Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Mon Feb 05, 2007 3:50 pm Post subject: Protection For Auxillary Power Jacks |
Assume that one wanted to install four "cigarette lighter" auxillary power jacks in an airplane, with two on the panel and two in the rear passenger area. Anywhere from none to all four might be used at any given time.
Would it be acceptable practice to put all of these on a single breaker?
Would it be acceptable to have more than one on a single breaker?
Or, should each jack have a separate breaker?
Thanks!
mprather(at)spro.net Guest
Posted: Mon Feb 05, 2007 4:50 pm Post subject: Protection For Auxillary Power Jacks |
My preference (bias)? No breakers - just fuses..
Either way, (as has been said) the cigarette lighter connection isn't all
that spiffy except that lots of portable electronics are designed to use
them. I've seen up to about 5A run through one with good success. Maybe
it's safe to run more than that through them. Need to research that some
more.
Whatever, as is the case when choosing wire and circuit protection for any
other application, the breaker/fuse must be small enough to protect the
skinniest wire/component being used in the circuit.
So, I don't see a way to provide protection for the plug and the wire if
you gang them, assuming you want to support the max capability of the
plug. If you assume the plug will support 5A, you put a 5A breaker/fuse
on the circuit. If you gang multiple plugs onto the same breaker then 5A
is still the largest circuit protection you can select. However, if you
don't mind imposing a total power budget on your users - not letting them
use more than 5A total, then by all means put them all on one breaker.
If it were mine, depending on where my breaker/fuse panel is and how
accessible it is in flight, I'd split the load into at least two chunks.
If one of the devices craps out (shorts its power supply), or your kid
tries to drive two laptops into one plug (adapter on top of adapter), only
half the cig buss will be dead. I would probably build it with one per
adapter. Or maybe two fuses for the front and one to cover the pair in
the rear - 3 total.
I think one big thing to consider is whether the adapters will be used for
mission-convenient/comfortable appliances. I don't say mission-critical
because I kind of think cigarette adapters aren't appropriate for
mission-critical power sources. My handheld GPS probably isn't mission
critical, but I'd like it's power source to be very stable none the less.
Matt-
<bdenton(at)bdenton.com>
Thanks!
http://forums.matronics.com/viewtopic.php?p=93067#93067
khorton01(at)rogers.com Guest
On 5 Feb 2007, at 18:50, Bill Denton wrote:
breaker?
Thanks!
No problem with all on one breaker. But, that breaker must be large
enough to handle the total possible load. And, all wiring must be
sized so that it wouldn't overheat if current up to the breaker size
was going through it. E.g., let's say you except no more than 2.5
amps per circuit. The breaker must be able to handle 10 amps,
without opening. You need some margin, so you decide to use a 15 amp
breaker. Now you need to make sure all wiring is large enough to
handle up to 15 amps, because a short would put that much current in
the wire before the breaker popped.
If you use 4 separate breakers, then the breaker size can be smaller,
and that will allow the use of smaller wires.
Total weight, complication, and cost are probably lowest by putting
all four through one breaker, unless the wire runs would be quite
long. If the wire runs are long enough, it might be lighter to go
with four breakers.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
nuckollsr(at)cox.net Guest
Posted: Mon Feb 05, 2007 6:44 pm Post subject: Protection For Auxillary Power Jacks |
At 03:50 PM 2/5/2007 -0800, you wrote:
Problem with one breaker/fuse does all is that a fault in one
system takes down all systems. If you don't use fuse blocks with
the necessary spares, then suggest in-line fuse holders with
one fuse for each accessory.
http://www.aeroelectric.com/Pictures/Fuses/ifh-2.jpg
Cigarette lighter jacks are about the poorest excuse for a connector
without being completely worthless. For use in aircaft, consider
these devices from Radio Shack.
http://www.aeroelectric.com/Pictures/Connectors/274-010.jpg
http://www.aeroelectric.com/Pictures/Connectors/274-013.jpg
These are REAL connectors. They're more compact than the cigar
lighter and have a positive locking feature that prevents the
plug from being inadvertently dislodged.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
willslau(at)alumni.rice.e Guest
Posted: Tue Feb 06, 2007 3:28 am Post subject: Protection For Auxillary Power Jacks |
Regardless of the protection scheme, take a look at these plugs and sockets.
www.powerletproducts.com These come highly recommended by one of my
motorcyle riding friends, and are what I'm planning to use.
William Slaughter
RV-8
