mr.sun
Posted: Thu Feb 08, 2007 9:17 pm Post subject: RPM Chart |
My RV-7 has an IO-360, lightspeed ignition and Hartzell constant speed prop. I'm looking for a chart with RPM & MP & %power that I can use to set up cruise flight efficiently. My Lycoming & Hartzell books don't help. Any help out there? Greg
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Greg RV-7 |
Kellym
Posted: Thu Feb 08, 2007 9:31 pm Post subject: RPM Chart |
Get your hands on owners manual for 200hp Mooney, Cardinal, Arrow for a
starting point.
Generally rpm/100+MP=49 will put you pretty close to 75%, give or take
3%. Fuel flow ROP will be about 10.5-11. Lean of peak figure 9.5-10gph.
Make sure with Hartzell the rpm recommendations/limitations for your
specific engine/crank and prop combination. Many have restricted areas.
Especially the A1A engine with the more desirable non-counterweighted
crank, at least if aerobatics are contemplated. (My Mooney with that
combination has restricted range from 2000-2350)
Greg Williams wrote:
Quote: | My RV-7 has an IO-360, lightspeed ignition and Hartzell constant speed
KCHD |
n801bh(at)netzero.com Guest
Posted: Thu Feb 08, 2007 9:52 pm Post subject: RPM Chart |
GPS, a fuel flow meter and some cruising around will give you the best numbers..
Ben Haas
N801BH
www.haaspowerair.com
tronics.com
khorton01(at)rogers.com Guest
Posted: Fri Feb 09, 2007 3:04 am Post subject: RPM Chart |
Parallel valve or angle valve IO-360?
Kevin Horton
Ottawa, Canada
