Albert Gardner
Posted: Tue Feb 27, 2007 12:23 pm Post subject: Extra Holes in Aft Tunnel |
There are 2 small holes in the aft part of the tunnel that are still empty. They are located near the flap motor, near the top of the tunnel and are arranged in a vertical pattern. They show up in the plans from place to place but I can’t see what they are for. Early on I thought they would be for rudder cable guides but if they are I have overlooked installing them and they don’t seem to be lined up correctly if that is the intended use. Any help would be appreciated.
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Posted: Tue Feb 27, 2007 12:49 pm Post subject: Extra Holes in Aft Tunnel |
I would need a little more detail. The rudder cable holes are in the top corners of that area, and side by side, not vertically aligned. Do you have a picture? What size are the holes? Someone with that part open will probably be able to help more.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner
Sent: Tuesday, February 27, 2007 3:02 PM
Subject: FW: Extra Holes in Aft Tunnel
Albert Gardner
Yuma, AZ
[quote] [b]
Albert Gardner
Posted: Tue Feb 27, 2007 1:12 pm Post subject: Extra Holes in Aft Tunnel |
There are 2 small holes in the aft part of the tunnel on each side that are still empty as I well along in construction. They are located near the flap motor, near the top of the tunnel and are arranged in a vertical pattern. They show up in the plans from place to place but I can’t see what they are for. Early on I thought they would be for rudder cable guides but if they are I have overlooked installing them and they don’t seem to be lined up correctly if that is the intended use. Any help would be appreciated.
Albert Gardner
Yuma, AZ
RV-10 N991RV |
ron.mcgann(at)baesystems. Guest
Posted: Tue Feb 27, 2007 1:36 pm Post subject: Extra Holes in Aft Tunnel |
Albert,
The holes are for rudder cable guides - See page 38-9. Installation is not mentioned in the instructions, but they are in the drawings. I have seen several web sites with these guides missing.
cheers,
Ron
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Albert Gardner
Sent: Wednesday, 28 February 2007 7:42 AM
Subject: Extra Holes in Aft Tunnel
Albert Gardner
Yuma, AZ
Quote: |
| [b]
Posted: Tue Feb 27, 2007 2:20 pm Post subject: Extra Holes in Aft Tunnel |
OK, now I see. Little holes, like #40 holes, on the side of the tunnel, not on the bulkhead. They are being riveted in the attached picture. The part is F-1016H and can be found in the plans on page 38-9.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Tuesday, February 27, 2007 4:35 PM
Subject: RE: Extra Holes in Aft Tunnel
Albert,
cheers,
Ron Quote: |
Albert Gardner
Yuma, AZ
Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | |
Description: |
Filesize: |
21.55 KB |
Viewed: |
231 Time(s) |
Albert Gardner
Posted: Tue Feb 27, 2007 2:25 pm Post subject: Extra Holes in Aft Tunnel |
OK, I’ve attached a pic and circled the holes in question.
Albert Gardner
Yuma, AZ
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Albert Gardner
Yuma, AZ
Description: |
Filesize: |
40.24 KB |
Viewed: |
233 Time(s) |
RV-10 N991RV |
rvbuilder(at)sausen.net Guest
Posted: Tue Feb 27, 2007 4:58 pm Post subject: Extra Holes in Aft Tunnel |
Yep, one of those sites would be mine darn it. Nothing worse than having everything all hooked up and realizing you forgot them.
Michael
Sent: Tuesday, February 27, 2007 3:35 PM
Albert,
cheers,
Ron Quote: |
Albert Gardner
Yuma, AZ
Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | | 0123456789
CJohnston(at)popsound.com Guest
Posted: Tue Feb 27, 2007 6:20 pm Post subject: Extra Holes in Aft Tunnel |
Hahahaha. It’s funny because those little aluminum pieces for the snap bushings are the ONLY pieces in my entire aircraft that weren’t primed with AKZO primer because it was late, and I discovered it as you did in the plans picture only, and I had already run the cables, so I cheated and shot it with a lesser rattle can primer. The only grey primer on the aircraft. Probably one for the gotcha page.
cj
#40410
fuse
www.perfectlygoodairplane.net
Posted: Tue Feb 27, 2007 6:41 pm Post subject: Extra Holes in Aft Tunnel |
They almost 'got' me (and Tim O) too - see <http://www.myrv10.com/tips/gotchas.html>
BTW Mine don't have the BMS 10-11 Super Anzapon green primer either - they have rattle can grey
Ron
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Chris Johnston
Sent: Wednesday, 28 February 2007 12:50 PM
cj
#40410
fuse
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Tuesday, February 27, 2007 4:58 PM
Michael
Albert,
cheers,
Ron Quote: |
Albert Gardner
Yuma, AZ
Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | http://www.matronics.com/Navigator?RV10-List | 0123456789 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 5 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 6 Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 7
Quote: | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 8[b]
