Skykingjfg(at)aol.com Guest
Posted: Sun Feb 19, 2006 7:25 am Post subject: Filter Air Box |
I'm trying to install the FAB on my 7A. I have an XP 360 Carburetor engine. There doesn't seem to be enough clearance between the air box and the landing gear leg. In fact, if I just hold the filter element against the bottom plate there is only 1/2" gap between the element and the gear leg. This leg has got to flex a little when landing. I concerned that it will flex and hit the airbox. Anyone run into this and have a solution?
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
dan(at)rvproject.com Guest
Posted: Sun Feb 19, 2006 9:58 am Post subject: Filter Air Box |
Heat it up with a heat gun a press into it with a pipe. It'll form a "dent" (intentionally) that will provide clearance. I don't have a nosedragger, but that's what I'd try first.
If that doesn't work, chop a hole into it where the nosegear leg interferes, and re-glass it so it won't! Get out the tools and make it work!!!
)_( Dan
RV-7 N714D
http://www.rvproject.com
