k9hxt(at)sbcglobal.net Guest
Posted: Wed Feb 15, 2006 9:38 pm Post subject: Tow Bar |
Does anyone know who makes a tow bar for the RV-7A ?? I bought one about 5 years ago for a RV-6A but don't remember who the guy was? It was real simple and worked fine etc. Had a spring loaded pin that secured it into the socket heads of the screws that hold on the nose wheel pant.
Larry, RV-7A about ready to fly!!
"LIMA TANGO SENDS"
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
diff(at)foothill.net Guest
Posted: Thu Feb 16, 2006 7:21 am Post subject: Tow Bar |
Larry,
I did some searching and finally ordered a Bogert towbar from ACS (their #
13-01811 for $74.00). Short story was it didn't work properly so I called
Richard Bogert, the owner, and he sent me modified parts at no charge which
solved the problem after I re-drilled the pivot hole to fit my wheel pant.
I also clamped on a simple stop per his suggestion to hold the bar in closed
position so it won't pop off when steering the nosewheel. I think he may be
adding a stop/latch in the future. If he does, it will be one trick unit.
Lightweight, good quality, and collapsible for stowing in the baggage
compartment. I would give him a call. He is super nice. info(at)bogert-av.com
or 509-736-1513.
Scott Diffenbaugh
RV-7A N814SD FAA inspection today!
jack.lockamy(at)navy.mil Guest
Posted: Fri Feb 17, 2006 7:36 am Post subject: Tow Bar |
Cleveland Tool Co. sells a tow bar made specifically for tri-gear RVs for about $50. You can order it online from their catalog. It also collapses for easy storage in the baggage compartment. I have two of them... one for the hangar and one kept in the plane.
They work perfectly!
Jack Lockamy
RV-7A N174JL 140 hrs
Camarillo, CA
www.jacklockamy.com
