		info(at)usjabiru.com Guest
				 Posted: Thu Feb 08, 2007 7:12 am    Post subject: Empty Weight |
				The Arion Aircraft development team has been working hard to reduce the empty weight of the basic Lightning.  We have found new core materials and new methods of fabrication that reduce weight but maintain the strength of the structural components.  We have redesigned some of the non structural components as well to make them lighter.  Based on the empty weights of recently completed Lightnings we are reducing the empty weight specification by 25 lbs to 775 lbs.  Builders can achieve this weight for a Lightning with VFR instruments, Becker Radios (they are light), minimal interior finish, and a wood prop.
 Pete Krotje
 Arion Aircraft, LLC
  |  | - The Matronics Lightning-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Lightning-List |
		pequeajim
  Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
				 Posted: Fri Feb 09, 2007 10:18 pm    Post subject: Re: Empty Weight |
				Hi Pete:
 That's great news...  Continuous inprovement!
 When do you think this updage will make it into production?
 Jim!
		pete(at)flylightning.net Guest
				 Posted: Sat Feb 10, 2007 7:13 am    Post subject: Empty Weight |
				Jim,
 It's already there.  The last 15 or so kits would be able to be built at the
 lighter weight.  Final weight will always depend on additions to the basic
 airframe.  Nice interiors add 8 lbs or so.  Carbon ground adjustable prop
 adds two or three lbs.  Extra paint (pearl, extra stripes, etc) can add 5
 lbs or more.  Extra instruments or EFIS's can add 5 lbs.  Garmin radios
 instead of Becker add 4 lbs.  Auto pilot servo's weigh 3 lbs+ each.
 It's easy to make it heavier and a real challenge to make it lighter.
 Pete
		JamesL(at)Lugoj.com Guest
				 Posted: Sat Feb 10, 2007 8:41 pm    Post subject: Empty Weight |
				Hi all,
 Speaking of empty weight, have any of the Lightnings built so far had
 the BRS parachute option installed? If so, what was the weight penalty
 and what did it do to the empty balance relative to a comparably
 equipped non-BRS plane?
 Thanks for any information you can supply!
 Jim Logajan,
 Still just kicking tires.
		dashvii(at)hotmail.com Guest
				 Posted: Sun Feb 11, 2007 6:18 am    Post subject: Empty Weight |
				Jim,
    There was the prototype built with a BRS, don't know the weight penalty,
 Nick can answer that.  There was also one customer plane with it, but the
 plane is on hold until finances and medical can be worked out as I
 understand.  It does signifigantly reduce the amount of room you have for
 baggage though since that is where it hangs.  Brian W.
 Reply-To: lightning-list(at)matronics.com
 Subject: Re: Re: Empty Weight
 Date: Sat, 10 Feb 2007 20:39:42 -0800
 Hi all,
 Jim Logajan,
 Don’t miss your chance to WIN 10 hours of private jet travel from Microsoft
		georgiemun
				 Posted: Sun Feb 11, 2007 12:04 pm    Post subject: Re: Empty Weight |
				What about useful load now?
 On the web site, it lists the following:
 Gross Weight   1425 lbs
 Empty Weight   775  lbs
 That makes the useful load 650.  Are these the latest figures?  The weight that is listed, is this with a standard instrument package; or what configuration was used to determine the empty weight?
				 Posted: Sun Feb 11, 2007 1:01 pm    Post subject: Empty Weight |
				These are the latest figures.  To quote from the web site:
 "The Arion Aircraft development team has been working hard to reduce the
 empty weight of the basic Lightning.  Based on the empty weights of recently
 completed Lightnings we are reducing the empty weight spec by 25 lbs to 775
 Becker Radios (they are light), minimal interior finish, and a wood prop."
 As you can see this weight is achievable with VFR instruments, a Becker Comm
 radio, intercom, EIS engine monitor, wood prop, and a lightweight interior.
 We really have no such thing as a "standard" instrument package as most
 builders use the panel to individualize their plane.
 Pete
		vettin74(at)yahoo.com Guest
				 Posted: Mon Feb 12, 2007 6:15 am    Post subject: Empty Weight |
				Aircraft with a bacic interior, meaning mostly speckled paint in the rear baggae are and on the sides of the cockpit, carpet on the baggage floor and cockpit floor, nice seat cushions. As for instruments, a single Horizon sport EFIS , EIS, becker radio and transponder, PM501 intercomm, swiches and breakers. A wood prop, 2 color paint. The basics to make a good day/night VFR aircraft...
   Nick
 georgiemun <georgiemun(at)yahoo.com> wrote:
   [quote]--> Lightning-List message posted by: "georgiemun"
 That makes the useful load 650. Are these the latest figures? The weight that is listed, is this when a standard instrument package, or what [quote][b]
