Roger Lee
Posted: Sun Feb 18, 2007 8:03 pm Post subject: Rotax Class |
Hi All,
Just got back from a Rotax repairman course. I would highly recommend taking the class. It puts facts and Myths into perspective and may keep someone from spending big bucks in the future from bad advise or poor repairs. There is lots of good information. You strip an engine down and reassemble it. They supply the books and cover all of the 912's systems.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Roger Lee
Posted: Mon Feb 19, 2007 2:22 pm Post subject: Re: Rotax Class |
Hi All,
From Eric Tucker at Kodiak/Rotax.
The 912 came out in 1989 and the certified S came out in 1990. The original TBO was 600 hrs. Rotax currently produces 5k 912's a year. With a little more data they might go to 1800 hr. TBO. Business is booming worldwide for the Rotax.
I recommend everyone that works on a Rotax engine take the class. Lots of good info.
1. If you built or changed your prop then you should get a Dynamic prop balance for the longevity of your gearbox.
2. The engine was set up to run better temps. and vibration smoothness at 4800-5200 rpm. 4700 and below usually run a little more temp, but more vibration, whether you feel it or not. I have heard of some guys that want to run the engine at 5500 rpm all the time, well yes it can, but you will pay more in excessive wear later.
3. Mufflers should have 5 liters volume for your Rotax 912uls/s to have a tuned exhaust. This is stated in the instalation manual.
4. Your 912 was set up to fly for up to 30 minutes at 75% power if you lose oil pressure. Yes, better to land, but not at the expense of crashing. Yes the engine will need some work if you go for the 75% at 30 min. Remember your cylinders are not water cooled, only the heads.
5. Water temp gauges are not needed if you are keeping you CHT's in limits.
6. Use only mineral spirits to clean you aluminum engine if it becomes necessary. If you use some types of cleaners and note that there are color changes then this is undesirable.
7. clean your carbs with only mineral spirits. No carb cleaners. They are too harsh.
8. No automotive wire connectors are supposed to be used.
9. Rotax would like to see an oil sample sent in to analysis lab once a year at annual.
10. Shock cooling a Rotax is not an issue while flying. Lots of data to support this.
Just some tips and issues discussed at the Rotax class. If you haven't been, or you heard something from a friend or other mechanic then it is just hearsay or some other logic or experience from a different engine type.
There have been quite a few items that have changed over the years and some of the old ideas do not apply to todays engines v.s. the 10-15 year old 912's.
Tucson, Az.
Cell 520-349-7056 |
Roger Lee
Posted: Mon Feb 19, 2007 2:24 pm Post subject: Re: Rotax Class |
Hi Guys,
Myth
Bottom line for the ethanol/methanol is don't worry about it. It might rob a little power, but will not hurt a Rotax engine. Not all engines can say that, but Rotax can. The factory did test up to 5% because of places around the world that use it and that is why you see it printed in their manual, but just didn't test more. They can not test all variables from users from around the world. There are some places in the world that add up to 15-20%. There is nothing in the Rotax engine that comes in contact with fuel that this will bother. This comes fro Eric Tucker from the Rotax/Kodiak. He is the go to man for all engine issues of any kind including accident investigation, trouble shooting, maint. instruction and tech support. He has seen it all, more or less.
Tucson, Az.
Cell 520-349-7056 |
Richard Pike
Posted: Mon Feb 19, 2007 3:00 pm Post subject: Rotax Class |
Not all Rotax engines used in Kolbs are 4 strokes, yet based on this post
and your previous post, you make everything sound all inclusive, but only
refer to the 912, or the 912S, so could you clarify things a bit?
Richard Pike
MKIII N420P (420ldPoops)
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
knowvne(at)aol.com Guest
Posted: Mon Feb 19, 2007 4:38 pm Post subject: Rotax Class |
Hi Roger:
Glad you got to go to 912 school. Paul Petty and I have had the
opportunity to attend three of Eric's courses so far.
How come I have to get a dynamic prop balance if I fly a Warp Drive
that is balanced?
During the last 13 years and 2,500+ hours flight time with 912uls and
912ul, I have discovered temps tend to drop rapidly, not increase,
below 5,000 rpm, especially the 912ul. I like flying 5000 to 5200 rpm
normal cruise. The 912uls generates much more heat than the 912ul
primarily because of increased compression ration and power output.
The 912uls also rapidly cools below 5000 rpm.
Roger, check your notes on the above. I believe the engine will run
for quite some time without coolant, if you come back on the power and
keep the oil temp down. Engine oil does more cooling than water,
including the head. The cylinders are aircooled. Yes, if you lose a
water hose, keep on flying until you find a safe place to land.
Now, if you lose oil pressue in a 912 series engine, you just bought
yourself an engine. First thing to go is the crankshaft, and that
only takes a few seconds when the oil pressure is gone.
Don't think it is hearsay if the friend or mechanic has attended the
912 School and taken copius notes.
Be sure and check you notes on the "loss of oil pressure and continued
flight" statement.
hauck's holler 912 mechanic 1st class.
_________________ John Hauck
Titus, Alabama |
Roger Lee
Posted: Mon Feb 19, 2007 7:47 pm Post subject: Re: Rotax Class |
Hi John,
1. Prop balance, because all the components out there with the prop are not balanced and nuts and bolts don't always weigh the same. It needs to be balanced as a complete system, not just the prop. Everything from the mounting hub is not balanced. Talking to Warp Drive they said there props are within a couple of grams and add this to the other components and I think you might find it out farther than you might think. The only way to tell for sure is to get it checked with the proper tool.
2. The 912 standard and the 912 certified engine are pretty much the same engine. A quote fron Eric Tucker. Just more documented paperwork for the certification and one or two minor changes. There should be no difference in temps. unless it is just because two engines are running differently (i.e. fuel, oil, climate, ect.)
3. Sorry about the misprint on oil. It is in fact the coolant loss and the extended flight time. I had been up since 3 a.m. that day. Just to tired and blurry eyed.
4. Said nothing about anyone that had been to a Rotax class, only those who have never been and have tried to use info gleened from other engines, rumors (lots of those) or old time A&P's. The Rotax 912 is a different and better engine than some. Some of the notes have changed.
Tucson, Az.
Cell 520-349-7056 |
Roger Lee
Posted: Mon Feb 19, 2007 7:49 pm Post subject: Re: Rotax Class |
Hi Richard,
Sorry I was only talking about the 912 engine series.
Tucson, Az.
Cell 520-349-7056 |
Posted: Mon Feb 19, 2007 8:31 pm Post subject: Rotax Class |
Hi Roger:
same engine.
Agree with the above. The only difference in the two is parts are
serial numbered and there is a paper trail to track the certified
engine. They also get a longer run in at the factory than the
uncertified version.
| 4. The Rotax 912 is a different and better engine than some.
I believe the beauty of the 912 series engines are not that they are
different, but they are simple, 4 cyl flat opposed, overhead valve and
push rod actuated. Liquid and oil cooled heads, air cooled cyls.
When you get right down to it, they are great engines that perform
well. Are extremely reliable and will continue to operate well beyond
the current factory TBO.
We pulled the gear box off my last engine, 912ULS, at 1200+ hours.
There was not signs of wear on any component except one 50 cent thrust
washer. This is with a 72" Warp Drive Prop and no dynamic balancing.
So........if we can find a facility that will dynamically balance our
prop, we are going to really be in business.
When I sold my 912ULS it was producing the same power as it did the
first day I flew it.
When I spoke of operating temps in my previous post, I was not
comparing certified with uncertified. I was comparing 912UL and
912ULS. I flew my 912UL and 912ULS, both for more than 1200 hours
each. The 912UL does not produce nearly as much heat as the 912ULS.
Both engines will not maintain proper CHT and engine oil temps below
4800-5000 rpm. That is the reason to quickly come off cruise power to
bring the heat down should you lose coolant or water pump for some
reason.
I believe, with the increased use of the 912 series engines, as Eric
Tucker told you, the factory TBO will be increased. When I started
flying my first 912, TBO was 600 hours. The last engine was 1200.
Would love to see 1500 or 1800 or more next time.
Hope my new engine will give me the same performance and reliability
that the last two did.
Titus, Alabama |
Thom Riddle
Posted: Tue Feb 20, 2007 5:00 am Post subject: Rotax Class |
.. Bottom line for the ethanol/methanol is don't worry about
it....
Roger,
If alcohol is not an issue with Rotax engines, then why does Bing sell
an optional seal, float, etc kit for Bing 64 carburetors used on 912
series engines?
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Thom Riddle
Posted: Tue Feb 20, 2007 5:17 am Post subject: Re: Rotax Class |
John H,
The current TBO for the newer 912 series engine is already 1,500 hours, beginning with 4,404,718 on UL engines. Not sure which serial number on the ULS engines is the first w/ 1500 hour TBO. I think it will indeed be increased again sometime. We have only about 470 hours on our 912UL s/n 4,405,916 built in 2003 and it shows no signs of aging at all. GREAT engine but sure is expensive and getting more so with the US$ continuing to tank.
Thom in Buffalo
Posted: Tue Feb 20, 2007 6:20 am Post subject: Rotax Class |
hours, beginning with 4,404,718 on UL engines. | Thom in Buffalo
Morning Thom:
You are absolutely correct. My mistake.
Yes, they are very expensive, but they perform and are the most
reliable engine available. I'd rather spend the money and feel
comfortable to enjoy my sport, than the alternative.
Titus, Alabama |
eagle1(at)commspeed.net Guest
Posted: Tue Feb 20, 2007 9:04 am Post subject: Rotax Class |
Hi to John and all other Kolbers who were friends of Az. Dave as Dave
Pelletier was known.
I talked with Dave's wife, Eve just the other day. She told me that the
NTSB had finished the inspection of Dave's plane and found NO mechanical
faults with it. I am sure we all knew this would be the result, but it is
good to know the official results. The remains will come back up to Prescott
to the Embry Riddle Aeronautical University for further inspections and
tests. They have an aircraft "Accident" investigation course that recognized
as world class.
I am going to try to make MV again this year. Hope to see all of you
there.
The Az. Bald Eagle (George Thompson)
To: <kolb-list(at)matronics.com>
Sent: Tuesday, February 20, 2007 7:20 AM
Subject: Re: Re: Rotax Class
Morning Thom:
1:44 PM
hillstw(at)jhill.biz Guest
Posted: Tue Feb 20, 2007 10:58 am Post subject: Rotax Class |
Speaking of Rotax classes; who knows when and where upcoming 912 classes
will be?
Jimmy
912S
Roger Lee
Posted: Tue Feb 20, 2007 2:18 pm Post subject: Re: Rotax Class |
Hi All,
Eric Tucker mentioned that they were looking at the 1800 TBO.
Hi Thom,
I don't know about Bing, but only what Eric Tucker stated.
Tucson, Az.
Cell 520-349-7056 |
Steve Boetto
Posted: Tue Feb 20, 2007 2:19 pm Post subject: Rotax Class |
ATI PLANS ROTAX TRAINING CLASSES AT SUN 'N FUN
Aero Technical Institute (ATI) will offer several Rotax engine training classes at the Sun 'n Fun Fly-in at Lakeland Florida in mid-April. A 4-stroke class will be held on April 17-18, and if that fills up, another will be offered April 22-23. A 2-stroke class will be held April 19-20. Also offered is a one-day class on 4-strokes on April 21. All classes are from 8 a.m.-5 p.m. at the Lockwood display in the new Sun 'n Fun Light Plane area (formerly Paradise City/Ultralight Area). Cost is $445 for advance registration and $545 if you register at the event. The one-day class is $295 before March 15, 2007, or $325 afterwards. To register, call 863-655-5100. For more information, visit www.AeroTechnicalInstitute.com.
steve
[b]Check out free AOL[/b]. Most comprehensive set of free safety and security tools, millions of free high-quality videos from across the web, free AOL Mail and much more.
Posted: Tue Feb 20, 2007 5:36 pm Post subject: Rotax Class |
Steve:
Who is going to teach the 912 class? Eric Tucker?
I, personally, would rather attend his classes based on his experience
with the two stroke and the 912.
DO NOT ARCHIVE
Titus, Alabama |
Steve Boetto
Posted: Tue Feb 20, 2007 6:36 pm Post subject: Rotax Class |
DO NOT ARCHIVE
John,
Do not know, I saw that notice on the regular EAA update I get.
Someone will have to call.
Steve
[b]Check out free AOL. Most comprehensive set of free safety and security tools, millions of free high-quality videos from across the web, free AOL Mail and much more.
Roger Lee
Posted: Tue Feb 20, 2007 8:25 pm Post subject: Re: Rotax Class |
Hi Guys,
If you have the choice take the 3 day class. There is way too much stuff to cover in one day. It took all three days.
Tucson, Az.
Cell 520-349-7056 |
