. And afterwards I cleaned up the outside by running it on the Scotchbrite Wheel (fine). I'm sure the ways suggested would yield a perfect result, but I've seen nothing in the operation of the bellcrank as installed to indicate I've created any sort of problem doing it via the fast method. Of course, the plane isn't flying yet.
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Brad Oliver
Posted: Thu Nov 30, 2006 1:25 pm Post subject: Bell Crank Brass Bushing |
I haven't done this yet, so I should probably just keep my head down and
my mouth shut, but it is a slow day at work. Here is what I am
*thinking* of doing when the time comes, which should be very soon. It
may seem convoluted, but it should only take a few minutes. Please,
somebody tell me I am crazy, or shoot holes in my proposed method.
1. On the the drill press, drill a small (3" square or so) scrap piece
of wood with drill bit that is equal to or slightly smaller than the OD
of the bushing. If you have a drill press vise, this step may not be
necessary.
2. Cut the wood in half bisecting the circle you just drilled
3. Insert bushing between pieces of wood and clamp (in drilled hole).
Cutting the wood in half should have removed enough material to allow
you to clamp the bushing so it won't move, if not, sand away some of
the wood along where you just cut to allow it to clamp the bushing.
4. Locate a drill bit that is equal to the ID of the bushing, and insert
it into the drill press (hopefully it is a common size).
5. Put the clamped bushing assembly onto drill press table and crank
down the bit (while drill press is off) into the bushing to center the
clamped bushing assembly on the drill bit, then while the bit is
holding the assembly centered, clamp the the assembly to the table.
6. Release the handle and remove the bit, then insert the appropriate
reamer and ream away. Theoretically, the reamer should be centered
perfectly (I hope).
If someone is brave enough to try this before I get to it, please let me
know how it works out.
Brad Oliver
RV-7 | Livermore, CA
www.RV7Factory.com
[quote] ------
gerf(at)gerf.com Guest
Posted: Thu Nov 30, 2006 1:42 pm Post subject: Bell Crank Brass Bushing |
It is worth getting this right - because you follow a very
similar process in the fuselage kit for the control stick
bushing. I goofed mine up trying to use a regular drill bit in
drill press. The upshot is that my control stick wobbles
around like a p**** in a bucket. Needless to say I'll be
re-doing the bushing shortly.
I think the idea behind the reamer in an hand drill is that the
existing hole in the bushing will "guide" the reamer into a
coaxial position, I think
g
Bob Collins
St. Paul, Minn.
RV Builder's Hotline (free!)
http://home.comcast.net/~rvnewsletter/
http://forums.matronics.com/viewtopic.php?p=78236#78236
__g__
Gerry Filby gerf(at)gerf.com
Bob Collins
Posted: Thu Nov 30, 2006 2:38 pm Post subject: Re: Bell Crank Brass Bushing |
Sure, but I guess my point is, what is right? Like I said, I did it a quick way at the time -- I didn't have a drill press, nor a set of reamers -- and it came out OK and the control stick bushings came out the same way. As near as I can tell, there's no binding that's occurring, the bolt fits in snugly, but fits and everything seems OK. I'd certainly be interested in how others - especially old-timers - have approached this part.
St. Paul, Minn.
jmsears(at)adelphia.net Guest
Posted: Thu Nov 30, 2006 2:54 pm Post subject: Bell Crank Brass Bushing |
| Quote: | > Sure, but I guess my point is, what is right? Like I said, I did it a
> part.<<
I didn't have a lathe or reamers, either. I put mine in a vice, started
with a bit that just barely cut metal, and increased bits in size by a
little on each drill pass until the hole was just big enough for the bolt to
pass through nicely. My process took several passes per bushing. I also
drilled out the weldment to allow the bushing to fit inside that. So far,
I've done this on three RVs with no problems.
Now, to add another twist, so to speak. My IA buddy told me the preferred
method for the bushing is to make the bushing stationary in the weldment and
allow the assembly to rotate around the bolt. That way, the bolt wears out
instead of the weldment. That's what I did in my first RV. I did the more
popular method of letting the bushing rotate in the last two. Which is
better, I have no idea. It will probably take more than my lifetime to
prove either out. Both work smoothly; and, I guess that's the main thing.
Jim Sears in KY
RV-6A N198JS (Scooter)
RV-7A #70317 (Fuselage on hold due to pure laziness.)
EAA Tech Counselor
dan(at)rvproject.com Guest
Posted: Thu Nov 30, 2006 4:00 pm Post subject: Bell Crank Brass Bushing |
You done good. Press on.
This is one of those items where obsessing over a clean hole is irrelevant.
The stick/bellcrank rotates around the stationary brass bushing, AS PER
PLANS (RV-7[A]). The hole through the middle of the bushing can be ratty
and burry and all that and it doesn't make a bit of difference. If you can
get a bolt through, you're done.
)_( Dan
hooverra(at)verizon.net Guest
Posted: Thu Nov 30, 2006 5:21 pm Post subject: Bell Crank Brass Bushing |
Brad,
I have used your method many times prior to owning a lathe with one
variation. Make the block longer about 4 x 1.5 x 3/4, cut the slot first
and then clamp the slot closed. Now drill your hole = to the bushing OD,
now when you un-clamp the block the bushing will fit and can be clamped
tight. If the saw kerf is too wide just clamp it partially closed
prior to drilling (a piece of thin cardboard helps). Now proceed as you
describe.
Good luck.
Ralph Hoover
RV7A (wiring)
rv8builder(at)earthlink.n Guest
Posted: Thu Nov 30, 2006 7:10 pm Post subject: Bell Crank Brass Bushing |
I too, used a hand drill to ream out the bushings. Except, I hand held the bushing while wearing a leather glove. The bushings ended up looking decent considering the crude method!
Dale Ellis, building a RV-8 and 2 bids, one check-ride and 91 days from retirement
bo124rs(at)hotmail.com Guest
Posted: Fri Dec 01, 2006 4:21 am Post subject: Bell Crank Brass Bushing |
Brad, , what you posted will work fine. Reamer, drill bit, whatever will
center itself good enough fo this application. Drill, ream and move on.
Don't spend excess money or lose sleep over this, it "ain't" much.
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/blackwing1.jpg
[quote]From: Brad Oliver <brad(at)rv7factory.com>
Reply-To: rv-list(at)matronics.com
Subject: RE: Bell Crank Brass Bushing
Date: Thu, 30 Nov 2006 14:24:15 -0700
necessary.
perfectly (I hope).
Brad Oliver
www.RV7Factory.com
ghinman(at)mts.net Guest
Posted: Fri Dec 01, 2006 3:35 pm Post subject: Bell Crank Brass Bushing |
To ream out the inside of the brass bushings , Insert the
reamer backwards through the bushing , then insert the reamer in the drill
chuck, pull the reamer through the bushing backwards.
Bob Collins
George H. Inman
ghinman(at)mts.net
