		N1BZRich(at)AOL.COM Guest
				 Posted: Fri Feb 02, 2007 3:16 pm    Post subject: Baggage area and rear bulkhead |
				Someone on the list was asking to see baggage area  and rear bulkhead photos.  I finally found one of my aircraft, N31BZ, the  Esqual LS - Lightning Stuff.  B&B in Shelbyville (they do contract work  for Pete and the guys) did my interior and they had the embroidery done on the  bulkhead.  In this photo the side panels in the cockpit are not in place  yet and it looks like the baggage area headliner is also not in  place.  The slits on either side of the clear FAA paperwork holder are for  the shoulder harnesses.
      As a side thought and suggestion for Lightning  builders, I will be adding some sort of vent in the bulkhead to let air out of  the cockpit.  In the summer when you have both cockpit fresh air vents open  and  you are cruising at 170 or so, so much air come into the cockpit  that there is some pressurization of the cockpit.  The canopy actually  bulges out slightly on each side.  Some way for this air to flow through  the cockpit into the aft fuselage should fix this situation.
  Blue Skies,
  Buz
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
		lozhoffman(at)yahoo.com Guest
				 Posted: Fri Feb 02, 2007 4:13 pm    Post subject: Baggage area and rear bulkhead |
				Buz,
 Even at 80-90kts in the motorglider the cockpit
 pressurisation is significant as a function of the
 effective cabin ventilation. I fitted what looks like
 a small radio speaker cover to the bulkhead as a vent
 into the rear fuselage and the increae in airflow into
 the cockpit is doubled.
 I did however fit it a little low on the bulkhead as
 when the baggage area is holding a lot of gear it will
 usually block the vent partially so it would pay to
 set it higher on the bulkhead.
 How effect is the Lightning cockpit ventilation
 without canopy side scoops?
 Laurie
 Sydney
 --- N1BZRich(at)aol.com wrote:
  	  | Quote: | 	 		   Someone on the list was asking to see baggage area
  harnesses.
  builders, I will be
  there is some
  fix this situation.
  Blue Skies,
  Buz
 Need Mail bonding?
 Go to the Yahoo! Mail Q&A for great tips from Yahoo! Answers users.
 http://answers.yahoo.com/dir/?link=list&sid=396546091
 <pre><b><font size  color="#000000" face="courier new,courier">
				 Posted: Fri Feb 02, 2007 7:16 pm    Post subject: Baggage area and rear bulkhead |
				In a message dated 2/2/2007 7:16:16 P.M. Eastern Standard Time,  lozhoffman(at)yahoo.com writes:
   	  | Quote: | 	 		  How    effect is the Lightning cockpit ventilation
  Hi Laurie,
      The Lightning has great cockpit ventilation.   Each side of the fuselage, just aft of the firewall, has a NACA ducts that  provide air to the cockpit.  In the cockpit are adjustable outlets that  lets you open and close off the air flow.  There are no canopy side  scoops.  However there is an option to add a small sliding canopy opening  similar to what I have seen on gliders.  I have one of these on my Esqual  canopy.  On the ground you can taxi with the Lightning canopy slightly open  for fresh air.
      As far as a mod to let air flow through the  cockpit, I have found some round 3" aluminum vents that I plan to use.  I  will put one on each side of the aft baggage bulkhead near the top.  How  large was that outlet vent you used?
  Buz
				 Posted: Fri Feb 02, 2007 10:17 pm    Post subject: Baggage area and rear bulkhead |
				Buz,
 About 5" diameter. Pleased to hear that the Lightning
 canopy can be cracked open on the ground. Sure does
 get hot in this country at times.
 Laurie
  Standard Time,
  Hi Laurie,
  Buz
 Don't pick lemons.
 See all the new 2007 cars at Yahoo! Autos.
 http://autos.yahoo.com/new_cars.html
		Scotty
  Joined: 08 Oct 2006 Posts: 44 Location: Peachtree City, GA
				 Posted: Sat Feb 03, 2007 4:45 am    Post subject: Re: Baggage area and rear bulkhead |
				Buz and Laurie, et al,
 The Diamond DA40 has the same style canopy as the Lightning.  There is an additional locking hole for the canopy latching pin to go into.  It is located about 1 inch above the "closed and locked" hole.  You raise the canopy, and latch it in this slightly opened position when on the ground and it provides a great ventilation on the ground when the engine is running.
 The DA-40 also has a little vent window on the side.  It is worthless in flight and on the ground unless you stick your hand out and "scoop" some air into the cockpit.
 I am not recommending this additional hole except as a possibility, because I have not looked at the fuselage strength where the canopy latch hole is located.  It is a great feature on the DA-40.  Check it out the next time you see a DA-40.
 Another feature they have is a painted "ceiling" on the roof of the canopy to block some of the sun.  However, the sun and the painted "ceiling" are in cahoots.  They move just enough for the sun to beat on your head or get into your eyes on EVERY flight.
 Oops.  On re-looking at Buz's picture, the canopy lock down system may be different than on the DA-40.  Ready Fire Aim....
 Scotty
		dashvii(at)hotmail.com Guest
				 Posted: Sat Feb 03, 2007 5:33 am    Post subject: Baggage area and rear bulkhead |
				Scotty,
    The two-hole canopy latching part is also on the Lightning prototype.
 Not sure if anybody else uses it or not.  Also Buz utilized something that
 looks like a painted cieling, but it's the stick on type of sun visor stuff
 so it is just a darkened area above the cockpit.  When I flew the Ligthning
 out to Arizona I had some stick on sun visors and they worked really well
 and I could move them around as the sun moved around.  Brian W.
 Reply-To: lightning-list(at)matronics.com
 Subject: Re: Baggage area and rear bulkhead
 Date: Sat,  3 Feb 2007 04:45:04 -0800
 into the cockpit.
 you see a DA-40.
   [Laughing]
 Scotty
 He who doesn't read the news is UN-informed.
 He who reads the news is IL-informed.
 Mark Twain
 http://forums.matronics.com/viewtopic.php?p=92543#92543
 Turn searches into helpful donations. Make your search count.
		Scotty
				 Posted: Sat Feb 03, 2007 6:00 am    Post subject: Re: Baggage area and rear bulkhead |
				Brian,
 Yes, I get them at Walmart (in the FAA approved section, of course) and keep them in my flight bag.  When they quit sticking to the window, I wash them with a mild detergent and they magically start sticking again.
 Scotty
 Technology sufficiently advanced is indistinguishable from magic.
		corky(at)hbci.com Guest
				 Posted: Sat Feb 03, 2007 6:27 am    Post subject: Baggage area and rear bulkhead |
				Laurie
 I have an Esqual which I have installed a Kroger sunshade.  It slides back
 on a track that is double faced taped to inside of canopy. It keeps cockpit
 cooler on sunny days and on cloudy days you simply slide it back.  It never
 gets in the way and it looks cool. Got mine through Vans Aircraft.
 Rosen makes a sunshade that I also use, You simply apply it with suction
 cubs. Blocks sun very well.
 Dave McC.
		lbmathias(at)verizon.net Guest
				 Posted: Mon Feb 05, 2007 6:38 am    Post subject: Baggage area and rear bulkhead |
				We have two side windows in the canopy of our Lightning;  they aren't sliding windows but are actually small rectangular windows that are  hinged on the bottom so open down.  They will be either open or closed  - no partial opening.
                                                         Linda
  [quote]   ---
		pequeajim
  Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
				 Posted: Mon Feb 05, 2007 6:50 am    Post subject: Baggage area and rear bulkhead |
				That's kind of cool.  Are they large enough to stick a camera lens through, or is that not practical?  Also, do you have a pic of the installation?
  On 2/5/07, JOSEPH MATHIAS LINDA MATHIAS <lbmathias(at)verizon.net (lbmathias(at)verizon.net)> wrote: [quote]      We have two side windows in the canopy of our Lightning; they aren't sliding windows but are actually small rectangular windows that are hinged on the bottom so open down.  They will be either open or closed - no partial opening.
                                                      Linda
				 Posted: Mon Feb 05, 2007 7:07 am    Post subject: Baggage area and rear bulkhead |
				Jim,
    Here's a blow up of a pic that I took.  Not of the canopy, but I cropped
 it.  The windows are similar to many different versions of Piper Arrows that
 I have flown.  Just a little fold down.  You could probably get a camera
 lense through the hole, but it's not very practical as the wing is right
 there.  You might could turn the plane on its side every now and again and
 get a shot out of it.  Regardless it helps with cockpit ventilation.  It's
 similar to Buz's sliding window, just this one henges and folds down.  Brian
 W.
 Date: Mon, 5 Feb 2007 09:50:23 -0500
 partial
 opening.
                                                      Linda
				 Posted: Mon Feb 05, 2007 8:14 am    Post subject: Baggage area and rear bulkhead |
				JIm,
      Brian answered the question  about camera lens but I think you can see the windows a little better in the  picture I am attaching.   We did not install the side windows; the  canopy was delivered with the windows installed.
                                                Linda
		pequeajim
				 Posted: Mon Feb 05, 2007 8:34 am    Post subject: Baggage area and rear bulkhead |
				VERY NICE!   Thanks to you both for the information.  THe reasont that I asked is that my daughter LOVES to take pictures and is very excited about going up in ANY aircraft that I fly.  RIght now, I am flying a rental 172 and you can't open the windows and they are typically scratched so the pics come out foggy.  Having a big clear canopy will make things a little better,  Having a small window to stick the lens through might work too.
  Will you have your aircraft at Sun N Fun?  If so, I can get a look at them when I'm at the show.
  Jim!
  On 2/5/07, JOSEPH MATHIAS LINDA MATHIAS <lbmathias(at)verizon.net (lbmathias(at)verizon.net)> wrote: [quote]  JIm,
                                               Linda
				 Posted: Mon Feb 05, 2007 9:09 am    Post subject: Baggage area and rear bulkhead |
				Jim,
   I too love to shoot aerial photos.  I did a photoshoot for a local paper
 last year of industry around the city.  We got some great pics.  I had to
 use a Cherokee 140.  Well the wing was always in the way.  The pilot wa an
 ex- Air Force B-52 and F-111 pilot.  He would crank it over 90 degrees and
 let me get a shot.  Problem was that we couldn't hold that but for a second.
   I've found that high wing airplanes that the window will open fully or the
 door can be removed is best for that.  There is a Rans S7S with a Jabiru
 firewall forward kit on it at Shelbyville right now.  It'd make a fantastic
 camera platform as the whole side of the plane can be removed for flight.
 Brian W.
 Date: Mon, 5 Feb 2007 11:33:18 -0500
 Jim!
   JIm,
 installed.
                                               Linda
				 Posted: Mon Feb 05, 2007 12:15 pm    Post subject: Baggage area and rear bulkhead |
				Jim,
      We plan to be at Sun 'n' Fun if  the registration comes in time for the inspection and 40 hours to be flown  off.     Just in a holding pattern right now!
                                                     Linda
  [quote]   ---
