CardinalNSB(at)aol.com Guest
Posted: Thu Jan 18, 2007 7:46 am Post subject: lycoming dual mag D engine alternative mag question |
I got a D engine O-320 H2AD as part of a project, in good condition, already mounted so I want to keep it. It needs a mag rebuild. This is the "D" mag, dual drive, allegedly more failure prone because of a common drive gear.
1. any recommendations on upgrades to the D mag while still keeping the D mag engine certified
2. any information/recommendations on using a "crank trigger" ignition as the source for firing the second set of plugs? from what I read in hot rod magazine these are old hat in big hp stressed engines, maybe a Megasquirt with 4 separate coils? This would avoid the single point failure of the drive gear, and would be fun to play with timing changes.
I'll keep the carb for now.
Is there an easy conversion to use a single regular mag driven off the accessory case?
While I am here, what is the latest information re roller cam followers for this engine, there is no T modification done to this engine.
This is in an experimental so I could ....
Thanks for any help, Skip Simpson
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
archie97(at)earthlink.net Guest
Posted: Thu Jan 18, 2007 3:12 pm Post subject: lycoming dual mag D engine alternative mag question |
glcasey(at)adelphia.net Guest
Posted: Fri Jan 19, 2007 5:38 am Post subject: lycoming dual mag D engine alternative mag question |
The most straightforward thing to do is have the D mag rebuilt with
all the AD's complied with. If that is done the reliability is
reported to be as good as that of dual mags. If you want a
performance increase I believe you can buy a Lightspeed ignition with
a crank trigger that would fire half the plugs. You can bolt a
single mag, presumably without an impulse coupling, in the place of
the dual. A third option is to convert the accessory case to a dual
drive, but I doubt if the H engine allows that.
Gary Casey
| Quote: | Time: 07:46:17 AM PST US
Subject: lycoming dual mag D engine alternative mag
question
condition, already
the "D" mag,
gear.
keeping the D
ignition as
in hot rod
Megasquirt with
the drive
accessory case?
followers for
Float Flyr
Posted: Fri Jan 19, 2007 6:47 am Post subject: lycoming dual mag D engine alternative mag question |
If you are taking votes I would vote for the single mag and the Lightspeed
CDI combi...
Noel
Do not archive.... See sometimes I do remember.
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
w_sweet(at)comcast.net Guest
Posted: Fri Jan 19, 2007 7:32 am Post subject: lycoming dual mag D engine alternative mag question |
I agree with this idea. However, make sure you do a mag check at the end of
every flight, so if the mag died in flight, you can fix it before the next
flight, since you will see no noticeable indications in flight. The mag in a
LSE CDI - mag combo is there just in case, since it does little or nothing;
turning off the mag on a regular mag check shows no RPM drop, at least in my
initial installation. I now have dual LSE CDI's and had to warn a CFI giving
me a biennual check that there would be no RPM drop when shutting off either
CDI. That says something about how efficient those CDI's are.
Wayne
Gosh2Fly(at)aol.com Guest
Posted: Sat Jan 20, 2007 6:59 am Post subject: lycoming dual mag D engine alternative mag question |
Skip' I presently fly an Acro Sport with a 0320H2AD. I have used both the crank sensor with the elecr. unit. and 3000 series dual mag. The 3000 series mag was rebuilt and has not given me any trouble. I also use the SilverHawk fuel injection system on the 0320H2AD
