		pequeajim
  Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
				 Posted: Sun Jan 14, 2007 5:00 pm    Post subject: information on the Lightning |
				I saw the Lightning at Sebring and am very interested in the possibilities of this aircraft.  The design seems to meet everything that I am looking for in a small fast glass airplane.  I am confused about some of the specifications though and maybe some of you who have built and flown the aircraft and help me.
 <![if !supportLists]>-         <![endif]>The specs say a 17:1 glide ratio with a wing of 90 sq ft?  How is this possible?  The CT has a large wing and a 13:1 GR?
 <![if !supportLists]>-         <![endif]>Take off roll of 310ft?
 <![if !supportLists]>-          <![endif]>The price list has an option for dual brakes.  Doesn’t the aircraft come with brakes as standard equip?
 <![if !supportLists]>-          <![endif]>Is the nose wheel castering or steerable?
 <![if !supportLists]>-          <![endif]>What is the delivery schedule at this point?
 Thanks for any feedback you all can give.
 Jim!
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
		N1BZRich(at)AOL.COM Guest
				 Posted: Sun Jan 14, 2007 6:32 pm    Post subject: information on the Lightning |
				Jim,
      I am sure the Lightning guys  will answer your questions when they get back from Sebring and get caught up,  but until then here are my thoughts on your questions:
         -    The  specs say a 17:1 glide ratio with a wing of 90 sq ft?  How is this  possible?  The CT has a large wing and a 13:1 GR?
              Different  airfoil, less drag, less weight.  Probably a combination of all  of these.
              When you fly  one you will sometimes wish you had speed brakes.
 -          Take off  roll of 310ft?
     Yep,  depending on the prop and whether you build your Lightning as light sport  compliant, but probably not at gross weight on a hot day.  That would be  closer to 500 ft.
 -           The price  list has an option for dual brakes.  Doesn’t the aircraft come with brakes  as standard equip?
     The aircraft comes with toe brakes on the pilot side as  standard.  Dual brakes would include brakes on the co-pilot side as  well.
 -           Is the  nose wheel castering or steerable?
     Castering - 30 degrees each side of  center.
 -           What is the delivery  schedule at this point?
     Probably depends on how many they sold at Sebring, but call  them next week for the real answer.
 Jim, hope this helps.   The Lightning is a super airplane if you are looking to get in the air quickly  and at an economical cost.  It is a dream to  fly.
 Blue  Skies,
 Buz  [quote][b]
		dashvii(at)hotmail.com Guest
				 Posted: Sun Jan 14, 2007 6:35 pm    Post subject: information on the Lightning |
				Jim,
    To answer some of your questions.  I haven't verified the glide ratio,
 but it is high due to wing loading.  Also the wing is a pretty thick wing.
 aircraft and help me.  The takeoff roll is extremely short.  With 2 of us on
 board, full fuel and about 20 lbs of baggage we took off from Carlsbad, NM
 at 4000 feet field elevation and 105 degree temps in maybe 500 feet.  The
 optional dual brakes if for brakes in the passenger side floor.  The
 prototype only has brakes on the pilot's side.  The nosewheel is castering,
 which means extremely tight turns on the ground.  Anymore that I can help,
 let me know.  Brian W.
 The MSN Entertainment Guide to Golden Globes is here.  Get all the scoop.
 http://tv.msn.com/tv/globes2007/?icid=nctagline2
		pequeajim
				 Posted: Mon Jan 15, 2007 5:03 am    Post subject: Re: information on the Lightning |
				I'm going to give those guys a call today and try to setup a weekend visit if at all possible.
		Kayberg(at)aol.com Guest
				 Posted: Mon Jan 15, 2007 7:38 am    Post subject: information on the Lightning |
				Jim,
  Call Ryan at Green Landings.....304-754-6010.
  We have a kit coming that should be delivered in the next  month.   We were going to build it ourselves, but could be pursuaded  with money!!!!
  Doug
  In a message dated 1/14/2007 9:33:40 PM Eastern Standard Time,  N1BZRich(at)aol.com writes:
   	  | Quote: | 	 		     Jim,
 Blue    Skies,
 Buz 	  | Quote: |
 href="http://www.matronics.com/Navigator?Lightning-List">http://www.matron.matronics.com/">http://forums.matronics.com
		pete(at)flylightning.net Guest
				 Posted: Mon Jan 15, 2007 7:54 am    Post subject: information on the Lightning |
				Hello Jim,
 Some simple answers:
 17:1 comes from having a very clean airframe with least amount of drag as possible.
 Takeoff can be less than 310 if we really work at it.
 The airplane kit comes with hydraulic brakes on the pilot’s side.  Dual brakes add brakes on the copilot side as well.
 It has a castering nose wheel.
 Delivery for an order today would be March
 Let me know if you need more info.
 Pete  Krotje
 Arion Aircraft, LLC
 From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Jim Langley
  Sent: Sunday, January 14, 2007 7:00 PM
  To: lightning-list(at)matronics.com
  Subject: Lightning-List: information on the Lightning
 Jim!   	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Lightning-List  | 	  01234
		IFLYSMODEL(at)AOL.COM Guest
				 Posted: Mon Jan 15, 2007 11:12 am    Post subject: information on the Lightning |
				Hey Pete: Were you at the Sport Pilot expo? I saw the lightening there, but  did not have time to stay and ask for a demo ride. I did put a request on the  Internet. I liked what I saw, and am seriously considering ordering a kit. You  said the kit ordered now would come in March, does that include the Jabiru  engine? I heard that their deliveries are backed up to October at present.
      How much deposit is required to put a kit on  order?
  Lynn Nelsen
		pequeajim
				 Posted: Mon Jan 15, 2007 5:43 pm    Post subject: Re: information on the Lightning |
				Thanks Peter.
 I am going to try to arracnge for a visit to your location by next month.  I would like to get a look at the operation and talk to your person that heads up the builder assist program.
 Jim!
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
