tonyrenshaw268(at)gmail.c Guest
Posted: Fri Feb 28, 2014 4:20 pm Post subject: Potential problem with second Nicopress and dull SS control, |
Gidday,
So, I've tried using a second incompressible, but am now concerned I have done that correctly. I placed the second one up against the other one, and as they compress, we know they exude outward, even a little bit. I reckon the cable I between the 2 could now be under tension, continually, and possibly quite a lot. Whatever stress it is preloaded is an equivalent weight, which in essence would minimise the stress loading on the cable.
I've Lao got cable kicking around that looks more like gal than Stainless Steel, but I know I have only ever bought the right stuff 7x7 3/32" dia control cable. Is there a reason why over time Stainess Steel cable can go dull over time?
Tony Renshaw
Sent from my iPad
On 1 Mar 2014, at 9:52 am, Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
[quote]Yes I did. The 25mm long tail Richard talks about, instead of using tape I use an additional sleeve.
Tim Ward12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 1/03/2014, at 11:22 am, Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)> wrote:
Quote: | Hi Tim,
So did you use two on all the ends, from pedal all the way thru to rudder?
TR
On 1 Mar 2014, at 8:52, Tim Ward <ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)> wrote:
Quote: | Tony,
As Richard stated, I used two Nicopress Sleeves for " peace of mind".
Good recommendation.
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
On 1/03/2014, at 6:39 am, "richard" <rcollings(at)talktalk.net (rcollings(at)talktalk.net)> wrote:
Quote: | Hi Tony You must leave an inch long tail after the sleeve and shrink a short length of electric wire sleeving on to that end for protection.
Two things you can do also, conduct a proof load test, I don’t know the loads but Europa may, or you could drop an email to Andy Draper at the LAA engineering dept he would know. The other way of being certain is to build the cables with two Nicopress sleeves on each end. I know its more weight but “Piece of mind”is worth a few ounces .
Best of luck
Richard
Sent: Friday, February 28, 2014 10:41 AM
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Nicopress Squeezes Using Aviation Approved Squeezer......comments requested .
Gidday,
I’ve attached 2 photos of my Nicopress squeezes, and 1 of the jaws of the tool. Any input gratefully received.
Tony Renshaw
<2014_02_28_Distorted_Nicopress-12.jpeg><2014_02_28_Squeezed_Nicopress_End-14.jpeg>
<2014_02_28_Nicopress_Crimper_Jaws-11.jpeg>
Checked by AVG - www.avg.com
Version: 2014.0.4335 / Virus Database: 3705/7131 - Release Date: 02/27/14
a-List"">http://www.matronics.com/Navigator?Europa-List
//forums.matronics.com
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Sun Mar 02, 2014 8:34 am Post subject: Potential problem with second Nicopress and dull SS control, |
Hi Tony
The BGA here in England banned the use of stainless steel for rudder cables about 10 years age. I think it was because with age like us it gets a bit brittle but still looks good! As Graham has said the cable run is very straight forward mostly internal, don’t worry use the stuff supplied by Europa but get plated Nicropress sleeves.
Best wishes
Richard
Sent: Saturday, March 1, 2014 12:19 AM
Subject: Potential problem with second Nicopress and dull SS control,cable question
Gidday,
Tony Renshaw
Sent from my iPad
Quote: | Yes I did. The 25mm long tail Richard talks about, instead of using tape I use an additional sleeve.
Tim Ward 12 Waiwetu Street
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
TR
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
Best of luck
Richard
Gidday,
Tony Renshaw
Version: 2014.0.4335 / 02/27/14
a-List"">http://www.matronD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
ot;">http://www.matronics.com/cD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Version: 2014.0.4335 / Virus Database: 3705/7142 - Release Date: 03/02/14
Posted: Sun Mar 02, 2014 12:28 pm Post subject: Potential problem with second Nicopress and dull SS control, |
Hi Richard,
So yours must be the dull stuff too? I'll check the ACS catalogue again, but I thought that's all they sold, the Stainless Steel stuff. Funny that it's Ok in the US, where most of the worlds aviating occurs, but I understand bureaucracy. Thanks for the definitive answer. This stuff I have has been in a 15" dia roll since 1996. Do you think that is a concern?
Tony Renshaw
Sent from my iPad
On 3 Mar 2014, at 3:33 am, "richard" <rcollings(at)talktalk.net (rcollings(at)talktalk.net)> wrote:
[quote] Hi Tony
Best wishes
Richard
Gidday,
Tony Renshaw
Sent from my iPad
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
TR
Fendalton,
Christchurch, 8052
New Zealand.
Ph 64 3 3515166
Mob 0210640221
Best of luck
Richard
Gidday,
Tony Renshaw
