DanM
Joined: 16 Nov 2006 Posts: 64 Location: Kingsburg, Calif.
Posted: Thu Feb 22, 2007 2:13 pm Post subject: Tinted or clear windscreen |
I have smoke tinted one piece turtledeck for my model IV. I'm concidering going with a smoke tinted windscreen as well. Any opinions out there, pro or con??
_________________ Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM |
aldaniels(at)fmtcblue.com Guest
Posted: Thu Feb 22, 2007 2:27 pm Post subject: Tinted or clear windscreen |
It depends on if you intend to fly near or after dark. Some people feel
it really restricts vision at dusk and dark, others don't seem to mind.
You will get more heat and sun from overhead and a good sun shield is
really needed. I use a bungee and thin foam pad I can move around to
keep from baking in the sun.
DanM wrote:
Dan Mc Intyre
Kitfox Model IV, Jab 2200
http://forums.matronics.com/viewtopic.php?p=96747#96747
Float Flyr
Posted: Thu Feb 22, 2007 4:07 pm Post subject: Tinted or clear windscreen |
Don't ask why but for the front glass and side glass I prefer clear....
Especially for twilight hours. In broad daylight you can wear dark glasses
but when it gets dark it's hard to fly with your head out the window. (
Lucky Lindy did it on his transatlantic trip ) Overhead and turtle deck are
another quintal of fish!
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Graeme Toft
Posted: Thu Feb 22, 2007 4:20 pm Post subject: Tinted or clear windscreen |
Hi Dan, I have my classic1V fitted with tinted lexan and I dont regret for
one minute going for the tint. We have very hot sunny days here and the
reduced glared factor when travelling over water and salt pans makes the
trip so much more comfortable. Instruments such as my GPS are also easier to
read. The only issue I had to come to terms with is that in summer when we
get a lot of storms, the cloud looks a bit darker than it really is but I
look at this a an added safety factor that keeps you conscious of weather.
No noticeable difference in cabin temp. My theory is, if its hot go higher.
I ordered the lexan and cut it myself but due to it being 1/8" in thickness
I had to use a heat gun to bend it where the screen goes over the cross bar
to become the over head section. This area is subject to cracking due to the
compound curve but with the additional thickness and judicscious use of heat
Im happy with the results.
Graeme
flier(at)sbcglobal.net Guest
Posted: Thu Feb 22, 2007 7:08 pm Post subject: Tinted or clear windscreen |
I used tinted on the doors and turtledeck and clear on the windshield /
skylight. I then inserted tinted under the skylight.
Makes the Houston summers a little more bearable.
Ted
Lynn Matteson
Posted: Fri Feb 23, 2007 8:10 am Post subject: Tinted or clear windscreen |
I have the grey (smoke?) tinted LP Aeroplastics windshield/skylight
on my IV, and have found no problems with it.
Lynn
On Feb 22, 2007, at 5:14 PM, DanM wrote:
Dan Mc Intyre
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
DanM
Posted: Fri Feb 23, 2007 1:30 pm Post subject: Re: Tinted or clear windscreen |
Thanks all for the advice on the windscreen tinting decision, I think I will go with smoke tinted. Based on the replies as well as knowing how hot and bright get here in central california in the summer.
Do not archieve
Kitfox IV
Sensenich 62x46
N443DM |
jose_m_toro(at)yahoo.com Guest
Posted: Fri Feb 23, 2007 2:43 pm Post subject: Tinted or clear windscreen |
Dan:
Do you have a picture of your Jab powered Kitfox that you may share with the list?
Jose
DanM
Posted: Fri Feb 23, 2007 3:10 pm Post subject: Re: Tinted or clear windscreen |
Yes, some construction photos, the Kitfox is about 90% complete. I'll dig some up and try and post them.
Do not archieve
Kitfox IV
Sensenich 62x46
N443DM |
Lynn Matteson
Posted: Fri Feb 23, 2007 3:38 pm Post subject: Tinted or clear windscreen |
Welcome to Kitfox, and Kitfox's with Jabiru's in particular,
Dan....or have you been with this group for awhile, and I'm just senile?
Lynn
Kitfox IV Speedster...Jabiru 2200
On Feb 23, 2007, at 6:10 PM, DanM wrote:
Do not archieve
Dan Mc Intyre
N369LM |
DanM
Posted: Fri Feb 23, 2007 4:03 pm Post subject: Re: Tinted or clear windscreen |
Lynn, I've been a "lurker" for quite sometime. I have some questions so I thought I would join in. Working out pretty good.
Kitfox IV
Sensenich 62x46
N443DM |
