ellismcgaughy(at)gmail.co Guest
Posted: Wed Nov 27, 2013 5:57 am Post subject: Elevator bending brake |
I'm building my second set of rv7a elevators as I found my first set warped by about 1/2" at the inboard trailing edges.
I'm preparing to bend the skins and was wondering if anyone that might live within a hundred miles or so from Fayetteville NC might already have a bending brake I could use. Otherwise, I will plan to dive through all the warped lumber at my local neighborhood hardware store.
Ellis
A&P and Grumman tiger owner.
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
george(at)oilhelp.com Guest
Posted: Wed Nov 27, 2013 6:14 am Post subject: Elevator bending brake |
Ellis, I don't know anything about your project other than I plan to buy an already built RV 7 down the road. I have a traveler presently and keep it at my strip in TN at 2tn7. Are you building the RV to replace your tiger?
George
| Quote: | On Nov 27, 2013, at 8:57 AM, Ellismcgaughy <ellismcgaughy(at)gmail.com> wrote:
Ellis
ceengland7(at)gmail.com Guest
Posted: Wed Nov 27, 2013 6:46 am Post subject: Elevator bending brake |
On 11/27/2013 7:57 AM, Ellismcgaughy wrote:
Ellis
I'm not close, but might be able to offer a tip or two on doing the bend
if you build your own bender. 1st, using a dowel (wood, welding rod,
etc) taped into the trailing edge can help with preventing a too-sharp
bend. Also, I found that my home made brake tended to roll the bend
forward on the side that was on top side of the brake. I made the bend
in multiple steps, checking after each step by clecoing the skin onto
one side of the skeleton & checking hole alignment on the other side
while manually pressing the skin down against the skeleton.
Charlie
dan.pat.b(at)gmail.com Guest
Posted: Thu Nov 28, 2013 6:28 pm Post subject: Elevator bending brake |
EllisI still have the homemade brake I made about 10 years ago out of 2' x 8's and 3.5" hinges - you'd be welcome to it - problem is I'm in Massachusetts - wish I could offer you some advice - as I recall the bending process was pretty straight forward - only thing I can think of is make sure the lumber pieces you make your brake with are perfectly true with not the slightest sign of a warp - keep flipping the skins over after each press to avoid rolling the bend too far forward on one side or the other - good luck and stay with it -
Dan Bergeron
RV-7A - N307TB
442 hours since first flight
on Aug 4, 2009
On Wed, Nov 27, 2013 at 9:45 AM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
[quote]--> RV7-List message posted by: Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)>
| Quote: | --> RV7-List message posted by: Ellismcgaughy <ellismcgaughy(at)gmail.com (ellismcgaughy(at)gmail.com)>
Ellis
I'm not close, but might be able to offer a tip or two on doing the bend if you build your own bender. 1st, using a dowel (wood, welding rod, etc) taped into the trailing edge can help with preventing a too-sharp bend. Also, I found that my home made brake tended to roll the bend forward on the side that was on top side of the brake. I made the bend in multiple steps, checking after each step by clecoing the skin onto one side of the skeleton & checking hole alignment on the other side while manually pressing the skin down against the skeleton.
Charlie
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
rget="_blank">http://www.matronics.com/Navigator?RV7-List
http://forums.matronics.com
