Rick.Beckman(at)atk.com Guest
Posted: Wed Jan 04, 2006 11:10 am Post subject: First Flight |
=09
=09
Happy New Year, All Y'all !
I have a question: How many of you used a test pilot on the first flight?
My young bride wants me to give up that once in a lifetime event. So does my Doctor. I think he's the one prompting her to such thoughts. Any thoughts worth reading?
Rick
dsire(at)imt.net Guest
Posted: Wed Jan 04, 2006 11:29 am Post subject: First Flight |
Personally, I think it would be safest (for you and the airplane) if you
get several hours "in type" and then fly it yourself. That's what I plan
to do. Unless the test pilot has a number of hours in the same
configuration that you are building, their experience doesn't count for
all that much.
Doug Sire
601XL (waiting on kit)
the first flight?
Rick
frank.hinde(at)hp.com Guest
Posted: Wed Jan 04, 2006 11:50 am Post subject: First Flight |
Hi Rick,
First, let me say my wife is smart enough not to give me a choice
between her or my plane. My doctor has already said she would be
delighted to go for a ride in my plane.
In my case, I have not yet completed my plane, but when I do there
isn't enough force in the world to get me to allow someone else to test fly it.
In all fairness, I am qualified to do the test flying. I have had a
private license for 35 years, and my stick and rudder skills are
considerably above average. I know this because I used to scare
flight instructors - they told me they didn't have any skill margin
over me so they could not recover a plane if I lost it. Even after
that, they were still willing to go flying with me under very
marginal conditions.
In your case, I suggest you do a fair evaluation of your own
skills. It would be wise to take advantage of an EAA advisor to help
you do a fair analysis (I plan to to that). I also suggest you take
whatever steps are necessary or even reasonable to build your skills
to a sufficient point where it is a reasonably safe bet that you can
handle the flight testing. If necessary, fly rental planes for a
couple of hundred hours to build the necessary skills.
After all that, I suggest you have a nice frank talk with your spouse
and doctor. Let them know how you really feel and give them a chance
to reconsider their positions with the full knowledge that if they
put themselves between you and your plane they might just end up with
the fuzzy end of the stick.
Good luck,
Paul
XL wings
Rick
Posted: Wed Jan 04, 2006 12:11 pm Post subject: First Flight |
Personally I am torn. I don't think I have enough experience overall to
recover from some unexpected event. On the other hand there was that case
back east where the builder had a very experienced pilot (multiple thousands
of hours) do the first flight. As the builder watched the plane took off,
crashed into a building and the test pilot killed. The plane even had a BRS
and the pilot had been specifically instructed on arming and firing it. I
don't know that I can morally ask someone else to test my plane even if both
of us had gone over it with a fine-toothed comb.
So that leaves me testing it myself. Which brings up the oft-posed question:
is it better to just lift off on the first run and climb or do some short
hops first?
-- Craig
Posted: Wed Jan 04, 2006 12:36 pm Post subject: First Flight |
I certainly felt I had a feeling for its control during the high speed
taxi. I had a 6000ft runway and advised traffic I would be doing a
ground run only.
The naughty boy that I am I did allow it to lift off to 10 or 20 feet on
a number of these runs...I felt very comfortable come flight time..
Like you I could not imagine allowing somebody else to take the risk.
Frank
larrymc(at)qconline.com Guest
Posted: Wed Jan 04, 2006 1:25 pm Post subject: First Flight |
Rick,
If you're a good basic pilot with the necessity of flying a basic
aircraft that you've built and you have health, currency of medical
and a willingness to fly with an instructor in a similar aircraft,
there's no good reason to not fly first flight yourself. If your doctor
thinks you'll faint, you need another doctor. If your wife presumes her
judgment is better than yours, you have bigger problems to
deal with. You have to make this decision all by yourself, otherwise
you'll have to ask her for weather briefings to go flying.
Seriously, your first flight is going to be something that will occur
even if it is or isn't the first flight of your aircraft. It's going to be
something new and I wouldn't want to give that up just because the wife
says you can't do it. And an ATP pilot won't do it any better
than you would.
Larry McFarland - 601HDS - 601HDS at www.macsmachine.com
Rick
rdewees(at)mindspring.com Guest
Posted: Wed Jan 04, 2006 1:54 pm Post subject: First Flight |
Hi Rick,
I guess I am the odd duck on this question. I fly a 601 HDS taildragger
out of a 2200 foot turf strip with limited space for emergency
landings. I had no reason to expect a problem with the plane and have
several hundred hours in taildraggers and many more in complex
aircraft. That being said I was fortunate enough to have a pilot at our
field who has owned over 60 different planes and flown several hundred
more. He is so thorough that he researched the airfoil of the 601 and
found that it was the same one as a Bebe Jodel, which he had a lot of
experience with. He knew what to expect before he ever taxied it and
could almost have written the cruse and stall numbers before trying them
out.
He offered to do the checkout flight and I stood by and recorded
numbers over the radio. I still felt like a proud papa and my ego
wasn't bruised at all. My first flight was a non event for the plane
but a sky high one for me. I felt like I had an edge since I knew there
weren't going to be reversed controls, extreme trim problems or fuel
flow difficulties. If I had it to do again, I would! Not because he
had a gazillion hours, but because he know what to expect and was a lot
more objective than I was.
I would certainly agree that the HDS is a great plane, easy to fly,
and a LOT of fun. There just isn't (to me) a reason to add emotions to
a challenging first flight experience when talented pilots could improve
the odds of a successful event.
That's my experience. Your results may vary, etc.
Ron
=09
=09
Rick
JAPhillipsGA(at)aol.com Guest
Posted: Wed Jan 04, 2006 4:18 pm Post subject: First Flight |
Rick, I had the test pilot from AMD in Eastman fly my XL for the first flight
and I know for me it was the correct decision. I was so concerned about my
"baby" that I was a nervous wreck and I'm not ashamed to say it. I flew it the
second and all subsequent 50 plus hours and I do not regret it. Instead of just
flying and surviving I am sure I would have been analyzing every sound, bump
and ding to the point of absolute distraction. FWIW. Bill
planejim(at)bellsouth.net Guest
Posted: Wed Jan 04, 2006 4:43 pm Post subject: First Flight |
Rick and others,
FWIW I did some "Flight Advisor" work many years before the EAA started a
formal program. I have test flown all three of my homebuilt airplanes. I
have had problems on the first flight. Have a minimum properly briefed
groung crew. Let them do all the recording of numbers etc. I strongly urge
you to work with an EAA flight advisor if possible. Remember you will truly
be a test pilot!
Make sure you have a reasonable amount of current flying time. Prefeably in
similar or same type of aircraft.
Some taxiing is necessary, but be careful of "high speed" taxiing especially
with tail draggers. I've had personsal friends tear up airplanes doing this.
Get the airplane in the air, get comfortable with it, practice a couple of
approaches at altitude, noting the speed. Use this to determine the approach
speed for the first landing.
Don't be too proud to use a "test pilot".
Jim Hoak
jeffrey_davidson(at)earth Guest
Posted: Wed Jan 04, 2006 5:44 pm Post subject: First Flight |
"Personally I am torn. I don't think I have enough experience overall to
of hours) do the first flight. "
At least one lister had Nick and Roger come out from Mexico (MO), inspect
the plane, generate a "punch list" of things to correct, and do the first
flight. The advantage here is that both Nick and Roger know this plane very
well from both the building and flying perspectives. If there is any moral
question, certainly these two are very well qualified and extremely capable.
It was expensive, but I remember the lister saying it was worth it.
Jeff Davidson
CH 601 HD w/Jabiru 3300A
Posted: Wed Jan 04, 2006 5:55 pm Post subject: First Flight |
I have also heard (second-hand) that you can go to Mexico, MO for
familiarization flights in the factory demos. Has anyone done this?
-- Craig
leogates(at)allvantage.co Guest
Posted: Wed Jan 04, 2006 7:47 pm Post subject: First Flight |
I did 10 to 15 short hops. I had no surprises. Trim was OK and the
plane seemed to land itself, after pulling the power back. Then I had
my DAR inspection. He said, "You have short hopped it, right?"
Leo Gates
N601Z
82 hrs and I still can't stop smiling!
Do not archive.
hops first?
-- Craig
d3dw(at)msn.com Guest
Posted: Wed Jan 04, 2006 7:57 pm Post subject: First Flight |
I flew the prototype HDS three times. Twice in Mexico and once at the Tulsa fly -in in 1992.
cfd(at)thegateway.net Guest
Posted: Wed Jan 04, 2006 7:58 pm Post subject: First Flight |
Zenith alowed me to fly their 701 with Roger in the right seat before I
flew mine. I did have a very expeienced pilot fly my 701 the first time
though.
Chuck D.
N701TX
-- Craig
Posted: Thu Jan 05, 2006 5:22 am Post subject: First Flight |
=09
It's me, again, about this first flight thing.
I sure want to thank all of you for your input on this. What I left out of the first post is that the plane is not finished, but I only need a hundred hours or so to " git 'er done "! All that's left is the wiring, canopy, seats, and paint. This is an XL with a Jabiru 3300. The main runway at KLXT in Lee's Summit, MO, is 4015 ft. long, so it should allow a few hops and rather fast taxiing.
As for my Dr., he's just looking out for me, that's all. My wife? well, that's another story. She likes to fly with me and is learning to land and navigate---no desire to get her ticket, though. She does, however, need to know how to fly and land. I told her that if the Good Lord calls me home while we are up, there's no need fot both of us to go! This bird is going to be our vacation transportation to parts, as of yet, unknown. Few things in this world scare me, such as first flight, but I don't intend to tempt destruction, either. I do need more hours and definitely more time in this type. I've been told that ZAC might work out something for a little more time in the Demo. I'll have to check and see as the time to lift off gets closer.
Again, I want to thank all of you that responded to this. These types of responses are what make this site so SUPER!!
I hope and Pray that all of you have a happy and safe New Year !
Rick Beckman
Midwest Mudworks
729 MSL and sinking
www.sharbo.us/thebird
Do NOT archive
