Cleaning plexiglass
mjpienaar(at)shaw.ca
PostPosted: Mon Mar 31, 2014 5:53 pm    Post subject: Cleaning plexiglass Reply with quote
I have years worth of gunk from masking tape and electrical insulation tape
that is stuck to my windows.
Any hints on how I can clean them??
Mike
galinhdz(at)gmail.com
PostPosted: Mon Mar 31, 2014 6:38 pm    Post subject: Cleaning plexiglass Reply with quote
I use PLEXUS for my windshield. You may have to do it more than once over a few days if the sticky gunk is real thick. Otherwise 2000 grit sandpaper may be needed but that is in an extreme situation.
http://www.aircraftspruce.com/catalog/cspages/plexus.php
On Mon, Mar 31, 2014 at 9:52 PM, Mike Pienaar <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)> wrote:
[quote] --> KIS-List message posted by: "Mike Pienaar" <mjpienaar(at)shaw.ca (mjpienaar(at)shaw.ca)>
I have years worth of gunk from masking tape and electrical insulation tape that is stuck to my windows.
Mike
rget="_blank">http://www.matronics.com/Navigator?KIS-List
http://forums.matronics.com
le, List Admin.
Robert Reed
PostPosted: Mon Mar 31, 2014 6:52 pm    Post subject: Cleaning plexiglass Reply with quote
Test some Goo-B-Gone on it and check the label for compatible use. I have used it on many occasions with great results. Use very soft cloth and liberal application. Soap and water to Wash off residue.
Bob Reed
Mike
fredorosa(at)gmail.com
PostPosted: Tue Apr 01, 2014 2:18 am    Post subject: Cleaning plexiglass Reply with quote
I had success with Goo gone. Doesn't harm the windows.
Al
Mike
wschertz(at)comcast.net
PostPosted: Tue Apr 01, 2014 2:42 am    Post subject: Cleaning plexiglass Reply with quote
Whatever you do, DON'T use anything with Methanol in it. Will craze the
windows.
Bill
sstearns2(at)yahoo.com
PostPosted: Tue Apr 01, 2014 8:34 am    Post subject: Cleaning plexiglass Reply with quote
I would start with a plastic polish from the an auto parts store. If that is not working then try a more abrasive rubbing compound. If you have too you can use 2000 grit sandpaper and then buff it back out. I buffed my windows while I was buffing my paint using 3M paint buffing compound, but after that I clean them with plastic polish.
A headlight cleaning kit is a good place to start. It is amazing how many cars have yellowed headlights considering how easy it is to clean off the oxidation.
Scott
On Tuesday, April 1, 2014 3:45 AM, William Schertz <wschertz(at)comcast.net> wrote:
--> KIS-List message posted by: "William Schertz" <wschertz(at)comcast.net (wschertz(at)comcast.net)>
windows.
Bill
