jindoguy(at)gmail.com Guest
Posted: Mon Jan 30, 2006 8:35 pm Post subject: Thoughts on cameras |
Dave, I've mounted cameras on aircraft as varied as a Kasperwing ultralight
and a super LongEZ and my one suggestion would be to get a camera with a
remote. Digital still cameras typically don't have them, but digital video
usually do. It saves fussing with the camera and possibly moving it off the
shot you have it set for. The other suggestion is to make sure the camera
has a provision for a remote microphone. You can get fittings and cords at
Rat Shack to hook the camera into your intercom. I can send you pictures of
the LongEZ mount if you'd like. I built it one evening in the hangar while
Wayne (the LongEZ's owner) was clearing things off the to-do list. Nothing
fancy, just a piece of angle, three turnbuckles, three Adel clamps, and some
nuts and bolts. The turnbuckles gave the mount very good adjustability to
get the shot we wanted and were sturdy enough to stand up to the vibration
put out by the IO-360.
Rick Girard
"Pining for a home on the Range"
jlbaker(at)telepath.com Guest
Posted: Tue Jan 31, 2006 7:28 am Post subject: Thoughts on cameras |
Quote: | camera with a remote. Digital still cameras typically don't have
them,
Quote: | but digital video usually do.
The Canon Powershot cameras (some other Canons as well) and
some Olympus cameras (I have the 2100UZ Olympus as well) can
be controlled through the USB port. Almost everything can be
controlled. The beauty is that you can build a mount for the camera
and use a laptop to control it, including seeing the framed shots in a
window that appears to be through the viewfinder or the LCD. You
can also set up sequenced, timed shots that make it easy to stich
the frames together. I'm watching E Bay right now to find a broken
LCD unit that still takes good images.
http://www.steves-digicams.com/digsoftware_cameractrl.html
Holding a camera with one hand and flying with the other sucks. And
you never quite know if the nadir of the shot is going to be close to
vertical..
Jim Baker
580.788.2779
'71 SV, 492TC
Elmore City, OK
