Dick Maddux
Posted: Mon Apr 27, 2009 4:17 am Post subject: Making tape stick |
Hard to come up with a proper name for this subject. Anyway, I am always dressing up my airplane and recently I applied 1/8 inch vinyl trim tape around the bumps on my radial style cowl. It is a very tight turn around the front part and after a week it lost its adhesion and the tape is buckling and looks bad. Does anyone know of a clear adhesive enhancer I could apply to the surface to get the tape to stick ? (the tape is several months old)
If this doesn't work then I will have to buy matched paint and stripe it. I would rather not do this as it takes a quart minimum, rather expensive and requires a steady hand. Tape trim has worked well for the rest of my aircraft.
Thanks!
Dick Maddux
Pensacola, Fl
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
henrysfork1(at)msn.com Guest
Posted: Mon Apr 27, 2009 5:08 am Post subject: Making tape stick |
Dick
Try pre-cleaning the area with rubbing alchol prior to applying the tape. This works real well for other applications.
Dee Young
Model II
N345DY
Date: Mon C 27 Apr 2009 08:13:38 -0400
Subject: Making tape stick
Hard to come up with a proper name for this subject. Anyway C I am always dressing up my airplane and recently I applied 1/8 inch vinyl trim tape around the bumps on my radial style cowl. It is a very tight turn around the front part and after a week it lost its adhesion and the tape is buckling and looks bad. Does anyone know of a clear adhesive enhancer I could apply to the surface to get the tape to stick ? (the tape is several months old)
If this doesn't work then I will have to buy matched paint and stripe it. I would rather not do this as it takes a quart minimum C rather expensive and requires a steady hand. Tape trim has worked well for the rest of my aircraft.
Thanks!
Dick Maddux
Pensacola C Fl
Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
Gary
Joined: 20 Oct 2007 Posts: 13 Location: Toronto, Ontario, Canada
Posted: Mon Apr 27, 2009 5:10 am Post subject: Re: Making tape stick |
Most of my rc models are covered in peel and stick sign vinyl. What works for me is to wipe the surface and your fingertips with 99% rubbing alcohol so everything is squeaky clean. Apply the vinyl. Hit it lightly with a heat gun and rub it in with a gloved finger at the same time. The heat gun removes the tension in the stretched vinyl and gives the adhesive a jolt. This might prevent the vinyl form deforming on that hot engine cowl.
_________________ Gary Del Bel Belluz
Toronto, IV / 912UL
Just getting started |
lcfitt(at)sbcglobal.net Guest
Posted: Mon Apr 27, 2009 7:08 am Post subject: Making tape stick |
Dick,
If the previous suggestions don't fix the problem, pin stripe paint is
available in half pints for about $15. Check the link.
http://www.eastwoodco.com/ click on painting and pinstriping then One
Stop.
Lowell
rexinator
Posted: Mon Apr 27, 2009 8:10 am Post subject: Making tape stick |
Not sure there is another solution other than consider cutting sheet
adhesive vinyl to apply like a decal. There are of course folks that can
make custom cut vinyl signs who may have the software to make custom shapes.
I've seen booths in fleamarkets that make vinyl signs. Might be reasonable.
Rex Hefferan
Colorado M2/582
Catz631(at)aol.com wrote:
Quote: | Hard to come up with a proper name for this subject. Anyway, I am
Thanks!
Dick Maddux
Pensacola, Fl
*A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
Paul A. Franz, P.E.
Posted: Mon Apr 27, 2009 9:07 am Post subject: Making tape stick |
On Mon, April 27, 2009 5:13 am, Dick Maddux wrote:
Quote: | Hard to come up with a proper name for this subject. Anyway, I am always
aircraft.
Dick - I have been recently working with Vinyl lettering for signs on vehicles. I've
learned a little so naturally, I can spout off like a self-described expert who has
actually little expertise (me). OK, with that terribly honest disclaimer out of the
way, I think you should make the design in a vector graphics program such as Corel
Draw, Adobe Illustrator or AutoCAD. These programs create vector graphics as opposed
to raster graphics and are infinitely scalable so vinyl sign cutters can use the
output to make the pieces you need. The sign material is thinner than the vinyl tape
you're using and since it will be cut in the shape you need, it will stick down
tightly without curling away. There is quite a bit of layout skill required in my
opinion, meaning transferring the cut designs from the backing to the final
destination is a bit tricky.
So, to deal with that problem you can either do some practice, get some help from the
people that you choose to cut your design or you can just do it in pieces. Maybe have
the sign cutter just do the tight radius portions and you fill in the rest with your
straight tape or transfer the entire cut pieces for each bump in sections. I can't see
joints when the pieces are cut with a razor knife so if moving the finished cut pieces
from the backing can be done in sections and no one will be able to see it.
If you use Corel Draw, save your output as "Adobe Illustrator" .ai file as well as the
native .cdr and if using a cad program such as AutoCAD export it as IGES or DXF so
other programs can use the input. Many programs including Adobe Illustrator can import
DXF. Sign cutters use Adobe Illustrator frequently. Most CAD programs will output
drawings in DXF or IGES and there are a number of free CAD programs available. I
personally see the CAD programs as easier to learn for this task than the programs
like Corel Draw and Adobe Illustrator. BTW, Adobe Illustrator is free to download and
you can run it for a month before you have to buy it. But it is a pile of money so,
unless you're going to be using it a lot, you's be better off to just have the sign
cutting company do it for you. You can hand draw the things you want cut out and they
can measure and enter the data into the program.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
"Back in the thirties we were told we must collectivize the
nation because the people were so poor. Now we are told we must
collectivize the nation because the people are so rich."
-- National Review founder William F. Buckley Jr. (1925-2008)
"What's called the public debt stands at $11 trillion and growing.
That pales in comparison to the federal government's unfunded
liability -- obligations that are not covered by an asset of equal
or greater value. Mike Whalen, former policy chairman of the
Dallas-based National Center for Policy Analysis, commenting on
last year's Social Security Trustees annual report on the state of
the Social Security and Medicare programs, said, 'The report on the
state of entitlement programs is rather grim -- the combined
unfunded liabilities of both programs are $101 trillion.' What that
means is that in order for government to make good on its promises,
Congress would have to put aside tens of trillions of dollars in
the bank today. Keep in mind that our GDP is only $14 trillion. In
the absence of massive tax increases or cuts in benefits, in order
to meet its promises Congress must cease spending on one in four
programs by 2020, such as education and highway construction, and
one in two by 2030, and by 2050 or so all federal revenue will be
spent supporting Social Security, Medicare and prescription drug
benefits. Such a scenario is unsustainable. There will be economic
and political chaos. Today's politicians are not likely to take
measures to avoid the coming chaos because senior citizens, the
major beneficiaries of Social Security and Medicare, vote in large
numbers and will exact a high political price. Plus, neither
today's senior citizens nor today's politicians will be alive in
2050. I'd be more optimistic if my fellow Americans were simply
suffering from congressional deception as opposed to their not
caring about the economic calamity that awaits tomorrow's
Americans."
-- George Mason University economics professor Walter E. Williams
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Lynn Matteson
Posted: Tue Apr 28, 2009 5:02 am Post subject: Making tape stick |
I would suggest painting the stripes on with masked edges and a small
spray gun. It is the only permanent way to do the job....and scores
more points with the judges when it comes time to be judged...even if
the judging is only done by your hangar buddies. It shows that you
took some time (ok, a LONG time) and put some thought...and
pride...into the job.
Lynn Matteson
Jabiru 2200, #2062, 635.2 hrs
Sensenich 62x46
Status: flying
Thanks!
Dick Maddux
Pensacola, Fl
steps! _-
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Dick Maddux
Posted: Wed Apr 29, 2009 4:04 am Post subject: Making tape stick |
Lynn,
Your idea is a good one,however, I have been using vinyl tape trim on a number of aircraft in the past and you can hardly tell it from paint.It works very well.(ala the new Cessnas,cars,etc)
This is the first time I have had trouble having it stick but I know the reason is because of the very tight radius ,age and the width of the tape.
I assure you I can get a very nice looking job with the thin tape.
No one in my area even know what a Kitfox is.I am the only aircraft in my immediate area with a Rotax engine. Most of the other guys think I am flying around in one of those "whiney" ultralights.I really don't care what they think of course as I recently discovered fun flying again and I am flying this airplane more than any of the others I have had.
Dick Maddux
Pensacola,Fl
PS; I have a box full of awards for my British cars so adding any more for my airplane and pleasing judges, is not a factor. I just want to have a nice looking airplane without making a mess of an otherwise nice looking cowl
Big savings on Dell XPS Laptops and Desktops!
Lynn Matteson
Posted: Wed Apr 29, 2009 5:02 am Post subject: Making tape stick |
Hi Dick-
Have you tried the model airplane/hobby stores for narrow tape? The 5-
year old tape I have on hand is 1/8" and 1/4", and maybe like yours
is too old. I just looked up the Carl Goldberg line of tapes (that I
used in the past) and their address is: http://
www.carlgoldbergproducts.com/accys/gbgq0680.html
Another line is "Hangar 9" by Horizon Hobby, Inc. I haven't looked
into the automotive line of tapes, but they probably have a good line
of products as well. Maybe the modeler's tapes are better because of
the closer proximity of the viewer to the plane...the closer you get,
the better the tape has to be, might be the motto, I don't
know...just throwing ideas out there.
I saw you got one post that mentioned heat to relax "the stretched
vinyl". That...the stretching....is a no-no from what I have learned
and read: "DO NOT over-stretch Stripe during application! Tape must
lie comfortably on surface." says the instructions on the Carl
Goldberg Color Stripe instructions. Then they "apply medium heat
250-300 F, using an iron and a soft cloth to rub down...."
I've done this on models and it works well, but the trick is to
follow the "don't stretch" instructions, just like you would if you
were laying down the narrow masking tapes prior to painting....any
stretching and the tape will shrink and lift off the surface.
The reason I shy away from the tapes on a full-size plane is the
amount of time it will (probably) be in the sun. I've seen tapes lift
from a plane and then it looks bad.
Lynn Matteson
Sensenich 62x46
Status: flying
width of the tape.
Dick Maddux
Pensacola,Fl
Big savings on Dell XPS Laptops and Desktops! _-
N369LM |
Dick Maddux
Posted: Fri May 01, 2009 2:52 am Post subject: Making tape stick |
Lynn,
Thanks for the excellent advice !! I will try the heat and cloth method !
Right now I am at my cabin in the NC mountains driving my Triumph TR3B through the curves ! What a blast !! Won't be dealing with my Fox for a month or more
The Internet over the phone lines up here in the mountains is a dismal 21 k. Boy is it slow ! No other way though. Don't believe I will be writing much.
Dick Maddux
Bryson City, NC
Join ChristianMingle.com® FREE! Meet Christian Singles in your area. Start now!
Lynn Matteson
Posted: Fri May 01, 2009 4:47 am Post subject: Making tape stick |
Watch out for those mountain curves, Dick....sounds like a blast,
alright!
Lynn
On May 1, 2009, at 6:47 AM, Catz631(at)aol.com wrote:
cloth method !
Dick Maddux
Bryson City, NC
area. Start now!
N369LM |
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Sun May 03, 2009 2:12 pm Post subject: Re: Making tape stick |
Dick,
As you know, my plane has a lot of detail work. Here's my take on your problem. The compound curves are a given but can be overcome with the application of a little heat when installed. However, I think you may need to consider the temperature of the cowling after shutting down. That is enough to soften the adhesive on most vinyl products causing them to turn loose and then they naturally want to roll along the edges. I think painting is the better choice as mentioned by several.
Let me know when you're back in town!
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
