Gilles.Thesee(at)ac-greno Guest
Posted: Sun Nov 18, 2007 9:13 am Post subject: Re : RE: Re : Re: Rectifier-Regulator |
Output of the Rotax internal generator is 18A. 80% of that is
| Quote: | 14.4A. That
is the greatest load I expect you would want to put on your buss
and still
have a margin of safety.
Noel,
Experience from the field and from the lab seems to indicate that 12 A permanent load is the most one should expect from the Rotax Ducati regulator to avoid overheating and self-destruction.
So we'd better keep the loads to a minimum.
Best regards,
Gilles
http://contrails.free.fr
Float Flyr
Posted: Sun Nov 18, 2007 9:49 am Post subject: Re : RE: Re : Re: Rectifier-Regulator |
In this case I agree.... Go with the experience and limit the load to 12A
maximum. If you need more capacity than that, install a larger alternator.
2A (at) 12V may not seem to be very much.... Until you see how that can burn a
wire.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
