kfackler(at)ameritech.net Guest
Posted: Mon Jan 08, 2007 7:10 pm Post subject: Fuel cutoff valve: required or not? |
Gentlemen:
If you personally went through the inspection for an airworthiness
certificate, particularly if it was for an ELSA, can you tell me whether a
fuel cutoff value is required? My friend, Mark, believes that in a 'pump UP'
layout such as we have in our Kolbs, that they shouldn't be.
Thanks for your input,
-Ken Fackler
Kolb Mark II / N722KM (reserved but not applied)
Rochester MI
Posted: Mon Jan 08, 2007 9:08 pm Post subject: Fuel cutoff valve: required or not? |
Ken
I put a shut off valve on mine and my plane was inspected as a experimental
by some jerk out of the Grand Rapids MI. office. If you get the same guy he
was ONLY concerned about the paper work. His inspection consisted of making
sure the N numbers were the same on both sides of the plane, application
matched the data on the data plate and all the right info was correct on all
the forms etc. He wanted to hear the engine run and he was ready to sign
off. When I asked him to take a closer look at the plane he lifted the seat
belts and commented they didn't have the proper TSO numbers but he decided
to let me get away with them. A TSO number is not required on experimental
so from then on I decided to keep my mouth shut. A few years later I worked
with another inspector on the phone when I put the redrive on the engine
that was trying to do his job right but you just never know. The shut off
valve seemed like a good idea at the time but is it required?????
Rick Neilsen
Redrive VW powered MKIIIc
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Mon Jan 08, 2007 9:24 pm Post subject: Fuel cutoff valve: required or not? |
No...
On 1/8/07, Richard & Martha Neilsen <NeilsenRM(at)comcast.net (NeilsenRM(at)comcast.net)> wrote: | Quote: | | --> Kolb-List message posted by: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net (NeilsenRM(at)comcast.net)> |
[quote] The shut off
Rick Neilsen
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
Posted: Tue Jan 09, 2007 6:23 am Post subject: Fuel cutoff valve: required or not? |
shut off valve>>
Hi,
When I built my Challenger the requirement was for a cut off valve which
could be operated from the cockpit. Unfortunately I forgot it and the
inspector who was checking on the building didn`t mention it until the
plane was almost finished
We contrived a very snazzy system operated through bowden cables which
turned a cock fitted on the bulkhead just before the carbs.
Cheers
Pat
