henkjan(at)zme.nl Guest
Posted: Sun Jan 13, 2008 10:33 am Post subject: Flap position indicator |
Hello all,
I’m currently installing the ACS AF 2500 engine monitor, for the flap position indicator the manual says, “any 5K potentiometer” will give a measurement.
Searching the archives I found that I need a Ray Allen Pos 12 sensor, anybody who did this already? If yes I would like some pictures, no pictures found in the archives.
Thanks for the help,
RV10 40355
Henkjan van der Zouw
ZME v.o.f.
Rijksstraatweg 28
3545NA
Utrecht
Netherlands
tel. ..31 30 6665443
mob. ..31 653235372
fax. ..31 30 6664659
www.zme.nl
ScooterF15
Posted: Sun Jan 13, 2008 2:57 pm Post subject: Flap position indicator |
Pictures of my POS-12 switch install are posted to this thread:
http://forums.matronics.com/viewtopic.php?t=31209
-Jim
N312JE
In a message dated 1/13/2008 1:35:36 P.M. Eastern Standard Time, henkjan(at)zme.nl writes:
Hello all,
RV10 40355
ZME v.o.f.
Rijksstraatweg 28
3545NA
Utrecht
Netherlands
mob. ..31 653235372
www.zme.nl
Start the year off right. Easy ways to stay in shape in the new year.
ScooterF15
Posted: Sun Jan 13, 2008 10:49 pm Post subject: Flap position indicator |
Whoops, my mistake, I thought you could see the POS-12 in those posted pictures. Here are some photos of my POS-12 installation. I attached it to the inside of the tunnel near the flap actuator using blind rivets. I made a connection using model airplane a threaded pushrod with a z-bend at one end an a brass clevis at the other. I had to measure carefully/experiment a bit to select the appropriate attachment points and mounting angle to get the right throw and to avoid binding.
-Jim
N312JE
In a message dated 1/13/2008 6:00:18 P.M. Eastern Standard Time, JSMcGrew(at)aol.com writes:
| Quote: | Pictures of my POS-12 switch install are posted to this thread:
-Jim
N312JE
Hello all,
RV10 40355
ZME v.o.f.
Rijksstraatweg 28
3545NA
Utrecht
Netherlands
mob. ..31 653235372
www.zme.nl
="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
48.99 KB |
534 Time(s) |
37.08 KB |
550 Time(s) |
42.07 KB |
530 Time(s) |
Posted: Mon Jan 14, 2008 2:16 am Post subject: Flap position indicator |
Thank you!,
I had the same idea, now I know I’m on the right track.
Thanks again.
Henkjan
-----Oorspronkelijk bericht-----
Van: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] Namens JSMcGrew(at)aol.com
Verzonden: maandag 14 januari 2008 7:45
Aan: rv10-list(at)matronics.com
Onderwerp: Re: Flap position indicator
-Jim
N312JE
-Jim
N312JE
Hello all,
RV10 40355
ZME v.o.f.
Rijksstraatweg 28
3545NA
Utrecht
Netherlands
mob. ..31 653235372
www.zme.nl
| Quote: | | ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List.matronics.com/">http://forums.matronics.com://www.matronics.com/contribution">http://www.matronics.com/contribution |
48.99 KB |
497 Time(s) |
37.08 KB |
491 Time(s) |
42.07 KB |
481 Time(s) |
bcondrey
Posted: Mon Jan 14, 2008 11:46 am Post subject: Flap position indicator |
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Henkjan van der Zouw
Sent: Monday, January 14, 2008 3:25 AM
Subject: RE: Flap position indicator
Thank you!,
Thanks again.
Henkjan
-Jim
N312JE
-Jim
N312JE
Hello all,
RV10 40355
ZME v.o.f.
Rijksstraatweg 28
3545NA
Utrecht
Netherlands
tel. .31 30 6665443
mob. .31 653235372
fax. .31 30 6664659
www.zme.nl
48.99 KB |
478 Time(s) |
37.08 KB |
476 Time(s) |
42.07 KB |
463 Time(s) |
ericparlow(at)hotmail.com Guest
Posted: Mon Jan 14, 2008 12:12 pm Post subject: Flap position indicator |
Here's a couple photos of our Ray Allen Pos 12 flap position sensor.
We attached a tab/arm to the flap actuator bar/rod in the tunnel with aclamp.
The sensor is mounted on the tunnel side wall with a small bracket.
A small rod with an threaded joint connects the arm/tab to the sensor.
Eric
RV-10, 40014
N104EP
| Quote: | Date: Sun, 13 Jan 2008 19:40:34 +0100
Subject: RV10-List: Flap position indicator
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal{margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';}.ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink{color:blue;text-decoration:underline;}.ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed{color:purple;text-decoration:underline;}.ExternalClass EC_span.EmailStijl17{font-family:Arial;color:windowtext;}(at)page Section1{size:595.3pt 841.9pt;}.ExternalClass EC_div.Section1{page:Section1;}
Hello all,
Im currently installing the ACS AF 2500 engine monitor, for the flap position indicator the manual says, any 5K potentiometer will give a measurement.
RV10 40355
ZME v.o.f.
Rijksstraatweg 28
3545NA
Utrecht
Netherlands
mob. ..31 653235372
www.zme.nl
27.73 KB |
483 Time(s) |
34.43 KB |
516 Time(s) |
