rowil(at)clara.net Guest
Posted: Sat Jan 28, 2006 1:27 am Post subject: Fwd: Alternator Lamp |
This message was sent to the defunct forum address, so I have forwarded it:
Quote: | From: Timothy.P.Ward <ward.t(at)xtra.co.nz>
To: <forum(at)europaclub.org.uk>
Subject: Alternator Lamp
Date: Sat, 28 Jan 2006 9:48:33 +1300
Hi all,
Have had the alternator lamp come on during flights recently. On my
last flight I had to eventually save battery power and load shed as
the GPS shut down.
Before delving into the electrical side, of which I am no expert,
has anyone else had problems with their alternator/regulator? I have
used the exact wiring diagram Europa supplied for my Classic
monowheel. Engine has only 50hrs on it. First started when we had
cold weather. However I did have a problem with the battery +ve
connection which has been rectified. Any thoughts? Will check all
connections?
regards
Rowland
| Rowland Carson (retiring) Europa Club Membership Secretary - email for info!
| Europa 435 G-ROWI (750 hours building) PFA #16532
| e-mail <memsec(at)europaclub.org.uk> website <www.europaclub.org.uk>
SPurpura(at)aol.com Guest
Posted: Sat Jan 28, 2006 5:01 am Post subject: Fwd: Alternator Lamp |
CHECK YOUR REGULATOR WITH AN OHM METER,MINE WENT BAD AT 100 HRS.
rholder(at)avnet.co.uk Guest
Posted: Sat Jan 28, 2006 1:00 pm Post subject: Fwd: Alternator Lamp |
Quote: | > Have had the alternator lamp come on during flights
> recently. On my last flight I had to eventually save
> battery power and load shed as the GPS shut down.
> am no expert, has anyone else had problems with their
> alternator/regulator? I have used the exact wiring
> diagram Europa supplied for my Classic monowheel.
> had cold weather. However I did have a problem with
> the battery +ve connection which has been rectified.
> Any thoughts? Will check all connections? Cheers,
I assume it is a complete failure ? I have an intermittent
failure to charge ! I am sure it is a dry solder joint
somewhere inside the regulator which costs 150 and has
components worth 10 in it (max !)
If yours is a permanent failure it is much easier to diagnose.
You need to take the orange connector off the regulator
and add some small capacity wires into the faston
connectors - being careful not to leave any shorts. use
the orange connector with its existing wires as away of
keeping the additional wires in place.
Then connect up your voltmeter and stand back - staring
the engine.
First but the voltmeter in AC volts mode across the GG
terminals (the cables to the engine).
It should read 14 tick over - 30 ish at high revs. If not
- then the problem is the stator
The change to the B+ terminal and to earth. WHen the
engine is running is that at 12.5 volts DC (if so then it
is the regulator, if it is at 14 volts then the problem is
further towards your "alternator" switch.
Keep moving that way until you find where the break is.
Health and Safety. Propellors are dangerous !
if you are not exactly clear about what I am describing -
ask me again direct and I will make a bigger effort Do
not let any of the temporary wire short to anything !
you will need to charge the battery up to get the engine
to start, and if it continues to not charge then you will
have to keep charging up the battery.
Or come up and discuss it when you next "drop" into town
HTH
Richard Holder
gdh(at)isp.com Guest
Posted: Sat Jan 28, 2006 4:50 pm Post subject: Fwd: Alternator Lamp |
Sam,
What regulator did you use as a replacement?
Dale
Posted: Sun Jan 29, 2006 6:35 am Post subject: Fwd: Alternator Lamp |
A DUCATI FROM LOCKWOOD.
europabill(at)bellsouth.n Guest
Posted: Mon Jan 30, 2006 6:10 am Post subject: Fwd: Alternator Lamp |
Sorry,
Forgot to attach the URL.....
If you can read German, here's some interesting info from Ducati on the
regulator. Also has some schematics and a cross reference for the TP154E
thryristor (2N6507).
http://www.ducati.dk/teknik/MC_Elektro.pdf
A010 Classic Monowheel
Gilles.Thesee(at)ac-greno Guest
Posted: Mon Jan 30, 2006 6:27 am Post subject: Fwd: Alternator Lamp |
Bill Henderson a crit :
Bill,
Interesting find.
Unfortunately, it's not German, but Danish
Much harder to translate.
The schematic is not quite that of our rotax regulator. But it has some
similarities.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
karelvranken(at)hotmail.c Guest
Posted: Mon Jan 30, 2006 3:58 pm Post subject: Fwd: Alternator Lamp |
Bill,
Must be a skandinavian language. German, Dutch, English, French, OK but
that's all I can read and understand.
Karel Vranken
Horizonspace(at)aol.com Guest
Posted: Tue Jan 31, 2006 6:38 am Post subject: Fwd: Alternator Lamp |
The latest Rotax Installation article by Phil Lockwood explains the Rotax
912 electrical system including the operation of the alternator lamp. You can
find it at the following link:
_http://www.sportpilot.org/magazine/feature/2005%20-%2012%20December%20-%20Tip
s%20and%20Tricks%20for%20Ideal%20Rotax%20912%20Installation.pdf_
(http://www.sportpilot.org/magazine/feature/2005%20-%2012%20December%20-%20Tips%20and%20Tri
cks%20for%20Ideal%20Rotax%20912%20Installation.pdf)
T
flyinggpa(at)comcast.net Guest
