DrJSherm(at)aol.com Guest
Posted: Mon Feb 12, 2007 8:17 pm Post subject: ANYBODY DOING IT? |
I see NO activity on this site...considering an RV, and would like to see some info on current activity....Chute info, maneuver criteria, ....I would hope to engage in basic aerobatics if I buy such an A/C...what's going on in 2007???? JOHN SHERM, Wilmington, NC [quote][b]
| - The Matronics Aerobatic-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Aerobatic-List |
grant.piper(at)bigpond.co Guest
Posted: Tue Feb 13, 2007 12:57 am Post subject: ANYBODY DOING IT? |
Yes John, it is very quiet, and has been that way for some time. No one 'chats' about acro, all the secrets are very secret.....
I fly comp aero's in my RV-4 at Sportsman level, but have done one comp at Intermediate. I believe there is a guy in the US that flies Intermediate in an RV-8 (I'm in Australia). Most RVs (not a -9) will walk through Sportsman if flown right. The low drag and relatively slow roll rate can be a problem though. Be very aware of speed build up when nose low, and 45° down lines are steep! I try and keep the speed back below 140KIAS, as above that the roll rate seems to decrease and the forces go up. I use mid power, about 20"MAP for most normal acro, only using full power when going vertical, but also go back to idle when going down hill. This is very different than flying a Pitts, so beware 'good' advice from traditional acro aircraft pilots. Try and get some instruction from someone used to clean aircarft, say ex-military jet trainer or similar.
The RV-4 and -6 feel very similar to me, the -7 I flew felt heavier in the controls. I haven't flown an -8, but cannot see why it would not be suitable either. I think it is more about getting good advice and practice so you are very familiar with your aircraft. You can get through Sportsman without inverted fuel and oil systems, but it means you can't draw long inverted lines or do really s-l-o-w rolls.
I'm happy to talk more if you need to.
Grant Piper
RV-4 VH-PIO
2006 Australian Sportsman Champion
luckymacy(at)comcast.net Guest
Posted: Tue Feb 13, 2007 4:10 am Post subject: ANYBODY DOING IT? |
20MP but what RPM(s) for entry into ? maneuvers?
[quote]-------------- Original message --------------
Grant Piper
RV-4 VH-PIO
Posted: Tue Feb 13, 2007 12:53 pm Post subject: ANYBODY DOING IT? |
I have a FP wood prop, so its about 24-2500 for me. You can loop, barrell roll, slow roll stall turn anywhere from 110-140KIAS. Roilling manoeuvres above 140 get hard to do nicely due to high forces.
Grant
