		pdwalter(at)bigpond.net.a Guest
				 Posted: Tue Feb 14, 2006 10:56 pm    Post subject: Rudder |
				On the Rudder, does the 913 counter balance skin go  over or under the 901 rudder skin. The plan makes it hard to tell. It would seem  logical to have it over so the join running is with the air flow - I am just not  sure.
  Paul Walter
  |  | - The Matronics RV7-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV7-List |
		davcor(at)comcast.net Guest
				 Posted: Tue Feb 14, 2006 11:37 pm    Post subject: Rudder |
				Paul,
  look closely at drawing 7 grid f/g | 5/4 dashed lines are hidden. Not that over looked this or anything...
  squeeze 'em too don't buck...
  Dave
  RV7 - N898DC (rsvd)
  emp done, wings done finally, fuse firewall... de-burring and dimpling and countersinking
  when you get to your tanks, find (on ebay) an Orndorf video showing the tank build process (RV6 works), realize the stories aren't as bad... dive in. Don't forget to visit rvproject.com
   	  | Quote: | 	 		  -------------- Original message --------------
  Paul Walter
		sshook(at)cox.net Guest
				 Posted: Wed Feb 15, 2006 10:31 am    Post subject: Rudder |
				I had the same question…the plans are correct.  If memory serves me correctly, the dashed line has the skin edge into the wind.
 From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Paul Walter
  Sent: Tuesday, February 14, 2006 11:54 PM
  To: rv7-list(at)matronics.com
  Subject: Rudder
 Paul Walter
		John Brunke
				 Posted: Wed Feb 15, 2006 11:21 am    Post subject: Rudder |
				Paul,
  If you look in the archives there was a discussion  on this about a year ago.
  John Brunke
  [quote]   ---
		mk325ef(at)yahoo.com Guest
				 Posted: Wed Feb 15, 2006 5:57 pm    Post subject: Rudder |
				Hi Paul,
   The counterbalance skin goes over the left and right skins. I edge rolled the counterbalance skin to put a slight angle on it so it sits nicely flat on all edges against the skins.
   Greg
 "J. Brunke" <jdoody727(at)comcast.net> wrote:
   [quote]    v\:* {   BEHAVIOR: url(#default#VML)  }  o\:* {   BEHAVIOR: url(#default#VML)  }  w\:* {   BEHAVIOR: url(#default#VML)  }  .shape {   BEHAVIOR: url(#default#VML)  }    <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />    st1\:*{behavior:url(#default#ieooui) }              Paul,
   John Brunke
   [quote]  ---
		truflite(at)yahoo.com Guest
				 Posted: Wed Feb 15, 2006 8:37 pm    Post subject: Rudder |
				Hooboy,  I hope it works for you, because I think you
 are incorrect in putting the counterbalance skin on
 top.  The plans show two areas each side that require
 you to taper the edges of the CB skin, not unlike
 honing a razor blade.  This provides a gentle ramp for
 the rudder skins to lay onto, reducing any possibility
 of kinking the skin near the joint of the CB and
 rudder skin.  Reference Drawing 7, section G 10, and G
 5
 --- Greg C <mk325ef(at)yahoo.com> wrote:
 [quote] Hi Paul,
    Greg
  url(#default#VML)  }
  Paul,
    John Brunke
		Brad Oliver
				 Posted: Thu Feb 16, 2006 1:33 pm    Post subject: Rudder |
				Dave is correct... the rudder skin goes OVER the counterbalance skin.
 This has been brought up several times in several places, all with the
 same conclusion... the dashed lines on the plans indicate the rudder
 skin is on top of counterbalance skin.
 If you do as Dave says and taper the counterbalance skin, as the plans
 indicate, you will be surprised at how flat the rudder skin sits on top
 of the counterbalance.
 But hey, don't take our word for it... call Van's if you need
 verification.
 Good luck!
 Brad Oliver
 RV-7 Livermore, CA
 www.rv7factory.com
 [quote] ------
