AeroElectric-Archive.digest.vol-af
May 22, 2001 - June 26, 2001
      rotax 912.
      Thanks.
      --- Larry Bowen  wrote:
      > Bowen"
      > Have you considered heated seats instead?  I know
      > that doesn't cover your
      > toes and fingers, but....
      > After tentative investigation, I think I will go the
      > heated seat route, both
      > front and back, to supplement the std heat muff.
      > Larry Bowen
      > RV-8 wings
      Yahoo! Auctions - buy the things you want at great prices
      http://auctions.yahoo.com/
Subject: Re: electric heat
Date: May 22, 2001
I think 4 amps on "high". Do an archive search on seat & heat. Here is a link to an example: http://www.skylitesunroofs.com/p_carbotex_seat_heaters.html Larry Bowen Email: Larry(at)BowenAero.com Web: http://BowenAero.com > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of K.M. > Sent: Tuesday, May 22, 2001 11:12 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Re: electric heat > > > Larry: > > Please explain...... > and what is the current draw for these? I am building > a RANS S-12S and only have an 18 amp Alternator on the > rotax 912. > > Thanks. > > > --- Larry Bowen wrote: > > Bowen" > > > > Have you considered heated seats instead? I know > > that doesn't cover your > > toes and fingers, but.... > > > > After tentative investigation, I think I will go the > > heated seat route, both > > front and back, to supplement the std heat muff. > > > > Larry Bowen > > RV-8 wings > > Yahoo! Auctions - buy the things you want at great prices > http://auctions.yahoo.com/ > > ________________________________________________________________________________
Date: May 22, 2001
*** If you go to a motorcycle shop, you may find some really nice electric vests. "Eclipse" is one brand. They draw about four amps, and do an excellent job of keeping your torso warm while your head is still cool and clear. The Eclipse electric vest uses a "stereo power" connector. If _I_ were building an airplane, I'd seriously consider supplying one of those connectors near each seat. Once upon a time, I worked in a building without heat or AC. In the winter, I wore my Eclipse at my station, with a little 12V "CB" power supply to keep it going. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 22, 2001
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: [c-a] Virus warning
>Dale Martin wrote: >> >> I was sent the "homepagevbs" virus which takes all the OutLook >> email addresses and sends out email to the entire list. If you >> recieved an email from me yesterday with an attachment that says >> something like "this is cool"...... >> >> DO NOT OPEN IT AND DELETE THE EMAIL. >> >> Dale Martin LEZ 777DJ Lewiston, ID > >Ok, I'm more than a little biased, but this sounds like just one more reason to >boycott the totally insecure microsoft products. Not saying Netscape cannot >have problems, but it's always Outlook, isn't it? Not really. Just downloaded the latest McAfee virus scanning data files and did a total scan of my machines. Found two new virus programs on my every-day machine, one on my order taking machine and Dee is presently scanning her machine upstairs. She uses outlook but I use Eudora . . . ANY e-mail program will download and store potentially hazardous programs. I don't open attachments from ANYONE I don't know and then only if I'm expecting something from them. If it's anything but a .jpg or .gif file it will probably get zapped away anyhow. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Subject: Keepwarm system revisited
Date: May 23, 2001
Bob, What about an active circuit out in the wing using a 555 timer and a MOSFET switcher? A low frequency switcher with a low duty cycle (and "controlled" voltage rise times to eliminate RFI) would be easy to design and implement. Fred Stucklen N925RV (1775 hrs/7.8 Yrs) E. Windsor, CT 06088 WK Email: stuckle(at)ifc.utc.com Hm/Travel Email: wstucklen1(at)juno.com ____ From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com> Subject: AeroElectric-List: Re: Keepwarm system revisited . . . > >I guess I've got to ask for clarification here. I assume the idea is to >keep the bulb warm to reduce the inrush current on turn-on. A 50 watt >landing light probably has a cold resistance of a lot less than 1 ohm and a >"warm" resistance of maybe 1 ohm. 2 volts applied gives 2 amps of current - >per bulb. That sounds excessive, but to put negligible current into the >bulb would provide negligible heating. What's the scoop? Just measured a 55W halogen lamp at .25 ohms room temp. 1.0 volts applied produces a dull read glow at 0.8 amps for a "warm" resistance of 1.25 ohms . . . about a 5x increase. DC to DC converters will be pretty readily available in the 1.8 volt range . . . drop that through the isolation diode will give you about 1.1 to 1.2 volts applied to lamp. A 2A power supply could probably handle a landing and taxi light. Adding NAV lights would probably boost it to something on the order of 3A . . . the power supply should be capable of running constant current so that it doesn't "stall" when hit with the cold filaments. While "keep warm" is technically attractive, it's still pretty expensive practically. The major thrust of the keep warm system was driven by the high cost of "aircraft" lamps and relatively low life. Automotive halogens should last longer and of course the bulbs are much cheaper. If you have both landing and taxi lamps, (or hook up high and low beam filaments of a dual lamp) then you have a standby illuminator for landing. In retrospect, I think I'd try to maximize use of low cost automotive parts and have a backup as opposed to spending a lot of dollars (and increasing system complexity) with a keepwarm system to increase the life of a bulb that is eventually going to burn out anyhow. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 23, 2001
Subject: Re: Bob's Book
> >I'll play devil's advocate here. I found Bob's book to be helpful, but >certainly not to the degree that I had hoped. It goes into too much >detail in the wrong areas (detailed theory of battery construction, >magnetic fields, etc.) that just don't help too much in the grand scheme >of things. These things don't help too much when it comes down to "how >do I wire my plane". I've got *some* electronics background (amateur >radio, etc), and would have much rather seen more "applicable" >information in a Tony Bingelis fashion. Such as the order to do things: >run a grounding strap from your engine to your firewall ground block (2 >or 4 AWG), run a cable from this firewall ground block to your battery >NEG post (4 AWG), don't forget to do XXX, ... > >The diagrams are the greatest resource and worth the price of admission. > This newsgroup will probably make it worthwhile too! I also attended >one of Bob's seminars, which was worthwhile. All excellent points . . . -AND- the reason why this is a living document. Revision 10 of the 'Connection is going to do extensive upgrading of some old chapters. The new material is based on feedback from folks we've been working with for the last 12 years. This is "my" book only because I write down the things I know about at the time and print it. It's "your" book because you can participate in its evolution. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: Heated cushions
Date: May 23, 2001
This is just a heads-up: There is a recent thread about heating the seats versus the cockpit air. Good idea to limit the volume to be heated............BUT: I seem toi remember when the astronauts couches (the origin of this material) came into news, that the magic of form-fitted qualities came slowly from the temperature of the incumbent, that is, heat from the bod made a dent which fitted each person in turn. Tony Krzyzewski, a recent contributor might better speak to this, but I would ensure that I would say I planned to heat this expensive foam before I bought it in case it triggers a no-no. Cheers, Ferg, Europa A064 ________________________________________________________________________________
Date: May 23, 2001
Subject: Re: Keepwarm circuit for lamps.......
Bob, Recall that the WigWag Solid State Controller has a bulb warmer function which warms the filament. The WigWag Solid State Controller also detects a burned out bulb. When this is detected, it outsources a current that can drive an LED. This is done for each light. Of course, it also wigwags the leading edge lights. Price $90 plus $6 for shipping. Delivery 4 to 6 week. Send check to Bob Haan 14270 SW Koven Ct Tigard, OR 97224 Adobe Acrobat documentation at http://easystreet.com/~bhaan/ A very long time customer, Bob > by: "Robert L. Nuckolls, III" > > > >Has anyone found an good source for 12vdc to 2vdc > >step-down transformers for Bob's keepwarm circuits? > > There are some out there but still pretty pricey . . > about $60 for a 3.3v 2A device that runs from 9-18 > volts input. You can buy a LOT of bulbs for $60. > Additional load on the system would be small, perhaps > 0.2A or so. I think I'd wait on this. The converters > are becoming more common and volumes are going up. > I expect prices to come down and you can add this > feature very easily at some later time. > Bob Haan http://easystreet.com/~bhaan/ bhaan(at)easystreet.com Portland, OR RV6A 24461 Wiring the panel ________________________________________________________________________________
Date: May 23, 2001
Subject: Re: alternator speeds
>I've an alternator conversion from Air Tech to install on my TriPacer. It's >a Hitachi AM-053R, 45A alternator with a solid state "V1200" regulator >incorperating OV protection and low voltage light circuits. Do you know >anything about Air-Tec and its products? > >I'm concerned about the speed it will be operating with it's 2 5/8" Dia. >pulley. Should I be? The kit (with the small pulley) is not STC'd but has >been field approved for several aircraft. > >Have you a source for a larger pulley? Aircraft Spruce has a beauty but the >boss is too thick for this alternator. Why do you want to slow it down? The B&C L-40/L-60 series alternators run very happily on the front of a Lycoming with a very small pulley. The smaller pulley gets you more output at idle and taxi speeds and more cooling air in cruising flight. Depending on Air-Tec's attention to detail, they should either balance the rotor very well or KNOW that it doesn't need to be balanced any further. The field service life of a B&C (Nipon-Dienso conversion) is exemplary . . . I'd have the rotor checked for balance and leave the pulley alone. The L-40 has been installed on numerous Piper products using a field approval; my impression is that the owners are most pleased with their choice. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: Re: Stabilant 22
Date: May 23, 2001
Does anybody know where I can order Stabilant 22? This is a Canadian company. On their web-site they show Napa as a dealer, but my local Napa parts store never heard of it. I think only the Canadian Napa stores carry it. I have tried the big electronic supply houses but they don't carry it. Lonnie Wood ________________________________________________________________________________
Subject: Re: Bob's Bookh
Date: May 23, 2001
I have to say something about this as I have both Bob's book and Tony's trilogy. From a theoretical perspective Bob's book is far superior to Tony but, as someone else has already pointed out, is a little more specific about how to. However, I attended one of Bob's seminars last year and the opportunity to actually do things under his tutelage and being able to discuss things that he talks about in his book made his book come alive. That is what made the difference for me. Now the book is a great reference and I would not trade for it. As they say, give a man a fish and you've fed him once, teach him to fish and you've fed him a life time. ----- Original Message ----- From: "Jerome Kaidor" <jerryk(at)best.com> Sent: Tuesday, May 22, 2001 1:10 PM Subject: Re: AeroElectric-List: Bob's Bookh > > > > > I'm new on this list, and have been intimidated by electronic > > issues. The primary reason is the schematics, which are a foreign > > language to me. Question: Does Bob's book take a rank newbie like me > > by the hand, thru this new language to a point where I could actually > > read and understand a schematic drawing? If not, can you recommend a > > supplemental reading source that would get me started? > > *** It wouldn't hurt to read the first few chapters of the "Radio Amateur's > Handbook". It's published by the ARRL ( sort of like AOPA, only for radio > hams ). The book talks about electronics from a pretty basic level. It's > put out every year - doesn't matter which year you get. Should be at your > local library. There's ten or eleven of'em on Ebay right now. > > On a somewhat more advanced level - but still starting "from the > beginning" is "The Art of Electronics" by Horowitz and Hill. This book > started out as a class for scientists in other disciplines who wanted to "do > electronics". I can't recommend it too highly. The appendix on > "how not to draw schematics" alone is worth the price of admission. > > - Jerry Kaidor ( jerry(at)tr2.com ) > > ________________________________________________________________________________
Subject: Heated pitot current draw
Date: May 23, 2001
In an effort to gather information regarding the current draw for my 5814 heated pitot/static tube, I put together a setup on my bench and gathered some figures. If anyone is interested in the current draw trend form this particular pitot/static tube you might find the graph interesting. I'll be running this test later on and documenting the heat rise across the pitot tube vs. time. My basic electronics is a little weak and I was somewhat surprised at the results. The peak draw as I started the test turned out to be almost 19 amps and after stabilizing for 10 minutes the current draw was approximately 9 amps. The temperature across he pitot (as measured by a digital pyrometer) was about 425 degrees and slowly rising. Does anyone have any information on what the temperature of a pitot tube is suppose to be? I suppose the airflow across the tube once in the air will tend to keep things quite a bit cooler but I don't think ice will stand a chance against this setup. I don't know why, but I was expecting the current draw to be consistent whether the pitot tube was hot or cold. Anyway, check it out here and follow the links. http://bmnellis.com Mike Nellis Plainfield, IL RV6 N699BM (res) Building Flaps Stinson 108-2 N9666K ________________________________________________________________________________
Date: May 23, 2001
Subject: stabilant 22
Lonnie, I think I've seen it in the NAPA stores here in Montana. If it is normally stocked by NAPA then they have a part number assigned. I'll Check in the morning and post the part number if it is availible then all your local store has to do is order it through their D.C. Jim D. ________________________________________________________________________________
Date: May 24, 2001
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: Heated pitot current draw
>>--> RV-List message posted by: "Mike" >>I don't know why, but I was expecting the current draw to be consistent >>whether the pitot tube was hot or cold. Mike; The results you obtained are exactly consistant with what would be expected. The electrical resistance of almost all materials rises with an increase in temperature and therefore the current vs. time graph will be as you have experimentally proven. This resistance characteristic is why there is a large inrush current when you turn on a cold light bulb but the current quickly stabilizes at a much lower value as the fillament temperature rapidly rises. Bob McC ________________________________________________________________________________
Subject: Stabilant 22 - Contact Enhancer
Date: May 24, 2001
Stabilant 22 is (or was) sold in diluted form as "Tweek" in some audio repair stores. It may still be available as old stock. Some people complained that Stabilant sold as "Tweek" was diluted too much with isopropanol and evaporated from the contact over time. Stabilant 22 is an interesting viscous liquid that becomes conductive only in an electric field, thus enhancing contact effectiveness. Correctly applied it should last on a contact surface for many years. Stabilant 22 would be better known if it weren't for the marketing/sales incompetence of its Canadian manufacturer. (A common problem among Canadian companies). Check the "orders" webpage of www.stabilant.com to see an example of how to alienate potential customers. Stabilant 22 is available from the manufacturer at retail list prices but the manufacturer makes ordering difficult - they won't accept credit cards ! I'm not a dealer but I have a few 5ml tubes of Stabilant 22A (a moderately diluted form) available for builders who can't find it at retail. E-mail me at vaso(at)bovan.com for details if interested. -Vaso ---------------------------------------------- Does anybody know where I can order Stabilant 22? This is a Canadian company. On their web-site they show Napa as a dealer, but my local Napa parts store never heard of it. I think only the Canadian Napa stores carry it. I have tried the big electronic supply houses but they don't carry it. Lonnie Wood ________________________________________________________________________________
Date: May 24, 2001
Subject: Re: Keepwarm system revisited
> > >Bob, > > What about an active circuit out in the wing using a 555 timer and a >MOSFET switcher? A low frequency switcher with a low duty cycle (and >"controlled" voltage rise times to eliminate RFI) would be easy to design >and implement. > >Fred, Fred, we use a 555 and two MOSFETs in the WigWag Solid State Controller to warm the leading edge lights. Our duty cycle is 1/200. FYI, we use a second 555 and the same two MOSFETs for wigwaging (alternately flashing) he leading edge lights. We have set the wigwag flash rate so that:- 1. The bulbs come up to full brightness on each flash. Full brightness means that you will be seen from a greater distance. The police car behind you with a fast flash rate does not need to be seen from miles away. 2. Both lights are not visible at the same time. Since there is not a significant difference in the time required to warm up the filament to full brightness versus the time to cool off the filament so that it is dark, when one light is at full bright the other light is off. This alternating WigWag pattern will make the light appear to jump from on wing tip to the other. We have been conditioned to notice movement. This flash at one wing tip followed by the flash at the other wing tip creates apparent motion. This apparent motion is most important when approaching another plane head on where without the wigwag pattern there is no apparent motion. If the flash rate is to fast, instead of an apparent jump from on wing tip to the other, your eye will see two lights with alternating brightness. Another wigwaging benefit is that since the lights are on only half the time, the load on the alternator etc. is half the load when the leading edge lights are simply switched on in the day time for improved visibility. This can be significant since the leading edge lights are often the largest load in the plane. A Data Sheet and an Installation Guide plus Application Notes in a 135K Adobe Acrobate file are available at http://easystreet.com/~bhaan/ for viewing, downloading or printing. Fred, I will send you this file as an attachment . Others interested in receiving more information on the WigWag Solid State Controller can email a request and I will reply with this Adobe file attached. Bob http://easystreet.com/~bhaan/ bhaan(at)easystreet.com Portland, OR RV6A 24461 Wind Screen ________________________________________________________________________________
Date: May 24, 2001
Subject: Alt. b-lead fuseable link
I have the B&C specialties 80 amp inline fuse for the alternator big wire, is there any problem with attaching one end of this directly to the alternator post, instead of making a short section of wire between it and the alt? Kevin in WA RV 9A ________________________________________________________________________________
Date: May 24, 2001
Subject: Source for toggle switch and covers?
I'm working on my instrument sub-panel, and am looking for a good source for toggle switches with plastic covers on the handle (aren't they called 'bats' for some reason?). I definitely want white, but finding other colors like yellow and orange would be nice too. Standard size or mini, not sub-mini size. Thanks - Mitch RV6A Finish Kit San Mateo, CA ________________________________________________________________________________
Date: May 24, 2001
Subject: Re: Alt. b-lead fuseable link
> >I have the B&C specialties 80 amp inline fuse for the alternator big wire, is >there any problem with attaching one end of this directly to the alternator >post, instead of making a short section of wire between it and the alt? >Kevin in WA >RV 9A The fuse needs to go at the OTHER end of that wire. The energy source that is a threat to that wire is the BATTERY . . . not the alternator. Those fuses are not terribly structural . . . it would be best to have wires attached to both ends even if the end away from the alternator is a short one. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 24, 2001
Subject: Re: Source for toggle switch and covers?
From: mitchf(at)netscape.com (Mitchell Faatz) Subject: AeroElectric-List: Source for toggle switch and covers? Send reply to: aeroelectric-list(at)matronics.com > Faatz) > > I'm working on my instrument sub-panel, and am looking for a good source > for toggle switches with plastic covers on the handle (aren't they called > 'bats' for some reason?). I definitely want white, but finding other > colors like yellow and orange would be nice too. Standard size or mini, > not sub-mini size. > > Thanks - Mitch > > RV6A Finish Kit San Mateo, CA > >Mitch Try Peerlesselectronics.com Jim ________________________________________________________________________________
Date: May 24, 2001
> >In an effort to gather information regarding the current draw for my >5814 heated pitot/static tube, I put together a setup on my bench and >gathered some figures. > >My basic electronics is a little weak and I was somewhat surprised at >the results. The peak draw as I started the test turned out to be >almost 19 amps and after stabilizing for 10 minutes the current draw was >approximately 9 amps. The temperature across he pitot (as measured by a >digital pyrometer) was about 425 degrees and slowly rising. Does anyone >have any information on what the temperature of a pitot tube is suppose >to be? I suppose the airflow across the tube once in the air will tend >to keep things quite a bit cooler but I don't think ice will stand a >chance against this setup. > >I don't know why, but I was expecting the current draw to be consistent >whether the pitot tube was hot or cold. Your data is consistent with the way these things work. They have a very strong positive temperature coefficient of resistance. This both a boon and bane. It takes so long to get past the strong peak in current that you're obligated to use a 15A breaker and appropriately sized wire in spite of the fact that it draws only 8-9 amps in normal operation. However, as you have noticed, the critter gets REALLY hot after awhile . . . in fact, I would caution against prolonged operation on the workbench . . . these things are stressed pretty hard if operating without cooling air of a 100+ MPH slipstream. The up side is that you can design a controller that uses the device's internal resistance to sense whether or not there is ice to be melted. I designed a system for duty-cycle switching the heater and measuring the heater's resistance during the off cycle. It was pretty simple to set it up so that even when operated on the ground with no cooling air, the heater was just warm to the touch and consumed just over 20 watts. When hit with super-cooled water, the system would sense the heater's temperature drop and the duty cycle went up to what ever was necessary to keep the surface temperature of the probe at about 50F minimum . . . if you were in severe icing, the draw would go up to the tube's 100 watt rating but in most cases, it ran much lower . . . and if not in actual icing, it would loaf along at 40-50 watts. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 24, 2001
> > I'm working on my instrument sub-panel, and am looking for a good source > for toggle switches with plastic covers on the handle (aren't they > called 'bats' for some reason?). I definitely want white, but finding > other colors like yellow and orange would be nice too. Standard size or > mini, not sub-mini size. > *** Hi Mitch, Have you tried San Mateo Electronics, on 42nd Avenue? - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 25, 2001
The problem is that most of the major manufacturers don't stock anything. Everything is made to order. For example, my Eaton flap switch, with a white flap bat handle, took 10 weeks to receive. And then I had to buy 5 of the things as a mininum order. I kept one as a spare and sold the rest to other builders. Bruce Glasair III Jim Robinson wrote: > > Try Peerlesselectronics.com > > Jim ________________________________________________________________________________
From: "Mark A. Naig" <mark_a_naig(at)earthlink.net>
Subject: Toggle switch covers
Date: May 25, 2001
Mitch, I have an idea for a cheap way to get your multi-color switches. Buy your toggle switched with just the normal metal bats. Then purchase PlastiDip [Plastidip.com] in the color of your choice [Red, Yellow, Blue, Black, White, or Clear]. One source of PlastiDip is RadioShack.com. They sell the product for $7.99 USD per 14.5 Fl Oz can for dipping or $6.99 USD per 11 Fl Oz Spray-Can. While one can would cover more toggle switches than you will need for plane, the rest can be used to cover and protect your tools, or even other parts of your plane. I played with the stuff in high school shop and it worked great on tools. Sincerely, Mark A. Naig I'm working on my instrument sub-panel, and am looking for a good source for toggle switches with plastic covers on the handle (aren't they called 'bats' for some reason?). I definitely want white, but finding other colors like yellow and orange would be nice too. Standard size or mini, not sub-mini size. Thanks - Mitch RV6A Finish Kit San Mateo, CA ________________________________________________________________________________
Date: May 25, 2001
Hi Bob..is a circuit diagram of your pitot heater controller available?..no point in me re-inventing the wheel..Thanks, Vern Smith vismith(at)sympatico.ca "Robert L. Nuckolls, III" wrote: > > > > >In an effort to gather information regarding the current draw for my > >5814 heated pitot/static tube, I put together a setup on my bench and > >gathered some figures. > > > > > >My basic electronics is a little weak and I was somewhat surprised at > >the results. The peak draw as I started the test turned out to be > >almost 19 amps and after stabilizing for 10 minutes the current draw was > >approximately 9 amps. The temperature across he pitot (as measured by a > >digital pyrometer) was about 425 degrees and slowly rising. Does anyone > >have any information on what the temperature of a pitot tube is suppose > >to be? I suppose the airflow across the tube once in the air will tend > >to keep things quite a bit cooler but I don't think ice will stand a > >chance against this setup. > > > >I don't know why, but I was expecting the current draw to be consistent > >whether the pitot tube was hot or cold. > > Your data is consistent with the way these things work. They > have a very strong positive temperature coefficient of resistance. > This both a boon and bane. It takes so long to get past the strong > peak in current that you're obligated to use a 15A breaker and > appropriately sized wire in spite of the fact that it draws only > 8-9 amps in normal operation. > > However, as you have noticed, the critter gets REALLY hot after > awhile . . . in fact, I would caution against prolonged operation > on the workbench . . . these things are stressed pretty hard > if operating without cooling air of a 100+ MPH slipstream. > > The up side is that you can design a controller that uses the > device's internal resistance to sense whether or not there > is ice to be melted. I designed a system for duty-cycle > switching the heater and measuring the heater's resistance > during the off cycle. It was pretty simple to set it up > so that even when operated on the ground with no cooling air, > the heater was just warm to the touch and consumed just over > 20 watts. When hit with super-cooled water, the system would > sense the heater's temperature drop and the duty cycle went up > to what ever was necessary to keep the surface temperature of > the probe at about 50F minimum . . . if you were in severe > icing, the draw would go up to the tube's 100 watt rating > but in most cases, it ran much lower . . . and if not in > actual icing, it would loaf along at 40-50 watts. > > Bob . . . > --------------------------------------------------- > ( "Teaching should be such that what is offered ) > ( is perceived as a valuable gift and not as a ) > ( hard duty ." Albert Einstein ) > -------------------------------------------------- > http://www.aeroelectric.com > ________________________________________________________________________________
Date: May 25, 2001
> The up side is that you can design a controller that uses the > device's internal resistance to sense whether or not there > is ice to be melted. I designed a system for duty-cycle > switching the heater and measuring the heater's resistance > during the off cycle. It was pretty simple to set it up I, too would love to see the design for this! Gary, just now working on his wing. ________________________________________________________________________________
Date: May 25, 2001
> The problem is that most of the major manufacturers don't stock anything. Everything > is made to order. For example, my Eaton flap switch, with a white flap bat handle, > took 10 weeks to receive. And then I had to buy 5 of the things as a mininum Put some shrink tube on the bat handles. Comes in several colors. You could also make some wild switch shapes with blobs of aerobondo. Hal Kempthorne RV6a N7HK (Valentine) FLYING ________________________________________________________________________________
Subject: Re: RV-List: Heated pitot current draw
Date: May 25, 2001
> Mike, thanks for the pitot amps curve. > > What "system" did you use to record all those points? You're welcome, I used my handy, dandy Radio Shack Multimeter. The meter has a PC interface on it and comes with some software that allows you monitor and track the readings. It saves those readings to a *.txt file that is in a table format but will also show the reading on a graph. I used Excel to graph the table file then converted it to *.html format. I had to borrow my wife's laptop and lug it to the basement but otherwise it's pretty simple. After reading some responses I got on/offline and thinking about it a little more, I realize that the curve may not be valid in flight. The cool air (found when icing might occur) will probably keep the pitot tube significantly cooler than the conditions on the bench. I can therefore assume that the current draw will be consistently higher and the pitot tube cooler. I have used 14 gauge wire for the pitot tube heater and I'll be using a 20 amp fuse for circuit protection. Bob Nuckolls mentioned a circuit design that would allow automatic control of the pitot temperature so that might be an interesting option. Mike Nellis Plainfield, IL RV6 N699BM (res) Building Flaps Stinson 108-2 N9666K Mike ________________________________________________________________________________
Subject: 403mc Audio System
Date: May 25, 2001
Hi Bob, Can pin 18 (music input) be use for two inputs? Proprietary Software Systems AOA and RMI Monitor both have audio inputs. Best regards, Bruce Bell Lubbock, Texas ________________________________________________________________________________
Date: May 25, 2001
Subject: Locking switches
I would like to install locking switches for my mags and alternator. These switches require the knob to be pulled out in order to throw the switch. I've seen them in military and commercial planes, but I don't know their nomenclature or a source for the switches. Can anyone help? Charlie Brame RV-6AQB N11CB (Reserved) San Antonio ________________________________________________________________________________
Date: May 25, 2001
Subject: Re: Locking switches
> >I would like to install locking switches for my mags newark.com 2TL1-5K (MicroSwitch part nubmer but no stock) About $45 each > and alternator. newark.com 23F1987 2TL1-10A $46.96 each >These switches require the knob to be pulled out in order to throw the >switch. I've seen them in military and commercial planes, but I don't >know their nomenclature or a source for the switches. Can anyone help? They're very nice switches with a price to match . . . are you sure your REALLY want these? They add very little if anything in the way of safety . . . I'd rather see you buy the AeroElectric el-cheapos and use the extra cash toward a backup GPS from Walmart for $100 . . . Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 25, 2001
Charlie, I got mine from Allied electronics, but I'm using the 1/4" miniature versions (C&K 7000 series, $7 to $8 each). They have silver contacts rated at 5 amps, but I'm not using them anywhere near this rating (DPDT, both contacts in parallel for each Light Speed ignition, and a on-off-on for the left and right vital bus miniature contactors, about 100ma). Carl Froehlich RV-8A (systems install) Vienna, VA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Charles Brame Sent: Friday, May 25, 2001 12:49 PM Subject: AeroElectric-List: Locking switches I would like to install locking switches for my mags and alternator. These switches require the knob to be pulled out in order to throw the switch. I've seen them in military and commercial planes, but I don't know their nomenclature or a source for the switches. Can anyone help? Charlie Brame RV-6AQB N11CB (Reserved) San Antonio ________________________________________________________________________________
Date: May 25, 2001
Subject: Re: Toggle switch covers
> >Mitch, > >I have an idea for a cheap way to get your multi-color switches. > >Buy your toggle switched with just the normal metal bats. Then purchase >PlastiDip [Plastidip.com] in the color of your choice [Red, Yellow, Blue, >Black, White, or Clear]. One source of PlastiDip is RadioShack.com. They >sell the product for $7.99 USD per 14.5 Fl Oz can for dipping or $6.99 USD >per 11 Fl Oz Spray-Can. Here's the folks that make the stuff: http://www.plastidip.com/plastdip.html See list of various retail outlets at bottom of page. Here are additional sources: http://www.greenbrookelectronics.com/plastidip.htm http://www.radioshack.com/category.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F005%5F005%5F006%5F000&Page=1 http://www.mcmaster.com/ and search on "plasti-dip" then click on "plastic" then click on "plastic dip" I have a can of red that I bought at a local Harbor Freight store. They only stock red and black. You can see a picture of a do-it-yerself color coded toggle switch at: http://www.aeroelectric.com/articles/plastidip.jpg Several builders might go together and buy an assortment of colors and then do enough switches for all their airplanes. The stuff will store well . . . but even the tightest lid will not prevent evaporation of solvents. You can thin it back to original consistency with tolulene or xylene available from painting supply shops and many hardware stores. Don't let it get TOO thick in storage . . . it develops solids that are difficult if not impossible to get back into solution. This is why the sample coating in the above photograph is rough. You can't expect to store it maintenance free for very long. I'd suggest all the participants get their switches coated while the stuff is relatively fresh so that loss of the remainder won't torpedo your plans. I'm still looking for vinyl booties . . . I've seen them but yet to discovered where they are manufactured. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 25, 2001
Subject: Re: Automatic heated pitot controller
> >Hi Bob..is a circuit diagram of your pitot heater controller available?..no point in me >re-inventing the wheel..Thanks, Vern Smith vismith(at)sympatico.ca Yes . . . the first one was pretty simple but it was microprocessor based. I'll see if I can dope out a version with discrete components. I'll announce it on the list and post it on my website. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 25, 2001
Subject: Re: 403mc Audio System
> >Hi Bob, >Can pin 18 (music input) be use for two inputs? Proprietary Software Systems >AOA and RMI Monitor both have audio inputs. >Best regards, >Bruce Bell >Lubbock, Texas Probably. Put a 220 ohm, 1/2 watt resistor in series with each audio output before bringing them together at the 403MC's music input. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 26, 2001
> > > > >Hi Bob..is a circuit diagram of your pitot heater controller available?..no point in me > >re-inventing the wheel..Thanks, Vern Smith vismith(at)sympatico.ca > > Yes . . . the first one was pretty simple but it was microprocessor > based. *** That's how I would have done it. This kind of thing is just a piece of cake with a little microcontroller. I guess it's just harder to "give out a schematic" when there's a program to be burned into a part? - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 26, 2001
Charles-- I think that, over time, you'll find those locking-type toggles to be real pain in the a**. May I suggest just fabricating a simple aluminum shield, 2 or 3 sided shield around the switches, to prevent inadvertent bumping, if that's the reason for your concern. > > > I would like to install locking switches for my mags and alternator. > These switches require the knob to be pulled out in order to throw the > switch. I've seen them in military and commercial planes, but I don't > know their nomenclature or a source for the switches. Can anyone help? > > Charlie Brame > RV-6AQB N11CB (Reserved) > San Antonio > ________________________________________________________________________________
Date: May 26, 2001
> >> >Hi Bob..is a circuit diagram of your pitot heater controller available?..no point in me >> >re-inventing the wheel..Thanks, Vern Smith vismith(at)sympatico.ca >> >> Yes . . . the first one was pretty simple but it was microprocessor >> based. >*** That's how I would have done it. This kind of thing is just a piece of >cake with a little microcontroller. I guess it's just harder to "give out >a schematic" when there's a program to be burned into a part? > > - Jerry Kaidor ( jerry(at)tr2.com ) You got it. The first whack at this used a Rockwell 6502/1 (That ought to tell you how many gray hairs I have) and a National 8-bit, parallel-out A/D converter. There are some really neat, $3 a whack jellybean controllers coming out now . . . some with 10 and 12-bit A/D converters built in. If I were going to do the project again, I'd opt for a year 2001 u-product. I think I can make this work well with jellybean discrete parts too. Just need to noodle on it awhile. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: Re: Spike Catcher Diodes
Date: May 26, 2001
Bob, sent this to you for upgrade/correction a couple of weeks ago. Have you seen it? Looking to close up my top fwd skin and would Like to get this OVM back in before I do. Thanks Fran ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com> Sent: Thursday, May 03, 2001 10:21 Subject: Re: AeroElectric-List: Re: Spike Catcher Diodes > > > > >Bob, I'm using the starter solenoid from Van's which I guess is an > >automotive intermittant duty solenoid. The spike catcher is connected from > >terminal 1 ("switch" s) terminal to the case ground. The red band of the > >diode is connected to terminal 1. > > > >Thanks > > > >Fran Malczynski > >RV6 - N594EF > >Olcott, NY > > Okay, that's a good thing. Send me your OVM and I'll > upgrade it for you. > > > Bob . . . > --------------------------------------------------- > ( "Teaching should be such that what is offered ) > ( is perceived as a valuable gift and not as a ) > ( hard duty ." Albert Einstein ) > -------------------------------------------------- > http://www.aeroelectric.com > > ________________________________________________________________________________
Subject: Re: Stabilant 22 - Contact Enhancer
Date: May 26, 2001
I was told that CorrosionX has similar properties. I have used it with some success on my radio connectors. _____________ Gary Vaso said... Stabilant 22 is an interesting viscous liquid that becomes conductive only in an electric field, thus enhancing contact effectiveness. Correctly applied it should last on a contact surface for many years. -Vaso ________________________________________________________________________________
Date: May 27, 2001
From: "Mike & Lee Anne (mwiebe(at)sympatico.ca)" <mwiebe(at)sympatico.ca>
Subject: STabilant 22
Vaso....check out electrosonic...one of their dealers and a Canadian equivalent to something like digikey. Despite being a Canadian company, I think you'll find their e-commerce capabilities "worldly" enough to meet your needs, eh? ;-). Mike Stabilant 22 is an interesting viscous liquid that becomes conductive only in an electric field, thus enhancing contact effectiveness. Correctly applied it should last on a contact surface for many years. Stabilant 22 would be better known if it weren't for the marketing/sales incompetence of its Canadian manufacturer. (A common problem among Canadian companies). Check the "orders" webpage of www.stabilant.com to see an example of how to alienate potential customers. Stabilant 22 is available from the manufacturer at retail list prices but the manufacturer makes ordering difficult - they won't accept credit cards ! I'm not a dealer but I have a few 5ml tubes of Stabilant 22A (a moderately diluted form) available for builders who can't find it at retail. E-mail me at vaso(at)bovan.com for details if interested. -Vaso ________________________________________________________________________________
Date: May 27, 2001
ACF-50, Boeshield, and Corrosion-X are all moisture displacing products composed primarily of mineral oil and stoddard solvent (like safety kleen). The solvent dilutes the oil to lower its viscosity making it better able to flow into small spaces (lapped seams and around rivets) and this displaces the moisture. The solvent then evaporates and the oil is left behind. I don't think there is any component of these products which is a "viscous liquid that becomes conductive only in an electric field, thus enhancing contact effectiveness". It just displaces the moisture an leaves behind an oil. Which can help avionics or possibly any device contaminated with moisture. >I was told that CorrosionX has similar properties. I have used it with some >success on my radio connectors. >Stabilant 22 is an interesting viscous liquid that becomes conductive only >in an electric field, thus enhancing contact effectiveness. Correctly >applied it should last on a contact surface for many years. -Vaso Bob Steward Birmingham, AL ________________________________________________________________________________
Date: May 27, 2001
From: Wesley & Susan Knettle <wsknettl(at)centurytel.net>
Subject: Web site info
Anyone know where I can find N.A.T. Intervox intercoms on the net or does anyone have a wiring diagram for their ICS? Wes K ________________________________________________________________________________
Date: May 27, 2001
Subject: Shadin Fuel Flow
Was someone on this site looking for a used Shadin indicator? Wes K ________________________________________________________________________________
Subject: Re: Web site info
Date: May 27, 2001
The NAT website is http://www.northernairborne.com/ They are very helpful. Ed Perry eperry(at)san.rr.com ----- Original Message ----- From: Wesley & Susan Knettle <wsknettl(at)centurytel.net> Sent: Sunday, May 27, 2001 8:03 AM Subject: AeroElectric-List: Web site info > > Anyone know where I can find N.A.T. Intervox intercoms on the net or > does anyone have a wiring diagram for their ICS? > > Wes K > > ________________________________________________________________________________
Date: May 27, 2001
Subject: Re: Contact "Enhancers"
> >ACF-50, Boeshield, and Corrosion-X are all moisture displacing products >composed primarily of mineral oil and stoddard solvent (like safety >kleen). The solvent dilutes the oil to lower its viscosity making it >better able to flow into small spaces (lapped seams and around rivets) and >this displaces the moisture. The solvent then evaporates and the oil is >left behind. > >I don't think there is any component of these products which is a "viscous >liquid that becomes conductive only in an electric field, thus enhancing >contact effectiveness". It just displaces the moisture an leaves behind an >oil. Which can help avionics or possibly any device contaminated with >moisture. > >>I was told that CorrosionX has similar properties. I have used it with some >>success on my radio connectors. > >>Stabilant 22 is an interesting viscous liquid that becomes conductive only >>in an electric field, thus enhancing contact effectiveness. Correctly >>applied it should last on a contact surface for many years. -Vaso > > >Bob Steward >Birmingham, AL I've heard of this stuff (and similar products) for years. I have no personal experience with them (mostly because the perceived need for them has been VERY low if none-existent). Here are some choice links on hte web for Stabilant . . . http://www.syence.co.uk/stabilan.htm http://www.stabilant.com/appnt39h.htm I retrieved a copy of the patent on the product from: http://www.patentlawlinks.com/patsearc.htm and did a search on 4,696,832. You can also download a copy from: http://www.aeroelectric.com/articles/4696832.pdf In the patent text we read: "In any electrical contact, the actual co-operating contacting surfaces are not perfectly smooth or continuously planar. Indeed, such contact surfaces, if magnified sufficiently, may have the general appearance of a lunar landscape or even that of a mountain range. In other words, the contact surfaces, themselves, may be very rough, having a number of irregular peaks and a number of irregular pits or valleys. Except as discussed hereafter with particular reference to the present invention, the actual electrical transmission--i.e., the transmission of electrical current from one contact surface to the other--therefore ordinarily occurs only at those places where there is real physical contact between the material of the one co-operating contact surface and the material of the other co-operating contact surface." These words generally describe the the nature of most surfaces . . . The earth is smoother than a billiard ball. If you increase the size of a billiard ball to a diameter equal to the earth, pits an valleys in the ball's surface will exceed the depth and heights of the earth's surface imperfections. I've been doing work on some relay sticking problems on some RAC aircraft and having peered through a microscope at what appears to be brightly polished, gold plated surfaces, I can easily relate to the notion that when it comes to herding electrons between two conductors, "TANSTAASS" (their ain't no such thing as a smooth surface). Other noteworthy items from the patent are the size of the molecules for the active ingredients . . . two materials are described having a molecular weight "range of 1000-3000" and "1400-2800". These are big molecules. Given that they have a range (as opposed to fix length) suggests that the term "poly" lends credence in this amateur chemist's mind that they are relatively active and willing to form up in various sizes under an external influence. One thing is sure, those HUGE molecules don't evaporate . . . the patent speaks to wetting abilities of the material so I can believe that once in place, the stuff stays put. In 40+ years of putting airplanes together to meet the wishes of government's fondest dreams I've never heard of the need to enhance the performance of any precious metal or gas-tight contact by externally applied concoctions (except for our brief romance with aluminum wire). It's true that relatively rough surfaces never have intimate contact at the molecular level. However, when contact area is small, the PRESSURE on these areas is HUGE in spite of small forces. As long as the contacts don't become contaminated with external materials (dirt) or corrosion (gold doesn't corrode - nor do metals forced into gas-tight union), then contact integrity is assured. The patent cites tests to measure rise time and harmonic distortion - qualities totally internal to the products you're bolting to your panel. Connectors WITHIN general aviation's black boxes seldom carry signals wherein rise time and harmonic distortion are items of great concern. By the time wiring reaches the outside world where your pins are crimped on, the ability to enhance performance or longevity at the user- accessible level is tiny if not non-existent. Irrespective of how this material really functions, my strongest impressions are (1) that the stuff probably does no harm and (2) given the time and attention we SHOULD pay to the physics of making and keeping good electrical contacts - adding such a product to your toolbox should add little or no value to the end results. History has demonstrated that we KNOW how to make joints in our airplanes that last a very long time. Bob . . . ________________________________________________________________________________
Date: May 27, 2001
02:01:46 PM Bob Nuckolls writes eloquently about how good contacts do a great job for a long time without external chemical assistance. Which makes me wonder: I've seen radios, in particular, become unreliable seemingly because the connectors at the back of the rack degrade over time. Cleaning the contacts seems to help. Is it reasonable to conclude that the connectors typically used at the back of older radio racks just aren't up to keeping corrosion and dirt away? (I have the impression that modern pin and socket connectors, like the DB25, are much better.) Another recent example of a device which failed after 25 years in service is the panel light rheostat from a friend's Grumman Tiger, which now works perfectly after he spent some time carefully cleaning it with various chemicals. No opportunity there to make a gas-tight joint between the wire coil and the wiper brush. Would an annual dose of ACF-50 have kept that device working? And several spade lugs in that same airplane have loosened their grip over the years. One unreliable circuit was repaired by squeezing the spade lug with pliers, restoring a tighter joint. (Yes, replacing the spade lug would have been a better approach.) But I've seen ACF-50 improve this situation (or perhaps the improvement was psychosomatic). Is it effective in this situation, if only as a palliative? ________________________________________________________________________________
Date: May 27, 2001
> > > Which makes me wonder: I've seen radios, in particular, become unreliable > seemingly because the connectors at the back of the rack degrade over time. > Cleaning the contacts seems to help. Is it reasonable to conclude that the > connectors typically used at the back of older radio racks just aren't up > to keeping corrosion and dirt away? (I have the impression that modern pin > and socket connectors, like the DB25, are much better.) > *** Once upon a time, I worked as a line technician in a telephone equipment factory. We dealt with a _lot_ of connectors and connections, and used them heavily. I remember two things * Augat machine sockets *never* went intermittant. They worked perfectly until they broke. * The best connection, in general, was any connector with a round pin in a round hole. Which the Augats were. They were just the "best of the best" * Any socket system with flat contacts was inferior. We kept contact cleaner sprays on hand to spray them into submission. Never needed any sprays for those Augats... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
From: "James K. Glindemann" <jglind(at)netspace.net.au>
Subject: pin out request
Date: May 28, 2001
I am wiring a rebuild project (Australian Victa Airtourer) a friend of mine purchased part completed. It has a Sportflight (looks just like a westach to me) fuel guage with a capacitive probe fitted. The wiring for the probe looks pretty obvious due to the colouring of the wires but the pinout of the guage is not so obvious. Can somebody point me in the right direction? regards James K Glindemann ________________________________________________________________________________
Subject: RE: AeroElectric-List Digest: 9 Msgs - 05/27/01
Date: May 28, 2001
We deal in lots of electrical connectors. Our product probably has about 30 million contacts per year. Some of our automotive customers demand gold plated pins, one even silver plated, but most just specify tin plated. We have no data to support that one is better than the other. Some customers have investigate "greased" connections. The idea is that corrosion (either fretting or electrolytic) takes place at the interface and grease will keep the oxygen away while still allowing electrical contact because the connector pushes through the grease. Experience has shown that the light ends of the grease will evaporate, leaving behind wax, which can work its way between the contacts, creating intermittents. Note that all petroleum products contain almost the whole range of molecular weights from butane to wax - it's just the percentage of each that determines whether it is gasoline or grease. We ship no parts with grease in them, but we do have to put a corrosion-inhibitor on the silver pins so they don't tarnish before final installation. These days ALL (well, almost all) automotive connectors are environmentally sealed and they all work well. Add vibration (engine mounted) and none work very well. We get a lot of warranty parts back that work just fine - on a few of these I think that if the technician just unplugged and plugged them back in they probably would have worked. Almost none of the parts we get back show any kind of corrosion or distress at the connector pins. For the aerospace customers (Boeing, Airbus, Lockheed, etc) we just use Mil-spec connectors with gold plated pins and we ship them dry. On my race car stuff I solder the wires directly to the PC board of the controller and then pot the whole thing, making the harness integral. Never had a connector failure at the box - no connectors. I have seen builders of prefab instrument panels try to make it less work for the builder by bringing all the wiring to a central point and then put in a row of connectors so the builder can just plug-and-play. I think I will build my own with the idea of minimizing the number of electrical connections. All of which reinforces what Bob has to say: Irrespective of how this material really functions, my strongest impressions are (1) that the stuff probably does no harm and (2) given the time and attention we SHOULD pay to the physics of making and keeping good electrical contacts - adding such a product to your toolbox should add little or no value to the end results. History has demonstrated that we KNOW how to make joints in our airplanes that last a very long time. Bob . . . ________________________________________________________________________________
Date: May 28, 2001
> > >Bob Nuckolls writes eloquently about how good contacts do a great job for a >long time without external chemical assistance. Jerry made an astute observation about round versus flat contacts . . . and I have to generally agree. Plug and socket connectors for critical applications are close cousins to the D-sub connectors with machined pins. The male contacts are solid, the female contacts have contiguous barrels lined with multiple spring contacts. >Which makes me wonder: I've seen radios, in particular, become unreliable >seemingly because the connectors at the back of the rack degrade over time. >Cleaning the contacts seems to help. Is it reasonable to conclude that the >connectors typically used at the back of older radio racks just aren't up >to keeping corrosion and dirt away? (I have the impression that modern pin >and socket connectors, like the DB25, are much better.) I'm designing components of a new target we're building at Raytheon. I'm using d-sub connectors on the power distribution assembly (some feeds rated at 40 amps!) and on the electro- explosive device controller that sequences various electrical firecrackers to light the engines, disconnect the booster and destruct the target. The quality of inter-mated pins in the d-sub line are right up there with the best of them. They're also ROUND. The avionics industry had a brief romance with Winchester Blue Ribbon series connectors early-on (This is like the connector often called a "Centronics" connector on the back of most printers). This is indeed a "flat" contact connector that depends on one-side spring tension for integrity. I'll take the round pin connectors any day. >Another recent example of a device which failed after 25 years in service >is the panel light rheostat from a friend's Grumman Tiger, which now works >perfectly after he spent some time carefully cleaning it with various >chemicals. No opportunity there to make a gas-tight joint between the wire >coil and the wiper brush. Would an annual dose of ACF-50 have kept that >device working? If any kind of success with cleaning suggests a combination of dirt and/or corrosion. Almost anything that aids in washing/de-scaling the surfaces would be beneficial. This case is a tad off point with respect to connectors as the junction in question is hung out in the air and exposed to a lot of contamination . . . and not especially DESIGNED for long, maintenance free service. It may well be too that if he cycled his panel lighting from dim to bright and back to dim at every preflight, the surfaces would have remained electron-friendly with no further attention. >And several spade lugs in that same airplane have loosened their grip over >the years. One unreliable circuit was repaired by squeezing the spade lug >with pliers, restoring a tighter joint. (Yes, replacing the spade lug >would have been a better approach.) But I've seen ACF-50 improve this >situation (or perhaps the improvement was psychosomatic). Is it effective >in this situation, if only as a palliative? If they've loosened, they may have been crafted from an inferior alloy. If the lug carries relatively low current (say less than 2A) a simple tightening and reinstallation is probably going to last. If it's a high current path like landing light, pitot heat or incandescent strobe circuit, I'd replace the terminal. Bob . . . ________________________________________________________________________________
Date: May 28, 2001
> > >*** That's how I would have done it. This kind of thing is just a piece of > >cake with a little microcontroller. I guess it's just harder to "give out > >a schematic" when there's a program to be burned into a part? > > > > - Jerry Kaidor ( jerry(at)tr2.com ) > > You got it. The first whack at this used a Rockwell 6502/1 (That > ought to tell you how many gray hairs I have) *** Right up there with you on the gray hairs, Bob. My first foray into microprocessors was the "RCA 1802". Didn't have an assembler, memorized all the opcodes on a set of flash cards - sped up coding considerably. Then I got to work on a BIG machine - a Digital PDP-8 :). Assembly language and all. Hey, if you do it with a PIC microcontroller, will you get to log PIC time? :) - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 28, 2001
Subject: Strobe wires
What size wires should I use to connect my strobe lights up to the power supply? At which end should the shielding in the wire be grounded to the airframe? I have a single Whelen power supply with 4 outputs. I'll be using 3 of them. It will be about a 25' run, one way, to each wing tip from the power supply, and about 15' one way to the tail. The A/C is a Murphy Super Rebel.. ie. All metal airframe.. Thanks, Dave ________________________________________________________________________________
Date: May 28, 2001
Subject: strobe wires
Dave- When I bought my install kit from Vans it came with a special high voltage wire... maybe not that special, but it's very convenient. Three conductors, all surrounded by a shield, and then jacketed again. There's a ground in there, too... I'm, sure you can get it other places, if get it from him, Vans nicked me $44.00 for 30' of the wire, plus some connectors. LN HD-60-1 INSTALLATION PKG $44.00 You can order it from them, or elsewhere if its easier. Dave- When I bought my install kit from Vans it came with a special high voltage wire... maybe not that special, but it's very convenient. Three 18 AWG conductors, all surrounded by a shield, and then jacketed again. There's a ground in there, too... It's also pictured in the ACS catalog but I didn't see it listed as an individual item like Vans has. I'm sure you can get it other places, but Vans nicked me got $44.00 for 30' of the wire, plus some connectors. LN HD-60-1 INSTALLATION PKG $44.00 Matthew ________________________________________________________________________________
Date: May 28, 2001
Subject: Re: strobe wires
> >Dave- > >When I bought my install kit from Vans it came with a special high voltage >wire... maybe not that special, but it's very convenient. Three conductors, >all surrounded by a shield, and then jacketed again. There's a ground in >there, too... I'm, sure you can get it other places, if get it from him, >Vans nicked me $44.00 for 30' of the wire, plus some connectors. > >LN HD-60-1 INSTALLATION PKG $44.00 > >You can order it from them, or elsewhere if its easier. The wire is Belden 971803 wire which you can view in the lower left corner of this page from Allied's catalog. http://www.alliedelec.com/catalog/pf.asp?FN=321.pdf As you can see, a 100' spool of this sells for $53 and change or about 0.53/foot. Van's probably bought 1000' spools for about 0.23/foot I think the connectors are: http://catalog.tycoelectronics.com/TE/docs/pdf/6/26/195626.pdf These can probably be had in quantities of 5 or 10 housings to a bag and bags of 100 mating pins. Haven't bought these for years but I'd judge they cost about $1 ea for housings and .20 ea for pins in small quantities. If your time to track this stuff down and order it is worth anything, I suspect the pricing from Van's is fair and attractive. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 28, 2001
> >*** Right up there with you on the gray hairs, Bob. My first foray into >microprocessors was the "RCA 1802". Didn't have an assembler, memorized >all the opcodes on a set of flash cards - sped up coding considerably. I had it easy. Cut my assembler teeth on a Rockwell AIM-65 with full ascii keyboard, 20 character display and printer with a really nice editor and two-pass assembler. I'd been putting off starting to learn microcontrollers because of all the sweat I observed on the part of my contemporaries. Stumbled into the AIM-65 and was writing code I could sell in two weeks. It would never have happened so soon on any other low cost development system. Got to speak to it in plain language mnemonics from the get-go. > Then I got to work on a BIG machine - a Digital PDP-8 :). Assembly >language and all. Hmmm . . . I'd forgotten how to speak in octal after the byte came along . . . then I began to work on setting permissions in Unix for my website server . . . it all came back! >Hey, if you do it with a PIC microcontroller, will you get to log >PIC time? :) Yeah, but only if the PIC parts are DO-160 qualified and the code is blessed with DO-178! Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Subject: Unreliable Connectors & Stabilant
Date: May 29, 2001
>All of which reinforces what Bob has to say: Irrespective of how this material really functions, my strongest impressions are (1) that the stuff [Stabilant] probably does no harm and (2) given the time and attention we SHOULD pay to the physics of making and keeping good electrical contacts - adding such a product to your toolbox should add little or no value to the end results. History has demonstrated that we KNOW how to make joints in our airplanes that last a very long time. Bob . . .< I make my living selecting and qualifying components for clients in the electronics industry. Connectors and related components such as relays are by far the least reliable electronic/electromechanical parts. My view of Stabilant is that Bob and others are quite correct to say that we know how to make reliable connections. However, in the real world, conditions are not ideal and sometimes connector design and implementation is quite shoddy. I've walked around the last two Oshkosh and Sun-N-Fun shows examining "non-certificated" electronic gadgets meant for experimental aircraft. Some of these assemblies have totally inadequate connectors - for example tin-to-gold mating surfaces, or - more commonly - "gold flash"-plated contacts whose porous gold is there only for cosmetic appeal. Or, they have cheap connectors with unreliable stamped-and-formed terminals. (There are good stamped-and-formed terminals but they are invariably post-plated - ie the gold plating is applied after the stamping). Even among D-Sub connectors, there are good connectors from reputable manufacturers (AMP, etc) but the market is flooded with cheap and nasty D-Sub connector housings and terminals that can't be guaranteed to be interchangeable with the mating D-Sub connector from another manufacturer. I've seen situations where the cheap stamped-and-formed male pin from one manufacturer caught on the lip of the corresponding female terminal or gouged and removed the gold plating along the length of the mating terminal. The resulting corrosion problem doesn't always show until a year or two of field service. There are other connector problems that are not due to shoddy manufacture, but are inherent in the compromises necessary in modern connector design. As connector pin densities go up, connector manufacturers are often forced to reduce insertion and "normal" contact per-pin forces to reasonable levels. Many connectors today - for instance card-edge connectors and 100+pin on-board PGA ICs - have low-insertion force and low normal force terminals. (The connector manufacturers try to compensate with fancy terminal designs such as "bifurcated" terminals with two contacts of different length and different mechanical resonant frequencies). Low force connectors are susceptible to intermittent contact, especially in the high vibration environment of kitbuilt aircraft. The race is on between better-designed connectors which tend to increase reliability, and higher pin densities and lower currents and lower voltages which tend to decrease reliability. It used to be that 50u" of gold plating was required (by Bellcore) for all connectors used in low voltage telecommunications applications. Recently, this has been lowered to 30" but only if time-consuming and expensive testing proves the adequacy of 30u" gold (or gold-palladium). I'm sure Garmin, and King, and other reputable and established manufacturers have the resources to ensure connector reliability. Mom and Pop operations making assemblies solely for the homebuilt market manifestly do not. The point is that the average aircraft kitbuilder is at the mercy of gadget assembly manufacturers and the connectors they select. Yes, a well-designed and implemented gas-tight connection between two mating surfaces with similar metal plating will not benefit from Stabilant 22. However, there are plenty of situations, mostly low voltage, low current, high vibration applications, where Stabilant 22 gives increased reliability and peace of mind. -Vaso Bovan ________________________________________________________________________________
Date: May 29, 2001
If you would drop a note on the algorithm, I can convert it to one of the current cheap micros such as PIC16F872, which is $2.83 from Digikey if you get together an order for 25 at once. > -----Original Message----- > From: Robert L. Nuckolls, III [mailto:nuckolls(at)aeroelectric.com] > Sent: Saturday, May 26, 2001 12:41 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Automatic heated pitot controller > > > III" > > > > > >> >Hi Bob..is a circuit diagram of your pitot heater > controller available?..no point in me > >> >re-inventing the wheel..Thanks, Vern Smith vismith(at)sympatico.ca > >> > >> Yes . . . the first one was pretty simple but it was > microprocessor > >> based. > > > >*** That's how I would have done it. This kind of thing is > just a piece of > >cake with a little microcontroller. I guess it's just > harder to "give out > >a schematic" when there's a program to be burned into a part? > > > > - Jerry Kaidor ( jerry(at)tr2.com ) > > You got it. The first whack at this used a Rockwell 6502/1 (That > ought to tell you how many gray hairs I have) and a National > 8-bit, parallel-out A/D converter. There are some really > neat, $3 a whack jellybean controllers coming out now . . . > some with 10 and 12-bit A/D converters built in. If I were > going to do the project again, I'd opt for a year 2001 u-product. > > I think I can make this work well with jellybean discrete > parts too. Just need to noodle on it awhile. > > > Bob . . . > --------------------------------------------------- > ( "Teaching should be such that what is offered ) > ( is perceived as a valuable gift and not as a ) > ( hard duty ." Albert Einstein ) > -------------------------------------------------- > http://www.aeroelectric.com > > > > > > ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Date: May 29, 2001
> >*** Right up there with you on the gray hairs, Bob. > >microprocessors ??? ..... with full ascii keyboard ? ? ..... 20 character display?? ...... nice editor and two-pass assembler???......plain language mnemonics ????..........ETC., ETC. I'm really impressed with your modern technology. When I started, 400 warehouse people depended on me to octally patch - at the bit level the bootsrtrap routine before manually patching the computer to read in the program (2/3s of a tray of Hollerith cards) ...all the program could do was sort a few records. If one card was wrinkled the warehouse may have to schedule overtime and begin work only after I rewrote or patched modified code. This was actually mainframe processing. Ahh!! The good old days. No keyboard or display (console or printer) You had to navigate the registers and read the lights - 0 is off, 1 is on. Probably as dependable as early Windows. Ernest Kells RV-9A - Fuselage, O-235, Planning Wood Prop Sault Ste. Marie, Ontario ________________________________________________________________________________
Date: May 29, 2001
Subject: Your OVM upgrade
> >Bob, sent this to you for upgrade/correction a couple of weeks ago. Have you >seen it? Looking to close up my top fwd skin and would Like to get this OVM >back in before I do. > >Thanks Out in today's mail . . . Bob . . . ________________________________________________________________________________
Subject: Dual MAC trim system
Date: May 29, 2001
Bob, I was wondering if you have a schematic for a dual MAC electric trim system using their G5 stick grips. It would be a pretty straight forward hookup until you get two in parallel. They suggest a SPDT swith to select either the right or left stick. But my analysis indicates that I will need 8 diodes (4 for the elevator and 4 for the aileron servos) to keep the system from finding a ground when both sticks are used at the same time and thus blowing a fuse. Is there a better way to do this? Anyone else done this? Thanks, Pat Hatch RV-4, N17PH @ VRB, 700 hours TT O-320, Hartzell C/S RV-6, Fuselage O-360, Hartzell C/S ________________________________________________________________________________
Date: May 29, 2001
Subject: Re: Unreliable Connectors & Stabilant
> >>All of which reinforces what Bob has to say: > Irrespective of how this material really functions, > my strongest impressions are (1) that the stuff [Stabilant] > probably does no harm and (2) given the time and > attention we SHOULD pay to the physics of making > and keeping good electrical contacts - adding such > a product to your toolbox should add little or > no value to the end results. History has demonstrated > that we KNOW how to make joints in our airplanes that > last a very long time. > Bob . . .< > >I make my living selecting and qualifying components for clients in the >electronics industry. Connectors and related components such as relays are >by far the least reliable electronic/electromechanical parts. My view of >Stabilant is that Bob and others are quite correct to say that we know how >to make reliable connections. However, in the real world, conditions are not >ideal and sometimes connector design and implementation is quite shoddy. >The point is that the average aircraft kitbuilder is at the mercy of gadget >assembly manufacturers and the connectors they select. Yes, a well-designed >and implemented gas-tight connection between two mating surfaces with >similar metal plating will not benefit from Stabilant 22. However, there are >plenty of situations, mostly low voltage, low current, high vibration >applications, where Stabilant 22 gives increased reliability and peace of >mind. > >-Vaso Bovan Vaso is dead-on correct about the variability of quality offered to the various industries . . . and to be sure, there are many devices offered to other venues that can be quite useful to us in aircraft applications. The only mitigating comment I have to offer is in response to "the average aircraft kitbuilder is at the mercy of gadget assembly manufacturers and the connectors they select." The folks on this list-server are not average kitbuilders or they wouldn't be reading this now. The fact that this thread has produced such learned and considered commentary has further elevated our brethren's understanding of the technology. I believe everyone on this list will now peer into the back of some contemplated new appliance with an elevated clarity of vision and understanding . . . it would warm the soul to hear any of them say, "I looked at that thing but the connector on the back just didn't look like it would stay with me for 10 years . . . I decided NOT to put it in my airplane." Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 29, 2001
I used two of Matronics Governor units (speed control/relay deck) with G7 & G5 grips. For the electron-challenged, like me, the wiring is a rats nest. You're right that it's fairly straight forward until you put the 2nd grip in parallel. I made diagrams and labeled everything and it all works... but I hope I never have to troubleshoot it. This seems like a good case for a many-connectored box with a PC board (or ?)inside to handle the inter-connections. From memory, I've got: a) 8 wires from the G7; ground, 4 for trim, PTT, 2 aux - the PTT and aux need to route back to the panel. b) 6 wires from the G5; ground, 4 for trim, PTT the Governors each have 2 pigtails - one goes to switches, one to servo and bus power gets in there somewhere c) 5 conductor wire from each servo needs to hook to Governor with two or three of the wires continuing to the panel for the indicator. Of course, the trim wires from the 2 grips need to pair-up going into the Governor but then you need connectors before that if you want the control sticks removable. Same for the Governors if you want them replaceable without cutting and splicing. And you pretty much need to break the servo cable since part goes to the panel and part stays by the sticks. Here's a rough cut at the connections needed: a) (2) connectors for each stick grip accommodating all their bells and whistles b) (4) connectors for the speed governors - better yet, build them in and eliminate the connectors c) (2) connectors for the servo wiring d) one or more connectors to bring in power and ground and send out the trim indicator signals and whatever other doodads are on the grips. I'm sure if you've done a dozen of these, you can make it neat, if not elegant. But for a first and only, it was aggravation akin to fitting my canopy. So how about it, anyone want to market a black box for this? Regards, Greg Young RV-6 N6GY Houston (DWH) FWF - most electrons are under control > > > Bob, > > I was wondering if you have a schematic for a dual MAC electric trim > system using their G5 stick grips. It would be a pretty straight > forward hookup until you get two in parallel. They suggest a > SPDT switch > to select either the right or left stick. But my analysis indicates > that I will need 8 diodes (4 for the elevator and 4 for the aileron > servos) to keep the system from finding a ground when both sticks are > used at the same time and thus blowing a fuse. Is there a > better way to > do this? Anyone else done this? > ________________________________________________________________________________
Date: May 29, 2001
> > > > > >*** Right up there with you on the gray hairs, Bob. My first foray into > >microprocessors was the "RCA 1802". Didn't have an assembler, memorized > >all the opcodes on a set of flash cards - sped up coding considerably. > > I had it easy. Cut my assembler teeth on a Rockwell AIM-65 *** Gee, I couldn't afford one of those. I think they cost about $300, real money back in the 70's. Especially if you were a poor electronics tech. > > > Then I got to work on a BIG machine - a Digital PDP-8 :). Assembly > >language and all. > > Hmmm . . . I'd forgotten how to speak in octal after > the byte came along . . . then I began to work on > setting permissions in Unix for my website server . . . > it all came back! > ** Snick-snack-snick-snack-DEPOSIT! Snick-snack-snick-snack-DEPOSIT! ( Boot roms? Our boot roms were on paper tape :-). I hand-disassembled that paper tape loader - the one you'd enter with the toggle switches. It was the most efficient program I ever saw: it literally ate itself, consuming no longer needed instructions for data memory. ) Truely I knew that the world had changed, when mighty DEC was acquired by a PC Clone manufacturer. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 29, 2001
Phew, You guys must be about my vintage. I think I made my first industrial controller based on a Signetics 2650. Gee I bet I'd be hard pressed to buy on of those today !! Cheers, Paul (Also with gray hairs) From: Jerome Kaidor <jerryk(at)best.com> Subject: Re: AeroElectric-List: Re: Automatic heated pitot controller > > >*** That's how I would have done it. This kind of thing is just a piece of > >cake with a little microcontroller. I guess it's just harder to "give out > >a schematic" when there's a program to be burned into a part? > > > > - Jerry Kaidor ( jerry(at)tr2.com ) > > You got it. The first whack at this used a Rockwell 6502/1 (That > ought to tell you how many gray hairs I have) *** Right up there with you on the gray hairs, Bob. My first foray into microprocessors was the "RCA 1802". Didn't have an assembler, memorized all the opcodes on a set of flash cards - sped up coding considerably. Then I got to work on a BIG machine - a Digital PDP-8 :). Assembly language and all. Hey, if you do it with a PIC microcontroller, will you get to log PIC time? :) - Jerry Kaidor ( jerry(at)tr2.com ) Regards, Paul McAllister Builder 363 - http://pma.obtero.net ________________________________________________________________________________
Date: May 29, 2001
Subject: OUT OF TOWN for awhile . . .
Dee and I are launching for parts west early in the morning . . . for a few days I'm going to be Internet deprived. We're scheduled to spend some time on the beach north of San Simeon, CA counting seagulls. I'll be meeting some of you at the Watsonville seminar next Saturday. I'll probably not collect any e-mail until then. Be back in the saddle here on the list next Monday. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: May 29, 2001
> > >*** Right up there with you on the gray hairs, Bob. > > >microprocessors ??? ..... with full ascii keyboard ? ? ..... 20 > character display?? ...... nice editor and two-pass assembler???......plain > language mnemonics ????..........ETC., ETC. > > I'm really impressed with your modern technology. When I started, 400 > warehouse people depended on me to octally patch - at the bit level the > bootsrtrap routine before manually patching the computer to read in the > program (2/3s of a tray of Hollerith cards) ...all the program could do was > sort a few records. If one card was wrinkled the warehouse may have to > schedule overtime and begin work only after I rewrote or patched modified > code. This was actually mainframe processing. Ahh!! The good old days. > No keyboard or display (console or printer) You had to navigate the > registers and read the lights - 0 is off, 1 is on. Probably as dependable > as early Windows. > Ernest Kells RV-9A - Fuselage, O-235, Planning Wood Prop > Sault Ste. Marie, Ontario Weren't you guys all on EGYPT - BEYOND THE PYRIMIDS on the History Channel last night???? Geez, I don't even think they HAD electricity back then. That must have been before lightening!!! :-) Charlie Kuss ________________________________________________________________________________
Date: May 29, 2001
> > sort a few records. If one card was wrinkled the warehouse may have to > Ernest Kells RV-9A - Fuselage, O-235, Planning Wood Prop > > Sault Ste. Marie, Ontario > > Weren't you guys all on EGYPT - BEYOND THE PYRIMIDS on the History Channel last > night???? Geez, I don't even think they HAD electricity back then. That must have been > before lightening!!! :-) > Charlie Kuss > ....Sigh. That's the trouble with kids today:) - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <stuckle(at)ifc.utc.com>
Subject: Alt. b-lead fuseable link
Date: May 30, 2001
Bob, Do you recommend that the fuse be put in the cockpit area of an RV-6? Fred Stucklen N925RV (1730 hrs/7.75 Yrs) E. Windsor, CT 06088 WK Email: stuckle(at)ifc.utc.com Hm/Travel Email: wstucklen1(at)juno.com ____ From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com> Subject: Re: AeroElectric-List: Alt. b-lead fuseable link > >I have the B&C specialties 80 amp inline fuse for the alternator big wire, is >there any problem with attaching one end of this directly to the alternator >post, instead of making a short section of wire between it and the alt? >Kevin in WA >RV 9A The fuse needs to go at the OTHER end of that wire. The energy source that is a threat to that wire is the BATTERY . . . not the alternator. Those fuses are not terribly structural . . . it would be best to have wires attached to both ends even if the end away from the alternator is a short one. Bob . . . ________________________________________________________________________________
Date: May 30, 2001
Subject: RS232 connect UPS Avionics SL70 Xponder - Rky Mt encoder
Hi List, Has anyone connected the UPS Avionics SL70 Transponder to the Rocky Mt encoder using RS232 instead of grey code? If so, would you confirm the connections. Thanks, Bob Bob Haan http://easystreet.com/~bhaan/ bhaan(at)easystreet.com Portland, OR RV6A 24461 Wiring the panel ________________________________________________________________________________
Date: May 30, 2001
Subject: RS232 UPS Avionics SL70Xponder RkyMt encoder
Subject: Re: RS232 connect UPS Avionics SL70 Xponder - Rky Mt
encoder
Date: May 30, 2001
> Has anyone connected the UPS Avionics SL70 Transponder to the Rocky Mt > encoder using RS232 instead of grey code? If so, would you confirm the > connections. > > Thanks, > > Bob > > Bob Haan > http://easystreet.com/~bhaan/ > bhaan(at)easystreet.com > Portland, OR > RV6A 24461 Wiring the panel Bob, I used the grey code instead of the RS232 output so as to save it for future use with functions that UPSAT will be coming out with. I know, the serial connection requires 2 wires wheras the grey code requires about 13... you can do it! Randy Lervold RV-8, N558RL, 28.2 hrs. www.rv-8.com Home Wing VAF ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 12 Msgs - 05/29/01
Date: May 31, 2001
Subject : Connections for dual stick/dual trim servo I am in the process of building a Lancair-360, and I had the the same problem with all the wires going from the sticks to various control elements. You will eventually want to remove the stic for alterations (or repair ?), and it is pretty hard to find a 16+ way connector to fit inside a 3/4" tube. Somewhere on the web I saw an idea with some sort of network in the A/C. They placed a microprocessor (16pin PIC) inside the stick, feeded it with (filtered) 12V system supply or a regulated 5V, and had serial or network connection to all the control elements. This gives you only 3 wires up the stick i.e. power, ground and signal. I have implemented the setup in my sticks, but I am using the Atmel 89C2051 in a SOT package. The communication is serial NMEA-183 look alike, but for reliability I use a CAN-bus driver for the network inteface. I am not flying yet, but elements has been tried out in my old Auster Mk-V from 1944. It is just as vibrating as I expect my Lancair to be. I have 4-way trim on each stick, PTT, TXP-ident, CWS, A/P-disengage, stopwatch start/stop, and have included a 5 digit display for clock, timer, altitude readout, frequency preselect, all with only four wires going up the stick. I did not beleive this was a problem for others, so I do not intent to produce or sell the gadget, but I can have PC-boards made up at a really fair price. Regards Villi H. Seemann Senior Engineer Infrastructure-Network Phone direct (+45) 3333 2101 FAX (+45) 3333 1130 Cellphone (+45) 2220 7690 ________________________________________________________________________________
Subject: Back from the IA
Date: May 31, 2001
...With a small problem. As you may know, I'm going to be installing a GNS-430 in my Sundowner. An IFR GPS like the 430 is installed with two FAA 337 forms. The first form ( which the FSDO has just stamped & signed ) is considered the VFR approval. It covers the basic installation of the equipment, and certifies that you used proper wiring techniques, the right breakers, the right mechanical mounting, cooling, etc etc. After the first 337 is executed, the airplane is again airworthy for VFR purposes, but the GPS is not approved for IFR. With the newly airworthy plane, a flight test is accomplished, verifying that the GPS is adequate for IFR. A second 337 is filed, certificating that the GPS passed the flight test. The problem is with the second 337. My IA won't touch it. His liability insurance doesn't cover flying airplanes in connection with his airplane repair business. So it looks like I have to find a second IA, just to flight test the thing with me.......(sigh)! - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jun 01, 2001
Subject: Re: attitude gyros
Hi guys - We had a great discussion a month ago about the pros and cons of both the turn coordinator, and the turn and slip indicator. Check out the instrument panel in the May 2001 issue of "Sport Aviation" - page 34. You can sure see what this builder's preference is! Note: the a/c is set up for right seat P.I.C. Thanks again all - Bill RANS Courier/912uls (up on the gear) Castro Valley, Ca. (SF bay area) ________________________________________________________________________________
Date: Jun 02, 2001
Subject: 24v battery tester
Bob, I am looking at page 2-9 figure 2-4 of your Aeroelectric Connection and I am wondering what needs to be changed to make it work for 24 volt batteries. The clock would be the same. The relay would either have to be rated for 24v or I would have to figure out what resistor to put in series with the coil. Questions: Would the same transister work? Are the 470 ohm resisters matched to the zener or the 55w lamp? Would they have to be different for a 24 volt battery and load? What about if the I used a different load? Say, a 100w landing light? Are zeners available in 20 or 21 volt versions or is there an easy way to make they work at other volatages? What watt rating does the zener need? Thanks in advance. Dan Rogers ________________________________________________________________________________
Date: Jun 04, 2001
Subject: Re: Back from the IA
> >...With a small problem. As you may know, I'm going to be installing a >GNS-430 in my Sundowner. > > An IFR GPS like the 430 is installed with two FAA 337 forms. The first >form ( which the FSDO has just stamped & signed ) is considered >the VFR approval. It covers the basic installation of the equipment, >and certifies that you used proper wiring techniques, the right breakers, >the right mechanical mounting, cooling, etc etc. After >the first 337 is executed, the airplane is again airworthy for VFR >purposes, but the GPS is not approved for IFR. > > With the newly airworthy plane, a flight test is accomplished, >verifying that the GPS is adequate for IFR. A second 337 is filed, >certificating that the GPS passed the flight test. > > The problem is with the second 337. My IA won't touch it. >His liability insurance doesn't cover flying airplanes in connection >with his airplane repair business. He doesn't have to fly the airplane. He only needs to dictate a flight test ("go fly these approaches and flips all these knobs and flip these switches" . . . you don't even need to be under a hood or have a safety pilot but putting a second person in the right seat doesn't hurt). Would he ride with you in your airplane while you fly? His task is not to evaluate anyone's ability to fly or even the ability of your airplane to fly. He's interested in whether or not the equipment performs as expected while flying. For this you go out to an airport with low traffic with published approaches. Shoot the approaches heads up an note that the airplane bores a reasonable hole in the sky on it's way toward the end of the runway. While running down the "ILS" you key up transmitters on various frequencies at 1 Mhz intervals, run blower motors, run flaps up and down, cycle other electrical goodies in the airplane to see if they have any observable effect on what the radio is telling you to do with respect to flying the approach. He doesn't have to touch the controls of the airplane or tell you to do anything while in flight . . . only observe the effects of actions called out in your flight test plan. In fact, he doesn't even have to personally observe the test. If he helps develop a test plan and you go fly it with another pilot observer, he only needs to trust your collective judgement that the unit performs as expected. Why would anyone LIE TO HIM if it doesn't work right? His responsibility is to help you cover all the bases to uncover potential problems and then approve the system when no problems are discovered. He's really making this MUCH more complicated than it needs to be. Bob . . . ________________________________________________________________________________
Date: Jun 04, 2001
Date: Jun 04, 2001
Subject: Who did Nuckolls say makes engraved panels?
Date: Jun 05, 2001
11:12:39 AM Bob Nuckolls mentioned an outfit that'll make custom engraved panels for switches and whatnot. I think he said they're laminated plexiglass, engraved from behind. Is that written up somewhere? ________________________________________________________________________________
Date: Jun 05, 2001
Subject: Re: Who did Nuckolls say makes engraved panels?
Try aircraft engravers at http://www.engravers.net Bruce Glasair III Steve Williams wrote: > > Bob Nuckolls mentioned an outfit that'll make custom engraved panels for > switches and whatnot. I think he said they're laminated plexiglass, > engraved from behind. Is that written up somewhere? > ________________________________________________________________________________
Date: Jun 05, 2001
Subject: Re: Alt. b-lead fuseable link
> >Bob, > > Do you recommend that the fuse be put in the cockpit area of an RV-6? It can be if your starter contactor is in the cockpit too . . . I prefer and recommend mounting the contactor on the forward side of the firewall so that the fuse can go out there and the always hot feeder between battery master and starter contactor can be used to bring alternator power into the system. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 05, 2001
> Bob Nuckolls mentioned an outfit that'll make custom engraved panels for > switches and whatnot. I think he said they're laminated plexiglass, > engraved from behind. Is that written up somewhere? You can also try Panel Pilot http://members.aol.com/PANELCUT/ Steve is a great guy. Ross ________________________________________________________________________________
Date: Jun 05, 2001
> Try aircraft engravers at http://www.engravers.net > > > > Bob Nuckolls mentioned an outfit that'll make custom > engraved panels for > > switches and whatnot. I think he said they're laminated plexiglass, > > engraved from behind. Is that written up somewhere? Here are a couple others (don't know if they were mentioned by Bob). Engraved from behind: http://www.aeroengraving.com/ Looks like engraving only from the front: http://www.aeronorthwest.com/ Bill Cox recently wrote about his own Mooney in Plane&Pilot (April '01 at p. 37). His panel is backside-engraved wood by Hal Pflueger. (800) 256-6845 or hpflueger(at)aol.com. I saw this at Golden West last summer -- looks REALLY nice. My personal taste leans toward the clean/industrial look of grey or beige like those shown at aeroengraving.com, though. Regards, Jim Ivey jim(at)iveylaw.com Oakland, CA ________________________________________________________________________________
Subject: 3 pin connector
Date: Jun 05, 2001
I have a 3 pin connector on my Turn coordinator and I want to hook it up. The label says A-pos, B-neg, C-open. How do I determine the orientation of A & B? The notch is on top and the pins are shaped like an inverted triangle, 2 pins horizontally across the top and one pin below. Thank you, Ed Perry eperry(at)san.rr.com ________________________________________________________________________________
Date: Jun 05, 2001
Subject: Re: 3 pin connector
Ed. Pin A is on the right, pin B is in the center at the bottom (opposite the notch), pin C is on the left. check for continuity between pins B and C, mine has them tied together. Use a magnifying glass and a strong light, look into the connector the pins are labeled on the black gasket. It is very hard to see though. Ed. Sadler pebvjs(at)aol.com ________________________________________________________________________________
Date: Jun 05, 2001
Thank You. The flashlight verified the locations. You are correct. Ed Perry eperry(at)san.rr.com ----- Original Message ----- From: <Pebvjs(at)aol.com> Sent: Tuesday, June 05, 2001 1:51 PM Subject: Re: AeroElectric-List: 3 pin connector > > Ed. > Pin A is on the right, pin B is in the center at the bottom (opposite the > notch), pin C is on the left. check for continuity between pins B and C, mine > has them tied together. Use a magnifying glass and a strong light, look into > the connector the pins are labeled on the black gasket. It is very hard to > see though. > Ed. Sadler pebvjs(at)aol.com > > ________________________________________________________________________________
Date: Jun 06, 2001
Bob, Putting the starter contactor in the engine compartment will dictate that a load style ammeter must be used. I do prefer the +_ auto type, but am willing to forgo that for system simplicity. It also results in an un-fused hot wire going through the firewall (master contactor to starter contactor). What type of firewall feed thru do you recommend? A hole in thin stainless with a grommet on it to protect a heavy current carrying always hot wire (when the master contactor is closed) doesn't meet my long term safety requirements. If the alternator fuse is in the engine compartment, what are your preferences concerning how it is mounted? Fred Stucklen N925RV (1730 hrs/7.75 Yrs) E. Windsor, CT 06088 WK Email: stuckle(at)ifc.utc.com Hm/Travel Email: wstucklen1(at)juno.com ____ From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com> Subject: Re: AeroElectric-List: Alt. b-lead fuseable link IFC" > >Bob, > > Do you recommend that the fuse be put in the cockpit area of an RV-6? It can be if your starter contactor is in the cockpit too . . . I prefer and recommend mounting the contactor on the forward side of the firewall so that the fuse can go out there and the always hot feeder between battery master and starter contactor can be used to bring alternator power into the system. Bob . . . ________________________________________________________________________________
Date: Jun 06, 2001
> >Bob, > > Putting the starter contactor in the engine compartment will dictate that >a load style ammeter must be used. I do prefer the +_ auto type, but am >willing to forgo that for system simplicity. Understand . . . but I think the loadmeter when combined with a voltmeter (which you need anyhow for battery only operations) will give you a clearer picture of system condition. > It also results in an un-fused hot wire going through the firewall >(master contactor to starter contactor). What type of firewall feed thru do >you recommend? A hole in thin stainless with a grommet on it to protect a >heavy current carrying always hot wire (when the master contactor is closed) >doesn't meet my long term safety requirements. Been done for decades on hundreds of thousands of airplanes. Running a main feeder through a grommet that's properly shielded on the engine side is pretty rudimentary technology. I'd add a layer of fire-putty over the grommet shield on the engine side. The bonanza uses a 90-degree flanged elbow with about 1" i.d. to bring most wires through the firewall. The elbow is on the engine side of the firewall. A piece of firesleeve and two stainless steel clamps are used to close the open end of the transition tightly around the bundle. This technique has been tested in Bad Jack's house of horrible tortures and shown to take 2000 degrees open flame for a long time. > If the alternator fuse is in the engine compartment, what are your >preferences concerning how it is mounted? As an in-line fuse with wires attached to both ends and heat shrink over the whole. Our b-lead fuse kit is supplied with all the necessary heat shrinks. You CAN put the starter contactor inside . . . and bring the alternator b-lead through instead of the always hot feed to the starter contactor . . . the b-lead fuse is to protect the b-lead from BATTERY current . . . not alternator current. Bob . . . ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Fwd: Crowbars
> >This month's KP column is on crowbars. I'm going to do the opamp version as >opposed to the NPN-PNP crosscoupled way you did it...but do you mind if I >use the rather brilliant scheme you have for testing in the airplane using >lantern batteries in series with the airplane battery? I'll give you >credit, of course. Take care that you insure LOTS of gate drive to the SCR. The reason for cross-coupled transistors is to simulate the 4-layer trigger diodes that are now impossible to find in low voltage versions. The op-amp version can be more accurate in terms of setting trip point . . . but accuracy is not a strong virtue in ov protection. ANYTHING over 16 and less than 17 is fine. >I have absolutely no idea what SCR I'm going to use; I only have one in >inventory and I'll probably use it. I know it is a Teccor, but I don't >remember which version I used in the other application I had -- I can't even >remember if it is logic level or sensitive gate. If it is the same number >as yours, I promise I didn't steal it from you. It just shows what good >design sense we both have {;-) The MCR69 series devices from MOT have been tested and used in our production OV modules for hundreds of airplanes . . . low cost and plenty robust. Still need to reply on your offer to supply Microair product. I've been out of town last week and have a ton of catch-up . . . I think I wasn't clear as to the exact nature of your offer. I'll try to get to it later today. Fly comfortably . . . Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 06, 2001
panels? > >Bob Nuckolls mentioned an outfit that'll make custom engraved panels for >switches and whatnot. I think he said they're laminated plexiglass, >engraved from behind. Is that written up somewhere? My personal favorite source of engraved panels is offered by Werner Berry who has a website at: http://www.aeroengraving.com/ Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 06, 2001
Subject: Re: A Wire Query
>I am just beginning my construction of a Europa Trigear and while I know >it will be a while before I actually need it, I bought a copy of >Aeroelectric Connection and have enjoyed reading it. I wonder if I might >ask your opinion about choosing an insulation system. Most homebuilders >seem to promote tefzel, and it is the only system available from AC >Spruce, etc. From what I hear however the military and airliners are >moving away from tefzel due to flammability, toxicity of combustion >products, and relatively poor abrasion resistance. The new darling >seems to be TKT. > >Is this a tempest in a teapot in your opinion or should I try to find a >source for small quantities of TKT (which a web search failed at!). 60 years ago we wired airplanes with cotton covered rubber and it smelled really bad when it burned, made lots of smoke and fungus would munch it. What's more, it would pretty much fall off the wires after 30 years or so. 40 years ago we got PVC with nylon jacket over it. It too smelled bad, made lots of smoke . . . at least the fungus wouldn't eat it. The nylon got brittle and fell off after 20 years or so but the PVC hung in there better than rubber. 30 years ago we got teflon. It still smelled bad, made lots of poisonous smoke but at least it didn't get brittle and break off. It also had EXCELLENT temperature characteristics. However, it's extrusion temperatures were so high that we had to put it over silver plated wire. Expensive. The stuff was kinda soft and stripped with difficulty. 20 years ago tefzel came along and it smelled bad, made lots of somewhat less toxic smoke but was much more abrasion resistant. It stripped cleaner than teflon and extruded onto wires at lower temperatures so silver plating wasn't necessary. Still has excellent performance at temperatures and is readily available at low cost. Hmmm . . . 20 years is a LONG time . . . the wire manufacturers are probably scrambling around trying to justify yet another new wire . . . but I bet it still smells bad, smokes a lot and will initially be harder to find and more expensive. The FAA is paid to worry and airlines fall right in line behind them . . . after all, who could be AGAINST making the safest transportation in the universe yet more safe? The bottom line is that only certified aircraft suffer electrical emergencies by regulatory decree. There is no reason for an owner built and maintained aircraft to even get a wire real hot much less smoke it. We're allowed to evolve our designs and FIX our aircraft when a problem is identified. If it were my airplane and had an unlimited expense account with which to build it, I'd still go tefzel all the way with the possible exception of a few pieces of very flexible welding cable at choice spots for enhanced maintenance. Bob . . . --------------------------------------------------- ( "Teaching should be such that what is offered ) ( is perceived as a valuable gift and not as a ) ( hard duty ." Albert Einstein ) -------------------------------------------------- http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 06, 2001
01:05:32 PM Thanks, Bob. Can you provide a bit more deatil about the engraved panels you described at your seminar in Watsonville? Werner Berry's web site doesn't offer a lot of detail on his products and services. If I were to call him, I wouldn't know exactly what to ask for. Also, you made some suggestions for applications of his stuff. Not just switch legends, but also blind annunciators? ________________________________________________________________________________
Date: Jun 06, 2001
> > >Thanks, Bob. > >Can you provide a bit more deatil about the engraved panels you described >at your seminar in Watsonville? Sure . . . Werner offers reverse engraved panels with a satin finish, lexan front surface. VERY resistant to scratching and showing fingerprints. Panel color is a function of a plastic layer laminated to the back of the lexan. Engraving is accomplished from behind. You may fill the letters with any color of paint so that the lettering viewed from the front are colored. -OR- you may leave the lettering unfilled. You can then place colored gells between the back side of the placard and an illumination source to provide brilliant, saturated colors of illuminated lettering that essentially disappears (dead front) when illumination is off. >Werner Berry's web site doesn't offer a lot of detail on his products and >services. If I were to call him, I wouldn't know exactly what to ask for. > >Also, you made some suggestions for applications of his stuff. Not just >switch legends, but also blind annunciators? He can build parts of about any needed size ranging from whole panel overlays or placards for individual groupings of controls. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 06, 2001
> > He doesn't have to fly the airplane. He only needs to dictate > a flight test ("go fly these approaches and flips all these > knobs and flip these switches" . . . you don't even need *** Yes, that's exactly what the inspector at the FSDO told me. I figured to go one step at a time. Once I get the thing installed and signed off VFR, I at least have an airworthy airplane. Then I can go back to the FSDO and work up an IFR approval sequence, have the IA talk to the inspector, see if he can be convinced. If not, go to another IA. Absolute last resort, fly the airplane to the shop in the midwest where I bought the radio. Now there is another snag - in the first, VFR 337. In the text of that 337, I promise to verify that the altitude reporting system still works - after hooking the GPS up to it, and installing isolation diodes in series with the transponder inputs. The IA is freaking out over this, says he's not a static-pitot guy, what am I asking him to sign? I was going to have the avionics shop on the field do this, but they're pretty busy, and have made it obvious that I am VERY low on their list of priorities ( I don't spend much money ). I think that if I get a static/pitot IFR cert done, he'll be comfortable - even though it doesn't need it. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: Panel legends
Date: Jun 06, 2001
Interesting, all this stuff about panel overlays... however, I've decided to go for stick on legends on a painted panel (Europa) so what I would like is laser cut, backed lettering to spec, rather like stick on Reg letters (or numbers) but in 12-24 pt. Possibly even as paint masks... So far, I haven't found anyone who can do it that small - anyone got any bright ideas? Miles ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 9 Msgs - 06/06/01
From: "Richard Deciero" <Richard_Deciero(at)raytheon.com>
Date: Jun 07, 2001
06/07/2001 08:13:52 AM Fred, I labored over the same question of safely getting the big, hot wire through the firewall. My solution was to spin out a nylon bushing with a 5/8 ID, 7/8 OD and a head on it about 1 1/8 dia x .1 thick. Smooth out the ends of the holes to a nice rounded edge. The bushing is secured to the firewall with a -14 DG clamp and that is all bolted to a right angle bracket that is riveted to the firewall. There are nylon bulkhead bushings available from aircraft spruce (see page 374 of their latest catalog). I found these after I made my own. I would recommend a minimum of a 3/4 ID. Also I opted not to use an ammeter. I feel that a volt meter is adequate to monitor the electrical system when used in conjunction with the B & C voltage regulator. The regulator will alert me to an charging system failure via the supplied warning light when the voltage from the bus drops off of approx 13.8 volts, and my volt meter has an adjustable warning light system that I will set at maybe 11 volts. With these two redundant warning systems and the E-bus concept I feel confident in managing an electrical system failure to a successful uneventful conclusion. I have not installed a vacuum system and have planned to use electric gyro's when I am done flying off my certification. Dual 17ah AGM batteries are being used with one LSE electronic ignition. My airplane is an IFR equipped Murphy Rebel and I hope to fly it this fall. I am experimenting with high brightness LED's for warning lights. They provide more than adequate visibility even in direct sunlight. Also check out the article in Kitplanes March 2001 regarding panel lighting. It utilizes Superbright LED's and offers very low current drain and long life. Maybe I can get rid of the large light dimmer that I already installed. Most of my electrical design and philosophy was developed in conjunction with the Bingilis books, AC43, and most importantly the AeroElectric Connection book. The E-bus concept was totally new to me until I read The AEROELECTRIC Connection. Absolutly essential reading for anyone building an airplane or even flying certified birds. And once again I must commend and encourage Bob Nuckolls on his contribution to us all in the flying community. His tireless efforts have benefited many I am sure. We are lucky to have him on our side. I have also read some of the constructive criticism regarding his book and was happy to read his post regarding how he will address some of those issues. No book has all of the answers and will not tell you how to wire your plane wire for wire. You must read, read, and then read some more in order for us non electric types to understand enough to get through the electrical system design. Good luck, Rick D. Hudson, MA ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: Panel legends
Aerographics, at 4221 W. Eisenhower BLVD., Loveland, Colorado 80537; ph. (970) 461-2057, or 1-800-336-9633, are the only folks that I have found able to do the small sized computer-cut adhesive placards we need, and do a superb job. Excellent work and value, and very experienced. Ask for Marilyn. ________________________________________________________________________________
Date: Jun 07, 2001
> > Now there is another snag - in the first, VFR 337. In the text of that >337, I promise to verify that the altitude reporting system still works - >after hooking the GPS up to it, and installing isolation diodes in series >with the transponder inputs. The IA is freaking out over this, says he's >not a static-pitot guy, what am I asking him to sign? I was going to have >the avionics shop on the field do this, but they're pretty busy, and have >made it obvious that I am VERY low on their list of priorities ( I don't >spend much money ). What you NEED is a gizmo like http://www.airsport-corp.com/ifrvfdinfo.html that reports what your transponder is telling the ground with respect to your real altitude. This can be used in conjunction with a pitot-static test set on the ground to exercise the system over the full range of interest . . . or used in the air to see that altitudes reported translate smoothly in 100' increments as you fly to your service ceiling. Either way, this device requires no electrical connection to the airplane. I've called the folks at Airsport and they're going to see if they can do me a deal on a box that can't be sold but is suitably functional. I can keep it around here for rent/loan to folks who are wrestling with the Big Bear . . . Won't know for a couple of days but will let you and the list know what I find out. Some of you may want to consider buying this product as an accessory to your airplane . . . check out the website. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Subject: Wot, no kapton?
Date: Jun 07, 2001
Bob: "60 years ago ............cotton covered rubber " "40 years ago we got PVC " "30 years ago we got teflon" "20 years ago tefzel came along " What about Kapton? Isn't that what a lot of us are riding around on? (Just curious) Ferg Europa #A064 ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Mag Switches
For Charles Brame (who started this thread) or anyone intersted , I have two pair of "THE best mag switches" available for sale . These are Microswitch P/N 111AT25. They are less than one half inch wide so can be mounted one inch apart on center & still be easily operated together w/ thumb & index finger. They are three position : Down (off) is locked , must pull out to move to "on" (center position) which is also a locked position, pull out again to move to momentary "start" (top position) , when released from "start" position lever returns to "on" (center position) . These are new switches (factory pressed in nylon locknuts are virgin , never seen threads). The switch assy contains two microswitches : each individually replacable (readily available & about$4 ea) by drilling out two rivets , each rated @ 5 amps w/ one set each normally open & normally closed contacts. The sad , comical , disgusting part is that they "LIST" for $256 each from Microswitch. Thats the price of all that Mil Specing , certifying stuff ! I will sell the switches I have for $100 each if anyone is building "that" worthy of a Starship that they must have them ! See attachment for photo . Respond on or off the list if interested. Chris. ________________________________________________________________________________
Subject: RE: Wigwag with Galls Flasher
Date: Jun 07, 2001
3 questions 1. The green lead from the Galls unit is grounded to G3 PNL (what does this stand for?) 2. Where can one obtains a Gall Traffic Flasher? 3. I have a local electronics store that stocks lots of "diodes", what specs do I need to look for for mounting in this setup? Sorry for the basic questions and thanks, Chris Cartwright Menlo Park,CA ________________________________________________________________________________
Date: Jun 07, 2001
> >Bob: > "60 years ago ............cotton covered rubber " > "40 years ago we got PVC " > "30 years ago we got teflon" > "20 years ago tefzel came along " >What about Kapton? Isn't that what a lot of us are riding around on? >(Just curious) Ferg Europa #A064 Oh yeah . . . some guy was trying to sell me that stuff for the GP-180 about 20 years ago. We considered it until we got some feedback on unhappy experiences in some military programs. I was surprised to hear later that anyone was using it in volume. It's a neat, very thin and relatively tough insulation but it doesn't seem to survive well in the aircraft environment. See: http://www.iasa.com.au/twaletter.html http://www.pleo.com/dupont/kapton.htm http://www.vision.net.au/~apaterson/aviation/kapton_mangold.htm In spite of it's apparent popularity with some manufacturers I've never considered it as a serious contender in the Wiring Hall of Fame as the-best-we-knew-how-to-do at-the-time. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 07, 2001
From: Graham Singleton <grasingleton(at)avnet.co.uk>
Subject: Re: Wot, no kapton?
> >Bob: > "60 years ago ............cotton covered rubber " > "40 years ago we got PVC " > "30 years ago we got teflon" > "20 years ago tefzel came along " >What about Kapton? Isn't that what a lot of us are riding around on? >(Just curious) Ferg Europa #A064 Most airliner builders have banned Kapton because it explodes if provoked, ( a Swissair DC10 caught fire and crashed due to a wiring problem behind the panel if memory is working properly) Certainly the USAF have banned it's use. Graham ________________________________________________________________________________
Date: Jun 07, 2001
> What you NEED is a gizmo like > > http://www.airsport-corp.com/ifrvfdinfo.html > ** Yeah, I was already thinking about that. > that reports what your transponder is telling the > ground with respect to your real altitude. This can > be used in conjunction with a pitot-static test set > on the ground to exercise the system over the full > range of interest . . . *** Pitot-static test set? That's not a vacuum pump, is it? Here's a plan I came up with: I hook up a mity-vac to the static port. Pull the lever - the altimeter starts to wind up. I call the tower - things are pretty peaceful early in the morning - "Hi, I've just invented this virtual vertical takeoff machine. Could you look at your scope and tell me where I've got to?" - Jerry Kaidor ( jerry(at)tr2.com ) or used in the air to see that > altitudes reported translate smoothly in 100' increments > as you fly to your service ceiling. Either way, this > device requires no electrical connection to the airplane. > > I've called the folks at Airsport and they're going > to see if they can do me a deal on a box that can't be > sold but is suitably functional. I can keep it around > here for rent/loan to folks who are wrestling with > the Big Bear . . . > > Won't know for a couple of days but will let you and > the list know what I find out. Some of you may want > to consider buying this product as an accessory to > your airplane . . . check out the website. > > > Bob . . . > > ( An inventor is simply a person who doesn't take his education ) > ( too seriously. We often say that the biggest job we have is ) > ( to teach a newly hired employee how to fail intelligently. ) > ( We have to train him to experiment over and over and to keep ) > ( on trying and failing until he learns what will work. ) > ( Charles Kettering ) > http://www.aeroelectric.com > > > > > > > ________________________________________________________________________________
Date: Jun 07, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com>
"mustangaero(at)yahoogroups.com" , plugs up rotary list , Rotary list , RV list , thorplist , aeroelectric list
Subject: Get a (cheap) charge out of this
I think I may have a tip to offer the more uhh, frugal among us. While searching the shelves for plexi working tools at our local Harbor Freight outlet, I took a long hard look at their version of the little rechargable 'jump start' packages everyone seems to own these days. The box says 17 amp. Sounds familiar. It says 400 amp starting power. Sounds optimistic, but... Weight is listed as 19 lbs for the package. Hmmmm.... So, I brought one home & took the back off. Guess what's inside. There are couple of #4 cables (1 red & 1 black) just about the right length to reach a master contactor. And a rather cheap looking (and costs less) 0-15 V voltmeter. And an AC trickle-charger. And several cigar lighter connectors which I bet could be used for something, *and*, even a little floodlight which might work as an emergency panel light. All these goodies for less than $40. Oh, by the way, there's also that funny little black box that weighs around 14 lbs. It looks suspiciously like some rather expensive jetski batteries I've been reading about lately, just without anyone's name on the black case. I hope someone finds this useful. Charlie RV-4 sold RV2+2 bought, working on a new windshield ________________________________________________________________________________
Date: Jun 07, 2001
Subject: Re: RE: Wigwag with Galls Flasher
Chris, You could install a WigWag Solid State Controller. The Gall's Flasher was designed for installation in a police car. A police car that is already wired. The Galls Flasher has been designed to work with the factory wiring already in place in the police car. But, this makes for a very strange wiring installation in an airplane because the airplane does not have wires routed like the factory cars. If you want to add to the circuit other features, this gets very annoying. For example, making the leading edge light's 12 volt power redundant. Bill Benedict preached that the leading edge lights should be redundant. That a fault in one light circuit should not make the other light unusable. It would be unfortunate to have a wire short in one wing and land in the dark because you did not build a redundant 12 volt power system. It is most unfortunate to land in the dark with one good light. The WigWag Solid State Controller has a redundant 12 volt power design. To make the Galls redundant, I had to add two more relays in addition to the relays in the Galls. The result was that, accounting for all the components, the Galls real cost was more than the price of the WigWag. The Galls Flasher flashes at more than twice the a rate that should be used to optimizes your plane's noticeabilitiy. The rate should be slow enough that the filament in the un-powered bulb stops glowing. That means the other bulb has gotten to full bright which is important for being seen in day light. This results in the point of light appearing to jump from one wing tip to the other. We are trained to react to motion. There are many other features available with the WigWag Solid State Controller such as using different types of switches and arranging these switches so that they perform the exact functions you would like to have in your airplane. For more information, go to http://easystreet.com/~bhaan/ to see a picture, the data sheets, the installation guide and several application notes for different switch types and configurations.. Or ask me to send you the 1490K Adobe acrobat file for these documents. > > >3 questions >1. The green lead from the Galls unit is grounded to G3 PNL (what does this >stand for?) >2.c >============================================== Bob Haan http://easystreet.com/~bhaan/ bhaan(at)easystreet.com Portland, OR RV6A 24461 Wiring the panel ________________________________________________________________________________
Date: Jun 08, 2001
> >> What you NEED is a gizmo like >> >> http://www.airsport-corp.com/ifrvfdinfo.html >> >** Yeah, I was already thinking about that. > >> that reports what your transponder is telling the >> ground with respect to your real altitude. This can >> be used in conjunction with a pitot-static test set >> on the ground to exercise the system over the full >> range of interest . . . > >*** Pitot-static test set? That's not a vacuum pump, is it? >Here's a plan I came up with: > > I hook up a mity-vac to the static port. Pull the lever - the >altimeter starts to wind up. I call the tower - things are pretty >peaceful early in the morning - "Hi, I've just invented this virtual >vertical takeoff machine. Could you look at your scope and tell me >where I've got to?" That'll work too. The biggest concern for "accurate and intact wiring" is to make sure that not only does the value reported by the transponder roughly (+/- 100 ft) agree with your altimeter (set for 29.92) but that ALL increments of 100' are seen . . . that is, no missing values. The coding of digital data between the encoder and transponder is designed so that missing codes will show up as some pretty gross errors. > - Jerry Kaidor ( jerry(at)tr2.com ) > > > Bob . . . ________________________________________________________________________________
Date: Jun 08, 2001
Subject: Re: Wigwag with Galls Flasher
> >3 questions >1. The green lead from the Galls unit is grounded to G3 PNL (what does this >stand for?) This goes to ground. The term "PNL" is used on most of our wiring diagrams to denote a common ground bus behind the panel. We recommend: http://www.aeroelectric.com/Catalog/wiring/wiring.html#gndblk >2. Where can one obtains a Gall Traffic Flasher? See: http://www.galls.com/shop/viewProductDetail.jsp?item=FS033 This is the model I tested for development of the wiring diagrams at: http://www.aeroelectric.com/articles/gallsww.pdf and http://www.aeroelectric.com/articles/galls2ww.pdf >3. I have a local electronics store that stocks lots of "diodes", what specs >do I need to look for for mounting in this setup? See http://www.aeroelectric.com/Catalog/wiring/wiring.html#S401-25 click on larger image and print the photo. The part is so UNcritical that ANY device that looks like this on will do. Radio shack used to stock one like it (diode bridge assembly good for about 25A at 50v or more). >Sorry for the basic questions and thanks, >Chris Cartwright >Menlo Park,CA No problem. With respect to debatable issues on the Galls options: (1) the need to "optimize" the flash rate for visibility encompasses two issues. (a) actual rate of flashing and (b) how bright the lamps get on each flashing cycle. For warning lights, the general rule of thumb for attention getting is 3 flashes per second . . . 3 flashes/second does not allow big bulbs to cycle over their maximum range of full bright to invisible light output. Exactly what IS optimal for wig-wags using the various high intensity lamps with respect to the ergonomics of human perception could be hotly debated . . . I aware of no documented studies on this question. An anecdotal data point suggests that when the policeman pulls up behind you with his Galls system in operation, he's very hard to ignore much less miss entirely for lack of "optimized" performance. (2) both diagrams depicted for use of the Galls flasher make normal operation of each lamp completely independent of failures in the opposite lamp system -or- the Galls flasher assembly. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 08, 2001
> > I hook up a mity-vac to the static port. Pull the lever - the > >altimeter starts to wind up. I call the tower - things are pretty > >peaceful early in the morning - "Hi, I've just invented this virtual > >vertical takeoff machine. Could you look at your scope and tell me > >where I've got to?" > > That'll work too. The biggest concern for "accurate and *** Uh, no it won't. I finished my project today - after 70 hours of work. My aches have aches. The plane is all together. The weight & balance is done. Heck, I even made up a sticker for the logbook entry! ...But the IA won't sign. Nope, he sure won't. No matter what test I accomplish on that transponder - even if I taught it to sit up and speak French, he wouldn't sign. Doesn't know anything about transponders, doesn't WANT to know anything about transponders. Just wants to see a logbook entry from a sanctified static/pitot/transponder person. No logbook entry, no washee. Period. And the on-field avionics shop says they can't get me in the queue for at least a week. Heck, with the amount of stuff they've got sitting in front of the shop, a week sounds optimistic. Anybody know of a traveling static-pitot guy in Northern California? - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jun 08, 2001
Can you get a ferry permit and go to another field/shop? > > ...But the IA won't sign. Nope, he sure won't. No matter > what test I > accomplish on that transponder - even if I taught it to sit up and > speak French, he wouldn't sign. Doesn't know anything about > transponders, > doesn't WANT to know anything about transponders. Just wants to see > a logbook entry from a sanctified static/pitot/transponder person. No > logbook entry, no washee. Period. > > And the on-field avionics shop says they can't get me in > the queue > for at least a week. Heck, with the amount of stuff they've > got sitting > in front of the shop, a week sounds optimistic. > > Anybody know of a traveling static-pitot guy in Northern > California? > > - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jun 10, 2001
Subject: Re: wire description
>Hi Bob, > >I have aquired for a good price 1000 feet of 22759 / 7 - 6 wire. I am sure >it is good quality but I can find no reference to / 7 in the lists of 22759 >wire you gave links to the other day. Can you point me in the right >direction. I think this stuff is pure Teflon as opposed to Tefzel. I can only find brief chunks of the ratings out on the net, I'll need to wait until Monday when I can get access to the detail specs from my desk at RAC. However, given that the brief specs call this stuff "TFE" with a 200C operating temperature, I'm 99% certain that it's Teflon. Tefzel is tougher and is called "ETFE" with a rating of only 150C. Also, you say it's /7-6? 6AWG wire? Pretty hefty stuff. >I have also noted that in the Raychem catalogue for spec 55 wire they >describe wire as "airframe " or "hookup" but the working voltage and the >temperature rating are the same ( the insulation is thinner for hookup than >airframe ) can you describe what the criteria wold be to enable the use of >hookup rather than airframe. It would seem to me that in a well protected >harness, particularly in a non conductive structure like a Long EZ that >there should be no problem with using the hookup wire for everything, but >maybe I am missing something and besides I value your opinion. I use spec 55 wire in some of my programs . . . not sure as to the specific part numbers but the insulation is about the same thickness as the 22759/16 that is in very common usage in general aviation. If you have a choice and the price differential isn't great, I'd go for the heavier insulation. I encourage my builders here in US to go to Aircraft Spruce, or some other retailer of the "good" stuff and pay retail if necessary . . . you won't spend $100 on enough wire to do the whole airplane and there is little risk in knowing exactly what you're getting. I'll check out the detail 22759 spec Monday . . . might see if I can get a .pdf copy to post on my website. Good info for the troops to have access to. Bob . . . ________________________________________________________________________________
Subject: Hi-temp wire ties
Date: Jun 10, 2001
Bob, Do you know of a source of hi-temp wire ties, suitable for use forward of the firewall? Lots of folks seem to think that the black nylon ones are OK, but their temp specs are the same, they're just treated for UV resistance for outdoor use. It's clumsy to use Adel clamps all over the place, and the stainless ties want to cut into insulation. Jim Cameron Lancair ES Builder ________________________________________________________________________________
From: "Jesse Kluijfhout, PE1RUI" <jessevli(at)zeelandnet.nl>
Subject: Re: Hi-temp wire ties
Date: Jun 10, 2001
Hi Jim, Your right. At my work as A&P I see a lot of white and black wire ties. They are fine in front of the fire wall as long as you keep some space (few inches) between the exhaust and youre wire ties. Its better for the ties and for youre cable. If you mount them too close to the exhaust they will damage youre cable as they tend to meld into the cables. I once had the same with wiring near the exhaust prevented to chaving with spiralex, but the spiralex (I dont know if thats the correct word) melded and made a short circuit in the cables. Just be carefull when routing youre cable. Regards, Jesse ----- Original Message ----- From: "J. N. Cameron" <toucan@the-i.net> Sent: Sunday, June 10, 2001 4:03 PM Subject: AeroElectric-List: Hi-temp wire ties <toucan@the-i.net> > > Bob, > > Do you know of a source of hi-temp wire ties, suitable for use forward > of the firewall? Lots of folks seem to think that the black nylon ones are > OK, but their temp specs are the same, they're just treated for UV > resistance for outdoor use. It's clumsy to use Adel clamps all over the > place, and the stainless ties want to cut into insulation. > > Jim Cameron > Lancair ES Builder > > ________________________________________________________________________________
Date: Jun 10, 2001
Jim, I was out looking over the C-17 production line a few weeks ago. Got a chance to look at the engine as delivered from the factory. Alot of the wire bundles routed about the engine were neatly tied off with cording. It looked very neat and tidy, if not a little old fashioned. Sometimes the old ways are hard to beat. John ... > Do you know of a source of hi-temp wire ties, suitable for use forward >of the firewall? Lots of folks seem to think that the black nylon ones are >OK, but their temp specs are the same, they're just treated for UV >resistance for outdoor use. It's clumsy to use Adel clamps all over the >place, and the stainless ties want to cut into insulation. >Jim Cameron >Lancair ES Builder ________________________________________________________________________________
Date: Jun 10, 2001
Subject: Telephone wire
My son has a large roll of telephone cable containing eight (twisted pairs?) color coded wires. It just so happens I have eight wires going to the tail of my RV-6 (six to the MAC trim unit and two to the tail light.) The cable is convenient, light weight, and free. Is there any reason NOT to use it in an airplane? Charlie Brame RV-6AQB - Canopy San Antonio ________________________________________________________________________________
Date: Jun 10, 2001
> >Bob, > > Do you know of a source of hi-temp wire ties, suitable for use forward >of the firewall? Lots of folks seem to think that the black nylon ones are >OK, but their temp specs are the same, they're just treated for UV >resistance for outdoor use. It's clumsy to use Adel clamps all over the >place, and the stainless ties want to cut into insulation. > >Jim Cameron >Lancair ES Builder Ties treated for superior UV resistance are either black or dark green. You're right, the material's temperature ratings remain unchanged. You can buy ties made of Tefzel . . . but they're about $1 each. The plain-vanilla ties work pretty good under the cowl. It's going to be hydrocarbon fumes and ozone that will attack them more than gross temperature. I've seen the plain vanilla ties used very successfully under the cowl . . you just have to snip them off and replace them every annual. An easy, low cost alternative to super-ties. If you want a wire bundling methodology that has stood the test of time in the field, buy some Dacron flat-lace . . . I prefer the waxed variety over the lacquered . . When you mentioned Adel clamps . . . I presume you're also wanting ties that have mounting bases on them to secure bundles to structure. I wouldn't use ANY plastic device for this job. If the bundle needs mechanical security to airframe, the Adel clamp is the only way to go. Individual string or nylon ties are fine for holding bundle shape but not for mechanical support. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 10, 2001
Subject: Re: Telephone wire
> >My son has a large roll of telephone cable containing eight (twisted >pairs?) color coded wires. It just so happens I have eight wires going >to the tail of my RV-6 (six to the MAC trim unit and two to the tail >light.) The cable is convenient, light weight, and free. Is there any >reason NOT to use it in an airplane? Most telephone cable is single strand wire and pvc insulation. I don't recommend it. Ya just can't beat a nicely tied bundle of Tefzel for price and performance in your airplane. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 10, 2001
> Do you know of a source of hi-temp wire ties, suitable for use forward > of the firewall http://www.terminaltown.com/ - I ordered some but they don't seem to be in stock yet. Gary K. ________________________________________________________________________________
Date: Jun 10, 2001
I'm gonna jump in here. Telephone wire tends to get crumbly and fragile in uncontrolled temperature environments. I've ended up replacing phone lines in a couple houses that was wired just fine, but aged and developed breaks in the insulation, then started shorting. I'd think that would just accelerate in a plane. Bill "Robert L. Nuckolls, III" wrote: > > > > >My son has a large roll of telephone cable containing eight (twisted > >pairs?) color coded wires. It just so happens I have eight wires going > >to the tail of my RV-6 (six to the MAC trim unit and two to the tail > >light.) The cable is convenient, light weight, and free. Is there any > >reason NOT to use it in an airplane? > Most telephone cable is single strand wire and pvc insulation. > I don't recommend it. Ya just can't beat a nicely tied > bundle of Tefzel for price and performance in your airplane. > > Bob . . . > > ( An inventor is simply a person who doesn't take his education ) > ( too seriously. We often say that the biggest job we have is ) > ( to teach a newly hired employee how to fail intelligently. ) > ( We have to train him to experiment over and over and to keep ) > ( on trying and failing until he learns what will work. ) > ( Charles Kettering ) > http://www.aeroelectric.com > ________________________________________________________________________________
Date: Jun 10, 2001
Doesn't anyone use Koroseal lacing anymore? It's still available and approved as a substitute for clamps anywhere on the aircraft. ----- Original Message ----- From: John W Livingston <jliving(at)erinet.com> Sent: Sunday, June 10, 2001 8:46 AM Subject: RE: AeroElectric-List: Hi-temp wire ties > > Jim, > > I was out looking over the C-17 production line a few weeks ago. Got a > chance to look at the engine as delivered from the factory. Alot of the wire > bundles routed about the engine were neatly tied off with cording. It looked > very neat and tidy, if not a little old fashioned. Sometimes the old ways > are hard to beat. > > John > > > ... > > Do you know of a source of hi-temp wire ties, suitable for use forward > >of the firewall? Lots of folks seem to think that the black nylon ones are > >OK, but their temp specs are the same, they're just treated for UV > >resistance for outdoor use. It's clumsy to use Adel clamps all over the > >place, and the stainless ties want to cut into insulation. > > >Jim Cameron > >Lancair ES Builder > > ________________________________________________________________________________
From: "James K. Glindemann" <jglind(at)netspace.net.au>
Date: Jun 11, 2001
"ETFE" with a rating of only 150C. Also, you say > it's /7-6? 6AWG wire? Pretty hefty stuff. It is 6AWG > > >I have also noted that in the Raychem catalogue for spec 55 wire they > >describe wire as "airframe " or "hookup" but the working voltage and the > >temperature rating are the same ( the insulation is thinner for hookup than > >airframe ) can you describe what the criteria wold be to enable the use of > >hookup rather than airframe. It would seem to me that in a well protected > >harness, particularly in a non conductive structure like a Long EZ that > >there should be no problem with using the hookup wire for everything, but > >maybe I am missing something and besides I value your opinion. > > I use spec 55 wire in some of my programs . . . not > sure as to the specific part numbers but the insulation > is about the same thickness as the 22759/16 that is > in very common usage in general aviation. If you have > a choice and the price differential isn't great, I'd > go for the heavier insulation. The wire I am refering to here is 22759/33 which I have also aquired large quantities of (many thousands of feet), mostly 28, 26, 24,22 and 20 guages. I am not planning on using the 28 or 26 on the aircraft except maybe inside boxes for various units I will be making up ( that is what experimental is all about ) The only reason I mentioned the Raychem spec 55 is that that was where I found the reference to "hookup" for 22759/33 as opposed to "airframe", Best regards James K Glindemann ________________________________________________________________________________
Date: Jun 10, 2001
Thread-Topic: AeroElectric-List: Re: Hi-temp wire ties Thread-Index: AcDx1KfXV4WnnR36RS+6Z5Pumbp0igAONNRg
Check out the mcmaster-carr catalog (www.mcmaster.com), page 702. They have 100 packs of 4" tefzel zip ties for $12.75. Their service is excellent, too. Bob Japundza RV-6 N244BJ O-360C/S flying 155 hours > -----Original Message----- > From: Robert L. Nuckolls, III [mailto:nuckolls(at)aeroelectric.com] > Sent: Sunday, June 10, 2001 12:18 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Hi-temp wire ties > > > III" > > <toucan@the-i.net> > > > >Bob, > > > > Do you know of a source of hi-temp wire ties, suitable > for use forward > >of the firewall? Lots of folks seem to think that the black > nylon ones are > >OK, but their temp specs are the same, they're just treated for UV > >resistance for outdoor use. It's clumsy to use Adel clamps > all over the > >place, and the stainless ties want to cut into insulation. > > > >Jim Cameron > >Lancair ES Builder > > Ties treated for superior UV resistance are either > black or dark green. You're right, the material's > temperature ratings remain unchanged. You can buy > ties made of Tefzel . . . but they're about $1 each. > > The plain-vanilla ties work pretty good under the cowl. > It's going to be hydrocarbon fumes and ozone that will > attack them more than gross temperature. I've seen > the plain vanilla ties used very successfully under > the cowl . . you just have to snip them off and replace > them every annual. An easy, low cost alternative > to super-ties. > > If you want a wire bundling methodology that has > stood the test of time in the field, buy some Dacron > flat-lace . . . I prefer the waxed variety over the > lacquered . . > > When you mentioned Adel clamps . . . I presume you're > also wanting ties that have mounting bases on them > to secure bundles to structure. I wouldn't use > ANY plastic device for this job. If the bundle > needs mechanical security to airframe, the Adel > clamp is the only way to go. Individual string or > nylon ties are fine for holding bundle shape but > not for mechanical support. > > > Bob . . . > > ( An inventor is simply a person who doesn't take his education ) > ( too seriously. We often say that the biggest job we have is ) > ( to teach a newly hired employee how to fail intelligently. ) > ( We have to train him to experiment over and over and to keep ) > ( on trying and failing until he learns what will work. ) > ( Charles Kettering ) > http://www.aeroelectric.com > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2001
Thread-Topic: AeroElectric-List: Telephone wire Thread-Index: AcDx1TLywcbfsOqCQtGoARgqICus7QAOaL+w
Charlie, Don't use it unless it's stranded. You can go down to your local radio shack and pick up some ethernet CAT5 patch cord; it's stranded and is the same gauge as the MAC servo wiring, and has the same color-coding for the wires. Just clip the RG-45 ends off the patch cord and you're in business. They sell them in in various lengths. Radio shack also carries small crimp splices that also work well for wiring the MAC servos. I wouldn't advise using the same cable for the tail position light. Bob Japundza RV-6 N244BJ O-360C/S flying 155 hours > -----Original Message----- > From: Charles Brame [mailto:charleyb(at)earthlink.net] > Sent: Sunday, June 10, 2001 12:02 PM > To: AeroElectric List > Subject: AeroElectric-List: Telephone wire > > > > > My son has a large roll of telephone cable containing eight (twisted > pairs?) color coded wires. It just so happens I have eight wires going > to the tail of my RV-6 (six to the MAC trim unit and two to the tail > light.) The cable is convenient, light weight, and free. Is there any > reason NOT to use it in an airplane? > > Charlie Brame > RV-6AQB - Canopy > San Antonio > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2001
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Bob; The page you cite at McMaster-Carr does indeed list tefzel cable ties in various sizes, but you will notice a red asterisk next to the price indicating the package size to be 25 not 100 as are most of the other materials. (Not meaning to be picky, just trying to keep the record straight.) Bob McC > >Check out the mcmaster-carr catalog (www.mcmaster.com), page 702. They >have 100 packs of 4" tefzel zip ties for $12.75. Their service is >excellent, too. >Bob Japundza >RV-6 N244BJ O-360C/S flying 155 hours ________________________________________________________________________________
Date: Jun 10, 2001
Thread-Topic: AeroElectric-List: Re: Hi-temp wire ties Thread-Index: AcDyHPi4gTeCoAcrTIyEVD/P8JYfHAAA9Fgg
Hi Bob, You are correct. I should have paid more attention to the fine print! FWIW, when I installed the wiring in the engine compartment I opted for the fireproof ties on the same page. My biggest concern was not having anything up front that would support combustion. They've been holding up well, especially on the wiring that passes under the cylinders to the alternator. I did a burn test on them and they melted, but didn't catch on fire as advertised. Bob Japundza RV-6 N244BJ O-360C/S flying 155 hours > -----Original Message----- > From: Robert McCallum [mailto:robert.mccallum2(at)sympatico.ca] > Sent: Sunday, June 10, 2001 9:02 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Hi-temp wire ties > > > > > Bob; > > The page you cite at McMaster-Carr does indeed list tefzel > cable ties in > various sizes, but you will notice a red asterisk next to the price > indicating the package size to be 25 not 100 as are most of the other > materials. (Not meaning to be picky, just trying to keep the record > straight.) > > Bob McC > > > > > > >Check out the mcmaster-carr catalog (www.mcmaster.com), page > 702. They > > >have 100 packs of 4" tefzel zip ties for $12.75. Their service is > >excellent, too. > > >Bob Japundza > >RV-6 N244BJ O-360C/S flying 155 hours > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2001
----- Original Message ----- From: J. N. Cameron <toucan@the-i.net> Sent: Sunday, June 10, 2001 09:03 Subject: AeroElectric-List: Hi-temp wire ties <toucan@the-i.net> > > Bob, > > Do you know of a source of hi-temp wire ties, suitable for use forward > of the firewall? www.terminaltown.com has 3-3/4" and 7" tefzel cable ties in stock. $8.40 per 20 for the 3-3/4" and $17.60 per 20 for the 7". Gaylen Lerohl Terminaltown.com ________________________________________________________________________________
Date: Jun 11, 2001
> > >"ETFE" with a rating of only 150C. Also, you say >> it's /7-6? 6AWG wire? Pretty hefty stuff. > >It is 6AWG Hmmmm . . . 1000' of that stuff will wire a LOT of airplanes. About the only place you'd use that gage of wire would be between the alternator b-lead terminal and the starter contactor . . . and from starter contactor to main bus . . . perhaps 6-8' of wire per airplane. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 11, 2001
> >I'm gonna jump in here. Telephone wire tends to get crumbly and fragile in uncontrolled >temperature environments. I've ended up replacing phone lines in a couple houses that was wired >just fine, but aged and developed breaks in the insulation, then started shorting. I'd think that >would just accelerate in a plane. > >Bill Exactly . . . PVC does that. Someone else suggested some Cat5 network cable as being stranded conductors and perhaps more suited . . . except it it's STILL PVC. Please folks, we're building the best airplanes to have ever flown . . . as long as we don't regress to the 1960's when PVC was the best we knew how to do back then . . . Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 11, 2001
Subject: RE: Hi-temp wire ties
> >Check out the mcmaster-carr catalog (www.mcmaster.com), page 702. They >have 100 packs of 4" tefzel zip ties for $12.75. Their service is >excellent, too. These are much lower cost . . . about $.50 each after you adjust for the package size of 25 pieces. Not too bad. Here's Newark's listing of lacing tapes: http://www.newark.com/C118_modules/6285.html Also LC140 and LC143 tapes from Allied here: http://www.alliedelec.com/catalog/pf.asp?FN=300.pdf Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Subject: Airmap 100 antenna
Date: Jun 11, 2001
I'm in need of a new coax connector for the external antenna cable for my Lowrance Airmap 100. Does anyone know what style it is ( ie, Type F, TNC, etc.)? This is for the connection on the back of the GPS unit. Lowrance wants $100 for a complete molded assy. which includes the antenna. Thanks, Stan Blanton RV-6 ________________________________________________________________________________
Date: Jun 11, 2001
Subject: Raychem Polyswitch polyfuses
In the July issue of Kitplanes, pg 5, Lisa Jones from Tyco electronics categorically states that the Polyswitch polyfuses "are not tested for, nor will they be tested for true FAA approvals" and also says "We believe that your article may lead the reader to believe that Polyswitch resettable fuses are appropriate for use in the application you discuss, and we do not recommend our products for this use. Please do not encourage your readers to use our products believing the information in the article is accurate or that we are working toward FAA approvals." That's enough for me, I guess. She also points out that putting the polyfuses "in parallel does not yield twice the amperage protection as is proposed in the article." Too bad she didn't explain why about any of this - if it's just liability CYA, then I understand that. If there is an engineering reason, that would be useful information, too. Sigh. Makes me wonder about "intended purpose" and FAA approval" for automotive type fuses, too. Gary Liming ________________________________________________________________________________
Subject: Re: Raychem Polyswitch polyfuses
Date: Jun 11, 2001
> > > She also points out that putting the polyfuses "in parallel does not yield > twice the amperage protection as is proposed in the article." > > Too bad she didn't explain why about any of this - if it's just liability > CYA, then I understand that. If there is an engineering reason, that would > be useful information, too. *** I would guess that there is no way to guarantee equal current sharing between the two parallelled fuses - unless they hold the internal resistance of the fuse to a tight tolerance. If the fuses resistances are not equal, one of them will "hog" the current. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jun 11, 2001
> between the two parallelled fuses - unless they hold the internal resistance > of the fuse to a tight tolerance. If the fuses resistances are not equal, > one of them will "hog" the current. Time for something like mesh currents etc??? If the fuses resistances are not accurate won't the fuse ratings also be off.? At any rate, it sounds like a hokie* setup. (* don't read this - go pound your rivets! -- There was once a tractor manufacturer named Hoke - his product did fare well in the market as the weird design made forward viewing of such things as rows of crops nearly impossible. I wonder if that is the origin of "hokey"?) Hal Kempthorne RV6a N7HK (Valentine) FLYING ________________________________________________________________________________
Date: Jun 11, 2001
None of the cat 5 wire I've ever seen was stranded. It's all twisted pairs of solid copper of about 22 ga. The high number of twists per foot make it less likely to induce noise from other pairs (there's 8 pair in the cable) and that's why computer networks use it. It's also good, if not overkill, for telephone. I have plenty of it laying around, but don't intend to use it in my airplane. Ed Holyoke General building contractor RV-6 QB ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com> Sent: Monday, June 11, 2001 7:42 AM Subject: AeroElectric-List: Re: Telephone wire > > > > >I'm gonna jump in here. Telephone wire tends to get crumbly and fragile in uncontrolled > >temperature environments. I've ended up replacing phone lines in a couple houses that was wired > >just fine, but aged and developed breaks in the insulation, then started shorting. I'd think that > >would just accelerate in a plane. > > > >Bill > > Exactly . . . PVC does that. Someone else suggested some > Cat5 network cable as being stranded conductors and > perhaps more suited . . . except it it's STILL PVC. > Please folks, we're building the best airplanes to > have ever flown . . . as long as we don't regress to > the 1960's when PVC was the best we knew how to do > back then . . . > > > Bob . . . > > ( An inventor is simply a person who doesn't take his education ) > ( too seriously. We often say that the biggest job we have is ) > ( to teach a newly hired employee how to fail intelligently. ) > ( We have to train him to experiment over and over and to keep ) > ( on trying and failing until he learns what will work. ) > ( Charles Kettering ) > http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 11, 2001
Opps... Make that 4 pair. ----- Original Message ----- From: "Ed Holyoke" <bicyclop(at)pacbell.net> Sent: Monday, June 11, 2001 5:36 PM Subject: Re: AeroElectric-List: Re: Telephone wire > > None of the cat 5 wire I've ever seen was stranded. It's all twisted pairs > of solid copper of about 22 ga. The high number of twists per foot make it > less likely to induce noise from other pairs (there's 8 pair in the cable) > and that's why computer networks use it. It's also good, if not overkill, > for telephone. I have plenty of it laying around, but don't intend to use it > in my airplane. > > Ed Holyoke > General building contractor > RV-6 QB > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com> > To: > Sent: Monday, June 11, 2001 7:42 AM > Subject: AeroElectric-List: Re: Telephone wire > > > > > > > > > > > >I'm gonna jump in here. Telephone wire tends to get crumbly and fragile > in uncontrolled > > >temperature environments. I've ended up replacing phone lines in a > couple houses that was wired > > >just fine, but aged and developed breaks in the insulation, then started > shorting. I'd think that > > >would just accelerate in a plane. > > > > > >Bill > > > > Exactly . . . PVC does that. Someone else suggested some > > Cat5 network cable as being stranded conductors and > > perhaps more suited . . . except it it's STILL PVC. > > Please folks, we're building the best airplanes to > > have ever flown . . . as long as we don't regress to > > the 1960's when PVC was the best we knew how to do > > back then . . . > > > > > > Bob . . . > > ________________________________________________________________________________
Date: Jun 12, 2001
Subject: Eliminating Switch Contact Noise Generation
I have a Lancair 320 with a gear hydraulic system using pressure switches the fluid circuits to activate high current carrying relays which ulitmately energize the pump. A recently installed "newer generation" hi pressure switch (1200 psi) oozes closed as the pressure drops and introduces a 1 or 1.5 second burst of noise thru the radio as the contacts come together before the pump actually runs. This noise is isolated to the switch by pulling the gear system circuit breaker in flight, waiting for the pressure to bleed down and completely close the pressure switch contacts followed by closing the breaker to witness only a blip of pump activity with no radio noise. Even though the switch action may be bad, is there a simple electronic "fix" in the contact circuitry to eliminate contact make/break noise? Will the contacts eventually become useless because of carbon buildup due to arcing? Thanks, Scott Krueger N92EX ________________________________________________________________________________
Date: Jun 12, 2001
Subject: Re: Eliminating Switch Contact Noise
Generation > >I have a Lancair 320 with a gear hydraulic system using pressure switches the >fluid circuits to activate high current carrying relays which ulitmately >energize the pump. A recently installed "newer generation" hi pressure >switch (1200 psi) oozes closed as the pressure drops and introduces a 1 or >1.5 second burst of noise thru the radio as the contacts come together before >the pump actually runs. This noise is isolated to the switch by pulling the >gear system circuit breaker in flight, waiting for the pressure to bleed down >and completely close the pressure switch contacts followed by closing the >breaker to witness only a blip of pump activity with no radio noise. > >Even though the switch action may be bad, is there a simple electronic "fix" >in the contact circuitry to eliminate contact make/break noise? Will the >contacts eventually become useless because of carbon buildup due to arcing? > >Thanks, >Scott Krueger >N92EX Your concerns are valid . . . a switch that takes so long to "tease" closed is subject to accelerated electrical wear. First suggestion is to find a switch with a better snap action. There are LOTS of pressure switch manufacturers. There has to be a better part out there. Second, you could use some sort of electronic circuity between the switch and it's loads to eliminate the noise by reducing the current through the switch. However, this adds to parts count and drives reliability down. As I recall, those switches drive intermittent duty contactors . . . which may have high coil current requirements. Do you know the resistance of the coils on these contactors? Do you have a make and part number on the switch that's giving you problems? Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 12, 2001
> >In the July issue of Kitplanes, pg 5, Lisa Jones from Tyco electronics >categorically states that the Polyswitch polyfuses "are not tested for, nor >will they be tested for true FAA approvals" and also says "We believe that >your article may lead the reader to believe that Polyswitch resettable >fuses are appropriate for use in the application you discuss, and we do not >recommend our products for this use. Please do not encourage your readers >to use our products believing the information in the article is accurate or >that we are working toward FAA approvals." > >That's enough for me, I guess. > >She also points out that putting the polyfuses "in parallel does not yield >twice the amperage protection as is proposed in the article." > >Too bad she didn't explain why about any of this - if it's just liability >CYA, then I understand that. If there is an engineering reason, that would >be useful information, too. Sigh. Makes me wonder about "intended purpose" >and FAA approval" for automotive type fuses, too. First, the FAA doesn't "approve" any particular part for use on aircraft. An aircraft manufacturer can propose to use ANY part it chooses in it's basic design and the FAA will then approve the design. There are no doubt many Polyfuse type products in service inside appliances that are approved . . . automotive ATC style fuses can be found in some of the new Cessnas too . . . At Raytheon, I'm aware of at least three different attempts over the past 20 years to consider polyfuses for inclusion into our designs . . . to date, I'm aware of no takers on any of RAC/Beechcraft products. That doesn't mean that the polyfuse doesn't work as the data says it's supposed to. Decisions for NOT using them have to include performance, installation ease, reliability, cost/performance as compared to alternatives, maintainability, customer acceptance, etc, etc. Enthusiastic supporters of the polyfuse as replacement for breakers and fuses have concentrated on specifications only and brushed aside or ignored all the details that boil down to "total cost of ownership and is it worth it for the perceived performance?". It took me 15-20 years to appreciate the scope of consideration required to craft the elegant design. I'm still looking for a combination of parts that will top the cost/performance of the fuse-block/toggle-switch combination of power distribution and control. When I find it, you folks will be the first ones to hear about it. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 12, 2001
Subject: Re: Airmap 100 antenna
> >I'm in need of a new coax connector for the external antenna cable for my >Lowrance Airmap 100. Does anyone know what style it is ( ie, Type F, TNC, >etc.)? This is for the connection on the back of the GPS unit. Lowrance >wants $100 for a complete molded assy. which includes the antenna. > >Thanks, > >Stan Blanton >RV-6 I need to see the connector or a good picture of it. Do you have a damaged one you can send me? Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 12, 2001
> > > > > >In the July issue of Kitplanes, pg 5, Lisa Jones from Tyco electronics > >categorically states that the Polyswitch polyfuses "are not tested for, nor > >will they be tested for true FAA approvals" and also says "We believe that > >your article may lead the reader to believe that Polyswitch resettable > >fuses are appropriate for use in the application you discuss, and we do not > >recommend our products for this use. Please do not encourage your readers > >to use our products believing the information in the article is accurate or > >that we are working toward FAA approvals." > > > >That's enough for me, I guess. > > > >She also points out that putting the polyfuses "in parallel does not yield > >twice the amperage protection as is proposed in the article." > > > >Too bad she didn't explain why about any of this - if it's just liability > >CYA, then I understand that. If there is an engineering reason, that would > >be useful information, too. Sigh. Makes me wonder about "intended purpose" > >and FAA approval" for automotive type fuses, too. > > First, the FAA doesn't "approve" any particular part > for use on aircraft. An aircraft manufacturer can propose > to use ANY part it chooses in it's basic design and the > FAA will then approve the design. There are no doubt > many Polyfuse type products in service inside appliances > that are approved . . . automotive ATC style fuses can > be found in some of the new Cessnas too . . . I wonder why the Tyco representative got it wrong. Especially to come out and deny their part for use like that. Most companies welcome new uses for their product. > At Raytheon, I'm aware of at least three different attempts > over the past 20 years to consider polyfuses for inclusion > into our designs . . . to date, I'm aware of no takers > on any of RAC/Beechcraft products. That doesn't mean that the > polyfuse doesn't work as the > data says it's supposed to. Decisions for NOT using them > have to include performance, installation ease, reliability, > cost/performance as compared to alternatives, maintainability, > customer acceptance, etc, etc. Enthusiastic supporters of > the polyfuse as replacement for breakers and fuses have > concentrated on specifications only and brushed aside or > ignored all the details that boil down to "total cost of > ownership and is it worth it for the perceived performance?". I still can't quite agree with that, though. If you are going to have a pc board power controller, fuses are much clumsier to use than polyfuses and this very much includes "total cost of ownership and is it worth it for the perceived performance? For many of the considerations listed above, I think (according to the companies' published specs) polyfuses gets the nod. I couldn't easily find any firm reliability numbers on the ATC fuse/fuse block combo, though, I would like to - its not in the Aeroelectric Connection) I think a pc board controller could make sense - I can't say I'm wild about the idea of an ov module(a pc board itself) hanging out there on a skyhook, for one. I am trying add a consideration, not ignore some - perhaps not so relevant to commercial aircraft with its AP brotherhood, but adding the consideration of maintainability to the list of factors for owner built and maintained aircraft is important, I think. However, I am not going to use a part when a company spokesperson has stated its a bad idea, even if she apparently doesn't understand the approval process. Should some spokesperson for fuse companies come out and state they are not recommended for aircraft use, I guess I won't use them either, even if they are hidden inside a Cessna. I just wish I knew why they say what they say. Is it really just that there is not enough sales volume to justify the liability? > It took me 15-20 years to appreciate the > scope of consideration required to craft the elegant > design. I'm still looking for a combination of > parts that will top the cost/performance of the > fuse-block/toggle-switch combination of power > distribution and control. When I find it, you folks > will be the first ones to hear about it. That's why I am going with many of your ideas, even though I might disagree with the argumentation from time to time. Most of what I see I do really appreciate and will use. Gary Liming ________________________________________________________________________________
Date: Jun 12, 2001
Subject: Battery suggestions
Hello Aeroelectric list, I am researching to buy a battery for my Pulsar project. I have the 3300 cc Jabiru 6 cylinder engine. Jabiru recommends a 20ah battery. I found that Digikey offers a 20ah panasonic SLA for $47. B&C has a 20ah for $124. I can't tell that the panasonic is any worse than the B&C. Anyone have any recommendations? Thanks, Ned ________________________________________________________________________________
From: "David A. Leonard" <dleonar1(at)maine.rr.com>
Subject: Re: AeroElectric-List Digest: 9 Msgs - 06/11/01
Date: Jun 12, 2001
Once again, I find myself turning to the "amateur" gorup for infomation none of the "certicicated" people seem to have! Glad I found this list! One of the Bellanca group guys posted this <<<<>>> Anyone know the answer? C'mon guys..make me look good here! Thanks, Dave Leonard ________________________________________________________________________________
Subject: 6v relay source
Date: Jun 12, 2001
Once again, I find myself turning to the "amateur" group for information none of the "certificated" people seem to have! Glad I found this list! One of the Bellanca group guys posted this <<<<>>> Anyone know the answer? C'mon guys..make me look good here! Thanks, Dave Leonard ________________________________________________________________________________
Date: Jun 12, 2001
----- Original Message ----- From: "David A. Leonard" <dleonar1(at)maine.rr.com> Sent: Tuesday, June 12, 2001 8:18 PM Subject: AeroElectric-List: Re: AeroElectric-List Digest: 9 Msgs - 06/11/01 > > Once again, I find myself turning to the "amateur" gorup for infomation none > of the "certicicated" people seem to have! Glad I found this list! > > One of the Bellanca group guys posted this > > > <<<< Date: Mon, 11 Jun 2001 11:56:55 EDT > From: CRQVikingPilot(at)aol.com > Subject: Relay > > Hey has anyone been able to find the 6V relay that senses the alternator has > failed and illuminates the warning light? My 1971 SV has a malfunctioning > one that keeps the light on all the time the engine is running. My mechanic > called Bellanca and they are not returning calls and Millers said it isn't > available>>>> > > > Anyone know the answer? > > C'mon guys..make me look good here! > > Thanks, > > Dave Leonard > > Try any of the electronic supply houses, Digikey, Mouser, etc. Digikey has a 5 volt coil SPST, NO contacts rated at 6amps Part#PB353ND $6.22 Try them. As a better alternative get their catalog and pick your own relay. There are lots of 5volt relays that would work and you can always put a resistance in series with the operating coil to bring the 6 volts down to the specified 5 volts. Ian Crowe ________________________________________________________________________________
Date: Jun 12, 2001
Subject: re: switch configuration
Bob How would I wire a situation where I want 4 items to have separate breakers, but I would like 1 switch to turn them all on/off? They have different breaker requirements. Jim ________________________________________________________________________________
Subject: Raychem PolySwitch Prohibition in Aircraft ?
Date: Jun 13, 2001
From: Gary Liming <gary(at)liming.org> Subject: AeroElectric-List: Raychem Polyswitch polyfuses >In the July issue of Kitplanes, pg 5, Lisa Jones from Tyco electronics categorically states that the Polyswitch polyfuses "are not tested for, nor will they be tested for true FAA approvals"...She also points out that putting the polyfuses "in parallel does not yield twice the amperage protection as is proposed in the article."...Too bad she didn't explain why about any of this - if it's just liability CYA, then I understand that. If there is an engineering reason, that would be useful information, too. Sigh. Makes me wonder about "intended purpose" and FAA approval" for automotive type fuses, too. Gary Liming< Raychem's own Application Notes show how to account for parallel Polyswitch operation. Essentially the problem is that self-heating of parallel Polyswitches can significantly alters device behavior. Two thermally isolated Polyswitches - ie Polyswitches that don't heat each other - behave like two separate Polyswitches. Equal-valued thermally isolated Polyswitches operating in parallel will have double the hold current and half the resistance. However, when two Polyswitches are not thermally isolated - ie when they are too close together - they interact, and change their behavior in complex ways. I don't see anything in Raychem's Polyswitch datasheets or App notes that would prohibit operation in aircraft, but the overall impression is that Polyswitches are not simply plug-in replacements for fuses. Polyswitch characteristics are highly dependent on thermal conditions surrounding the Polyswitch circuitry - airflow, ambient temperature, heat sinks, etc, so that Polyswitch behavior in any given circuitry is difficult to predict without substantial testing or modeling. Worse yet, Polyswitch performance may not be closely repeatable between production batches. Even a single Polyswitch has hysteresis - its own characteristics change after the first trip. My guess is that Raychem wants to avoid being seen as encouraging aviation use of the Polyswitch for these reasons. Also, Raychem has the usual litigation paranoia: their App Note on medical applications strongly cautions against using the Polyswitch in any situation where failure of the Polyswitch "may reasonably be expected to cause" the failure of the system or affect its safety. Given the lunatic judgments civil juries award these days, Raychem has to protect itself as best it can. -Vaso ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Date: Jun 13, 2001
Subject: AeroElectric-List: Raychem Polyswitch polyfuses >I don't see anything in Raychem's Polyswitch datasheets or App notes that >would prohibit operation in aircraft, Raychem doesn't have the authority to prohibit their use in aircraft. They can say they don't want any part of it, and even refuse to sell to anyone with aircraft in their name as some company's have done, but the FAA can approve whatever design has been shown to meet their interpretation of the regs. >but the overall impression is that Polyswitches are not simply >plug-in replacements for fuses. Exactly. In order to prevent nuisance tripping, you size the polyfuse according to it's hold current at the hot end of the operating environment. The wire then must be sized according to the polyfuse's trip current at the cold end of the operating environment. This may result in having to use wire that is larger than a fuse or circuit breaker would demand. In the certificated world, trying to plug and play in place of a fuse would most likely not meet the requirements of 23.1357: (c) Each resettable circuit protective device ("trip free" device in which the tripping mechanism cannot be overridden by the operating control) must be designed so that -- (1) A manual operation is required to restore service after tripping; David Swartzendruber Not building yet Wichita ________________________________________________________________________________
Date: Jun 13, 2001
From: Wesley & Susan Knettle <wsknettl(at)centurytel.net>
Subject: RE: Tygo Electric's Polyfuse
Gary "In the July issue of Kitplanes, pg 5, Lisa Jones from Tyco electronics > >categorically states that the Polyswitch polyfuses "are not tested for, nor > >will they be tested for true FAA approvals" and also says "We believe that > >your article may lead the reader to believe that Polyswitch resettable > >fuses are appropriate for use in the application you discuss, and we do not > >recommend our products for this use. Please do not encourage your readers > >to use our products believing the information in the article is accurate or > >that we are working toward FAA approvals." " Bob is correct on manufacturers of certificated aircraft do use and include these products in their aircraft. The FAA approves the aircraft's type design but the OEM (Cessna, Beech etc) assume the liability. Lisa is correct about securing FAA approval in that her company could request a PMA (Parts Manufacturer Approval) from the FAA. Lisa is also correct in voicing her company's legal position. Very few companies are willing to throw their resources into today's frivolous suit happy environment. It is our legal system stymying modernization of our industry.The FAA, OEMs, A&P's and IA's are only reacting to the high cost of protecting their livlyhoods from the legal aggressors. ________________________________________________________________________________
Date: Jun 13, 2001
Subject: Re: Battery suggestions
> >Hello Aeroelectric list, > >I am researching to buy a battery for my Pulsar project. I have the 3300 cc >Jabiru 6 cylinder engine. Jabiru recommends a 20ah battery. I found that Digikey >offers a 20ah panasonic SLA for $47. B&C has a 20ah for $124. I can't tell that >the panasonic is any worse than the B&C. Anyone have any recommendations? > >Thanks, >Ned Probably 90% of the airplanes flying and under construction can make good use of the 17-20 a.h. devices in the 3 x 6 x 6.5 inch format. LOTS of manufacturers build batteries in this form factor and a.h. range for reasonable prices. I would not depart from this class of battery without strong design and operation goals dictating the change. These batteries are excellent value and performance. I'd go with the Panasonic/Powersonic/Yuasa/etc.etc. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 13, 2001
Subject: Re: Polyswitch polyfuses
> >> First, the FAA doesn't "approve" any particular part >> for use on aircraft. An aircraft manufacturer can propose >> to use ANY part it chooses in it's basic design and the >> FAA will then approve the design. There are no doubt >> many Polyfuse type products in service inside appliances >> that are approved . . . automotive ATC style fuses can >> be found in some of the new Cessnas too . . . > >I wonder why the Tyco representative got it wrong. Especially to come out >and deny their part for use like that. Most companies welcome new uses for >their product. How many people do you know that really UNDERSTANDS how government agencies work? Most companies would very much like to cater to any customer that can make good use of their product . . . but when faced with a predatory Trial Lawyers Assn looking to retire on their next "win" -AND- you work for a company with deep pockets, you use other than trash barrel lids or paper weights. The easiest thing to do is "prohibit" your products use in certain venues . . . of course it may find its way into any product through open market distribution. Some corporate lawyers find solace in being able to claim that their product was, "used in a manner contrary to corporate policy." >> At Raytheon, I'm aware of at least three different attempts >> over the past 20 years to consider polyfuses for inclusion >> into our designs . . . to date, I'm aware of no takers >> on any of RAC/Beechcraft products. That doesn't mean that the >> polyfuse doesn't work as the >> data says it's supposed to. Decisions for NOT using them >> have to include performance, installation ease, reliability, >> cost/performance as compared to alternatives, maintainability, >> customer acceptance, etc, etc. Enthusiastic supporters of >> the polyfuse as replacement for breakers and fuses have >> concentrated on specifications only and brushed aside or >> ignored all the details that boil down to "total cost of >> ownership and is it worth it for the perceived performance?". > >I still can't quite agree with that, though. If you are going to have a pc >board power controller, fuses are much clumsier to use than polyfuses and >this very much includes "total cost of ownership and is it worth it for the >perceived performance? For many of the considerations listed above, I >think (according to the companies' published specs) polyfuses gets the >nod. I couldn't easily find any firm reliability numbers on the ATC >fuse/fuse block combo, though, I would like to - its not in the >Aeroelectric Connection) . . . and it never will be. Published "reliability" numbers are by-and-large a pap for those who would try to put order into our lives by regulatory decree. Most people who wield these numbers to drive your design decisions have no knowledge of how your system works or how your customer should be educated to use it. If you design for failure tolerance and use parts with a wide range of choices for features, then your system is free to evolved as you see fit without hazard to your health and welfare. >I think a pc board controller could make sense - I >can't say I'm wild about the idea of an ov module(a pc board itself) >hanging out there on a skyhook, for one. Why? What is the failure mode for a 5 gm device tied into a wire bundle with string or a tye-wrap? > . . . . I am trying add a consideration, >not ignore some - perhaps not so relevant to commercial aircraft with its >AP brotherhood, but adding the consideration of maintainability to the list >of factors for owner built and maintained aircraft is important, I think. > >However, I am not going to use a part when a company spokesperson has >stated its a bad idea, even if she apparently doesn't understand the >approval process. Should some spokesperson for fuse companies come out and >state they are not recommended for aircraft use, I guess I won't use them >either, even if they are hidden inside a Cessna. I just wish I knew why >they say what they say. Is it really just that there is not enough sales >volume to justify the liability? How does the PCB controller give you and edge over the fuseblock/switch combo? You have to design and fabricate the device which now becomes unique to your aircraft. Repair and/or refurbishment parts are no longer off-the-shelf devices available from multiple sources and exchanged with ordinary hand tools. I've done some PCB controllers for clients with ATC fuses that plug onto the board with off-the-shelf sockets. Fuses don't hide latent or transient failures. The FIRST time the line is overloaded for a few tens of milliseconds, the fuse opens and the system shuts down. This is the best clue that something begs my attention. I wouldn't take ANY manufacture's word for suitability (or unsuitability) of his device for my intended design. Bottom line it is that your or my design decisions need to be accomplished with UNDERSTANDING of the task in terms of design, operation, maintenance and tolerance to failure. Nobody in his right mind would "recommend" that you use his product in any perceived high-risk environment. All he should say is, "here's a gizmo and here's what it does and here's what it costs." It's up to me to apply the part in a learned, responsible manner that meets the needs of my customer. >That's why I am going with many of your ideas, even though I might disagree >with the argumentation from time to time. Most of what I see I do really >appreciate and will use. Thank you! Bob . . . ________________________________________________________________________________
Date: Jun 13, 2001
Subject: Re: Alternator fail light on Bellanca
> >Once again, I find myself turning to the "amateur" gorup for infomation none >of the "certicicated" people seem to have! Glad I found this list! > >One of the Bellanca group guys posted this > > ><<<< Date: Mon, 11 Jun 2001 11:56:55 EDT > From: CRQVikingPilot(at)aol.com >Subject: Relay > >Hey has anyone been able to find the 6V relay that senses the alternator has >failed and illuminates the warning light? My 1971 SV has a malfunctioning >one that keeps the light on all the time the engine is running. My mechanic >called Bellanca and they are not returning calls and Millers said it isn't >available>>>> > > >Anyone know the answer? > >C'mon guys..make me look good here! This sounds like an alternator failure sensing technique used on many aircraft in the 70's and 80's. The sensing device watches the "aux" terminal of a wye-wound alternator which normally runs at about half bus voltage when the system was operating normally. Cars used this terminal to drive a field excitation relay such that the field was automatically shut down if the alternator is not spinning. There are some solid state alternatives to relays . . . I used to supply various two-transistor modules to Cessna and Beech for this purpose. 6V relays are getting VERY hard to find. 6V was a common automotive and consumer electronics voltage level 30+ years ago. The most common low voltage relay now has a 5V rating . . . some those might work. If it were MY airplane, I'd ditch the aux terminal sensor and replace it with a low volts warning light set for 13.0 volts. OR - if you can send me a copy of the wiring for the alternator failure light, I can sketch out an easy to build, solid state replacement for the relay. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 13, 2001
Subject: Re: switch configuration
> >Bob > >How would I wire a situation where I want 4 items to have separate >breakers, but I would like 1 switch to turn them all on/off? They >have different breaker requirements. > >Jim Are you sure you want all four systems to be vulnerable to failure of a single switch? There are 4-pole devices available that are about twice the width of a 2-pole. Kinda expensive. My supplier for the low cost switches doesn't show a 4-pole. I'll dig around some more and see what I can find. 4-pole devices from Microswitch are stocked catalog items with Newark and Allied . . . plan on paying about $40. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Subject: Re: RE: Tygo Electric's Polyfuse
Date: Jun 13, 2001
> > suit happy environment. It is our legal system stymying modernization of > our industry.The FAA, OEMs, A&P's and IA's are only reacting to the high > cost of protecting their livlyhoods from the legal aggressors. > *** Amen. Let's talk "high costs". My IA pays $9000/year in liability insurance! In fact, his insurance just came due, and he was making noises about getting out of the business. I hauled ass and installed my GNS430 quick while he was still around. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jun 13, 2001
In a message dated 6/13/01 6:54:51 AM Pacific Daylight Time, nuckolls(at)aeroelectric.com writes: << Probably 90% of the airplanes flying and under construction can make good use of the 17-20 a.h. devices in the 3 x 6 x 6.5 inch format. LOTS of manufacturers build batteries in this form factor and a.h. range for reasonable prices. I would not depart from this class of battery without strong design and operation goals dictating the change. These batteries are excellent value and performance. I'd go with the Panasonic/Powersonic/Yuasa/etc.etc. >> Bob: Just to make sure I understand your answer above, are you saying that the relatively inexpensive batteries made by Panasonic, etc., (compared to the Odyssey) will have adequate cranking capacity for, say, an 0-360? Harry Crosby Pleasanton, California RV-6, finish kit stuff ________________________________________________________________________________
Subject: PTT Connection
Date: Jun 13, 2001
Good Afternoon Bob, On your 403mc Audio System the white wire from the pilots PTT button is connected to the pin on the pilots mic plug. I have pre-wired most on my components and it would be convenient for me,on my installation, to connect the white wire and the red wire to pin 7 on the 403mc. Not wire the white wire from the PTT directly to the mic plug. Best regards, Bruce Bell Lubbock, Texas ________________________________________________________________________________
Date: Jun 13, 2001
> >In a message dated 6/13/01 6:54:51 AM Pacific Daylight Time, >nuckolls(at)aeroelectric.com writes: > ><< Probably 90% of the airplanes flying and under construction can make good >use of the 17-20 a.h. devices in the 3 x 6 x 6.5 inch format. LOTS of >manufacturers build batteries in this form factor and a.h. range for >reasonable prices. I would not depart from this class of battery without >strong design and operation goals dictating the change. These batteries are >excellent value and performance. I'd go with the >Panasonic/Powersonic/Yuasa/etc.etc. >> > >Bob: Just to make sure I understand your answer above, are you saying that >the relatively inexpensive batteries made by Panasonic, etc., (compared to >the Odyssey) >will have adequate cranking capacity for, say, an 0-360? You betcha. There are some VERY small batteries that will crank an engine. The BIG issue is service life and since we're going to make SURE we have enough stored capacity on board to be really useful, we'll either check the battery capacity every 6 months or simply replace the battery every annual. This philosophy lets us launch into the grey with great confidence irreseptive of how much money we spent on the battery. I'd much rather put a $50 battery in every year than try to keep close tabs on a more expensive product. My time is worth more than that. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 13, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com>
"Robert L. Nuckolls, III" wrote: > > > > > >Bob > > > >How would I wire a situation where I want 4 items to have separate > >breakers, but I would like 1 switch to turn them all on/off? They > >have different breaker requirements. > > > >Jim > Are you sure you want all four systems to be vulnerable to > failure of a single switch? There are 4-pole devices available > that are about twice the width of a 2-pole. Kinda expensive. > My supplier for the low cost switches doesn't show a 4-pole. > I'll dig around some more and see what I can find. 4-pole > devices from Microswitch are stocked catalog items with Newark > and Allied . . . plan on paying about $40. > > Bob . . . why not just wire the fuses after the single pole switch? B+ > (fuse to protect wire to switch, if desired) > switch > fuse fuse fuse fuse ________________________________________________________________________________
Date: Jun 13, 2001
> > You have to design and > fabricate the device which now becomes unique to your > aircraft. I'm doing that in just about 80% of my plane- at least that much fab, and maybe a little design - I'm building a homebuilt, not repairing a 172. > Repair and/or refurbishment parts are no > longer off-the-shelf devices available from multiple > sources and exchanged with ordinary hand tools. This is an argument often used to kill innovation. It is really just an argument for convenience, isn't it? - if I can fabricate the part myself (and have control over the quality and performance to boot) why is that bad? If I want to take on the design process myself, I will take on the process of maintenance as well. > I've done some PCB controllers for clients > with ATC fuses that plug onto the board with off-the-shelf > sockets. I would have thought that the sockets only introduced another contact to go bad. I know IC sockets are frowned on for that reason. One of the reasons that polyfuses looked good. Was pulling the fuse a requirement? > Fuses don't hide latent or transient failures. It hasn't been demonstrated that polyfuses do, either. You do state that polyfuses work as represented, but then this kind of statement confuses me. > I wouldn't take ANY manufacture's word for suitability > (or unsuitability) of his device for my intended design. I still bow to your experience, but why ignore the manufacturers input? In the medical electronics world, where there is arguably more at stake (more lives, more money, *much* more litigation, etc.) manufacturers do provide data, and designers need them to stand behind their product. > Bottom line it is that your or my design decisions > need to be accomplished with UNDERSTANDING of > the task in terms of design, operation, maintenance > and tolerance to failure. We agree on this, and it was never challenged. My previous message was wishing that the polyfuse representative had made clear why they did not recommend them for aircraft use - I was trying to understand their reasoning. Until they do, neither you or I understand their reasons for doing so, which is unfortunate. >Nobody in his right mind > would "recommend" that you use his product in any > perceived high-risk environment. I am surprised at this. Most of the medical equipment manufacturers get regulatory approval and do actively recommend their products in a high risk environment, like their intended use in surgical procedures or life support. Pharmaceutical companies recommend their drugs in a high risk environment, and get regulatory approval. They do this because no doctor in his right mind would use a product when the manufacturer actively denies its use for that purpose. (Actually, this has happened when a drug has a "side effect" that turns out to be beneficial, but the doctor gets in trouble for prescribing it until the drug is approved for that use.) I do understand an executive decision on the part of a company not to go into a particular market segment because the risk/reward ration was too large, and if that is all the announcement was, fine. I am new to the aviation field (well, I did work for McDonnell Douglas in the early seventies, toggling in boot sequences on a PDP-8!) and therefore bow to your experience, but how did the cart get turned around before the horse where aircraft designers use products their supplier won't stand behind? Was it divorce attorneys that created the adversarial relationship you are describing between supplier and product builder? > All he should say > is, "here's a gizmo and here's what it does and > here's what it costs." It's up to me to apply > the part in a learned, responsible manner that meets > the needs of my customer. I'm not sure that is all that should be said, but in this case (s)he *is* saying "we don't stand behind your decision to use this part in your design" and she is not telling you why. I don't mean to be so argumentative - I am sure we are past the dead horse stage, but I do not understand some of the things that are said, but I am trying. Gary Liming ________________________________________________________________________________
Date: Jun 14, 2001
Subject: Re: polyfuses
> > >> You have to design and >> fabricate the device which now becomes unique to your >> aircraft. > >I'm doing that in just about 80% of my plane- at least that much fab, and >maybe a little design - I'm building a homebuilt, not repairing a 172. Understand . . . and that's great if it's something you want to do and invest the time and energy on. I've had a number of builders over the years who have invested a lot of resources on their projects over and above that needed for a no-sweat, easily maintained aircraft. >> Repair and/or refurbishment parts are no >> longer off-the-shelf devices available from multiple >> sources and exchanged with ordinary hand tools. > >This is an argument often used to kill innovation. It is really just an >argument for convenience, isn't it? - if I can fabricate the part myself >(and have control over the quality and performance to boot) why is that >bad? If I want to take on the design process myself, I will take on the >process of maintenance as well. Again, more power to you sir and my best wishes for your enjoyment of both the task and the result. A goal for my readers is to help sort out the many innovations in search of those with (for lack of a better phrase) market potential. I've seen lots of one-of-a-kind aircraft at OSH and other shows that are a marvel to behold and a credit to the designer/builder's ingenuity and patience. But many will always be one-of-a-kind because the return on investment for 99% of the builders just isn't there. We work in a market where gadgetry and hype surrounding it is easy to confuse with viable product. The majority of folk reading this list don't make a living at this stuff. If I'm going to recommend that someone go out and spend hours/dollars to do a task, I have to weigh that advice against the need to build as reliable a flight system as possible in the minimum time and expense. >> I've done some PCB controllers for clients >> with ATC fuses that plug onto the board with off-the-shelf >> sockets. > >I would have thought that the sockets only introduced another contact to go >bad. I know IC sockets are frowned on for that reason. One of the reasons >that polyfuses looked good. Was pulling the fuse a requirement? > >> Fuses don't hide latent or transient failures. > >It hasn't been demonstrated that polyfuses do, either. You do state that >polyfuses work as represented, but then this kind of statement confuses me. An intermittent short or transient overload may go unnoticed for a long time with any form of self resetting circuit protection. Given that faults which cause circuit protection to be invoked are very rare (got over 1500 hours and have had only one breaker trip that was not designed into the airplane) the rational I've adopted is that I'd rather have the fuse pop on the first manifestation of the fault. >> I wouldn't take ANY manufacture's word for suitability >> (or unsuitability) of his device for my intended design. > >I still bow to your experience, but why ignore the manufacturers input? In >the medical electronics world, where there is arguably more at stake (more >lives, more money, *much* more litigation, etc.) manufacturers do provide >data, and designers need them to stand behind their product. I didn't say ignore their input, certainly they know more about how their product performs than anyone. But I've met very few gizmo peddlers that have ever had to build and airplane, certify it, teach the customer how to use it, teach the techs how to fix it and ultimately stand up to catch the rocks and bottles if some part of the system turns out to be a dog. I depend on the manufacture to tell me exactly how his gizmo works . . . whether or not it is suitable for my task is my decision alone. >>Nobody in his right mind >> would "recommend" that you use his product in any >> perceived high-risk environment. > >I am surprised at this. Most of the medical equipment manufacturers get >regulatory approval and do actively recommend their products in a high risk >environment, like their intended use in surgical procedures or life >support. Pharmaceutical companies recommend their drugs in a high risk >environment, and get regulatory approval. They do this because no doctor >in his right mind would use a product when the manufacturer actively denies >its use for that purpose. (Actually, this has happened when a drug has a >"side effect" that turns out to be beneficial, but the doctor gets in >trouble for prescribing it until the drug is approved for that use.) > >I do understand an executive decision on the part of a company not to go >into a particular market segment because the risk/reward ration was too >large, and if that is all the announcement was, fine. Like railroads (self insured) many industries build litigation and judgement expenses into the price of their products. When you sell things like food and medicine, necessary things for which there are no substitutes, the market has built in protection from predatory litigation . . . The price simply goes up and we pay it. For discretionary things like airplanes, there are no protections . . . we'll never see 16,000 production airplanes built in a single year again . . . because insurance premiums on the 16,000th airplane in one year had to cover the 100,000 or so airplanes that preceded it. Unlike food and medicines that are consumed on the spot, airplanes hung around for a long time and built a staggering liability. The market was doomed when they turned the lawyers loose. Why would anyone in his right mind "recommend" a popular product for installation on the fleet of about 130,000 aircraft? His fondest dream and worst nightmare come hand in hand. You make a ton of money for product going out the door but there are thousands of lawyers who make a damned good living finding out who's products were installed on the last airplane that crashed. >I am new to the aviation field (well, I did work for McDonnell Douglas in >the early seventies, toggling in boot sequences on a PDP-8!) and therefore >bow to your experience, but how did the cart get turned around before the >horse where aircraft designers use products their supplier won't stand >behind? Was it divorce attorneys that created the adversarial relationship >you are describing between supplier and product builder? That's one good reason, the biggest was probably the horrible notion that one can be properly "compensated" for life's risks by taking lots of money from someone who has the insurance willing to cover it. I suspect insurance companies are as culpable as the lawyers. >> All he should say >> is, "here's a gizmo and here's what it does and >> here's what it costs." It's up to me to apply >> the part in a learned, responsible manner that meets >> the needs of my customer. > >I'm not sure that is all that should be said, but in this case (s)he *is* >saying "we don't stand behind your decision to use this part in your >design" and she is not telling you why. Keep in mind that owner built and maintained aircraft are the least understood products in aviation. People like Raychem are very familiar with the certified aircraft risks . . . they grew up with them. Now, here comes a bunch of yahoos hammering hang-gliders on steroids together in their barns. "Good lord," says the CEO, "the last thing we need is a bunch of amateurs sticking OUR prized products into THEIR death traps." The Wrights were amateurs of the most professional kind. I'd like to believe that builders who take the time to exchange information on this list are equally professional. Until manufacturers like Raychem are willing educate potential customers by participating at this level of information exchange, my best recommendation to them is to maintain some corporate distance. In the mean time, it's up to folks like you and I to identify the value of any idea or product and help our brothers understand how it may meet their personal goals for maximizing performance with a minimum investment of time and cost of ownership. >I don't mean to be so argumentative - I am sure we are past the dead horse >stage, but I do not understand some of the things that are said, but I am >trying. Understand. No offense taken and I sincerely hope none is felt. I believe our missions are ultimately the same. I've suggested that the finest airplanes to have ever flown are being built in people's basements and garages. The exchange of ideas and filtering them through years of experience and good critical review can only make the product better. Bob . . . ________________________________________________________________________________
From: "Muzzy Norman E" <MuzzyNormanE(at)johndeere.com>
Subject: Batteries
Date: Jun 14, 2001
<< Probably 90% of the airplanes flying and under construction can make good use of the 17-20 a.h. devices in the 3 x 6 x 6.5 inch format. LOTS of manufacturers build batteries in this form factor and a.h. range for reasonable prices. I would not depart from this class of battery without strong design and operation goals dictating the change. These batteries are excellent value and performance. I'd go with the Panasonic/Powersonic/Yuasa/etc.etc. >> Bob: Just to make sure I understand your answer above, are you saying that the relatively inexpensive batteries made by Panasonic, etc., (compared to the Odyssey) will have adequate cranking capacity for, say, an 0-360? >>> << You betcha. There are some VERY small batteries that will crank an engine. The BIG issue is >> There are many batteries that are this exact form factor. There are also considerable differences between their ability to output sufficient current. If you are looking for a cheap battery that size, buy one from the surplus sites such as www.meci.com part number 140-0094 for $19.95! Exact same size as the battery that B&C sells, but I can tell you that the cranking performance on these is roughly proportional to the battery cost. So maybe use a cheap one to hold space and power your accessories while you are building, and then buy a real battery for flying. (I have used these batteries in some robots. I couldn't get the performance that I needed, so I put in a pair of the B&C batteries. The difference was amazing. The cheap batteries cannot deliver the current like the good batteries. So the trick is to figure out which are good and which are not.) Regards- Norm Muzzy Cozy MKIV filling and finishing! ________________________________________________________________________________
Subject: Batteries
Date: Jun 14, 2001
>So the trick is to figure out which are good and which are not.) The last time I tested one, the Panasonic did pretty well. David Swartzendruber not building yet Wichita ________________________________________________________________________________
Date: Jun 14, 2001
Subject: Re: PTT Connection
> >Good Afternoon Bob, >On your 403mc Audio System the white wire from the pilots PTT button is >connected to the pin on the pilots mic plug. I have pre-wired most on my >components and it would be convenient for me,on my installation, to connect >the white wire and the red wire to pin 7 on the 403mc. Not wire the white >wire from the PTT directly to the mic plug. >Best regards, >Bruce Bell >Lubbock, Texas That would certainly work. The consideration for wiring to the d-sub is that two wires need to go to the same place. Splice them together with solder a few inches outside the plug's backshell and take a single lead into the connector's pin. The reason I recommend the system show is because it's easy to attach multiple wires to the jacks. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 14, 2001
Subject: RE: Batteries
> >>So the trick is to figure out which are good and which are not.) > >The last time I tested one, the Panasonic did pretty well. > >David Swartzendruber >not building yet >Wichita This brings up an interesting data point about changing out the battery every annual . . . . even batteries that are a tad short on longevity, will still perform satisfactorily for a year. The test that B&C runs on new batteries is to put an ADJUSTABLE load tester on it and crank up the amps until the meter dips to 8.5 volts. The load required to do this should be no less than 300A and it shouldn't drop below 200A in less than 20-30 seconds. Some batteries are so-so (300-400A) and others are stellar (600+ amps). This is one advantage of purchasing from a Battery Mart type storefront. They're almost sure to have a tester on hand to demonstrate the capability of their offering. Now, this says NOTHING about longevity. It's conceivable that a new battery could come out of the gate breathing fire and fall on it's face in half the time of its nearest competitor. This is another beauty of the new-battery-a-year philosophy . . . some pretty soggy products may do quite well for that period of time. If anyone on the list has experience (good or bad) with a particular brand . . . publish it here. I've seen some portable "jumper battery" products in the stores for as little as $39!!!! I've purchased several of these to tear down and see what battery was inside. All have contained the 3 x 6 x 6.5 inch SLA battery. Why so inexpensive? Consumer product sales outnumber techno-specific products by an order of magnitude or better. Just because it's inexpensive doesn't mean it shouldn't be considered. Try 'em out folks and tell us about it here . . . The risks are minimal and the value of good data on field service is VERY high . . . Bob . . . ________________________________________________________________________________
Date: Jun 14, 2001
Subject: Re: Batteries
I've run into the problem of not having a consistent method of comparing batteries performance. The panasonic engineer says he would probably not recommend his battery because it is less suited to higher temps as one would encounter under the hood of an auto or airplane. Panasonic does not give a CCA rating. He did say that the battery is used on some lawn tracters. Hawker gives CCA rating but doesn't have a 20ah battery in this ~ 7 x 3 x 6 dimension. Theirs is only a 16ah. Their "spiral" design makes it have less lead so its lighter but has less capacity. Odyssey gives CCA and is expensive like B&C ~ $120 and is only 16ah. I've also learned that the CCA is not always specified at the same temp. Nor is the ah rating given the same way. Is it kind of like buying a tire for a car? Every tire manufacture rates the traction of the tire. It is my understanding that the traction rating designation is agreed to across the tire industry but the method of measuring is different so that the consumer is not really comparing apples with apples....... If this is so, then I conclude it may very well be worth paying a"premium" for the battery from B&C because they have the "reputation" of testing the various products and selecting the "optimum".......at least, so goes my logic. I guess it boils down to trust??? What do you all think? Muzzy Norman E wrote: > > << Probably 90% of the airplanes flying and under construction can make > good > use of the 17-20 a.h. devices in the 3 x 6 x 6.5 inch format. LOTS of > manufacturers build batteries in this form factor and a.h. range for > reasonable prices. I would not depart from this class of battery without > strong design and operation goals dictating the change. These batteries are > excellent value and performance. I'd go with the > Panasonic/Powersonic/Yuasa/etc.etc. >> > > Bob: Just to make sure I understand your answer above, are you saying > that > the relatively inexpensive batteries made by Panasonic, etc., (compared to > the Odyssey) > will have adequate cranking capacity for, say, an 0-360? >>> > > << You betcha. There are some VERY small batteries that > will crank an engine. The BIG issue is >> > > There are many batteries that are this exact form factor. There are also > considerable differences between their ability to output sufficient current. > If you are looking for a cheap battery that size, buy one from the surplus > sites such as www.meci.com part number 140-0094 for $19.95! Exact same > size as the battery that B&C sells, but I can tell you that the cranking > performance on these is roughly proportional to the battery cost. So maybe > use a cheap one to hold space and power your accessories while you are > building, and then buy a real battery for flying. > > (I have used these batteries in some robots. I couldn't get the performance > that I needed, so I put in a pair of the B&C batteries. The difference was > amazing. The cheap batteries cannot deliver the current like the good > batteries. So the trick is to figure out which are good and which are not.) > > Regards- > Norm Muzzy > Cozy MKIV filling and finishing! > ________________________________________________________________________________
Date: Jun 14, 2001
Subject: Re: RE: Batteries
Dear List, For any who are inerested, I have attached a Word file containing the batteries that I got information on. Ned "Robert L. Nuckolls, III" wrote: > > > > >>So the trick is to figure out which are good and which are not.) > > > >The last time I tested one, the Panasonic did pretty well. > > > >David Swartzendruber > >not building yet > >Wichita > > This brings up an interesting data point about > changing out the battery every annual . . . . > even batteries that are a tad short on longevity, > will still perform satisfactorily for a year. > > The test that B&C runs on new batteries is to > put an ADJUSTABLE load tester on it and crank up > the amps until the meter dips to 8.5 volts. > The load required to do this should be no less > than 300A and it shouldn't drop below 200A > in less than 20-30 seconds. > > Some batteries are so-so (300-400A) and others > are stellar (600+ amps). This is one advantage > of purchasing from a Battery Mart type storefront. > They're almost sure to have a tester on hand to > demonstrate the capability of their offering. > > Now, this says NOTHING about longevity. It's > conceivable that a new battery could come out > of the gate breathing fire and fall on it's > face in half the time of its nearest competitor. > This is another beauty of the new-battery-a-year > philosophy . . . some pretty soggy products may > do quite well for that period of time. > > If anyone on the list has experience (good or > bad) with a particular brand . . . publish it > here. I've seen some portable "jumper battery" > products in the stores for as little as $39!!!! > I've purchased several of these to tear down > and see what battery was inside. All have > contained the 3 x 6 x 6.5 inch SLA battery. > Why so inexpensive? Consumer product sales > outnumber techno-specific products by an order > of magnitude or better. Just because it's > inexpensive doesn't mean it shouldn't be > considered. Try 'em out folks and tell us > about it here . . . The risks are minimal > and the value of good data on field service > is VERY high . . . > > Bob . . . > ________________________________________________________________________________
Date: Jun 14, 2001
Dear List, For any who are inerested, I have attached a Word file containing the batteries that I got information on. It is interesting to see the comparisons of $ per pound and amp-hour per pound. The Powersonic and the Panasonic put out the highest AH per pound and cost the least per pound. Ned "Robert L. Nuckolls, III" wrote: > > > > >>So the trick is to figure out which are good and which are not.) > > > >The last time I tested one, the Panasonic did pretty well. > > > >David Swartzendruber > >not building yet > >Wichita > > This brings up an interesting data point about > changing out the battery every annual . . . . > even batteries that are a tad short on longevity, > will still perform satisfactorily for a year. > > The test that B&C runs on new batteries is to > put an ADJUSTABLE load tester on it and crank up > the amps until the meter dips to 8.5 volts. > The load required to do this should be no less > than 300A and it shouldn't drop below 200A > in less than 20-30 seconds. > > Some batteries are so-so (300-400A) and others > are stellar (600+ amps). This is one advantage > of purchasing from a Battery Mart type storefront. > They're almost sure to have a tester on hand to > demonstrate the capability of their offering. > > Now, this says NOTHING about longevity. It's > conceivable that a new battery could come out > of the gate breathing fire and fall on it's > face in half the time of its nearest competitor. > This is another beauty of the new-battery-a-year > philosophy . . . some pretty soggy products may > do quite well for that period of time. > > If anyone on the list has experience (good or > bad) with a particular brand . . . publish it > here. I've seen some portable "jumper battery" > products in the stores for as little as $39!!!! > I've purchased several of these to tear down > and see what battery was inside. All have > contained the 3 x 6 x 6.5 inch SLA battery. > Why so inexpensive? Consumer product sales > outnumber techno-specific products by an order > of magnitude or better. Just because it's > inexpensive doesn't mean it shouldn't be > considered. Try 'em out folks and tell us > about it here . . . The risks are minimal > and the value of good data on field service > is VERY high . . . > > Bob . . . > ________________________________________________________________________________
Date: Jun 14, 2001
Subject: Legal problems in aviation
>Now,here comes a bunch of yahoos hammering hang-gliders > on steroids together in their barns. Now, that's ridiculous! I don't own a barn. : ) Gary Liming ________________________________________________________________________________
Date: Jun 14, 2001
Manufacture AH wgt Length Width Height CCA Price AH / wgt $ / wgt B&C BC120-1 20 15.3 6.94 3.43 6.05 300 $124 1.31 8.10 Hawker G16EP 16 13.5 7.15 3.005 6.605 285 $63 1.19 4.67 Odyssey PC680 16 14.7 7.27 3.12 6.67 280 $120 1.09 8.16 Panasonic X1220P 20 14.56 7.126 2.933 6.57 $47 1.37 3.23 Powersonic PS12180 18 13.1 7.13 2.99 6.57 $52 1.37 3.97 YUASA NP18-12 18 13.64 7.13 2.99 6.57 $60 1.32 4.40 Ned Thomas wrote: > > Dear List, > > For any who are inerested, I have attached a Word file containing the batteries that I got > information on. > > Ned > > "Robert L. Nuckolls, III" wrote: > > > > > > > > >>So the trick is to figure out which are good and which are not.) > > > > > >The last time I tested one, the Panasonic did pretty well. > > > > > >David Swartzendruber > > >not building yet > > >Wichita > > > > This brings up an interesting data point about > > changing out the battery every annual . . . . > > even batteries that are a tad short on longevity, > > will still perform satisfactorily for a year. > > > > The test that B&C runs on new batteries is to > > put an ADJUSTABLE load tester on it and crank up > > the amps until the meter dips to 8.5 volts. > > The load required to do this should be no less > > than 300A and it shouldn't drop below 200A > > in less than 20-30 seconds. > > > > Some batteries are so-so (300-400A) and others > > are stellar (600+ amps). This is one advantage > > of purchasing from a Battery Mart type storefront. > > They're almost sure to have a tester on hand to > > demonstrate the capability of their offering. > > > > Now, this says NOTHING about longevity. It's > > conceivable that a new battery could come out > > of the gate breathing fire and fall on it's > > face in half the time of its nearest competitor. > > This is another beauty of the new-battery-a-year > > philosophy . . . some pretty soggy products may > > do quite well for that period of time. > > > > If anyone on the list has experience (good or > > bad) with a particular brand . . . publish it > > here. I've seen some portable "jumper battery" > > products in the stores for as little as $39!!!! > > I've purchased several of these to tear down > > and see what battery was inside. All have > > contained the 3 x 6 x 6.5 inch SLA battery. > > Why so inexpensive? Consumer product sales > > outnumber techno-specific products by an order > > of magnitude or better. Just because it's > > inexpensive doesn't mean it shouldn't be > > considered. Try 'em out folks and tell us > > about it here . . . The risks are minimal > > and the value of good data on field service > > is VERY high . . . > > > > Bob . . . > > > ________________________________________________________________________________
Date: Jun 14, 2001
Ned, If you attached a file to your message the only place it's going is back to you. Try this link to post it. We'd all love to see what you've come up with. http://www.matronics.com/enclosures.html Mike Nellis - http://bmnellis.com Plainfield, IL RV6 N699BM (res) Building Flaps Stinson 108-2 N9666K > Dear List, > > For any who are inerested, I have attached a Word file containing the > batteries that I got information on. > > It is interesting to see the comparisons of $ per pound and amp-hour per pound. > > The Powersonic and the Panasonic put out the highest AH per pound and cost the least per pound. ________________________________________________________________________________
Date: Jun 14, 2001
> >Dear List, > >For any who are inerested, I have attached a Word file containing the >batteries that I got information on. I would like to see your file, but the list doesn't distribute attachments. Is there a website you can put it up? Gary Liming ________________________________________________________________________________
Date: Jun 14, 2001
Reply to: Re: AeroElectric-List: Batteries Have you checked into the WestCo line of batteries? They are maintenance free "gell" batteries. They came out on top in a recent GoldWing motorcycle magazine battery test. I think they would be worth a look. Their url is: https://www.westcobattery.com/tech_info.html >If this is so, then I conclude it may very well be worth paying a"premium" >for the battery >from B&C because they have the "reputation" of testing the various products >and selecting >the "optimum".......at least, so goes my logic. > >I guess it boils down to trust??? What do you all think? > ________________________________________________________________________________
Subject: Re: Legal problems in aviation
Date: Jun 14, 2001
I'm building my Europa in a chicken shed.... does that count? Miles > > >Now,here comes a bunch of yahoos hammering hang-gliders > > on steroids together in their barns. > > Now, that's ridiculous! I don't own a barn. : ) > > Gary Liming > ________________________________________________________________________________
From: "Craig Chipley" <craigchipley(at)hotmail.com>
Date: Jun 14, 2001
Can anyone Give a review of different handheld Comms? >From: Gary Liming <gary(at)liming.org> >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Legal problems in aviation >Date: Thu, 14 Jun 2001 12:51:41 -0700 > > > >Now,here comes a bunch of yahoos hammering hang-gliders > > on steroids together in their barns. > >Now, that's ridiculous! I don't own a barn. : ) > >Gary Liming > > ________________________________________________________________________________
Date: Jun 14, 2001
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: Re: Hand helds
> >Can anyone Give a review of different handheld Comms? > I've seen several but so long ago that I don't recall where. I'd check the archives of Avweb, Aviation Consumer and an e-mail to the various aviation journals may turn up some articles. I have Japan Radio VHF Comm/VOR hand held that I'll get to play with for the first time tomorrow. Dee and I are off to Rockford, IL in the morning in a rented C-172. No matter what hand-held you end up with, plan on a means for connecting it to one of ship's regular comm antennas. The receiver technology in most hand helds is about as good as the panel mounted stuff . . . but NO radio plays back signals it can't hear . . . a decent antenna is a must. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 14, 2001
Hey Ned, nice piece of work. How about setting it up in Access or Excel and sending a copy to me directly. I'll post it on my website. Folks can download it, update it and then mail it back to me and I update the post. It might be a nice way to put a shared database together. Put a column at the far right for notes. As people have feedback on any item listed in the data base, we'll key it to a number in the notes column and post that too. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 14, 2001
> > > No matter what hand-held you end up with, plan on a means > for connecting it to one of ship's regular comm antennas. *** Can you recommend the King handheld connection box? This is a small shielded box with a pair of BNC's at the back, and an ordinary miniature phone jack at the front. One BNC goes to your panel-mounted COM transceiver, the other goes to the antenna. When you plug King's special cord into the phone jack, it disconnects the panel com and connects your handheld. Questions: * Is the mini phone jack reliable enough? I would mostly worry about it going intermittant, in which case my panel COM could lose antenna. I really doubt that it is something super-duper. * Mini phone jacks are not an RF connector, and even though the box is shielded, some leakage will occur. Is this a problem? - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jun 14, 2001
> >I've run into the problem of not having a consistent method of comparing batteries >performance. The panasonic engineer says he would probably not recommend his battery >because it is less suited to higher temps as one would encounter under the hood of an auto >or airplane. Here's where the rubber hits the road on comments I made earlier about "manufacturer's judgement as to suitability" . . . How long does an airplane battery spend "hot" as compared to cars . . . A car can run hot several hours a day, an average airplane is 4 hours a MONTH. The guy probably doesn't even KNOW that folks are using his product very successfully in their airplanes. > Panasonic does not give a CCA rating. He did say that the battery is used >on some lawn tracters. Hawker gives CCA rating but doesn't have a 20ah battery in this ~ >7 x 3 x 6 dimension. Theirs is only a 16ah. Their "spiral" design makes it have less >lead so its lighter but has less capacity. But the jelly roll cell has a much lower internal resistance which raises it ability to crank an engine compared to other batteries its size. >Odyssey gives CCA and is expensive like B&C ` $120 and is only 16ah. > >I've also learned that the CCA is not always specified at the same temp. Nor is the ah >rating given the same way. Yup . . . so the "experts" who offer them cannot even make learned comparisons between their own product and their competitors . . . and nobody bothers to do real laboratory grade data gathering in such matters. . . . >Is it kind of like buying a tire for a car? Every tire manufacture rates the traction of >the tire. It is my understanding that the traction rating designation is agreed to across >the tire industry but the method of measuring is different so that the consumer is not >really comparing apples with apples....... > >If this is so, then I conclude it may very well be worth paying a"premium" for the battery >from B&C because they have the "reputation" of testing the various products and selecting >the "optimum".......at least, so goes my logic. B&C has not tested any battery for longevity . . only initial cranking performance when new. They've sold a number of models to LOTS of customers over the years. The reason they continue to SELL any particular battery is because folks ask for them. Many, many customers are buying their 3rd or 4th battery from B&C . . . from which I would infer that they consider the battery's performance to be of good value. >I guess it boils down to trust??? What do you all think? You're making this MUCH too difficult. Why not spend the time finishing some tedious task on your airplane instead of talking to people on the phone that have NO first hand experience and very little second hand data on how well their product will work for you. Buy the lightest and cheapest battery you can find and give it a try. It will certainly crank your engine when new. By the time it is down in capacity to the point where you need to change it out, then you can decide if it was a good value. If it was cheap, then you don't stand to loose much on a poor choice. We're building failure tolerant airplanes. The best reason for "upgrading" a part is because you're tired of changing out parts that you perceive to be poor value. Start out at the bottom, work your way up and save a lot of frustration. Bob . . . ________________________________________________________________________________
Date: Jun 14, 2001
From: "Joseph Kearns, DO,MPH,FACOEM" <Kearns(at)pol.net>
I think somewhere it is recommended batteries provide 30 minutes of power to the system should the alternator fail. Is this true? Ned Thomas wrote: > > > I've run into the problem of not having a consistent method of comparing batteries > performance. The panasonic engineer says he would probably not recommend his battery > because it is less suited to higher temps as one would encounter under the hood of an auto > or airplane. Panasonic does not give a CCA rating. He did say that the battery is used > on some lawn tracters. Hawker gives CCA rating but doesn't have a 20ah battery in this ~ > 7 x 3 x 6 dimension. Theirs is only a 16ah. Their "spiral" design makes it have less > lead so its lighter but has less capacity. Odyssey gives CCA and is expensive like B&C ~ > $120 and is only 16ah. > > I've also learned that the CCA is not always specified at the same temp. Nor is the ah > rating given the same way. > > Is it kind of like buying a tire for a car? Every tire manufacture rates the traction of > the tire. It is my understanding that the traction rating designation is agreed to across > the tire industry but the method of measuring is different so that the consumer is not > really comparing apples with apples....... > > If this is so, then I conclude it may very well be worth paying a"premium" for the battery > from B&C because they have the "reputation" of testing the various products and selecting > the "optimum".......at least, so goes my logic. > > I guess it boils down to trust??? What do you all think? > > Muzzy Norman E wrote: > > > > > << Probably 90% of the airplanes flying and under construction can make > > good > > use of the 17-20 a.h. devices in the 3 x 6 x 6.5 inch format. LOTS of > > manufacturers build batteries in this form factor and a.h. range for > > reasonable prices. I would not depart from this class of battery without > > strong design and operation goals dictating the change. These batteries are > > excellent value and performance. I'd go with the > > Panasonic/Powersonic/Yuasa/etc.etc. >> > > > > Bob: Just to make sure I understand your answer above, are you saying > > that > > the relatively inexpensive batteries made by Panasonic, etc., (compared to > > the Odyssey) > > will have adequate cranking capacity for, say, an 0-360? >>> > > > > << You betcha. There are some VERY small batteries that > > will crank an engine. The BIG issue is >> > > > > There are many batteries that are this exact form factor. There are also > > considerable differences between their ability to output sufficient current. > > If you are looking for a cheap battery that size, buy one from the surplus > > sites such as www.meci.com part number 140-0094 for $19.95! Exact same > > size as the battery that B&C sells, but I can tell you that the cranking > > performance on these is roughly proportional to the battery cost. So maybe > > use a cheap one to hold space and power your accessories while you are > > building, and then buy a real battery for flying. > > > > (I have used these batteries in some robots. I couldn't get the performance > > that I needed, so I put in a pair of the B&C batteries. The difference was > > amazing. The cheap batteries cannot deliver the current like the good > > batteries. So the trick is to figure out which are good and which are not.) > > > > Regards- > > Norm Muzzy > > Cozy MKIV filling and finishing! > > > ________________________________________________________________________________
Date: Jun 14, 2001
> >I think somewhere it is recommended batteries provide 30 minutes of >power to the system should the alternator fail. Is this true? That's on a certified airplane . . . on owner built and maintained airplanes, I recommend that your battery be able to run the minimum goodies for continued flight to intended destination with your only limitation being the gallons of fuel you have aboard. Why would you want to design a system that couldn't run as long as the engine is running too? Bob . . . ________________________________________________________________________________
Date: Jun 14, 2001
Dear list, I made a decision and purchased the Hawker Genesis GV16EP today from AVT, Inc., Littleton, CO, (800) 537-9602. They sell it for $55. I made this decision mainly based on the following: 1) Comparing the Discharge characteristic plots of the Panasonic and Hawker. My interpretation of the plots yielded that Panasonic held 60A for ~9 minutes while Hawker held 60A for ~10 minutes. 2) Hawker was one of the lightest at 13.5 lbs. and least expensive. It also had the lowest internal resistance advertised at 7mOhms. Panasonic is 11 mOhms. After I ordered the battery I got a recommendation to look over Westco batteries. I may have ordered their SVR20 instead of the Hawker. Maybe next year when I change out the bat. It is 1.5 lbs heavier but advertises a 300 CCA. Its also $45 higher than the Hawker at $89.98. I have been trying to follow matrionic directions to post my little table. Haven't been able to get it to work. It would be great for all to contribute to a historical feedback data base on their batteries. It wouldn't be long before we would cull out and find the best bat in this size if everyone could contribute their experiences. I agree with Bob Nuckolls that all these batteries seem really close in performance and that any one of these later generation batteries will probably do a fine job. I decided to buy the lesser expensive battery and put the savings into a good regulator / charging voltage controller. Best of luck in making your battery selection, Ned "Robert L. Nuckolls, III" wrote: > > > > >I've run into the problem of not having a consistent method of comparing batteries > >performance. The panasonic engineer says he would probably not recommend his battery > >because it is less suited to higher temps as one would encounter under the hood of an auto > >or airplane. > > Here's where the rubber hits the road on comments I made > earlier about "manufacturer's judgement as to suitability" . . . > How long does an airplane battery spend "hot" as compared > to cars . . . A car can run hot several hours a day, an average > airplane is 4 hours a MONTH. The guy probably doesn't even > KNOW that folks are using his product very successfully > in their airplanes. > > > Panasonic does not give a CCA rating. He did say that the battery is used > >on some lawn tracters. Hawker gives CCA rating but doesn't have a 20ah battery in this ~ > >7 x 3 x 6 dimension. Theirs is only a 16ah. Their "spiral" design makes it have less > >lead so its lighter but has less capacity. > > But the jelly roll cell has a much lower internal resistance > which raises it ability to crank an engine compared to other > batteries its size. > > >Odyssey gives CCA and is expensive like B&C ` $120 and is only 16ah. > > > >I've also learned that the CCA is not always specified at the same temp. Nor is the ah > >rating given the same way. > > Yup . . . so the "experts" who offer them cannot even make > learned comparisons between their own product and their > competitors . . . and nobody bothers to do real laboratory > grade data gathering in such matters. . . . > > >Is it kind of like buying a tire for a car? Every tire manufacture rates the traction of > >the tire. It is my understanding that the traction rating designation is agreed to across > >the tire industry but the method of measuring is different so that the consumer is not > >really comparing apples with apples....... > > > >If this is so, then I conclude it may very well be worth paying a"premium" for the battery > >from B&C because they have the "reputation" of testing the various products and selecting > >the "optimum".......at least, so goes my logic. > > B&C has not tested any battery for longevity . . only initial > cranking performance when new. They've sold a number of models > to LOTS of customers over the years. The reason they continue > to SELL any particular battery is because folks ask for them. > Many, many customers are buying their 3rd or 4th battery from > B&C . . . from which I would infer that they consider the > battery's performance to be of good value. > > >I guess it boils down to trust??? What do you all think? > > You're making this MUCH too difficult. Why not spend the > time finishing some tedious task on your airplane instead > of talking to people on the phone that have NO first hand > experience and very little second hand data on how well > their product will work for you. > > Buy the lightest and cheapest battery you can find and > give it a try. It will certainly crank your engine when > new. By the time it is down in capacity to the point where > you need to change it out, then you can decide if it was > a good value. If it was cheap, then you don't stand to > loose much on a poor choice. > > We're building failure tolerant airplanes. The best reason > for "upgrading" a part is because you're tired of changing > out parts that you perceive to be poor value. Start out at > the bottom, work your way up and save a lot of frustration. > > Bob . . . > ________________________________________________________________________________
Date: Jun 15, 2001
I'm a little confused by the 403MC wiring diagram as well. I don't understand the question just posted here -- not sure which red and white wires the poster was referring to. My question, which seems to be related, is: why does the PTT wire from pin 7 have to be connected to the mic jack? When transmitting, this wire is grounded anyway, so why not just run a single shielded wire from pin 7 direct to the PTT button? I'm assuming that the "mic hi" wire (pin 2) carries the actual signal from the microphone. ________________________________________________________________________________
Date: Jun 15, 2001
Subject: oil pressure switch
I bought an oil pressure switch from B&C and I'm concerned it's either defective or the wiring diagram is wrong. With my engine not running, the switch has a short between terminals S and P, while there is an open circuit between S and I. The wiring diagram implies it should be the other way around. I'm not yet at a stage where I can try running the engine. ________________________________________________________________________________
From: "Jesse Kluijfhout, PE1RUI" <jessevli(at)zeelandnet.nl>
Subject: Re: oil pressure switch
Date: Jun 15, 2001
Hi Andrew, You could use compressed air to see if the switch does switch. Be carefull not to use to much air pressure. Just use an air gun and be carefull not the squeeze it too much. Its not a calibrated messure, but you can determine if the switch does it work or not, without youre engine running. Good luck, Jesse ----- Original Message ----- From: "Andrew Larkin" <aj_larkin(at)yahoo.com> Sent: Friday, June 15, 2001 9:28 AM Subject: AeroElectric-List: oil pressure switch > > I bought an oil pressure switch from B&C and I'm > concerned it's either defective or the wiring diagram > is wrong. With my engine not running, the switch has > a short between terminals S and P, while there is an > open circuit between S and I. The wiring diagram > implies it should be the other way around. I'm not > yet at a stage where I can try running the engine. > > ________________________________________________________________________________
Date: Jun 15, 2001
The S and I should be normally closed and the S and P normally open. I have the same switch and I suspect a problem with mine also. I am getting an open circuit on both! I am going to see how it does when the engine is started and go from there. Jerry Calvert Edmond Ok -6 finish kit ----- Original Message ----- From: Andrew Larkin <aj_larkin(at)yahoo.com> Sent: Friday, June 15, 2001 2:28 AM Subject: AeroElectric-List: oil pressure switch > > I bought an oil pressure switch from B&C and I'm > concerned it's either defective or the wiring diagram > is wrong. With my engine not running, the switch has > a short between terminals S and P, while there is an > open circuit between S and I. The wiring diagram > implies it should be the other way around. I'm not > yet at a stage where I can try running the engine. > > ________________________________________________________________________________
Date: Jun 17, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com> Subject: Re: AeroElectric-List: Re: switch configuration Send reply to: aeroelectric-list(at)matronics.com > > > "Robert L. Nuckolls, III" wrote: > > > > > > > > > > > > > > >Bob > > > > > >How would I wire a situation where I want 4 items to have separate > > >breakers, but I would like 1 switch to turn them all on/off? They have > > >different breaker requirements. > > > > . > > > why not just wire the fuses after the single pole switch? > > B+ > (fuse to protect wire to switch, if desired) > > switch > fuse > fuse > fuse > fuse Charlie Thanks for the reply. It's been awhile since I had time to return email. I have 1 question. How do you determine the wire size and protection for the feed wire? Add all the loads attached after the switch and size the feed wire accordingly? Jim ________________________________________________________________________________
Date: Jun 14, 2001
Subject: Re: Recommendation on components that fit Microair
760 >Mr. Nuckolls, > >I'm writing for my friend who has a Hiperlight (2 seat) aircraft with a >Rotax 503 engine. He wants to update the radio, as well as gain the option >to fly through the Mode C veil around MCI, just north of Kansas City to get >in or out of smaller airports. > >He would like to purchase the Microair from you, but he's been waiting for >the new model to come out with the vox intercom included...as he's concerned >about the open mike feature of the current model's intercom because of the >high noise level in his airplane. Unfortunately, as you know, introduction >of the new model is not assured anytime soon, so he's ready to go ahead with >the current model, and add a separate intercom to achieve his goal. The intercom is NOT open mic . . . but push to talk. VOX systems do not reduce perceived noise while talking, they only make the best possible guess as to when you would normally be pushing a talk button by trying to distinguish your voice from other signals heard on the headset's microphone circuit. For aircraft with high noise levels, the PTT intercom system that is standard with the original Microair transceiver is the way to go. VOX systems are difficult to make work (I have a microprocessor based design that studies signal (voice) to noise (engine+wind) ratios in specific bandwidths in an attempt to fully automate the task of continuously adjusting for cabin noise. It's expensive and still not perfect. I've had very positive feedback from customers that have used this radio in a variety of aircraft. Once the passenger gets used to the push-to-talk feature (takes about 5 minutes) then both folks find the DEAD silence between spoken phrases to be most pleasant. >Do you have recommendations/suggestions about components from other >manufacturers (an intercom that will work well with the radio)or >transponder, encoder, etc. that you have experience with and will fit his >needs of small size, low weight and low power consumption? My best recommendation is that no additional equipment is needed for incorporation of this radio into your friend's application. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 14, 2001
> >> >> >> No matter what hand-held you end up with, plan on a means >> for connecting it to one of ship's regular comm antennas. > >*** Can you recommend the King handheld connection box? This is a small >shielded box with a pair of BNC's at the back, and an ordinary miniature >phone jack at the front. One BNC goes to your panel-mounted COM >transceiver, the other goes to the antenna. When you plug King's special >cord into the phone jack, it disconnects the panel com and connects your >handheld. > > Questions: > > * Is the mini phone jack reliable enough? I would mostly worry about it > going intermittant, in which case my panel COM could lose antenna. > I really doubt that it is something super-duper. But how often will it be used? Almost everybody's jacks are just fine when new . . . it's after several hundred insertion/removal cycles that they get tired. If this is a standby for already very reliable panel mounted stuff, what ever jack/plug combo is supplied will probably be fine. If you want to use the radio more consistently, you might want to fabricate up your own switch arrangement. Loop your comm antenna through the cockpit to a panel mounted BNC female/ cable male combination easily reached from the pilot's seat. Use short piece of coax with BNC both ends to jump between hand held and the panel mounted female after you've disconnected the otherwise disabled panel radio from it. Simple, inexpensive and does not compromise the performance of either radio. > * Mini phone jacks are not an RF connector, and even though the box > is shielded, some leakage will occur. Is this a problem? The system you describe, if supplied by King, has probably been well evaluated for performance. If you want to use something like this as a not often used backup, it's probably a good bet. If it were my airplane, I'd either have a second antenna for the hand held -OR- loop the comm antenna through the cockpit as described above. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
760
Date: Jun 18, 2001
Push to talk intercom?? OK, is this a second switch? Sounds like more complexity VS getting a good VOX system. They are out there; so most aircraft can be made to work very well on a VOX system. I fly often with a couple of different VOX systems and its rare when there is any unwanted side noise. The aircraft noise level is such that talk with no headsets is not possible. I do not like the concept of a second switch for the pilot, one for radio and a second for the intercom. I do not (usually) have a 3rd hand for the extra switch nor room etc on the stick. I can understand that passengers could use a special switch but I would not want a second switch for the pilot. I have too many already to worry about. :-) Paul -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Thursday, June 14, 2001 9:42 PM Subject: AeroElectric-List: Re: Recommendation on components that fit Microair 760 - The intercom is NOT open mic . . . but push to talk. VOX systems do not reduce perceived noise while talking, they only make the best possible guess as to when you would normally be pushing a talk button by trying to distinguish your voice from other signals heard on the headset's microphone circuit. For aircraft with high noise levels, the PTT intercom system that is standard with the original Microair transceiver is the way to go. VOX systems are difficult to make work (I have a microprocessor based design that studies signal (voice) to noise (engine+wind) ratios in specific bandwidths in an attempt to fully automate the task of continuously adjusting for cabin noise. It's expensive and still not perfect. I've had very positive feedback from customers that have used this radio in a variety of aircraft. Once the passenger gets used to the push-to-talk feature (takes about 5 minutes) then both folks find the DEAD silence between spoken phrases to be most pleasant. ________________________________________________________________________________
Date: Jun 18, 2001
Microair 760 > > >Push to talk intercom?? OK, is this a second switch? Sounds like more >complexity VS getting a good VOX system. They are out there; so most >aircraft can be made to work very well on a VOX system. I fly often with a >couple of different VOX systems and its rare when there is any unwanted side >noise. The aircraft noise level is such that talk with no headsets is not >possible. > >I do not like the concept of a second switch for the pilot, one for radio >and a second for the intercom. I do not (usually) have a 3rd hand for the >extra switch nor room etc on the stick. I can understand that passengers >could use a special switch but I would not want a second switch for the >pilot. I have too many already to worry about. :-) > >Paul Hi Paul and all - I much prefer a system allowing ptt for ICS (as installed on the Navy jets I worked on). The switch is a three position "slider", spring-loaded to center. Forward for XMIT and aft for ICS. Once you are used to it (very brief adjustment period) you have no more snorts, sneezes, coughs and throat clearing noise in the headset - NICE! It's also good for flying with the doors open as the rear-seater gets a lot more wind. If anyone knows of a source for this switch do tell. Bill RANS Courier in progress P.S. Of course the Navy had a switch to select VOX for ICS if preferred. ________________________________________________________________________________
Date: Jun 18, 2001
Subject: Re: switch configuration
Jim Robinson wrote: > > > From: Charlie and Tupper England <cengland(at)netdoor.com> > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: switch configuration > Send reply to: aeroelectric-list(at)matronics.com > > > > > > > "Robert L. Nuckolls, III" wrote: > > > > > > > > > > > > > > > > > > > > >Bob > > > > > > > >How would I wire a situation where I want 4 items to have separate > > > >breakers, but I would like 1 switch to turn them all on/off? They have > > > >different breaker requirements. > > > > > > . > > > > > > why not just wire the fuses after the single pole switch? > > > > B+ > (fuse to protect wire to switch, if desired) > > > switch > fuse > > fuse > > fuse > > fuse > Charlie > Thanks for the reply. It's been awhile since I had time to return > email. I have 1 question. How do you determine the wire size and > protection for the feed wire? Add all the loads attached after the > switch and size the feed wire accordingly? > Jim > Add the current requirements of the 4 loads. Size the primary wire, the switch, & each of the leads leaving the switch (or one wire daisy-chained to the 4 secondary fuses) to handle the total of all 4 loads. Size the primary fuse to protect the primary wire. Size each of the wires leaving the 4 secondary fuses to match its load. Size each secondary fuse to protect its wire (going to its load). Just don't forget that fuses/breakers protect the wire, not the device at the end of the wire. And, you have a single point of failure for all 4 devices. Unless you have an very complex panel, you can make your life a lot easier both while building & flying by standardizing on 2 or 3 sizes of wire & breakers. ex: Anything under 5 amp load gets a 5A breaker & wire. 5 to 10 amps gets 10A breaker & wire. The weight penalty is minimal for simple panels. Charlie ________________________________________________________________________________
Date: Jun 15, 2001
Subject: Re: oil pressure switch WIRING DIAGRAM ERROR
> I bought an oil pressure switch from B&C and I'm > concerned it's either defective or the wiring diagram > is wrong. With my engine not running, the switch has > a short between terminals S and P, while there is an > open circuit between S and I. The wiring diagram > implies it should be the other way around. I'm not > yet at a stage where I can try running the engine. I checked my data on these switches and found that the wiring diagram at: http://www.aeroelectric.com/Catalog/switch/oilpwarn.pdf . . . has errors. This is a big surprise to me as we've sold at least a hundred of these switches and this is the first time anyone has spotted it! The terminal lettering sequence got rolled when I did the drawing. The REAL connections are: Terminal P is the common lead and goes to ground. Terminal I is normally open and CLOSES to terminal P when pressure is applied and provides ground to the hour meter. Terminal S is normally connected to terminal P and OPENS when pressure is applied to remove ground from the oil pressure warning light and buzzer. As soon as I can find the original drawing, I'll correct it and repost it. Thanks for the heads-up on this folks! Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 15, 2001
Subject: RE: PTT intercom vs. VOX
>>Push to talk intercom?? OK, is this a second switch? Sounds like more >>complexity VS getting a good VOX system. They are out there; so most >>aircraft can be made to work very well on a VOX system. I fly often with a >>couple of different VOX systems and its rare when there is any unwanted side >>noise. The aircraft noise level is such that talk with no headsets is not >>possible. >> Actually, the biggest problem that VOX systems have to overcome is the quality of the microphone. The ability of noise cancelling microphones varies widely from product to product. I use an intercom with a VOX and it works pretty good MOST of the time . . . but combined with my headsets, it's sensitive to things like turning my head 90 degrees left to look out the window. The VOX setting that just quieted the noise while sitting normally is too loose when the noise wave-fronts at the microphone change direction and the system opens up. Also, if I open an air vent to allow cooling air to blow at my face, the VOX has to be tightened up. Of course, major changes in power setting and airspeed will change ambient cabin noise and unless the microphones are very good at mechanically nulling out ambient, the VOX setting needs to change. One of the most useful advances in VOX operated audio systems is the inclusion of a separate VOX setting for EACH microphone in the system. When you add more microphones to the system, the amount of cabin noise that the intercom sees goes up meaning that the VOX setting has to get tighter. The amount of signal from any one person talking is a relative constant . . . so 4-place systems with all 4 headsets plugged in tend to be a real pain in the arse. Years ago, I used to be able to buy a military surplus headset with what I perceived then as the best microphone available at the time. I think these were helicopter headsets. I had to build special amplifiers and matching networks to make them suitable for use in civil aircraft . . . but they were so effective that you didn't NEED a VOX system . . just run them hot all the time. VERY pleasant to use. The source dried up about 15 years ago and I've not had an opportunity to work anything quite as good since. BTW . . . the most expensive headsets are not necessarily the most capable of reducing ambient noise at the microphone. I wrote to five or six companies a few years back asking for samples of ALL the headset-microphone combos they had to offer. I was going to evaluate their microphone performance for the kinds of effects I noted above. Only two of the five responded and then only with part of their product line. I didn't think it was worth the trouble to set up the tests and write the article if I couldn't get a better cross-section of product to evaluate. By-and-large, the PTT intercom built into the Microair IS simpler because it takes advantage of circuitry that's already in place for the radio . . . no additional intercom hardware is needed . . . just separate p-buttons for intercom and transmit. My last customer put his xmit button on top of the stick and the intercom button on the side. Very easy to avoid confusion. Anyone who would like to see the wiring diagrams for a Microair transceiver can download them at: http://www.aeroelectric.com/articles/audio/760v1.pdf http://www.aeroelectric.com/articles/audio/760v2.pdf If you need a little fancier audio system to incorporate music inputs and/or audio from additional receivers or warning tones, you can add a distribution amplifier wired as shown in: http://www.aeroelectric.com/articles/audio/760v3.pdf http://www.aeroelectric.com/articles/audio/760v4.pdf Bob . . . ________________________________________________________________________________
Date: Jun 18, 2001
Thanks Charlie. Good words of wisdom. Jim ________________________________________________________________________________
From: "James K. Glindemann" <jglind(at)netspace.net.au>
Subject: Dynamic Mikes
Date: Jun 19, 2001
> Years ago, I used to be able to buy a military surplus headset > with what I perceived then as the best microphone available at > the time. I think these were helicopter headsets. I had to build > special amplifiers and matching networks to make them suitable > for use in civil aircraft . . . but they were so effective that Hi again Bob, Dont suppose you could find a copy of the diagram for the amplifiers and matching networks, I have been looking for a suitable circuit for some time. I work on S76 and my headset is set up for low impedence mikes normally, would be nice to use the same headset in the Long EZ without having to swap mikes. I use CEP in ear phones and find there is no problem with the difference in phone impedence, but the mike is another story. regards James K. Glindemann ________________________________________________________________________________
Subject: Contactors
Date: Jun 19, 2001
Bob and others, Here are a couple of questions that I have come up with when trying to figure out the FWF wiring, specifically the contactors. 1.First the battery contactor. When laying out the FWF wiring, It looks cleaner and wires don't get crossed, if I can take the battery contactor as delivered from B&C and turn the diode around and switch the jumper to the other side. Basically making a mirror image. Is there any thing wrong with doing this. I noticed that on the left side, "BAT" is stamped near the large post, does this mean anything? 2. On the starter contactor, do I use the S or the I for the starter engaged light? I assume I use the other for ground. Thanks in advance, Dan Frank RV-8 Finish Kit http://n808vr.homestead.com ________________________________________________________________________________
Date: Jun 15, 2001
Subject: Re: Contactors
> >Bob and others, > >Here are a couple of questions that I have come up with when trying to >figure out the FWF wiring, specifically the contactors. > >1.First the battery contactor. When laying out the FWF wiring, It looks >cleaner and wires don't get crossed, if I can take the battery contactor as >delivered from B&C and turn the diode around and switch the jumper to the >other side. Basically making a mirror image. Is there any thing wrong with >doing this. I noticed that on the left side, "BAT" is stamped near the >large post, does this mean anything? The housing that is used to fabricate the battery contactor we sell is the same housing for a 3-terminal device wherein the contactor's coil is internally wired to the "BAT" terminal. With the 4-terminal device, you can use either terminal as a BAT terminal and turning the diode/jumper comb around as you've suggested is okay to do. >2. On the starter contactor, do I use the S or the I for the starter >engaged light? I assume I use the other for ground. "S" goes to the starter switch or pushbutton. "I" may indeed be used as a "stuck contactor" indicator light. Put an inline fuse or fusible link right at terminal "I" to protect the wire. The mounting base of the contactor is ground . . . so if you're doing a composite airplane, you need to run a 20AWG jumper wire from a contator mounting bolt to the firewall ground bus. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 16, 2001
Subject: Re: Dynamic Mikes
> > >> Years ago, I used to be able to buy a military surplus headset >> with what I perceived then as the best microphone available at >> the time. I think these were helicopter headsets. I had to build >> special amplifiers and matching networks to make them suitable >> for use in civil aircraft . . . but they were so effective that > >Hi again Bob, > >Dont suppose you could find a copy of the diagram for the amplifiers and >matching networks, I have been looking for a suitable circuit for some time. >I work on S76 and my headset is set up for low impedence mikes normally, >would be nice to use the same headset in the Long EZ without having to swap >mikes. I use CEP in ear phones and find there is no problem with the >difference in phone impedence, but the mike is another story. Hmmmm . . . as I recall, the microphone was a very low impedance (about 5 ohms) dynamic device (moving coil and stationary magnet). I used an integrated circuit normally used to amplify the very meager output from a phonograph cartridge up to carbon microphone levels . . . about 700 mV pk-pk max for normal speech. This signal was coupled to about a 100 ohm resistor that dummy loaded the transmitter's mic input to make it think a standard mic was plugged in. I think I tried using the bias supplied by the transmitter to power the circuit without success . . . however, is suspect that modern chips might be capable of operating from the transmitter's normally mic-power . . . I'd have to do some hammering on the workbench to confirm and trim the design. If push comes to shove, you can always power the mic pre-amp independently of the vhf comm transmitter. Bob . . . ________________________________________________________________________________
Date: Jun 16, 2001
> > > I checked my data on these switches and found > that the wiring diagram at: > >http://www.aeroelectric.com/Catalog/switch/oilpwarn.pdf > > . . . has errors. The drawing has been corrected. Bob . . . ________________________________________________________________________________
Date: Jun 16, 2001
Subject: Re: Question on alternator/radio noise
>Bob, > >I have had a progressively worsening problem with radio "static" What >started as a periodic "popping" on my radios has now turned into a >near-constant static. The noise is eliminated when I turn off the >alternator. > >The noise is heard in both radios. It is worse on the one with the >windshield antenna (i.e. the one closer to the alternator) I am running >your scheme of two separate busses, and each radio is on a different buss. >The alternator is using a Ford solid state flatpack voltage regulator which >is attached to the alternator (Mark landoll) > >I am assuming that I am getting RF noise from the alternator into the >radios. I expect to troubleshoot the problem in the following order: > >1: Bypass the circuit to the master switch/overvoltage protection by moving >the VR sense wire directly over to the "B" lead of the alternator. This >should identify if the noise is emanating from the wiring circuit or the >alternator itself. Good thinking. If this has ANY positive effect, this would help deduce both the source and propagation mode for the noise. >2. Remove the alternator for bench testing. Perhaps oneof the diodes has >failed and what I am seeing is the result of some AC from the alternator. If a diode fails, you get LOTS of whine . . . this is not a diode failure. My best guess at the moment is worn brushes that were initially transiently intermittent but the condition is getting worse. How many hours on the alternator? Was it new, rebuilt or perhaps a salvage yard bolt-on? >3. Replace the VR. I have another model which can be mounted away from the >alternator. I would try this too before pulling the alternator. An inexpensive VR166 from the auto parts store is a stock piece of test equipment in my tool box. I can hook it up right at the back of the alternator and totally bypass all other alternator wiring except the b-lead . . . gives you a fast means for deducing a variety of system ills. Let me know what you find out. >Have you encountered this type of raspy static coming from the charging >system before? It is not the typical whine you would expect. Your perceptions are on the right track . . . let's run this dog to ground. Bob . . . ________________________________________________________________________________
Date: Jun 19, 2001
Subject: Alt. Antennas
Bob, (et al) How well do Rubber Ducky antennas work when mounted to a ground plane (e.g. glare shield, fuselage etc.)? I have seen them used for ELT systems (doesn't mean that they work well). It would be nice to have a handheld radio use its own antenna as a remote mount. Comments? Gary ________________________________________________________________________________
Date: Jun 19, 2001
On your starter you need to bring 12v from the starter switch to the "S" terminal. The cast is grounded. If you want a starter engage , run from the "I" to a light to ground. Don Jordan - 6A - N6DJ - dons6a(at)juno.com Arlington, TX ********************************************************** writes: > > > Bob and others, > > Here are a couple of questions that I have come up with when trying > to > figure out the FWF wiring, specifically the contactors. > > 1.First the battery contactor. When laying out the FWF wiring, It > looks > cleaner and wires don't get crossed, if I can take the battery > contactor as > delivered from B&C and turn the diode around and switch the jumper > to the > other side. Basically making a mirror image. Is there any thing > wrong with > doing this. I noticed that on the left side, "BAT" is stamped near > the > large post, does this mean anything? > > 2. On the starter contactor, do I use the S or the I for the > starter > engaged light? I assume I use the other for ground. > > Thanks in advance, > Dan Frank > RV-8 Finish Kit > http://n808vr.homestead.com > > ________________________________________________________________________________
Date: Jun 20, 2001
> Hmmmm . . . as I recall, the microphone was a very low > impedance (about 5 ohms) dynamic device (moving coil > and stationary magnet). I used an integrated circuit You are right , most of the larger helicopter installations still use these mikes. Thanks for the info regards James K. Glindemann ________________________________________________________________________________
Date: Jun 16, 2001
Subject: Re: Alt. Antennas
> >Bob, (et al) >How well do Rubber Ducky antennas work when mounted to a ground plane (e.g. >glare shield, fuselage etc.)? I have seen them used for ELT systems >(doesn't mean that they work well). It would be nice to have a handheld >radio use its own antenna as a remote mount. Comments? > >Gary No reason for them not to perform fairly well. You can mount a BNC connector to the ground plane and plug the antenna onto the connector. Then check it with an antenna analyzer to see how well it will accept power from the radio . . . it will probably be less than 3:1 swr. It's very difficult to predict performance as a radiator. Lots of variables when the antenna is located somewhat inside the cockpit. You can try it and then devise a "plan B" if it's unsatisfactory to your needs. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 19, 2001
Jim Robinson wrote: > > > Thanks Charlie. Good words of wisdom. > > Jim > Well, I've been accused of many things, but never wisdom. :-) See you at OSH. Charlie ________________________________________________________________________________
Date: Jun 19, 2001
From: Charlie and Tupper England <cengland(at)netdoor.com> Subject: Re: AeroElectric-List: Re: switch configuration Send reply to: aeroelectric-list(at)matronics.com > > > Jim Robinson wrote: > > > > > > > > Thanks Charlie. Good words of wisdom. > > > > Jim > > > Well, I've been accused of many things, but never wisdom. > :-) > > See you at OSH. > > Charlie > Charlie I will be in the Glasair area. Glasair 1, N714PT. Please look me up. Jim ________________________________________________________________________________
Date: Jun 22, 2001
Subject: Mag Toggle Swithces
Bob: Are the toggle switches used for a left mag, right elec ignition special swithces or just SPST? Pushbutton starter. Len Leggette RV-8A N901LL (res) Greensboro, N.C. Plumbing & Wiring ________________________________________________________________________________
Date: Jun 22, 2001
Subject: Re: Mag Toggle Swithces
> >Bob: > >Are the toggle switches used for a left mag, right elec ignition special >swithces or just SPST? Pushbutton starter. You can use plain vanilla toggles . . . If your right mag doesn't have an impulse coupler, I prefer to use DPST (S700-2-3 in our catalog) and wire the second poles in series with the starter push button (See S710-1) such that the starter cannot be engaged unless the left mag is ON and the right mag is OFF. See exemplar diagrams in Appendix Z download at: http://www.aeroelectric.com/errata/R9Z_0400.pdf Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Subject: 2awg wiring questions
Date: Jun 22, 2001
A few questions on the 2awg wires. I am using the figure Z-9 diagram for inspiration and my alternator is Van's 35amp. (1) Diagram uses two 2awg wires to connect battery to contactor and also to ground block. Mine will each be 8" in length. I want to order these from B&C, but theirs are 4awg. Will these be ok? (2) Since my alternator is 35 amp, can I substitute 8awg wire for the 4awg wire that goes from the battery contactor to the main bus. (3) Also can I substitute 8awg for the 4awg wire from the starter contactor thru the 80amp fuselink to the shunt and from the other side of the shunt to the alternator? Or would the wire melt before the fuselink would?? Thanks, Jerry RV-6 ________________________________________________________________________________
Date: Jun 22, 2001
Subject: Re: 2awg wiring questions
I used 4 to the starter. Its so heavy I think I will only get .00001 voltage drop. I would think that 8 would be OK from the alternator for the 35 amp. Don Jordan - 6A - N6DJ - dons6a(at)juno.com - Arlington, TX *********************************************************************** writes: > > > A few questions on the 2awg wires. I am using the figure Z-9 > diagram for > inspiration and my alternator is Van's 35amp. > > (1) Diagram uses two 2awg wires to connect battery to contactor and > also to > ground block. Mine will each be 8" in length. I want to order > these from > B&C, but theirs are 4awg. Will these be ok? > > (2) Since my alternator is 35 amp, can I substitute 8awg wire for > the 4awg > wire that goes from the battery contactor to the main bus. > > > (3) Also can I substitute 8awg for the 4awg wire from the starter > contactor > thru the 80amp fuselink to the shunt and from the other side of the > shunt to > the alternator? Or would the wire melt before the fuselink would?? > > Thanks, > Jerry > RV-6 > > ________________________________________________________________________________
Date: Jun 22, 2001
> >A few questions on the 2awg wires. I am using the figure Z-9 diagram for >inspiration and my alternator is Van's 35amp. > >(1) Diagram uses two 2awg wires to connect battery to contactor and also to >ground block. Mine will each be 8" in length. I want to order these from >B&C, but theirs are 4awg. Will these be ok? Sure . . . in fact, on an RV with a battery on firewall, you can use 4AWG throughout. >(2) Since my alternator is 35 amp, can I substitute 8awg wire for the 4awg >wire that goes from the battery contactor to the main bus. Yes . . >(3) Also can I substitute 8awg for the 4awg wire from the starter contactor >thru the 80amp fuselink to the shunt and from the other side of the shunt to >the alternator? Or would the wire melt before the fuselink would?? Yes and no . . . the fuse will pop only when you have shorted diodes in the alternator . . . a HARD fault that causes hundreds of amps to flow. The fuse will open in milliseconds . . . the wire will get barely warm to touch. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 22, 2001
Subject: Re: 2awg wiring questions - Poor Syntax in Answer
Looking back over my reply, I believe it's unclear. >>(3) Also can I substitute 8awg for the 4awg wire from the starter contactor >>thru the 80amp fuselink to the shunt and from the other side of the shunt to >>the alternator? Or would the wire melt before the fuselink would?? > > Yes . . . You CAN substitute a smaller wire and > and no . . . the fuse will pop only when you have shorted > diodes in the alternator . . . a HARD fault that causes hundreds > of amps to flow. The fuse will open in milliseconds . . . the > 8AWG wire will get barely warm to touch. Bob . . . ________________________________________________________________________________
Date: Jun 22, 2001
Bob, Thanks for the clarification. My Odessy battery and contactors are mounted on the firewall so I will use 4awg for all places that 2awg would have been used including the starter cable. Now I can have B&C make all my cables. Good to know the 8awg can be substituted also..that will be the fattest wire in the cockpit. Thanks again, Jerry ----- Original Message ----- From: Robert L. Nuckolls, III <nuckolls(at)aeroelectric.com> Sent: Friday, June 22, 2001 12:21 PM Subject: AeroElectric-List: Re: 2awg wiring questions > > > > >A few questions on the 2awg wires. I am using the figure Z-9 diagram for > >inspiration and my alternator is Van's 35amp. > > > >(1) Diagram uses two 2awg wires to connect battery to contactor and also to > >ground block. Mine will each be 8" in length. I want to order these from > >B&C, but theirs are 4awg. Will these be ok? > > Sure . . . in fact, on an RV with a battery on firewall, you > can use 4AWG throughout. > > > >(2) Since my alternator is 35 amp, can I substitute 8awg wire for the 4awg > >wire that goes from the battery contactor to the main bus. > > Yes . . > > > >(3) Also can I substitute 8awg for the 4awg wire from the starter contactor > >thru the 80amp fuselink to the shunt and from the other side of the shunt to > >the alternator? Or would the wire melt before the fuselink would?? > > Yes and no . . . the fuse will pop only when you have shorted > diodes in the alternator . . . a HARD fault that causes hundreds > of amps to flow. The fuse will open in milliseconds . . . the > wire will get barely warm to touch. > > > Bob . . . > > ( An inventor is simply a person who doesn't take his education ) > ( too seriously. We often say that the biggest job we have is ) > ( to teach a newly hired employee how to fail intelligently. ) > ( We have to train him to experiment over and over and to keep ) > ( on trying and failing until he learns what will work. ) > ( Charles Kettering ) > http://www.aeroelectric.com > > ________________________________________________________________________________
Subject: Starter Contactors Available?
Date: Jun 22, 2001
09:03:26 PM A Tiger owner tells me that somebody told him starter contactors are no longer available. I can't believe that, as the contactor used in the Tiger is the same as in dozens of other makes and models. What's a good source? (Production aircraft, so we'd need either the original part or a nearly identical part currently in use on production aircraft.) Steve Williams http://www.sbw.org/ ________________________________________________________________________________
Date: Jun 24, 2001
> You can use plain vanilla toggles . . . If your > right mag doesn't have an impulse coupler, I prefer > to use DPST (S700-2-3 in our catalog) and wire the > second poles in series with the starter push button > (See S710-1) such that the starter cannot be engaged > unless the left mag is ON and the right mag is OFF. Bob, If I understand the wiring diagram on page Z-9, you used 2-5 switches for the mags, which eliminates the starter button if you use the spring loaded position for start. Does this also reduce the safety margin by only requiring movement of one device to begin rotating the prop, and if so is there any way to regain the margin with that setup? Joel Harding ________________________________________________________________________________
Date: Jun 24, 2001
on 6/22/01 11:21, Robert L. Nuckolls, III at nuckolls(at)aeroelectric.com wrote: > (1) Diagram uses two 2awg wires to connect battery to contactor and also to >> ground block. Mine will each be 8" in length. I want to order these from >> B&C, but theirs are 4awg. Will these be ok? > > Sure . . . in fact, on an RV with a battery on firewall, you > can use 4AWG throughout. Bob I guess you do still recommend 2awg wire for the rear battery placement? Thanks, Joel Harding ________________________________________________________________________________
Date: Jun 24, 2001
I'm not Bob, but my battery is waaay back in the rear and I believe I've followed Bob's instructions correctly. 1. 2 AWG is necessary, esp. if you use a permanent magnet starter like the Sky-Tec, which I have. 2. Place the the battery contactor (relay) as close to the battery as practical. Mine is mounted to a brace attached to a longeron. The starter contactor stays FWF, so you're running the 2 AWG thru the firewall. 3. It's important that you're battery stay as fully charged as possible, given the long cable run and the current draw from the starter. I ran some 4AWG cables thru the lightening holes in the rear fuse. bulkhead to the empennage deck and attached them to an insulated block. The empennage fairing is held on with just 4 screws, so it's easy to get to for charging or jumping. So, get a charger that can be left on the battery--I use the EPS unit from Australia sold thru AC$, p/n EPS-1208(8 amps)/EPS-1214(14 amps). Boyd Braem Joel Harding wrote: > > > on 6/22/01 11:21, Robert L. Nuckolls, III at nuckolls(at)aeroelectric.com > wrote: > > > (1) Diagram uses two 2awg wires to connect battery to contactor and also to > >> ground block. Mine will each be 8" in length. I want to order these from > >> B&C, but theirs are 4awg. Will these be ok? > > > > Sure . . . in fact, on an RV with a battery on firewall, you > > can use 4AWG throughout. > > Bob > I guess you do still recommend 2awg wire for the rear battery placement? > > Thanks, Joel Harding > ________________________________________________________________________________
Date: Jun 24, 2001
Subject: input and power for music
I want music in my phones, but have changed my mind about a CD player in favor of one those solid state devices that have no moving parts and is immune (for the most part) to vibration. However, I still need power for it and a stereo to mono input to my intercom. What I propose is: For the input, taking the headphone jack from the music player and wiring each signal lead to a 470 ohm resistor, tying them together at the other end, and using that for the signal input to the intercom. For power, which requires 9V will little current (less than .5 amp) I would simply use a 7809 regulator to drop the voltage, along with some capacitors to steady it. Anybody know of a better way? Thanks, Gary Liming ________________________________________________________________________________
Date: Jun 24, 2001
Subject: More music in intercom questions
I was able to wire up a music input to a PS eng. intercom. I would like to use my MP3 player headphone jack - problem is the signal strength is low. Is there a way to amplify the signal? ________________________________________________________________________________
Date: Jun 24, 2001
Subject: Re: More music in intercom questions
Same problem I have with Garmin 340 audio panel and a few others. There is no way to increase signal level inside audio unit, so I developed amplifier. If you interested, drop me a note, I have PC board, and I could make them in small batches. Amplification could be adjust by an voltage control. Been air tested for 8 month. Simple to install/add to existing wiring. Vlad > >I was able to wire up a music input to a PS eng. intercom. I would like >to use my MP3 player headphone jack - problem is the signal strength is >low. Is there a way to amplify the signal? > > ________________________________________________________________________________
Date: Jun 22, 2001
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
> >I'm not Bob, but my battery is waaay back in the rear and I believe I've >followed Bob's instructions correctly. > >1. 2 AWG is necessary, esp. if you use a permanent magnet starter like >the Sky-Tec, which I have. If the battery is behind the cockpit, 2AWG is recommended. >2. Place the the battery contactor (relay) as close to the battery as >practical. Mine is mounted to a brace attached to a longeron. The >starter contactor stays FWF, so you're running the 2 AWG thru the firewall. >3. It's important that you're battery stay as fully charged as >possible, given the long cable run and the current draw from the >starter. I ran some 4AWG cables thru the lightening holes in the rear >fuse. bulkhead to the empennage deck and attached them to an insulated >block. The empennage fairing is held on with just 4 screws, so it's >easy to get to for charging or jumping. So, get a charger that can be >left on the battery--I use the EPS unit from Australia sold thru AC$, >p/n EPS-1208(8 amps)/EPS-1214(14 amps). This kind of attention paid to a recombinant gas battery is not necessary. The self discharge rate on an RG battery is less than 1/2 of 1% per day . . . unless you plan store the airplane for a very long time, I would not worry about keeping a charger on the battery. Bob . . . ________________________________________________________________________________
Date: Jun 22, 2001
> >on 6/22/01 11:21, Robert L. Nuckolls, III at nuckolls(at)aeroelectric.com >wrote: > >> (1) Diagram uses two 2awg wires to connect battery to contactor and also to >>> ground block. Mine will each be 8" in length. I want to order these from >>> B&C, but theirs are 4awg. Will these be ok? >> >> Sure . . . in fact, on an RV with a battery on firewall, you >> can use 4AWG throughout. > >Bob >I guess you do still recommend 2awg wire for the rear battery placement? > >Thanks, Joel Harding YES . . . ________________________________________________________________________________
Date: Jun 25, 2001
Hi Vlad, I am interrested, could you send me the schematic diagram ? Regards, Jesse ----- Original Message ----- From: "ET - #PU" <psi(at)hillweb.com> Sent: Monday, June 25, 2001 4:06 AM Subject: Re: AeroElectric-List: More music in intercom questions > > Same problem I have with Garmin 340 audio panel and a few others. > There is no way to increase signal level inside audio unit, so I developed > amplifier. If you interested, drop me a note, I have PC board, and > I could make them in small batches. > Amplification could be adjust by an voltage control. Been air tested > for 8 month. Simple to install/add to existing wiring. > Vlad > > > > > >I was able to wire up a music input to a PS eng. intercom. I would like > >to use my MP3 player headphone jack - problem is the signal strength is > >low. Is there a way to amplify the signal? > > > > > > ________________________________________________________________________________
Date: Jun 25, 2001
Currently this product we offered for sale, and we are sorry, but we could not provide any schematic. With unit we will provide connection diagram. Just buy product and fly! Do you want to resale products? We have more in our product line: - Anticollision Light Unit; - Audio Unit; - Servo Control Unit (will control two RC servo, mainly used for aerodynamical timers and other actuated applications); - Fuel Measurement and Warning unit; ... Please visit our site with UNET(tm) technologies: http://www.unet.umbtech.com Vlad > > >Hi Vlad, > >I am interrested, could you send me the schematic >diagram ? > >Regards, > >Jesse >----- Original Message ----- >From: "ET - #PU" <psi(at)hillweb.com> >To: >Sent: Monday, June 25, 2001 4:06 AM >Subject: Re: AeroElectric-List: More music in intercom questions > > > > > > Same problem I have with Garmin 340 audio panel and a few others. > > There is no way to increase signal level inside audio unit, so I developed > > amplifier. If you interested, drop me a note, I have PC board, and > > I could make them in small batches. > > Amplification could be adjust by an voltage control. Been air tested > > for 8 month. Simple to install/add to existing wiring. > > Vlad > > > > > > > > > >I was able to wire up a music input to a PS eng. intercom. I would like > > >to use my MP3 player headphone jack - problem is the signal strength is > > >low. Is there a way to amplify the signal? > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 25, 2001
> > >> You can use plain vanilla toggles . . . If your >> right mag doesn't have an impulse coupler, I prefer >> to use DPST (S700-2-3 in our catalog) and wire the >> second poles in series with the starter push button >> (See S710-1) such that the starter cannot be engaged >> unless the left mag is ON and the right mag is OFF. > > >Bob, >If I understand the wiring diagram on page Z-9, you used 2-5 switches for >the mags, which eliminates the starter button if you use the spring loaded >position for start. Does this also reduce the safety margin by only >requiring movement of one device to begin rotating the prop, and if so is >there any way to regain the margin with that setup? > >Joel Harding Explain the "lost safety margin" . . . what condition do you perceive that puts a pilot into a panic mode to energize the starter? Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
From: Marshall Robert <rmarshall@pilatus-aircraft.com>
Date: Jun 25, 2001
I would tend to agree with Joel... OK in flight it's not a problem but surely a single inadvertent action that could rotate a propeller is a hazard on the ground. It's not really a panic mode more an accidental knock of a switch that should be guarded against, there I've just answered my own objection put a guard on the switch = 2 actions to start. Bob Marshall -----Original Message----- From: Robert L. Nuckolls, III [mailto:nuckolls(at)aeroelectric.com] Sent: Monday, June 25, 2001 6:18 PM Subject: AeroElectric-List: Re: Mag Toggle Swithces > >Bob, >If I understand the wiring diagram on page Z-9, you used 2-5 switches for >the mags, which eliminates the starter button if you use the spring loaded >position for start. Does this also reduce the safety margin by only >requiring movement of one device to begin rotating the prop, and if so is >there any way to regain the margin with that setup? > >Joel Harding Explain the "lost safety margin" . . . what condition do you perceive that puts a pilot into a panic mode to energize the starter? Bob . . . ________________________________________________________________________________
Subject: Avionics book?
Date: Jun 25, 2001
Hello, I'm looking for some sort of book that would describe the electronics used in small planes. Best would be at a "technician" level, e.g. for someone who is already in electronics - not to waste my time and paper trying to teach the difference between voltage and current, and how a resistor works - I already know these things, thank you. The book I'm looking for would describe in detail the frequencies and modulation used for VOR signals. It would describe the standard interfaces between navcoms, glideslope receivers, indicators, and GPS's. It would describe the frequencies and pulses for DME's and transponders. It would tell the Gray codes used for mode C. Is there anything like this out there? Thanks in advance, - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jun 25, 2001
on 6/25/01 10:17, Robert L. Nuckolls, III at nuckolls(at)aeroelectric.com wrote: > > Explain the "lost safety margin" . . . what condition do you > perceive that puts a pilot into a panic mode to energize the > starter? I was thinking more about accidentally bumping the switch with my size thirteens, rather than being in some kind of panic mode. Even though I will place the switches in the lower right corner of the panel, I don't have experience yet crawling in and out of this thing, and it just seemed like it might be safer to require two actions to start the prop rotating rather than one. Thanks, Joel Harding ________________________________________________________________________________
Subject: More: Starter Contactors Available?
Date: Jun 25, 2001
05:38:30 PM I'm told that the Grumman parts book calls for a Prestolite starter contactor, and no replacement part has ever been identified. A Stancor replacement for the MASTER contactor, 70-914, is available, but Stancor doesn't make a corresponding intermittent duty contactor. In fact, the official drawings for the AG5B (the updated version of the AA5B, with a 24V electrical system, alas) call for a Stancor 70-915 as the starter contactor. Trouble is, that's the 24V version of the 70-914 continuous-duty contactor! I haven't actually HEARD of a lot of AG5B starter contactors sticking due to the use of this inappropriate part, but I am a bit surprised that FAA approved American General's production with that part. Now the AG5B is about to go back into production. I don't yet know whether they'll use a more appropriate part. I just KNOW that Cessna, Piper, Mooney, and every homebuilt out there are using an appropriate intermittent-duty contactor. Who's the manufacturer? What's the part number? If it's PMA'd for another production aircraft, I'm sure it'd be easy to get it approved in a Grumman. Thanks for any information you can provide. ________________________________________________________________________________
Date: Jun 25, 2001
Subject: Re: 403mc Audio System
>Good afternoon Bob, >Trying to trouble shoot why I can not transmit on my intercom. Volume and >squelch seem to work but no mike sound. Checked wires and connections. >Looking at your sketch and Flightcom's I note a difference of connections. >Flightcom's pin two goes to the short post on the mic jack. Yours to the >tall post. This is reversed on all your mic jacks. Could this be my problem? >Best regards, >Bruce Bell >Lubbock, Texas Not sure what you mean by "short" post and "tall" post. I've photographed a typical microphone jack and plug and identified their respective functions and terminals on the microphone jack. You are invited to check my "shop notes" at . . . http://www.aeroelectric.com/articles/micjack/micjack.html See if this explanation helps you sort out where the wires go on your connections to the microphone jack. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 25, 2001
Subject: Ipaq user feedback needed
Listers, Does anyone have experience with a Compaq Ipaq's survivability when dropped? Mine didn't. I had just received it (it was a gift; I'm a really great guy :->) & it did not survive a fall from waist height to a hard surface floor. If my experience is a fluke & others have had them survive this kind of 'test' then I will consider keeping it. The AnywhereMap software is really nice. If they aren't rugged enough to survive short falls like this, I'll have to return it & go for a conventional a/c GPS. Thanks for your input. Charlie ________________________________________________________________________________
Subject: 403mc Audio system
Date: Jun 25, 2001
Hi Bob, I didn't understand the mic symbol on your drawing. I took the short barb as the ring and the middle barb as the tip. But now I see you are using the short barb as the tip and the middle barb as the ring. Is this correct? I guess to reason out the symbol is to insert the mic plug from right to left. Doing this your drawing is correct and I wired my mic jacks backwards. Live and learn! I guess that is what home building is all about! Pulling all the mic jacks and doing it right! Best regards, Bruce Bell Lubbock, Texas ________________________________________________________________________________
Date: Jun 25, 2001
My wife's palm met the same fate after only two weeks. It fell from waist high to the carpeted floor. The screen cracked. Her's was free (!!!) at a trade show - it was the wireless one too. $100 to replace. It may seem sort of fragile, but would any of the Garmin products do any better in the same circumstance? I keep my IPAQ in it's zippered leather case when away from the desk. I haven't tried the anywhere map yet, but I'm tempted. Larry Bowen RV-8 canoe Email: Larry(at)BowenAero.com Web: http://BowenAero.com > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > Charlie and Tupper England > Sent: Monday, June 25, 2001 7:29 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Ipaq user feedback needed > > > England > > Listers, > > Does anyone have experience with a Compaq Ipaq's > survivability when dropped? Mine didn't. I had just received > it (it was a gift; I'm a really great guy :->) & it did not > survive a fall from waist height to a hard surface floor. > > If my experience is a fluke & others have had them survive > this kind of 'test' then I will consider keeping it. The > AnywhereMap software is really nice. > > If they aren't rugged enough to survive short falls like > this, I'll have to return it & go for a conventional a/c > GPS. > > Thanks for your input. > > Charlie > > ________________________________________________________________________________
From: "Harley, Ageless Wings" <Harley(at)AgelessWings.com>
Date: Jun 25, 2001
Hi, Charlie.. >>Does anyone have experience with a Compaq Ipaq's survivability when dropped? ...it did not survive a fall from waist height to a hard surface floor.<< I had left mine on the roof of my car (an RX-7) and forgot about it until I closed the drivers door, and saw it fall past the passenger window, onto the driveway. It's still fine. But, then again, maybe mine landed "just right". I sure don't want to test it to see how much it can take! I carry it with me everywhere, no problems yet. Harley Dixon ________________________________________________________________________________
Date: Jun 26, 2001
Subject: Re: 403mc Audio system
> >Hi Bob, >I didn't understand the mic symbol on your drawing. I took the short barb >as the ring and the middle barb as the tip. But now I see you are using the >short barb as the tip and the middle barb as the ring. Is this correct? Yes . . . if you stuck a plug into the symbolic jack, which contact would touch which part of the plug? >I >guess to reason out the symbol is to insert the mic plug from right to left. >Doing this your drawing is correct and I wired my mic jacks backwards. Live >and learn! I guess that is what home building is all about! Pulling all the >mic jacks and doing it right! I think you're on the right track my friend. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 26, 2001
> >on 6/25/01 10:17, Robert L. Nuckolls, III at nuckolls(at)aeroelectric.com >wrote: > >> >> Explain the "lost safety margin" . . . what condition do you >> perceive that puts a pilot into a panic mode to energize the >> starter? > >I was thinking more about accidentally bumping the switch with my size >thirteens, rather than being in some kind of panic mode. Even though I will >place the switches in the lower right corner of the panel, I don't have >experience yet crawling in and out of this thing, and it just seemed like it >might be safer to require two actions to start the prop rotating rather than >one. > >Thanks, > >Joel Harding It does . . . the battery master has to be on and the mag switch raised to the start condition at the same time. Actually, it's probably better to use two S700-2-3 switches and a guarded push button. You can combine the start switch into the right mag's spring loaded full-up with an S700-2-5 . . . but this functions the same way as the right mag disable jumper on the classic off-l-r-both-start keyswitch. There is still risk of having the engine still be rotating and the right mag firing to early during an aborted crank. If it were MY airplane and I had two mags, there would be two S700-2-3 switches and a push button. I'd run the starter pushbutton in series with MAG ON contacts of the left mag switch and MAG OFF contacts of the right mag switch. Figure Z-1, Revision 10 to the 'Connection will show this configuration. Bob . . . ________________________________________________________________________________
Subject: Daniels Wire Crimper
Date: Jun 26, 2001
I have a Daniels Mfg. Co. HX4 M22520/5-01 crimper (with M22520/5-100 dies for 10-26 gauge crimps), http://www.dmctools.com/dmctools/open-frame.html. I've contacted the manufacturer for an instruction sheet, in the meantime can anyone tell me how to use this beast so I can start wiring? Thanks. Rob Acker (RV-6Q, painting & wiring) ________________________________________________________________________________
Date: Jun 26, 2001
Subject: Re:TNC connectors
Bob: My GPS antenna requires a TNC connector. Could you recommend a mfg. and part no. for RG-400 coax. Also the GPS requires an altitude input D4 from the encoder but my encoder only supplies A1 thru C4. Would you please comment on this? Thanks, Steve ________________________________________________________________________________
Date: Jun 26, 2001
> > Bob: > > My GPS antenna requires a TNC connector. Could you recommend a mfg. and part > no. for RG-400 coax. Also the GPS requires an altitude input D4 from the > encoder but my encoder only supplies A1 thru C4. Would you please comment on > this? *** Well, I can't address the TNC connector, but the D4 wire... ....is for higher altitudes. One extra wire doubles the # of altitudes for a normal binary code, not sure what it does for Gray code. You can leave this D4 input unconnected, or maybe pull it high - although I think the standard is for inputs to have their own pullup resistors. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jun 26, 2001
Subject: Re: Daniels Wire Crimper
> >I have a Daniels Mfg. Co. HX4 M22520/5-01 crimper (with M22520/5-100 dies >for 10-26 gauge crimps), http://www.dmctools.com/dmctools/open-frame.html. > >I've contacted the manufacturer for an instruction sheet, in the meantime >can anyone tell me how to use this beast so I can start wiring? Thanks. You generally don't get instructions (except perhaps a note on how to change dies) with this kind of tool. For most folk in the industry, a crimp tool is like a screwdriver or hammer . . . I'd just get some terminals (cheap hardware store plasti-grips are fine) and do some experimentation. When you can do a pretty job on a junk terminal, you're ready to put the good ones into your airplane. Bob . . . ( An inventor is simply a person who doesn't take his education ) ( too seriously. We often say that the biggest job we have is ) ( to teach a newly hired employee how to fail intelligently. ) ( We have to train him to experiment over and over and to keep ) ( on trying and failing until he learns what will work. ) ( Charles Kettering ) http://www.aeroelectric.com ________________________________________________________________________________
Date: Jun 26, 2001
> >I have a Daniels Mfg. Co. HX4 M22520/5-01 crimper (with M22520/5-100 dies > >for 10-26 gauge crimps), http://www.dmctools.com/dmctools/open-frame.html. Is this tool suitable for crimping large wire gauges (4, 6, 8?) with the correct dies? Or is there another recommended tool for doing these larger sizes? Bob Steward Birmingham, AL ________________________________________________________________________________
Date: Jun 26, 2001
By replacing the dies, you can crimp many different types of connectors. I have ordered a catalog on-line to find out what selection is available. Rob. -----Original Message----- FROM: Bob Steward DATE: Tue 6/26/01 10:18 SUBJECT: Re: AeroElectric-List: Re: Daniels Wire Crimper > >I have a Daniels Mfg. Co. HX4 M22520/5-01 crimper (with M22520/5-100 dies > >for 10-26 gauge crimps), http://www.dmctools.com/dmctools/open-frame.html. Is this tool suitable for crimping large wire gauges (4, 6, 8?) with the correct dies? Or is there another recommended tool for doing these larger sizes? Bob Steward Birmingham, AL ________________________________________________________________________________
Date: Jun 26, 2001
> You generally don't get instructions (except perhaps a note on > how to change dies) with this kind of tool. For most folk in the > industry, a crimp tool is like a screwdriver or hammer . . . > I'd just get some terminals (cheap hardware store plasti-grips > are fine) and do some experimentation. When you can do a pretty > job on a junk terminal, you're ready to put the good ones into > your airplane. > > > Bob . . . Bob, Thanks for the reply. Indeed, all I got was a die change diagram (however, their web page had a nice sample step-by-step instruction sheet, which is what I am after). First, should I be using this tool? Or was I sold a bill of goods as this being one of the finest? Should I use the tool on the B&C page? I have experimented on a few terminals. The result is not readily visible, so how to I know I have the wire properly crimped and the strain relief properly done? Thanks, Rob (Wiring 101 for Dummies ) ________________________________________________________________________________
Subject: 403mc
Date: Jun 26, 2001
Hi Bob, Changed the wires around on the mic jacks and hooked up the radio correctly, per your 403mc drawing, and everything checks out. Didn't have another radio around but I do get a transmit light and side tone with the PTT. A word of caution, make sure the volume and squelch controls on the intercom are all the way down when you turn the battery switch on the first time. If not the noise will blast your ear drums. Ask me how I know! Thank you for all the help on this puppy. Best regards, Bruce Bell Lubbock, Texas ________________________________________________________________________________
Date: Jun 26, 2001
> I have experimented on a few terminals. The result is not readily > visible, so how to I know I have the wire properly crimped and the strain > relief properly done? *** Light Plane Maintenance had a really good article on crimpers and terminals a year or so ago. They made up a test jig with a crank and an inline scale, the kind you might use for weighing fish. Basically, they were looking for pullout strength. The bigger numbers they got on the scale, the better. They were also happy if the wire broke in two, rather than pulling out at the crimp. The very best crimps were done by a $300 AMP tool. The second best, as I remember, were a $70 tool made by Sargent. All of the "good" tools they reviewed were ratchet tools with removable dies. They also reviewed one general purpose "electrician" tool. It sucked, but they were able to get good crimps with decent connectors. With the combination of a cheap tool, and cheap connectors, they were unable to get a good crimp :). It also mattered which brand and type of connector was used. AMP came out on top, again... I don't remember any of the also-rans, I buy AMP.
May 22, 2001 - June 26, 2001
AeroElectric-Archive.digest.vol-af
