kolbmark3
Joined: 10 Jan 2006 Posts: 40 Location: Mt Clemens, MI
Posted: Tue Jan 23, 2007 5:23 am Post subject: Kolb glider |
"The Kolbs drop like a rock" - not really! Granted, it is not like a glider, but having experienced at least ten "engine outs" from as low as 300 feet to as high as 2000 feet, the Mark III does give you some time to land. But in any plane, even a GA, it is always a good idea (read life saver) to have a potential landing site picked out.
Jim
Mark III
_________________ Jim
Mark III
Mt. Clemens, MI |
dhkey(at)msn.com Guest
Posted: Tue Jan 23, 2007 5:45 am Post subject: Kolb glider |
Let me rephrase it then, I don't know many other planes that have a worse
glide ratio.
| Quote: | From: "flykolb" <flykolb(at)wowway.com>
Reply-To: kolb-list(at)matronics.com
To: <kolb-list(at)matronics.com>
Subject: Kolb glider
Date: Tue, 23 Jan 2007 08:27:50 -0500
Jim
Mark III
APilot(at)webtv.net Guest
Posted: Tue Jan 23, 2007 6:19 am Post subject: Kolb glider |
Very good point. Another reason to become proficient at the 180 degree
turn back to the runway. Practice at altitude - use it in an emergency.
I have had well over a dozen engine outs in ultralights which were all
my fault. And two in Cessna 150's and one was my fault. But, no matter
whose fault it is, it is good to have a safe place to land when to ole
beater quits..
Posted: Tue Jan 23, 2007 6:43 am Post subject: Kolb glider |
Race for worst glide ratio..........Ercoupe or Piper Colt or Kolb?
Steve Boetto
Posted: Tue Jan 23, 2007 7:53 am Post subject: Kolb glider |
To be Fair in this comparison I think you need to add in the factor of available landing sites that offer no damage to the aircraft. My Long-EZ had a glide ratio of over 20 to 1 with the blades stopped but there are few and far between landing sites. In comparison, my Firefly on floats probably has less than 8 to 1 but even at an altitude of 100 ft I can land with no damage 99.99999% of the time. Point is, There are other factors more important than Glide ratio.
Steve
FF #007 on Floats
Posted: Tue Jan 23, 2007 8:17 am Post subject: Kolb glider |
David
Kolbs are ultra low speed STOL airplanes. They have very large props for
their size and weight that create considerable drag when they stop. But it
is that large prop that makes these airplanes fly as well as they do. If you
compare a Kolb to a similar type of aircraft they do fairly well. You appear
to be comparing them to gliders or other streamlined GA aircraft. In a
airplane everything is a tradeoff. If we were to compare the features that
these planes were designed for against most any other airplane we would blow
them away. Again everything is a trade off and comparisons with other
categories of aircraft just don't make sense.
Rick Neilsen
Redrive VW powered MKIIIc
Eugene Zimmerman
Posted: Tue Jan 23, 2007 9:49 am Post subject: Kolb glider |
Hello,
My advise to all Kolb newbees,
Please ignore the advise of "the experts" who claim to have
experienced 10 or 12 engine outs.
d-m-hague(at)comcast.net Guest
Posted: Tue Jan 23, 2007 10:16 am Post subject: Kolb glider |
At 09:43 AM 1/23/2007, APilot(at)webtv.net wrote:
Hah! I haven't flown my Kolb yet, but it CAN'T be worse than the
Quicksilver I was flying last year!
OTOH, I actually soared my T-Craft a couple of times with the engine off....
-Dana
But if we LEGALIZE it, we can't take your HOUSE!
Posted: Tue Jan 23, 2007 10:22 am Post subject: Kolb glider |
At 10:52 AM 1/23/2007, n27sb(at)aol.com wrote:
| Quote: | To be Fair in this comparison I think you need to add in the factor of
available landing sites that offer no damage...my Firefly on floats
True, I fly PPG too... an unpowered PG does about 8:1 but it's probably
closer to 6:1 with a stopped motor... but when you can fly a 50' circle and
land with a few running steps even in no wind, you have a large pick of
landing sites even with the crappy ratio.
-Dana
jim
Posted: Tue Jan 23, 2007 10:46 am Post subject: Kolb glider |
I sold my Quicksilver MX in Aug 2006 to buy a Kolb Firefly (which I got in
October). I expected the Firefly to glide better, but it's actually
worse.
N. Idaho |
kolbmark3
Posted: Tue Jan 23, 2007 11:26 am Post subject: Kolb glider |
I certainly do not claim to be an "expert" nor do I "claim" to have had at
least 10 engines out - it's a fact Jack!
All I'm saying is that a Kolb does not "drop like a rock" - which is
straight down! Many on the Kolb list have experienced engine failure and
have "glided" to a safe landing. Some have not but even those did not "drop
like a rock". I just don't want to scare people who think that when an
engine quits on any plane it "drops out of the sky". Always have a good
landing site picked out no matter what you fly.
Peace and good flying.
Jim
Mark III
Mt. Clemens, MI |
N111KX (Kip)
Posted: Tue Jan 23, 2007 12:06 pm Post subject: Re: Kolb glider |
There are some dead-stick videos here where, for a rock, I have lot's of time to enjoy the view...
Kip
http://gyrobuilder.homelinux.org/gallery2/v/monarch_flight/july2006/?g2_page=4
_________________ Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta |
a58r(at)verizon.net Guest
Posted: Tue Jan 23, 2007 12:07 pm Post subject: Kolb glider |
TriPacer worse than Colt...dang nose thing-y grabs a load of wind.
BUTT, I got the FireFly to fly with "power," which it does as an
airplane (=vehicle in faa-speak). Anything else is just gravy/gravity.
regards,
Bob N. FireFly 070 Old Kolb
Posted: Tue Jan 23, 2007 12:38 pm Post subject: Kolb glider |
my Firefly on floats probably has less than 8 to 1 but even at an altitude of 100 ft I can land with no damage 99.99999% of the time..>>
well if you only fly over water all you have to do is wait a bit and then flare. Heh Heh.
I have had to land quickly twice in my Challenger when the toothed belt drive to the prop shed its teeth. Similar sort of glide performance as a Firefly I should think. It doesn`t `drop like a rock` but from the sort of height I usually fly, under 2000 ft, you look for a landing place in an emergency right underneath you because you are not going to have time to fly around searching for a spot. By the time you have flown a 360 looking for a place you had better be lined up on finals.
Cheers
Pat
GeoR38
Joined: 25 Jan 2006 Posts: 60 Location: The Villages, fl
Posted: Tue Jan 23, 2007 12:43 pm Post subject: Kolb glider |
In a message dated 1/23/2007 3:07:39 P.M. Eastern Standard Time, n111kx(at)mindspring.com writes:
| Quote: | http://gyrobuilder.homelinux.org/gallery2/v/monarch_flight/july2006/?g2_page=4
I can't let you guys get away with such bad press on the Kolb glide, which admittedly is by no means superior, but it is not as bad as the sound of your dialog. I am a glider pilot, albeit way back in '80 in El Paso and Las Cruzes NM, so I actually know the L/D that real gliders have.
my time in the Schweizer 233 and the 126 produced 20 to 1 or 25 to 1 L/D. On the field was an old old glider used before the Big One in the '30s and it had an L/D of 11 to 1. It was actually built a little like the Firestar inasmuch as it was a high wing with a boom going back to the tail and a semi-open cockpit.
It was a glider only.
And it was 11:1.
I have tested my Firestar KX many times and it always tests our at 9 or 9.5 to1. But every test was with the engine at idle.You could tell that the spinning prop was a brake as it was necessary to fire up the RPMs quite high, at least above 3000 rpm,Afore any assist was felt on the airframe., And I do not mean the aircraft was anywhere near climb mode. It was still mushing, but it seemed that the prop was not offering drag around that rpm.
I have never killed power completely, but I suspect that if the prop were stopped, the L/D would probably increase to at least 10:1....which is close to that ol training glider on my field way back in '80
My Firestar only has a 5 rib wing and is probably a little liter than the KXP, but a heavier glider has more penetration so ....who knows what the KXP has?
Firestar Driver from The Villages Florida
George Randolph
_________________ George Randolph
Firestar driver, The Villages, fl |
Posted: Tue Jan 23, 2007 2:06 pm Post subject: Kolb glider |
At 01:45 PM 1/23/2007, Jim Dunn wrote:
worse.
Hmmm, one of the guys I was sharing an MX with flew my Ultrastar a few
times (before I bought it) and said compared to the MX, "it's a real
floater". I don't know how the US glide compares to the Firefly, though.
Hopefully in a month or two I'll see for myself...
-Dana
possums(at)bellsouth.net Guest
planecrazzzy Guest
Posted: Tue Jan 23, 2007 3:34 pm Post subject: Re: Kolb glider |
I don't think they saw your video...otherwise they'd be sing'n a different tune...
Lotsa time , lota glide.....HEY , You got Helium in dat thing ???
Gotta Fly...
Mike & "Jaz" in MN
Posted: Tue Jan 23, 2007 3:50 pm Post subject: Kolb glider |
got in
| worse.
Jim D:
You musta got a bad one. The good ones fly pretty darn good, like
all Kolb airplanes.
DO NOT ARCHIVE
_________________ John Hauck
Titus, Alabama |
