Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Tue Dec 19, 2006 10:04 am Post subject: Hanger location |
Per a quote on the subject "q" as noted below:
"Leaving an airplane outside, even tied down, makes me nervous, and
I did it myself a long time ago. A shelter also needs some protection.
I built my open front, steel pole shed 30 years ago for about $800.
The main winds hit at a rear quarter and have to encounter an earthern
berm first which helps ramp them up and over. The ramp is hidden
within a fencerow thicket.
On a windy day scarcely a breeze can be felt standing outside the open
front."
I have a question regarding hangers. There seem to be several self hanger builders on this site and I was wondering which direction would one have the "opened" ends positioned"? A friend is building a metal hanger, much like a quansit hut" that is 27 feet wide by 30 feet long, and will, at least in the begining, leave bothe ends open. He will store his Titan in it and I will have my Firestar facing the opposit direction (head to toe). We can locate it in any direction and all directions, with the exception of West has open corn /soy fields. The West direction has a hanger about 40 feet from where we would locate our new hanger.
Any help would be greatly appreciated.
Ohio Ralph
jim
Posted: Tue Dec 19, 2006 11:11 am Post subject: Hanger location |
You want the hangar to take the wind, not the aircraft inside so I would
put the doors 90 degrees to the wind. I have an enclosed hangar with a
door on 1 side and I am sometimes concerned about the wind with the
ultralights sitting inside and the door open.
If I were to build my hangar again, I would put a few tie-downs in the
concrete on the floor (probably along the centerline). The lift-up kind
that fall flush when not in use. They can be used as an anchor for
winching, or tie down in windy conditions with the door open, etc.
Ohio Ralph
_________________ Jim
N. Idaho |
planecrazzzy Guest
Posted: Tue Dec 19, 2006 2:31 pm Post subject: Re: Hanger location |
Hey Ralph,
How ya been.... I see you were "Hide'n out" for the fund raiser....He he he
Anyway, your "Runway" has the answer your looking for....
usually a "Study" is done to determine which direction the wind "USUALLY" blows....Then you stick a runway in front of it....
You would probly want to postion you hanger the opposite of your MAIN
runway.....
Make cents ? ( at least 2 of them - mine )
Now drop and gemme 50
Gotta Fly...
Mike & "Jaz" in MN
cartejy(at)mtn-state.com Guest
Posted: Tue Dec 19, 2006 3:05 pm Post subject: Hanger location |
Ralph, Hope all going well for you..In answer to your question as to hanger
Direction,,Contact Wilinmton Nat Wx Service, they will have the Wind
Direction % for the year, Then you can figure which way to place it so it
will be best protected from Wind & Rain, Ect. Hope all well and it is Ok
here in E Liverpool, Have my Winter cover & heater working on My KXP Lt Sp
Exp Kolb (91) warm on cold days . Merry X May & update some time Jay Carter
East Liverpool Oh(right up here to W Va/Pa Line)...---- Original
Message -----
From: "Ralph Hoover" <flht99reh(at)columbus.rr.com>
To: <kolb-list(at)matronics.com>
Sent: Tuesday, December 19, 2006 10:04 AM
Subject: Hanger location
<flht99reh(at)Columbus.rr.com>
front."
Posted: Tue Dec 19, 2006 5:48 pm Post subject: Hanger location |
Ralph Hoover wrote:
front."
Ohio Ralph
If you leave both ends open, definitely put tiedowns inside for the
planes. If you close one end, it minimizes the risk.
One thing I haven't seen mentioned is to look at the direction of your
*severe* weather, not just prevailing wind.
mustangsally(at)semo.net Guest
Posted: Tue Dec 19, 2006 8:50 pm Post subject: Hanger location |
My hanger has sliding doors, wood frame. The doors face the wind. In strong
winds I am concerned about the doors blowing in on the plane. I would rather
have the back or side on the strong wind side.
Jerry
jim
Posted: Wed Dec 20, 2006 8:06 am Post subject: Hanger location |
I agree. Orient the hangar so the prevaling wind is hitting against a
solid wall of the hangar -- NOT an opening (i.e., sides or back wall).
That way the building will shield the contents from the wind and not allow
lots of wind inside or through the hangar. I think best would be to have
the wind coming into the back wall, not the sides.
Jim
strong
rather
Jerry
N. Idaho |
Thom Riddle
Posted: Thu Dec 21, 2006 6:02 am Post subject: Hanger location |
Since we rent hangar space at BQR and was on a waiting list to get that
space, orientation was not on my worry list. However, for those of you
living in the great white north and actually fly during the winter, one
other item is worth considering. Snow and Ice removal from the door. We
were fortunate to get a south facing hangar (door on south side) so
that the sun helps melt the snow and ice at the bottom of the door.
I've had hangar space on the north side and can tell you that the extra
work to get the doors open during the winter was incredible and was
sufficient to make me not fly on many occasions. I'm very glad indeed
for the south facing hangar, even though our prevailing winds are from
the SW and average wind speed here in the winter is 14 mph.... only 9
mph in August.
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
ulflyer(at)verizon.net Guest
Posted: Thu Dec 21, 2006 11:24 am Post subject: Hanger location |
Why can't you install removable anchors in the concrete
now. Shouldn't be that hard if you use a hammer drill. You can rent
one and even the bits from most industrial rental places. If your
intent is only to keep it from moving you shouldn't need that much
being sheltered by the hangar itself. They could screw in and out of
the floor.
jerb
At 01:10 PM 12/19/2006, you wrote:
> Ohio Ralph
jim
Posted: Thu Dec 21, 2006 2:18 pm Post subject: Hanger location |
Anchors will work for light duty, but for maximum stength they should be
imbedded in the concrete and tied into the rebar. That kind of strength
wouldn't be needed very often. (e.g., 2000# winch going up to the trusses
then back down to pick up an entire aircraft.
now.
N. Idaho |
biglar
Posted: Thu Dec 21, 2006 3:45 pm Post subject: Hanger location |
Yah, for max strength you're right, but not all anchors are created equal.
It'd be interesting to see some comparative tests of various concrete
anchors. I've worked with quite a few over the years, and some that I've
seen work OK in shear, but poorly in tension. Then again, some I've used
that have a tapered lower section that pulls up into an expandable sleeve
are perty husky. Some have impressed me quite a bit, and I'd be hard put to
picture one pulling out. That, of course, would depend to some extent on
the concrete itself. On that, I've seen some home mixed and poured stuff
that wasn't much better than putty. Others have been like granite, so ya
never know. Lar.
Larry Bourne
Santa Fe, NM
www.gogittum.com
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
russ(at)rkiphoto.com Guest
Posted: Thu Dec 21, 2006 7:05 pm Post subject: Hanger location |
LAR, YOUR WIDESPREAD KNOWLEDGE NEVER FAILS TO IMPRESS ME (sorry, hit
CaPS KEY)
Thanx for sharing with us.
equal. It'd be interesting to see some comparative tests of various
concrete anchors. I've worked with quite a few over the years, and
some that I've seen work OK in shear, but poorly in tension. Then
again, some I've used that have a tapered lower section that pulls
up into an expandable sleeve are perty husky. Some have impressed
me quite a bit, and I'd be hard put to picture one pulling out.
That, of course, would depend to some extent on the concrete
itself. On that, I've seen some home mixed and poured stuff that
ya never know. Lar.
Larry Bourne
Santa Fe, NM
www.gogittum.com
biglar
