Roger.Mills(at)btinternet Guest
Posted: Mon Jan 30, 2006 1:52 am Post subject: Mod 61 - Stall warner questionMod 61 - Stall warner question |
I personally found the welding wire to be a little too flexible to allow me
to confidently find the position. In the end I used a much stiffer 3mm
brazing rod and eyeballed it using Neville's technique. To confirm the
"eyeballed" position I found that a DIY stud finder also found the position
of the rib quite accurately and, to be triply sure, a DIY pipe finder also
confirmed the brazing rod tip position. (I needed a bit of re-assurance
before drilling the leading edge possibly in the wrong place!!)
Roger Mills
Europa 141
asarangan(at)YAHOO.COM Guest
Posted: Mon Jan 30, 2006 9:58 am Post subject: Mod 61 - Stall warner questionMod 61 - Stall warner question |
Thanks for that explanation. Here is a technique that I think might
work better (assuming I understand it correctly). My wingtips have
cutouts for the installation of nav lights at the leading egde. That
gives me access to the ribs in front of the spar. The rib we are
looking for is the second one from the tip. The first one (and
presumably all) have small holes for pressure equalization. I can push
a long wooden dowel through the first rib until it hits the second rib,
and get an exact measure of its distance from the tip. Then I transfer
that distance (minus 0.5" for the flange) along the leading edge and
drill the hole. Does that sound right?
I could not find Neville's posting in the archives on using a light
bulb to locate the distance. If anyone can send me a reference, I would
appreciate it. Thanks.
allow me
3mm
the
position
also
re-assurance
Roger Mills
Europa 141
Andrew Sarangan
http://www.sarangan.org
