Vanremog(at)aol.com Guest
Posted: Sun Dec 10, 2006 9:53 pm Post subject: Using Alternate Oil Filter |
Those of you using the Wix 51068 Oil Filter on the Lycoming engines, please advise how to get a 3/4"-16 threaded fitting, since the ones on the Champions appear to be crimped on. Am I missing something obvious here?
-Thx
GV (RV-6A N1GV O-360-A1A, C/S, Flying 823hrs, Silicon Valley, CA)
rocketbob(at)gmail.com Guest
Posted: Mon Dec 11, 2006 4:22 am Post subject: Using Alternate Oil Filter |
It'll come out. On one of your old champion filters, double nut the nipple on the filter and wrench it off. You'll have to do this every time you change the filter but its no big deal to do.
Bob Japundza
RV-6 flying F1 under const.
On 12/11/06, Vanremog(at)aol.com (Vanremog(at)aol.com) <Vanremog(at)aol.com (Vanremog(at)aol.com)> wrote:[quote] Those of you using the Wix 51068 Oil Filter on the Lycoming engines, please advise how to get a 3/4"-16 threaded fitting, since the ones on the Champions appear to be crimped on. Am I missing something obvious here?
-Thx
[quote][b] www.aeroelectric.com http://www.matronics.com/Navigator?RV-List [b]
av.8(at)bigpond.com Guest
Posted: Mon Dec 11, 2006 1:21 pm Post subject: Using Alternate Oil Filter |
Seeing that I am using Shell's semi-synthetic 15-50 aviation oil, I figured
that using the latest technology oil filter would be a good match for the
oil. With that in mind, I bought the latest Amsoil automotive filter, but
had to get an adaptor to mate the female oil filter thread to the female oil
filter boss on the Lycoming pad. Lycoming happen to have such an adaptor,
but not for the thread size of the Amsoil filter. I went to a friend that
runs an engineering shop, showed him the Lycoming adaptor and the oil
filter, and he machined one up. I haven't done an oil analysis as yet, but
hopeful of the next one showing less wear particles than the last.
Martin in Oz
khorton01(at)rogers.com Guest
Posted: Mon Dec 11, 2006 3:59 pm Post subject: Using Alternate Oil Filter |
On 11 Dec 2006, at 16:20, Martin & Chris wrote:
figured
for the
filter, but
female oil
adaptor,
friend that
yet, but
Martin - what is the rated pressure for the Amsoil filter? Lycoming
engines may produce higher oil pressures in some conditions than is
normally seen in automobile engines. I have seen several reports of
automotive oil filters bursting when installed on Lycomings, and I
have seen one report of an automotive oil cooler bursting too.
Admittedly I don't know whether these guys were running single weight
oil, or multi-grade, nor do I know the ambient temperatures that were
experienced.
Ottawa, Canada
http://www.kilohotel.com/rv8
HCRV6(at)comcast.net Guest
Posted: Mon Dec 11, 2006 10:41 pm Post subject: Using Alternate Oil Filter |
I must have missed the early part of this thread on alternate oil filters. Would someone please enlighten me as to why the interest in alternate filters. Seems like the aviation oil filters have worked quite well for some time and I have never heard of one bursting or any of the other things that seem to be a concern with automotive filters. If the issue is cost, it seems pretty silly to me to take any risks to save the equivalent of three or at most four gallons of 100 LL every 50 hours. Just curious.
Harry Crosby
RV-6 N16CX, 293 hours
-------------- Original message ----------------------
Martin in Oz
Posted: Tue Dec 12, 2006 5:14 am Post subject: Using Alternate Oil Filter |
Because they work better, have an anti-drainback valve, have better filtering media, have a better bypass spring and valve, have good burst pressure specs, are proven running in Lyc's, are available locally, and cost $5.79.
Bob Japundza
On 12/12/06, HCRV6(at)comcast.net (HCRV6(at)comcast.net) < HCRV6(at)comcast.net (HCRV6(at)comcast.net)> wrote:[quote]--> RV-List message posted by: HCRV6(at)comcast.net (HCRV6(at)comcast.net)
Harry Crosby
RV-6 N16CX, 293 hours[b]
n801bh(at)netzero.com Guest
Posted: Tue Dec 12, 2006 6:39 am Post subject: Using Alternate Oil Filter |
In all my years on the earth I have NEVER seen an automotive filter burst, in fact I have NEVER seen one loosen up over time, they always seem to get tighter <G>... The tab to safety wire thats on the aircraft filters probably don't need to be on there anymore... Just my two cents worth... And of course I am a Auto engine conversion addict....
Ben Haas
N801BH
www.haaspowerair.com
Harry Crosby
| Quote: | --> RV-List message posted by: "Martin & Chris" <av.8(at)bigpond.com>
Martin in Oz
======================== -- Please Support Youp; (And Get Some ber is the Annual List Fund Raiser. & this year's Terrific Free Incentivnbsp; * AeroElectric www.aeroelectric.com
;  ================================================sp; - The RV-List Email Forum p;utilities such as the Subscriptions page,
Posted: Tue Dec 12, 2006 12:39 pm Post subject: Using Alternate Oil Filter |
Kevin, Harry -
Like you, I was concerned about burst pressures and not having a lock wire
tab on the automotive filter, but after speaking to a friend who is licenced
aircraft mechanic as well as the local Amsoil distributor, I was satisfied
that the filters are tested to a much higher pressure than the 100 psi that
it is likely to ever see, and I used a hose clamp around the body to retain
the lockwire, same as I have done many times on race-bikes. The fact that I
use a multi-grade oil and live in a warm climate were just added insurance.
As for penny pinching being the main reason for changing, the Amsoil filter
costs me more here in Oz than the Kelly Aerospace ones that I had been
using.
Another 10 hours and I will drain the oil and have it analysed, then I will
have a better idea if this is going to be worthwhile.
Martin in Oz
