DYMO RhinoPRO3000 label writer
VE3LVO(at)rac.ca
PostPosted: Sun Dec 10, 2006 7:12 am    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
I looked it up as suggested and believe it's useful BUT the price of heat
shrink comes out to about $5 a foot, or perhaps 75cents a label (mistakes
excepted). Rolls come in 5 foot lengths. Any- body find better source?
Ferg Kyle
Europa A064 914 Classic
michele.delsol(at)microsi
PostPosted: Tue Dec 12, 2006 7:35 am    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
I've been using the Rhyno 5000 - I find that I have to be really careful on
printing the labels - many in a single pass so as not to minimize waste. The
yellow heat shrink tubes are really expensive and if not careful, one can go
through them at a pace which makes the labels a significant cost item. For
that matter, it is much like colour printers - cheap printer but you get
whacked on the cartridges. This being said, I find the Rhyno a great product
and time saver.
Michele
RV8 - Finishing
sarg314(at)comcast.net
PostPosted: Tue Dec 12, 2006 5:02 pm    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
Michele:
Do you have to use a special type of heat shrink, or will any old
type work?
and time saver.
Michele
RV8 - Finishing
PostPosted: Wed Dec 13, 2006 12:44 am    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
You have to use the Rhyno 5000 cartridges - they come as yellow tubing which
has been flatened in several sizes.
Michele
rtitsworth
PostPosted: Wed Dec 13, 2006 5:55 am    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
Just curious...
Does the 3000/5000 shrink tubing come rolled up into a special cartridge
along with an ink tape - or do you feed the flattened tubing in separately?
Has anyone experimented with flattening "regular" heat shrink tubing and
then trying to print/label on it? I think I even have some white "regular"
tubing that came flattened. Does anyone with a 3000 or 5000 have a picture
of the tubing before printing/cutting? How long is the flattened tubing
before printing/cutting? Is there any "leader" on it? Is there any waste
at the ends when printing? How do the small sizes stay centered when
printing?
Rick
Don Owens
PostPosted: Wed Dec 13, 2006 9:42 am    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
And furthermore, is there a better printer out there that some are using to
mark shrink tubing?
Don Owens
Just curious...
printing?
Rick
11:49 AM
jc-matronics_aeroelectric
PostPosted: Wed Dec 13, 2006 4:02 pm    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
Here is a P-touch labeller on sale for $68.43 at buy.com with free shipping.
http://www.buy.com/retail/product.asp?sku=10372536&loc=101&sp=1&adid=17662
I don't have one, but just noticed it and remembered the discussion on this
list. It piqued my curiosity. I wanted to know what these labels actually looked
like, since I have never seen one.
http://www.amazon.com/exec/obidos/ASIN/B0002AZ2RY/pricegrabbercpc11-20/ref=nosim
The link on amazon.com has a better picture. It actually shows a few sample
wires with wire labels attached. It sure does look nice for labelling wires.
One comment on here, though, mentions that he thought quite a bit of the labels
were wasted.
I am probably years away from needing one.
Jae
sportav8r(at)gmail.com
PostPosted: Wed Dec 13, 2006 4:39 pm    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
Seems like a golden business opportunity for someone with a deluxe-o
labelling set-up: market a kit of pre-printed heat shrink wire labels
in various alpha and numeric combinations as well as commonly used
words, like comm1, nav2, audio in, etc. Printed in bulk, they're
bound to be more cost-effective than wasting alot of $5 / foot heat
shrink in your own home Wink
-Bill B
were wasted.
Jae
Mark Phillips in TN
PostPosted: Wed Dec 13, 2006 7:18 pm    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
Since I started this discussion, thought I'd chime in on my purchase decision. I've opted for a Brady ID Pal, for about $100. It doesn't print heat-shrink tubing, but the Dymo Rhyno cartridges are pretty pricey for only 5 feet of tube. The standard cartridges are smaller (less total length) on the Dymos, and Brady claims there is less waste (margin) on their labels. We'll see..
My thinking is that if I really NEED a heat-shrink tube label, I'll make a standard label and apply a clear shrink-tube around it. Usual suspects might be anything FWF. But the MAJOR factor was that using the wrap-around labels, you can print up to 4 (I think) lines of text on each label- a no-brainer since this kind of label is vastly easier to read when you are standing on your head with a maglite in your teeth trying to find the "E1-26A" wire in that bundle going to the audio panel. Whatever. My best investigations indicate that the heat-shrink tubes only get one line of text- not too handy, IMHO...
Will produce a "product evaluation report" upon reciept and use of Brady label machine...
From The PossumWorks in TN
Mark
From The PossumWorks...
list(at)toddheffley.com
PostPosted: Thu Dec 14, 2006 4:19 am    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
Yes,
It went like this.
Take the platen roller out of a old Dot Matrix Printer. I found a
LARGE printer at a second hand store. 5$.
Turn several grooves of different sizes around the platen. I just
chucked it into a drill press and used a razor sharp chisel. Took
several attempts to shape the groove.
modified paper feeder to feed 3/16" wide "Paper".
I ordered white heat shrink, thin wall. (allied?). Being wrapped
around the platen, it automaticallty flattens out. I did use a clothes
iron to flatten the tubing, that was not helpfull.
Laout a Word Document 1 Character wide, 3 feet long. Bold text, letter
quality.
Final report. It Worked. Very inexpensive compared to alternatives. A
little hassle to set up.
Then a got a job at a company that had a Wire Stamp machine I could
use any time.... lost interest.
Email me if you want more details.
Dont overlook the simplicity of wrapping the heat shrink around a 1"
plastic pvc pipe and writing on it with a Sharpie. The tube flattens
out fine.
Todd
Todd Heffley
todd(at)toddheffley.com
(817)845-0145
----- End forwarded message -----
nghertner(at)verizon.net
PostPosted: Thu Dec 14, 2006 6:18 am    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
feet of
be
since
label machine...
Mark
I have been using a Kroy, bought new for around $200 for the last few years.
Operation is a little finicky but it prints stick on labels and white heat
shrink tubing which comes in cartridges for about $30 a piece. I used 3
cartridges (2 for small tubing and 1 for larger wires) to do my all electric
Glasair. I can only print 1 line of text on the smaller wires but multiple
on the larger. I put labels at each end of the wire and sometimes along
bundles.
Also, I actually print names of wires instead of codes, as I am an idiot at
things that aren't simple.
Lory Ghertner
rtitsworth
PostPosted: Thu Dec 14, 2006 12:53 pm    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
What model is your Kroy?
How long is a $30 cartridge of heat shrink?
PostPosted: Thu Dec 14, 2006 1:54 pm    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
I have the k2500. The cartridge holds 114" of the 1/8" heat shrink which
works very well for 22AWG. It wastes about an inch at the start of each
printing, and the space between each label is controllable.
Lory Ghertner
Don Owens
PostPosted: Sat Dec 16, 2006 10:25 am    Post subject: DYMO RhinoPRO3000 label writer Reply with quote
Hi Jae,
The labels look good, but how difficult is it to wrap these labels around
small (22 awg) wires??
Don Owens
looked
osim
labels
were wasted.
Jae
5:10 PM
