dosmythe(at)cox.net Guest
Posted: Thu Dec 07, 2006 4:02 pm Post subject: Spark Plugs |
Guys,
Bear with me on this spark plug issue. I'm starting to get excited about this and it reminds me of the old "KITFOXSAFE" days (beat it to death and come up with all the facts). The bits and pieces are coming in and I'm sure there is a simple answer to at least, my confusion. I've sent emails to CPS and NGK asking about the aviation/non aviation BR8ES plugs. Also asking about the delivered pre-gap settings of .018" versus .035". In my opinion, the shorter ground and .018" gap is a more important issue. I want some of them......
So far, there have been part numbers given for solid tip?????? They are for auto use only????? Rotax centers deliver solid tip/.018" gap?????? CPS delivers the same as you get in the auto store (.035" gap)?????
Still Confused but will get straight,
Don Smythe
eskflyer(at)lvcisp.com Guest
Posted: Thu Dec 07, 2006 4:14 pm Post subject: Spark Plugs |
Don
The gap comes anywhere from .017 to .035 none have ever been at .018
John Perry
aerocontrols(at)clearwave Guest
Posted: Thu Dec 07, 2006 4:43 pm Post subject: Spark Plugs |
John,
Don't know whre you have been buying your plugs, but we just went into the
stock room and checked about 50 of them ... all came in between ..017 and
.019 (these are the ones that come from Rotax)
The ones that came from the automotive wholesaler came in close to .035 and
have longer grounding tabs..
The automotove solid core plugs ARE different than the ones that are
purchased for aircraft. I have both types on my desk as I type.
Bob Robertson
Posted: Thu Dec 07, 2006 4:59 pm Post subject: Spark Plugs |
Don....
O.K. there are solid core automotove plugs and there are aviation solid
core plugs. The auto plugs have a larger gap (.035+-)
I can't comment on what other service centers are doing for their plugs
sales. I know we purchased a case of automotive solid core plugs
because they wer a dollar or so less expensive (my cost) that the ones we
were buying from Rotax.. I was dissapointed because ,firstly, they were
marked "not for aircraft use" and secondly ,the gap and grounding tab were
different. We returned all but 30 of these (a back up in case we got short
stocked on the ones we were getting from Rotax).
I would not be suprised that some Rotax dealers are actually selling the
automotive plug.
I'm pretty sure that Lockwood, LEAF and South Misissippi all handle the
plugs we get from Rotax.
As they come from Austria, our plugs come in bulk styrafoam flats (not
indicidual boxes).
How much difference are there between the two type of plugs in terms of
performance. Iff'n you change the plugs out at 25 hour intervals, I doubt
you would see any difference.
If you have a change out schedule of 50 hours I'm sure there would be a
difference. We have lots of customers who use a 75 or 100 hour change out
schedule (that's a lot longer than the manuals state, but the plugs seem to
be going the distance).
Hope this un-muddies the water a bit.
regards
Bob Robertson
Light Engine Services Ltd.
Rotax Service Center
Aero Control Enterprises, Inc.
St. Albert, Ab. T8N 1M8
Ph: (Tech Support) 1-780-418-4164
Ph: (Order Line) 1-866-418-4164 (TOLL FREE)
www.rtx-av-engines.ca
www.aerocontrols.net
Posted: Thu Dec 07, 2006 5:12 pm Post subject: Spark Plugs |
Bob then what is the NGK Stock number for the Aircraft BR8ES and B8ES I
would like to know so i can then compare some more and see if i change my
mind again lol .
John Perry
Guy Buchanan
Posted: Thu Dec 07, 2006 6:29 pm Post subject: Spark Plugs |
At 04:43 PM 12/7/2006, you wrote:
| Quote: | Don't know whre you have been buying your plugs, but we just went into the
Hi Bob! What are you selling? Are these NGK BR8ES and BRES? Is there a
source for similarly configured Iridium plugs? (I don't know why I want to
use these, I guess I thought they'd last longer. Maybe I'm wasting money.)
Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Fox5flyer Guest
Posted: Fri Dec 08, 2006 4:39 am Post subject: Spark Plugs |
Hey guys, I'm not trying to inhibit this thread and I know we're all learning a lot about spark plugs and that's a good thing, but these plugs aren't really all that much of a problem. Just buy the correct heat range available at the local auto parts house and like Don says, stake the cap on. Alternatively, use a drop of locktite to hold it on there. As for the ground terminal being too long, it's very simple to just gently tap it to the correct gap, then use a file or dremel to trim it back to the correct length, being sure to avoid nicking the electrode. Be sure that the end is flat and square with sharp right angles. It only takes a few minutes per plug.
Additionally, I remember that it was said that in the winter time people close the gap to the minimum to help with easier starts. I'm speaking of the 582s here, not the 912 which may be a bit different, but I doubt it.
Deke
Float Flyr
Posted: Fri Dec 08, 2006 6:51 am Post subject: Spark Plugs |
I've never had a problem starting a cold two stroke engine. Even when I lived in Labrador the two stroke engines usually started with one or two pulls on the cord. Keeping them going now that is a challenge!
Noel [quote]
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Fri Dec 08, 2006 7:38 am Post subject: Spark Plugs |
John,
There is no NJK stock number for the plug that Rotax sells. These are
configured for Rotax in Austria by NGK....I am not sure, but I think they
also congigure the plugs for a couple of other 2-stroke manufacturers as
well.
The Rotax part number is 897-055..... .
If I can fugure out my new digital camera software (off topic, but....why
cant manufacturers come up with software programs that those of us over 55
can understand).. I will post pictures of both types of plugs on the list.
regards
Bob Robertson
Posted: Fri Dec 08, 2006 7:47 am Post subject: Spark Plugs |
Good Morning Guy,
We only handle the plugs that come to us from Rotax.. These are NGK B8ES
and BR8ES.
Rotax does not list an irridium plug. I am not sure if you can get a solid
core irriduim.
My feeling on standard vs. irriduim plugs is that you can replace your BR8ES
plugs every 50 hours and still come out
ahead (fiscally).
Just my two cents
Bob Robertson
Guy Buchanan
Posted: Fri Dec 08, 2006 8:45 am Post subject: Spark Plugs |
At 07:46 AM 12/8/2006, you wrote:
| Quote: | My feeling on standard vs. irriduim plugs is that you can replace your BR8ES
ahead (fiscally).
Thanks Bob.
Guy Buchanan
Deceased K-IV 1200
Posted: Fri Dec 08, 2006 1:49 pm Post subject: Spark Plugs |
Remember, if you trim plugs this way to make sure that
there are no metal filings left in the plug recesses
to be introduced into the engine. Same when using
spark plug cleaning machines. Those abbrasives can
really tear up a cylinder.
Kurt S S-5
--- Fox5flyer <fox5flyer(at)i-star.com> wrote:
| Quote: | Hey guys, I'm not trying to inhibit this thread and
but I doubt it.
Deke
Lynn Matteson
Posted: Fri Dec 08, 2006 4:59 pm Post subject: Spark Plugs |
Kurt-
I'm surprised to hear/read you mention spark plug cleaning
machines...I've heard for the last 10 years or so, not to use a
sandblasting machine for cleaning spark plugs. Are there other cleaning
machines that do not use sand? The theory goes that the sand blasts the
ceramic/porcelain...whatever...insulator and this is bad for the plug.
Maybe somebody else closer to the subject can verify this info.
Lynn
On Friday, December 8, 2006, at 04:48 PM, kurt schrader wrote:
<smokey_bear_40220(at)yahoo.com>
Kurt S S-5
> but I doubt it.
> Deke
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Fri Dec 08, 2006 5:25 pm Post subject: Spark Plugs |
I do not know why anyone would clean a plug when they are available new for
less than 2 dollars each. Yes this is the NGK Stock # 3863 Stock # 3961
BR8ES, B8ES plugs . Solid cap plugs .
John Perry
Posted: Fri Dec 08, 2006 10:10 pm Post subject: Spark Plugs |
You are right Lynn,
I got rid of my plug cleaning machine many years ago.
It didn't use sand, but any abrasive can produce
damage if not thouroughly cleaned out. (Mine
supposedly didn't harm the ceramic. If I remember
correctly, it used ceramic chips)
If you are buying aviation plugs at around $10 each
and 2 per cyl, cleaning them may still make economic
sense.
And if you modify them a Deke suggests, you need to
carefully clean out any debris, just like the blasting
material, as well.
So, the need to clean plugs can still come up and that
is why I made the suggestion.
Kurt S.
--- Lynn Matteson <lynnmatt(at)jps.net> wrote:
| Quote: | Kurt-
cleaning
not to use a
the sand blasts the
bad for the plug.
this info.
Lynn
Any questions? Get answers on any topic at www.Answers.yahoo.com. Try it now.
Float Flyr
Posted: Sat Dec 09, 2006 5:19 am Post subject: Spark Plugs |
Certainly if you use the sandblasting machine you will want to pressure test
the plug before installing it. I've seen spark plugs cleaned with an awl...
Carefully pick out the debris. Definitely not recommended but common enough
to mention.
Noel
[quote] --
Kitfox III-A
Float Flyr
Posted: Sat Dec 09, 2006 5:30 am Post subject: Spark Plugs |
Some of those aviation plugs are the dear side of $50.00/plug. After
cleaning, by whatever method, they really should be blown out with air (
100psi or more ) and then pressure tested. It's amazing how some perfect
looking plugs arc all over the place only under pressure.
Noel
[quote] --
Kitfox III-A
lcfitt(at)sbcglobal.net Guest
Posted: Sat Dec 09, 2006 8:02 am Post subject: Spark Plugs |
I just read the LightSpeed installation manual for the electronic ignition
going into the Lancair IV. It recommends never using a blaster type
cleaner, but rather a propane torch to burn off any liquid deposits and a
"sharp steel" instrument to scrape off any hard deposits.
For what it's worth.
Lowell
Fox5flyer Guest
Posted: Sat Dec 09, 2006 8:23 am Post subject: Spark Plugs |
Good point Noel. I once experienced a bad ignition miss while under
full power takeoff that straightened out when I reduced power to
cruise rpm. I spent many hours going through the ignition and fuel
system trying to track down the problem finding nothing amiss so I
decided to change plugs to see what happens. Problem solved. I've
got one of those hand held spark plug blasters that does a nice job
cleaning up a plug, but what they can also do is crack the insulator
that causes exactly what I was experiencing. I no longer use if for
my airplane plugs. If they get sooted up or look suspect I just
replace them with new ones. $10 for four plugs gives good peace of
mind.
Deke
[quote]<noelloveys(at)yahoo.ca>
pressure test
awl...
enough
to mention.
Noel
Posted: Sat Dec 09, 2006 8:40 am Post subject: Spark Plugs |
Lynn,
Thats the word we get from Rotax as well. The ceramic becomes pitted and
can crack due to uneven stresses when heated to 1000+ degreesF.
That's the theory I was given.
regards
