brubakermal(at)yahoo.com Guest
Posted: Fri Oct 09, 2009 6:53 pm Post subject: tire wear out side |
i cant seem to figure why my tires wear on the out side how do i measure them to determine if the tow in or out and why they seem to wear evenly so I do not suspect hard landings malcolm mod 2
--- On Sat, 10/10/09, WurlyBird <james.t.trizzino(at)us.army.mil> wrote:
Subject: Larger Elevator
Date: Saturday, October 10, 2009, 1:50 AM
--> Kitfox-List message posted by: "WurlyBird" <[url=/mc/compose?to=james.t.trizzino(at)us.army.mil]james.t.trizzino(at)us.army.mil[/url]>
I have a laundry list of projects that involve my KF3 but aside from the new fuel lines (that will be another post all together) I am planning on starting with the larger elevator that McB offers. Does anyone have this elevator on a Mod 4 or earlier? I am looking for a little input on whether it makes a vast improvement or not. Thanks guys.
James
James
Kitfox 3 / 582 / GSC prop
The ink is still drying on my new certificate
http://forums.matronics.com/viewtopic.prchive Search & Download, 7-Day Browse, Chat, ; --> http://= - List Contributionsp; &bsp;--> http://ww=======================
clint_bazzill(at)hotmail. Guest
Posted: Fri Oct 09, 2009 7:25 pm Post subject: tire wear out side |
It seems to me to be very simple. There is no load on landing gear until you touch down. The outside of the tires will hit the ground first. Ok
Clint reverse the tires when you start seeing wear.
Date: Fri C 9 Oct 2009 19:46:48 -0700
Subject: tire wear out side
--- On Sat C 10/10/09 C WurlyBird <james.t.trizzino(at)us.army.mil> wrote:
Date: Saturday C October 10 C 2009 C 1:50 AM
--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil>
James
James
http://forums.matronics.com/viewtopic.prchive Search & Download C 7-Day Browse C Chat C ; --> http://= - List Contributionsp; &bsp;--> http://ww=======================
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
Guy Buchanan
Posted: Fri Oct 09, 2009 8:36 pm Post subject: tire wear out side |
At 07:46 PM 10/9/2009, you wrote:
| Quote: | i cant seem to figure why my tires wear on the out side how do i
Malcolm,
Probably either toe-in or camber or both. (Camber is when
the tops of the tires are farther apart than the bottoms.) Any camber
will make your tires appear toed in when you're sitting on the tail
wheel. I measured my toe-in by clamping a level 8' aluminum angle to
the brake disk and dropping a plumb bob mark to the ground at two
distances forward. (Say, 1' and 7'.) I did this for both sides and
then measured the athwartships distances between the marks. Do the
math and you get the toe-in. Do this with your plane level and on the
tailwheel.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Sat Oct 10, 2009 10:55 am Post subject: tire wear out side |
It's probably because the "Capitalization and Punctuation police" are
out to get you, Malcolm....sorry, just couldn't resist. : )
Due to the punctuation problem, I don't know whether you are saying
that they *do* or *don't* wear evenly. Do they wear evenly, or don't
they? At first it seems like you're saying that they wear on the
outside....that's uneven wear. And then you say that "they seem to
wear evenly"...I'm confused.
Do you have the Grove gear, or the tube and bungee (sp?) gear? Do you
do most of your landings on pavement or grass?
Lynn Matteson
Jabiru 2200, #2062, 790.2 hrs
Countdown to 1000 hrs~211 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying
Thanks guys.
James
James
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Roger Lee
Posted: Sun Oct 11, 2009 3:22 pm Post subject: Re: tire wear out side |
I'm with Guy. Check the tires toe-in, out and camber.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
