rexjan(at)bigpond.com Guest
Posted: Sun Dec 10, 2006 8:46 pm Post subject: Spark Plug Caps |
The 582 is one of the few beasties that has a recommendation to use both
resistor caps and resistor plugs. I had the resistors on a set of plugs
short out once and even with the resistor caps communications line of sight
with the tower was impossible. If you are carrying a radio I don't think
the automotive style caps will work.
Noel
Hi ! Noel,
I use non resistor NGK caps from the Auto store and BR8EIX resistor plugs and I certainly get no problems. My 582 Blue Head motor runs sweet and same with my communications. An Icom A20 MKII mounted on the panel with external antenna and power from the plane via a Pi filter circuit I made.
If you had trouble with say a resistor in a plug shorting out then I can well imagine the resistor caps are not going to cover this problem.
Rex.
