occom
Posted: Sun Dec 10, 2006 6:23 am Post subject: Gloves for Poly |
I have been using the blue nitrile gloves for work with the Hysol and with mek and such while working with my wings and such. I have found that they seem to degrade very quickly if I get mek on the fingers. I have a very heavy set of chemical resistant gloves made of neoprene that are better but with much less feel. The question is what do you use? I understand that once I get to the actual "gluing" with Polytak, I will be getting a bit of this on my fingers and if the nitril gloves that I wear while working on my bike aren't going to cut it, what will?
As always, please do not reply to the list. occom(at)ns.sympatico.ca (occom(at)ns.sympatico.ca)
aldaniels(at)fmtcblue.com Guest
Posted: Sun Dec 10, 2006 8:22 am Post subject: Gloves for Poly |
I use an invisible glove. It is a cream sold by most aircraft supply
places that will protect you from the chemicals, but will wash off with
water.
Dave G. wrote:
| Quote: | I have been using the blue nitrile gloves for work with the Hysol and
<mailto:occom(at)ns.sympatico.ca>
Lynn Matteson
Posted: Sun Dec 10, 2006 9:51 am Post subject: Gloves for Poly |
I used the invisible gloves...when I remembered...and also some orange
gloves that I got at Gordon Food Service, that said right on the
package that they are impervious to MEK, among other chemicals. They
aren't too thick to work with, I didn't feel....or actually, I DID
feel...pun intended.
Lynn
On Sunday, December 10, 2006, at 11:21 AM, Alan Daniels wrote:
<aldaniels(at)fmtcblue.com>
with water.
> cut it, what will?
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
flier(at)sbcglobal.net Guest
Posted: Sun Dec 10, 2006 12:32 pm Post subject: Gloves for Poly |
I've also used invisible glove. Works great.
Ted
akflyer Guest
Posted: Mon Dec 11, 2006 7:17 am Post subject: Re: Gloves for Poly |
I have been using the Blue Nitrile gloves while covering mine. They hold up well unless you go straight MEK, but no reason for that. They have held up to poly tac and poly brush so far, with a bit of acetone here and there.
Lynn Matteson
Posted: Mon Dec 11, 2006 8:31 am Post subject: Gloves for Poly |
A followup on my post...the gloves I used were latex #8430 from Impact
Products LLC...www.impact-products.com.
Lynn
On Monday, December 11, 2006, at 10:17 AM, akflyer wrote:
here and there.
Leni
Avid C W/582
1260 full lotus
.......DO NOT ARCHIVE.....
http://forums.matronics.com/viewtopic.php?p=80755#80755
N369LM |
