algrajek
Joined: 10 Jan 2006 Posts: 41 Location: Lexington, Ky
Posted: Thu Feb 15, 2007 9:48 am Post subject: Engine Backfires |
I think you are confused between BACKfire and AFTERfire.
All(or most) of the engines have afterfire when you pull to idle. All
engines do it. The ony reason you hear it in the RVs is you dont have a
muffler. It is just excess fuel burning off at the idle setting.
Al Grajek
RV8
_________________ just rv8in |
gerf(at)gerf.com Guest
Posted: Thu Feb 15, 2007 10:21 am Post subject: Engine Backfires |
Agreed that I am confused, if one can be confused having no knowledge whatsoever.
If "afterfire" is the case - where is the excess fuel coming from, assuming:
- fuel is burned to provide power when the throttle is open
- there is little or no fuel when the throttle is closed (or the engine would be developing power)
(BTW I have the muffled exhaust from Vettermans, although I understand its little more than 2 expansion chambers.)
g
Ed Anderson
Posted: Thu Feb 15, 2007 11:32 am Post subject: Engine Backfires |
"After fire" occurring in the exhaust system is the result of several factors.
One, when you close the throttle, you have immediately reduced the amount of air available to cylinders to combust fuel. But the fuel quantity already in the manifold does not fall off as quickly. That means there is generally some unburned fuel ending up in the exhaust system. This fuel can be "cooked off" by the temperatures it encounters in the exhaust - this is promoted in short exhausts as there are "reversion" waves reflected back from the exhaust pipe opening which can push some oxygen back into the exhaust system. When these two factors combine - "after fire" is a common result. There is generally no damage and nothing to worry about - unless you have a passenger with a weak heart. However, it occurred frequently and prolonged I would check my exhaust valves for cracks.
"Back firing" (occurring in the intake manifold) is generally when the combustion process occurs in the cylinder before the intake valve is completely closed. This may cause air/fuel mixture in the intake manifold to ignite - sometimes blowing off components depending on the degree of air/fuel mixture and other factors. This can happened due to misfire due to ignition time set incorrectly or to an overly lean mixture. Lean mixtures burn slowly and the process may not be completed if the mixture is very lean by the time the intake valve again opens. This can then ignite the mixture in the intake manifold. Back firing can result in damage.
At least that's what I recall about the topic.
Ed
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
Posted: Thu Feb 15, 2007 2:55 pm Post subject: Engine Backfires |
Thanks, that makes sense to me ... now I'm wondering why I experience the same backfiring when I lean too aggressively looking for the "peak" in cruise flight at altitude.
g
[quote]--
skylor4(at)yahoo.com Guest
Posted: Thu Feb 15, 2007 4:44 pm Post subject: Engine Backfires |
Backfires caused by over leaning is probably caused by
the engine missing frequently and the resulting
unburned mixture igniting in the exhaust. It may also
be due to the fact that the combustion rate at very
lean mixtures is so slow that the mixture continues to
burn as it leaves the cylinder and enters the exhaust.
Skylor
RV-8 QB
Under Construction
--- Gerry Filby <gerf(at)gerf.com> wrote:
[quote] Thanks, that makes sense to me ... now I'm
g
Ed Anderson
Posted: Thu Feb 15, 2007 4:54 pm Post subject: Engine Backfires |
G, It would take instrumentation to be certain, but I suspect that the cause is similar to closing the throttle.
If you have WOT then your manifold pressure is high meaning your engine in ingesting high density air into the cylinders. The piston then compresses the mixture and the plug fires it. However, igniting the mixture with an electrical spark under high pressure is not as easy with a lean mixture as it is with a richer mixture. As a consequence, there is more "misfire" , as you known the leaner the mixture the more misfire occurs until ultimately the engine will not run as the mixture is too lean. At this point no fuel is being burnt in the cylinders but fuel is still flowing into the exhaust. These lean misfires in the cylinder can once again result in unburned fuel getting into the exhaust and being "cooked - off". At least that's my take on it.
Ed
Matthews, NC
n616tb(at)btsapps.com Guest
Posted: Thu Feb 15, 2007 6:06 pm Post subject: Engine Backfires |
Your exhaust temps are also quite a bit higher when leaned and will re-burn
any spent fuel in the exhaust.
[quote] --
Posted: Thu Feb 15, 2007 7:05 pm Post subject: Engine Backfires |
Quite a bit higher than what? When Lean of Peak,
EGT's are lower than peak. At peak, the exhaust gas
temperatures are, of course, higher than anywhere
else, and backfire sounds don't occur there (unless
something is really wrong).
--- Tim Bryan <n616tb(at)btsapps.com> wrote:
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.
http://tools.search.yahoo.com/toolbar/features/mail/
sportav8r(at)gmail.com Guest
Posted: Fri Feb 16, 2007 8:08 am Post subject: Engine Backfires |
Thanks, Ed. I feel exonerated and "affirmed" for my earlier post in
this thread.
-Stormy
factors.
Ed
