		elleryweld(at)AOL.COM Guest
				 Posted: Tue Sep 08, 2009 4:13 pm    Post subject: HELP     Radio GPS Noise Question |
				In my Mk3CKThe radio & intercom system works great and no static at all until I turn on the GPS then there's steady noise (static) in the headsets that would drive anyone nuts so I have been flying  without GPS but I would like to find a remedy for this anyone have any ideas on what I can try to remedy this I have tried using the GPS running on its  internal battery's and I get the same results installed remote GPS Antenna and nothing seems to make a difference anyone else ever have this problem? How did you Fix it
    Thanks in advance if you can help me solve this problem
    Ellery in Maine
		lcottrell
				 Posted: Tue Sep 08, 2009 4:51 pm    Post subject: HELP     Radio GPS Noise Question |
				I had the same problem with my 196 on internal power, but  when I take it off it doesn't cause any problems or noise. Not usable with  internal power. Boyd suggested that it was the data wires integrated in the  cable. I drilled them out of the end that runs into the GPS, but it didn't cure  the problem. So I just run it on batteries. Not sure why you are still getting  static.
  Larry C
  [quote]   ---
		herbgh(at)nctc.com Guest
				 Posted: Tue Sep 08, 2009 5:18 pm    Post subject: HELP     Radio GPS Noise Question |
				The computer and digital circuits in the gps generate a wide band of radio noise.. By law the strength of the radiation is limited..  Separating the two devices as far as is practical might help?   Tying both units to a common ground might work? ..otherwise make an aluminum case for as much of the gps as is practical and ground that.. Herb
  At 07:41 PM 9/8/2009, you wrote:
  [quote]I had the same problem with my 196 on internal power, but when I take it off it doesn't cause any problems or noise. Not usable with internal power. Boyd suggested that it was the data wires integrated in the cable. I drilled them out of the end that runs into the GPS, but it didn't cure the problem. So I just run it on batteries. Not sure why you are still getting static.
  Larry C
