Michel
Posted: Sat Feb 10, 2007 12:38 am Post subject: GPS |
Kurt, Dave and Lynn,
On Feb 9, 2007, at 8:34 PM, kurt schrader wrote:
| Quote: | But at a guess, I'd say you are seeing some reflecting
signals off the water confusing your GPS a bit.
You are into something, Kurt! When I flew to Belgium, I noticed that
the "breadcrumbs" of the GPS moving map, where scattered over a certain
area of my flight over Germany. It started exactly at the edge of a
muddy bay and ended exactly at it's end. Now, this is a tidal North Sea
cove that nearly entirely dries out at low tide. And it was low tide:
very wet mud.
Lynn, such magnetic disturbances are not uncommon. I know of an
important one off the coast of Portugal. While I agree with Garmin that
a lot of things can affect the GPS signal reception, I really doubt
that this magnetic abnormality is the cause because, while an uneven
ferrous terrain will deviate the compass, it is not producing by itself
a magnetic field. Then the magnetic field from the Garmin screen should
be much more influential on you GPS antenna because much, much closer!
If your GPS didn't register your stop, it must be because of something
in the GPS software that detects your stop. In my GPS with PocketFMS
software, I've put 30 MPH as the lower limit of non-flying. What's
yours? You see, even in a place where the signal is disturbed by
whatever, your GPS may show scattered successive positions but it would
be very weird if none of those came under your lowest level of speed
for being airborne.
Michel
Lynn Matteson
Posted: Sat Feb 10, 2007 4:07 am Post subject: GPS |
In a previous response from Garmin Tech Support, they told me that
the unit starts a flight when it sees 500 feet AGL, and assuming that
it quits the flight when you descend to 500 feet AGL, the flight into
Escanaba should have been recorded.
The response was to a question that I had about the flight log. First
some background info. My uncharted, private field is about 2.5 miles
from a charted airport. My flight log often shows me taking off or
landing at this charted airport, when in fact I have been doing (for
example) pattern work at my field. This is annoying, but I live with
it. When I asked Garmin about this problem, they told me about the
500-foot thing. They told me to use an "airport identifier symbol" to
mark my field, and to be sure that I entered an elevation for my
field. Here is their response:
"One thing that you will need to make sure is that you have entered a
elevation for your airport. If the elevation is wrong or missing
then it
will pull the closest airport. Also if a public airport and a private
airport are close like the situation that you have described here
then the
unit will prefer the public airport over the private airport."
I didn't keep their response regarding the identifier symbol or the
500-foot elevation for the flight log starting point...I wish I had.
In regards to the "scattered successive positions", I did indeed have
the breadcrumb trail interrupted on one leg of the trip, but I just
figured that a mouse got on board somehow, and was having a party. : )
Lynn
On Feb 10, 2007, at 3:37 AM, Michel Verheughe wrote:
something in the GPS software that detects your stop. In my GPS
with PocketFMS software, I've put 30 MPH as the lower limit of non-
flying. What's yours? You see, even in a place where the signal is
disturbed by whatever, your GPS may show scattered successive
positions but it would be very weird if none of those came under
your lowest level of speed for being airborne.
Michel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
dave
Posted: Sat Feb 10, 2007 5:00 am Post subject: GPS |
Lynn,
We that discussion a few weeks ago about my Garmin 196 --
I pointed out to Michel that my does not log unless over 500 AGL and over
30 knots speed.
The latter is a given but the 500 AGL is something that I don't always see
on short flights.
Surely you were over 500 AGL ?
Also I am not positive but I am not sure if you can alter those settings in
the Garmin.
You can alter the VNAV settings though and set up some non precision
approaches. I have some set up now and at 500 feet agl and 1 Mile back
I am usually within 1/8 mile of the runway centreline. Mind you, I have
set these up for grass strips and Lakes where I frequent. Certainnly not a
ILS approach but helpful.
Happy Flying !!
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Sat Feb 10, 2007 5:37 am Post subject: Re: GPS |
Around here, we use hand-held GPS units for guidance, but have learned to not trust them. Friends and I have discussed seeing hand-held GPS units lock up or jump positions. My own units that have done this are a Garmin RINO 120 (hiking unit) on the motorcycle and Anywheremap in the cockpit. I know of an older Garmin aviation hand-held doing the same and my old instructor talked about seeing it, I think on his Lowrance 500. Living in the "occupied territory" north of Washington DC (Disney Central), knowledge of how close we are to the special use airspace is all that stands between us and a formation flight with a helicopter, or loss of our pilot license, so most of the locals either know absolutely where they are from experience or keep a paper map (even outdated) on their lap while the GPS is on.
Typically, you're moving along, the countryside is going by, and you suddenly realize that the map hasn't shown movement. As I understand, the maps are electronically "stitched" together and every now and then the process stops to think or just stops.
Note that this is only for hand-helds. With a panel-mounted IFR receiver, I have heard stories about scattered tracks and have seen signal loss (disappearance of the airplane icon), but never frozen icon.
On a related aspect, keep the tracks that the GPS records if you are ever even marginally near special use airspace. The FAA regularly seems to mix up N-numbers and accuse people of going where they shouldn't. That's a fight that you can't win without knowing how to secure radar records which may be over-written by the time they call, or having the track history from yur GPS.
_________________ Remember that internet advice may only be worth what you pay. |
Lynn Matteson
Posted: Sat Feb 10, 2007 6:19 am Post subject: GPS |
I think I read somewhere that you can download the tracks, or for
that matter any info on the GPS, into your PC and print it out.
Unfortunately, I'm on a Macintosh, but I have friends who are on
PC's, and could probably do it there. Garmin was supposed to come out
with Mac-compatible software (?), but I haven't heard of it yet.
Lynn
On Feb 10, 2007, at 8:37 AM, Bob wrote:
N369LM |
Lynn Matteson
Posted: Sat Feb 10, 2007 6:28 am Post subject: GPS |
Over 500 AGL? Yeah, about 5000-7000 over 500AGL...I got up to 8200'
MSL at one point when trying to keep the clouds below me...while of
course keeping the surface in view.
I'll look into the settings page on my 296 to see if there are any
changes that I can make....thanks Dave.
When I lift off at my home field, I'm about 500 AGL when I'm within
the area of the charted field that I mentioned, which is why the unit
thinks that I just departed from that charted field. If I take off in
an easterly direction, away from the charted field, the unit will
SOMETIMES say that I left MY field, sometimes not...toss a coin. : )
Lynn
On Feb 10, 2007, at 7:58 AM, dave wrote:
settings in the Garmin.
precision approaches. I have some set up now and at 500 feet
agl and 1 Mile back I am usually within 1/8 mile of the runway
centreline. Mind you, I have set these up for grass strips and
Lakes where I frequent. Certainnly not a ILS approach but helpful.
Happy Flying !!
Dave
N369LM |
rjdaugh
Posted: Sat Feb 10, 2007 10:50 am Post subject: GPS |
Somebody please educate me.
The 196 can't tell how far above ground level you are because it doesn't
have ground level data in it. (???) (You can get a USGS data base and
load into to it so you have contour data, but if you don't have that how can
it tell how for above ground you are?)
Randy - My field is at 4400'
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Michel
Posted: Sat Feb 10, 2007 12:44 pm Post subject: GPS |
On Feb 10, 2007, at 7:49 PM, Randy Daughenbaugh wrote:
| Quote: | The 196 can't tell how far above ground level you are because it
doesn't
From what I understand from Lynn and Dave, Randy, is that the
instrument will register a stop if you are less than 500 feet at, or in
the vicinity of an airfield of which the altitude AMSL is known and in
the database.
Michel
Lynn Matteson
Posted: Sat Feb 10, 2007 1:48 pm Post subject: GPS |
I just got the Instruction Manual out for my 296 (when all else
fails....), and under "Viewing the Flight Log" it says, "Recording
begins when your speed exceeds 30 knots and you gain 500 feet of
altitude." Further on..."If you land and groundspeed drops below 30
knots, the flight entry is saved and a new entry will be recorded
when you depart the airport. A touch-and-go or brief stop of less
than ten minutes appends to the current flight record rather than
starting a new entry."
This is contrary to what I encountered during my recent trip, but
that's electronics for you.
And while we're on the subject, I flew to an uncharted field today,
(with lots of snow on it, finally!) landed and stayed for an hour. I
left there, and came home, landing on the lake. Took off from there
after another hour stop, and put the plane away. My flight log showed
that I first landed at JXN, then that I took off from JYM, 20 miles
away from JXN, and landed at 3NP. Took off from 3NP, and flew Local.
In reality, I had first landed between JXN and JYM. If someone looked
at this flight log, they would think I trailered the plane between
the 20-miles-apart airports. Again, fun with electronics. : ) Just
another reason to record your flights in your logbook soon after you
park the airplane, lest you forget where you went or how you got
there. : )
Lynn
On Feb 10, 2007, at 3:43 PM, Michel Verheughe wrote:
> doesn't
or in the vicinity of an airfield of which the altitude AMSL is
known and in the database.
Michel
N369LM |
Michel
Posted: Sat Feb 10, 2007 2:47 pm Post subject: GPS |
On Feb 10, 2007, at 10:50 PM, Lynn Matteson wrote:
| Quote: | My flight log showed that I first landed at JXN, then that I took off
from JYM, 20 miles away from JXN, and landed at 3NP.
Yes Lynn, but - as Garmin told you - you have to define those bush
fields as airfields with name and elevation for the flight log to
register it. In other words, the instrument is not made for bush planes
like the Kitfox.
Michel
rjdaugh
Posted: Sat Feb 10, 2007 3:06 pm Post subject: GPS |
Ah yes, the airport elevation.... yup, that is in the database. I guess I
overlooked that since I land at so many places that are not "airports".
Randy
Kitfox 5/7 912S
Lynn Matteson
Posted: Sat Feb 10, 2007 3:16 pm Post subject: GPS |
Right you are Michel...no complaints there, but it was interesting to
point out that I "landed" at JXN (10 miles to the NE), but "took off"
from JYM (10 miles to the SW). Apparently the unit flipped a coin to
see which one I was really at and the coin landed on its edge. : )
Lynn
On Feb 10, 2007, at 5:46 PM, Michel Verheughe wrote:
> off from JYM, 20 miles away from JXN, and landed at 3NP.
planes like the Kitfox.
Michel
N369LM |
dave
Posted: Sat Feb 10, 2007 3:23 pm Post subject: GPS |
Michel ,
I will add when I am on floats in Lakes the elevation on the GPS is pretty
close.
I have use Google Earth and it shows the same .
Some how the moving map is tied into the elevation with referance to the
GPS co-ordinates I guess.
Dave
dave
Posted: Sat Feb 10, 2007 3:28 pm Post subject: GPS |
Lynn , you might have a setting that is off a bit .
I will have to pull mine out one day and run it on a program I have and it
will show a map with every track on it.
My wife runs X - country and she has a GPS wristband and if you look at
the log of her track it shows the elevations of the hills in our woods up
and down again. Although her signal fades in the bush a bit when the leaves
are full but she says rgiht now it works fine.
Amazing toys we got !!
I will that GPS makes you a lazy navigator and you better know dead
reckoning and have maps with you or you going to be lost if your GPS dies.
I have a NAV/Com as well and rarely use the VOR
Dave
Lynn Matteson
Posted: Sat Feb 10, 2007 7:58 pm Post subject: GPS |
Yup, you're right. I just checked and the elevation is showing
1800'...I now recall that I made that strip a waypoint when I flew
over it last year...at apparently 1800'. Next time I land down there,
I'll enter the elevation of 1001', give it an airport symbol and that
should fix it.
Lynn
On Feb 10, 2007, at 6:27 PM, dave wrote:
N369LM |
Float Flyr
Posted: Sun Feb 11, 2007 4:10 pm Post subject: GPS |
Most Bell 206 pilots will write up their flight logs while waiting for the
turbines to cool down ( something like three minutes) before engine shut
down. Maybe the best time to write up the logs is before getting out of the
plane.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
MichaelGibbs(at)cox.net Guest
Posted: Sun Feb 11, 2007 7:11 pm Post subject: GPS |
Lynn sez:
| Quote: | I think I read somewhere that you can download the tracks, or for
That depends on the GPS unit. Some do, some don't.
If you are in the United States and ATC has issued you a squawk code
(i.e., you are squawking something other than 1200), your ground
track will show up on FlightAware <http://www.flightaware.com>. Just
punch in your tail number and it plots your most recent trip. I
don't know how long it keeps the data, but I just looked up a flight
that dates back to the end of May, 2006 (roughly 8 months ago).
Mike G.
N728KF
Lynn Matteson
Posted: Mon Feb 12, 2007 6:47 am Post subject: GPS |
Interesting site, Mike. I put in my tail number but they couldn't
find it...guess I snuck one in there. : )
Actually, I only had to squawk/ident once during a recent flight, and
that was on 1200, so I guess that doesn't count.
My 296 unit is supposed to be capable of downloading data
recorded...at least that's what I understood at the time of purchase
(2005), but I either wasn't supplied with the USB cable when I bought
it, or I've misplaced it...and it would be for a PC anyway, and I'm
on a Mac. I think the USB part of the equation would fit Mac or PC,
but the Mac software isn't capable of the download...if I'm
understanding things correctly.
Lynn
On Feb 11, 2007, at 10:10 PM, Michael Gibbs wrote:
<MichaelGibbs(at)cox.net>
Lynn sez:
code (i.e., you are squawking something other than 1200), your
ground track will show up on FlightAware <http://
www.flightaware.com>. Just punch in your tail number and it plots
your most recent trip. I don't know how long it keeps the data,
but I just looked up a flight that dates back to the end of May,
Mike G.
N728KF
N369LM |
dave
Posted: Mon Feb 12, 2007 7:09 am Post subject: GPS |
Lynn,
My GPS plug to pc is a Data plug not a USB plug.
There are many programs you can use to fetch the data.
I will fetch some later for you and post a pic.
Dave
Lynn Matteson
Posted: Mon Feb 12, 2007 8:22 am Post subject: GPS |
Hi Dave-
My data out plug is a 5-pin connector which accepts the (missing)
cable. The other end would be the USB end. There is also a data card
slot.
I just called Garmin to find out about the "expected" Macintosh
interface that was supposed to be forthcoming. They said it was being
implemented on new products, like personal training devices
(treadmills, bicycles, etc), but not on existing devices like my 296.
So no point in ordering a cable in hopes of using it with my Mac, but
maybe order one (I misplaced the one that came with my unit) to use
with a friend's IBM/PC. Depends on how often I'd like to save a trip/
track, etc.
Lynn
On Feb 12, 2007, at 10:09 AM, dave wrote:
Lynn,
Dave
N369LM |
