Pietenpol-Archive.digest.vol-le
April 15, 2012 - May 06, 2012
[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, April 15, 2012 12:10 PM
Subject: Re: Wing Tip Bows
Here's where I am. I could get the temp compression stud out after mounting the wing tip with a saw if I had to. Jack, thanks for the info on tammeling. I assume it is imperative that the points you pick on the front and rear spars must line up from fore to aft exactly to get everything square. -------- John ________________________________________________________________________________
Date: Apr 15, 2012
Gary is correct. Trammel it before the LE and TE are attached. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Gary Boothe Sent: Sunday, April 15, 2012 1:40 PM Subject: RE: Pietenpol-List: Re: Wing Tip Bows Additional thought, John...I think it was Skip Gadd who talked about trammeling at least 3 times, during each phase of the construct. Seems like it would be a mistake to trammel the first time after the leading and trailing edges are on. Gary from Cool NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, April 15, 2012 9:10 AM Subject: Pietenpol-List: Re: Wing Tip Bows Here's where I am. I could get the temp compression stud out after mounting the wing tip with a saw if I had to. Jack, thanks for the info on tammeling. I assume it is imperative that the points you pick on the front and rear spars must line up from fore to aft exactly to get everything square. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370866#370866 Attachments: http://forums.matronics.com//files/tram4_192.jpg http://forums.matronics.com//files/tram3_849.jpg http://forums.matronics.com//files/tram2_154.jpg http://forums.matronics.com//files/tram1_203.jpg ________________________________________________________________________________
Date: Apr 15, 2012
John I made my wing tips out of poplar. Looks like I used 7 layers. It doesn't matter how many you use. I made them thin enough so they did not need soaking to bend. To form the tip I traced a wing rib on the back of my wing rib jig. I also marked where the end of the tapered end of the spars are. I then measured and drew a center line down the traced wing rib. I measured half inch above and below to draw the outer lines of the wing tip. Make sure you adjust the line so it coincides with the wing spars. I covered the board with plastic wrap, then hammered in 10 or 15 nails along the outer lines. Trial fit the sticks. After I had it all set up, I quickly glued each stick with T-88, stacked them together, covered them with plastic wrap and clamped with 1-inch binder clips. After they dried I sanded off the excess glue and rounded off the outer edges with my router but a plane or sand paper would work too. Some pictures http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_5056.JPG http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_5058.JPG http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_6043.JPG http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_6044.JPG Installed http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_5559.JPG http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_5560.JPG Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, April 15, 2012 8:27 AM Subject: Pietenpol-List: Re: Wing Tip Bows Gary, My plan shows 4 pieces of 1/4" laminated together. Did you soak and bend the plywood to shape? Did you then glue them together, clamp, and sand to the finished piece? John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370860#370860 ________________________________________________________________________________
Subject: 8-32 Machine Screws
Date: Apr 15, 2012
John, If you talking about the leading edge of the wing, I have no screws or bolts. I clamped it on. http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_5045.JPG Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Saturday, April 14, 2012 12:30 PM Subject: Pietenpol-List: 8-32 Machine Screws Can I use standard hardware screws to attach the leading edge or is this screw required to be aircraft grade? If so I can't find them in the ACS catalog. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370787#370787 ________________________________________________________________________________
Date: Apr 15, 2012
Without the wing tip bow in place we could still trammel the inner bay, correct? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370896#370896 ________________________________________________________________________________
Date: Apr 15, 2012
Yes. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Sunday, April 15, 2012 2:53 PM Subject: Pietenpol-List: Re: Wing Tip Bows Without the wing tip bow in place we could still trammel the inner bay, correct? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370896#370896 ________________________________________________________________________________
Date: Apr 15, 2012
Subject: Traveling to DFW area
If anyone on the list in the Dallas/Fort Worth metroplex would welcome a visit next Saturday afternoon, April 21, I'll be flying into DFW and will have a rental car and a bit of free time on my hands. I'd be delighted to spend an hour or two talking Pietenpols or lending a hand. Let me know off-list. Cheers, Ken ________________________________________________________________________________
Date: Apr 15, 2012
During Oshkosh 2004 we covered Mr. Pietenpol's 1966 Aircamper. It is the plane that is on display in the Pietenpol Hanger. Here is how he constructed the one piece wing in 1966. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370912#370912 Attachments: http://forums.matronics.com//files/wingtip_compression_strut_214.jpg ________________________________________________________________________________
Date: Apr 15, 2012
Sorry, This should look better than the previous... The compression strut was 3/4 X 3/4. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370913#370913 Attachments: http://forums.matronics.com//files/wingtip_compression_strut_209.jpg ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: Dangerous Dave's Piet
Date: Apr 16, 2012
Someone asked about the status of Dangerous Dave's "quick-build" Piet. I emailed him a few months ago since we haven't heard much after the first flight, and he didn't say a lot. Sounds like it hasn't flown much, that he's been very busy and the plane has moved airports. I too got the impression that he was disappointed with it's performance, but I think it was a pretty high runway. That's about all I Know. Dave, if you're still following the list, we'd sure be interested in a flight report. Douwe ________________________________________________________________________________
From: "skipgadd(at)earthlink.net" <skipgadd(at)earthlink.net>
Date: Apr 16, 2012
You are right Gary, had to look in the archives to recall what I said, Aug 8 2009. I agree with you, it is a good idea to measure corner to corner both ways frequently while assembling the wing, so the wing is as close as possible to square before you do the actual trammeling with turnbuckles. Skip > [Original Message] > From: Gary Boothe <gboothe5(at)comcast.net> > To: > Date: 4/15/2012 1:47:41 PM > Subject: RE: Pietenpol-List: Re: Wing Tip Bows > > > Additional thought, John...I think it was Skip Gadd who talked about > trammeling at least 3 times, during each phase of the construct. Seems like > it would be a mistake to trammel the first time after the leading and > trailing edges are on. > > Gary from Cool > NX308MB ________________________________________________________________________________
Subject: Re: aileron deflection
Date: Apr 16, 2012
Using .040" thick piano hinges for my ailerons and dimpling for 10-32 flatheads(to set flush), I get 20.6 degrees of down travel before the hinge plates close tight on each other. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370924#370924 ________________________________________________________________________________
Date: Apr 16, 2012
That's cool to see. My wing tips look a lot like this one. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: considering a piet build
Date: Apr 16, 2012
how does it fly ( climb, handle, stall , ground hanle) compared to a cub. previously owned a 1940 c85 cub. thinking of building one and teaching my two boys ( now 8 and 12 years) how to fly in it. also; love the wood struts, and gear, do builders just cover in spar varnish or fiberglass or just epoxy resin? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370934#370934 ________________________________________________________________________________
Date: Apr 16, 2012
Nightmare? First, what is your real name and where do you live? We kind of like to know names so we can put them with faces when we meet at Brodhead. Second, a Pietenpol flies more like a Cub than anything else I've ever flown - that's why I built one. I used to own a 1946 J-3 with a Continental 65 and chose to build a Pietenpol because I couldn't afford to buy a Cub at today's prices. I will say having flown both types, the Cub style "Improved" Pietenpol gear is easier to land than the straight axle wire wheel variety. If I were building one with an eye towards teaching kids to fly in it, I would build the Cub-Style gear. As for the wood struts, I have laminated spruce landing gear struts on mine and simply coated them with 4 coats of epoxy varnish, and they've held up very well in nearly 8 years of flying. For wooden lift struts and cabane struts I expect epoxy varnish would do even better (the landing gear takes more abuse from tall grass, rocks, etc.). Good Luck! Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of nightmare Sent: Monday, April 16, 2012 9:47 AM Subject: Pietenpol-List: considering a piet build how does it fly ( climb, handle, stall , ground hanle) compared to a cub. previously owned a 1940 c85 cub. thinking of building one and teaching my two boys ( now 8 and 12 years) how to fly in it. also; love the wood struts, and gear, do builders just cover in spar varnish or fiberglass or just epoxy resin? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370934#370934 ________________________________________________________________________________
Subject: Wing Hinge Strap
Date: Apr 16, 2012
Since the center section wing straps go on the inside of the wing straps I am assuming the plywood on the wing must be cut out for clearance? Looks like I missed this on the plans :( John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370941#370941 Attachments: http://forums.matronics.com//files/ws1_700.jpg ________________________________________________________________________________
Date: Apr 16, 2012
I'll be darn... the plans don't show it that way! The only braces I have are the ones shown in the plans (in red), but the plans also show a spruce wing tip bow, where I made mine from white pine. Perhaps I should look at adding the compression strut and additional braces that the 66 model have. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370945#370945 Attachments: http://forums.matronics.com//files/wing_braces_147.jpg ________________________________________________________________________________
Date: Apr 16, 2012
One of those little areas in the plans that simply can't be built as drawn. Vi Kapler put those in just to see if you were paying attention. The straps are .090" thick, or nearly the same as a piece of 3/32" plywood. You'll have to figure out how to arrange the doublers so the straps can overlap each other. I chose to just put the plywood doublers on the wing spars and omit them on the centersection spars, allowing the wing straps to just slip over the centersection straps as shown in the photo below: Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Monday, April 16, 2012 10:36 AM Subject: Pietenpol-List: Wing Hinge Strap Since the center section wing straps go on the inside of the wing straps I am assuming the plywood on the wing must be cut out for clearance? Looks like I missed this on the plans :( John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370941#370941 Attachments: http://forums.matronics.com//files/ws1_700.jpg ________________________________________________________________________________
Subject: Re: Wing Hinge Strap
Date: Apr 16, 2012
You are right John, but it isn't really pointed out in the plans. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370946#370946 ________________________________________________________________________________
Date: Apr 16, 2012
If it is not too late John, you can add another piece of plywood under your CS straps to make room for the wing strap. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 16, 2012
Subject: Re: considering a piet build
Nightmare, welcome. I can't answer any flying characteristic questions as my plane is still being built. However, on the wood...a varnish or some sort of wood protectant is needed. I use spar varnish on mine. Personally, I am fine with call signs. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 16, 2012
Or you can just remove your wing straps and Dremel/file/sand the material you need removed for clearance. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370950#370950 ________________________________________________________________________________
Date: Apr 16, 2012
As an owner of both I have to concur with what Jack stated. The Piet is very similar to the Cub in lot of ways. A few observations below: The Piet is a bit faster. My Cub is slow and 502rocket is pretty quick. I cruise easily at 75-77 and my Cub cruises at about 72. The sight lines are similar. Backseat solo gives the same lack of visibility that at Cub gives, especially on the ground. It is easier to lean your head out of the Piet to see around. Major flight numbers are about the same for both. Climb and final speeds the same. The Piet does have a much worse glide ratio than a Cub. Just plan accordingly. Stall is sharper than a Cub. Nothing bad but it drops quickly and is easily picked up with proper technique. Te be fair I have vortex generators on the Cub so it does not really stall at all. It just kind of mushes and nods its head. The Cub is much easier to load/unload and is more capable of giving the fat guy a ride. It does have seven more feet of wing and is more tolerant of CG and gross weight issues. The Cub has brakes for both occupants, a must for instruction. I have not seen a Piet that had brakes in the front but I bet it has been done with weight penalties and seldom use. The Cub rides turbulence better. When in bumps in a Cub one seems to instinctively be able to predict the airplane's response. In the Pietenpol it is "wahoo" we are along for the ride. I just pull the shoulder strap a little tighter. My daughter loves it because "it is like being in a roller coaster." Cub has a door that closes and some semblance of cabin heat, however, nothing is quite like the feeling of open cockpit. That is about all I can think of for now. -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Apr 16, 2012, at 10:18 AM, Michael Perez wrote: > Nightmare, welcome. > > I can't answer any flying characteristic questions as my plane is still being built. However, on the wood...a varnish or some sort of wood protectant is needed. I use spar varnish on mine. > > Personally, I am fine with call signs. > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > > > ________________________________________________________________________________
Date: Apr 16, 2012
Another wing tip bow example with a built up last rib and capping for additional strength. Not sure how much difference this makes when in compression but probably can't hurt. -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370951#370951 Attachments: http://forums.matronics.com//files/dsc00400_132.jpg http://forums.matronics.com//files/dsc00375_149.jpg ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Subject: Re: Need some help....off topic...
Date: Apr 16, 2012
Jim, I rebuilt a Piper PA22 a few years back and when I got ready to fly it, I took the spark plugs out and turned the engine over with the starter until the oil pressure built up. I then reinstalled the plugs, put fuel in the tanks, and started the engine normally. The engine ran fine until I sold it a couple of years later. A little MMO in the oil also helped a lot. It frees the rings and gives much better compression. Chuck ----- Original Message ----- From: "Jim Markle" <jim_markle(at)mindspring.com> Sent: Saturday, April 14, 2012 7:13 PM Subject: Pietenpol-List: Need some help....off topic... > > > A pilot friend passed on about a year (or two) ago and his Champ has just > been sitting...his daughter owns it now....it's on a grass strip about a > mile from us. > > I've recommended to her that we at least pull it out of the hangar and > start it from time to time. And she's fine with me taking it up if I > want. (Of course I'm fine with that!). Mainly I hate to see it waste > away...and it will if we don't do something. > > So do we just start propping to get it started or is there some process we > need to follow for an aircraft that's been sitting for so long? > > Sorry for such an "off topic" request but....well....maybe this could lead > to me getting some tailwheel time (yes, I know, ONLY after getting some > tailwheel training...) but that might make me a better Piet pilot, right? > :-) > > If someone has experience with such and could tell me what to watch for > and give some pointers it would be appreciated. > > Offlist please. > > Thanks, > Jim in Pryor (where the storms might pass us by this time....) > > > ________________________________________________________________________________
Date: Apr 16, 2012
As it typical when building a Pietenpol, if you look closely, its on the plans. Take note of the wood grain on the drawings then you will notice there is 3/32-inch plywood under the straps on the wing side and a triangle piece of 3/32-inch ply that is below (below not under) the strap on the center section side. Center section side http://www.westcoastpiet.com/images/Chris%20Tracy/images/IMG_1978.JPG Wing Side http://www.westcoastpiet.com/images/Chris%20Tracy/images/Center_Fitting_Back_Side.JPG -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370967#370967 ________________________________________________________________________________
Date: Apr 16, 2012
Jim, I know the guy who did some of the maintenance and quite possibly the last annual on that airplane. Shot you a text. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370968#370968 ________________________________________________________________________________
Date: Apr 16, 2012
I think what John is talking about is the area in red. It looks pretty obvious, but isn't really called out as needing clearance. -------- Mark Chouinard Wings, Center Section and Empannage framed up - Working on Fuselage Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370975#370975 Attachments: http://forums.matronics.com//files/wing_attach_171.jpg ________________________________________________________________________________
Date: Apr 16, 2012
When I read some of the replies, mentioning how the wingtip bow is actually a compression strut, I thought "that can't be right", since it is curved, and it sits out on the ends of the spars (fastened with brackets and screws). But then I took another look at the plans, and saw that it actually would act as a compression strut. Not really an ideal design , since all of the compressive forces are actually acting on the screws, rather than on the strut itself. While the 1966 BHP wing shown in Dan's photo does add a little bit of weight, it does seem to be a better design (in terms of providing a proper compression strut at the wing tip). When the time comes, I think I'll build mine like that (or similarly). Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370976#370976 ________________________________________________________________________________
Subject: more pictures
Date: Apr 16, 2012
Update with tail on and wheels on. some more pictures, Bob ________________________________________________________________________________
Date: Apr 16, 2012
Mark is correct but with the right tool (laminate trimmer) the job was easy. Thanks to all for the help. I love this list! -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370979#370979 Attachments: http://forums.matronics.com//files/strap4_532.jpg http://forums.matronics.com//files/strap3_130.jpg http://forums.matronics.com//files/strap2_658.jpg ________________________________________________________________________________
Date: Apr 16, 2012
Wow , you guys are great. thanks for all the quick responses. My name is Paul Donahue and i live in royal palm beach florida (5 miles west of west palm beach int'l). If you don't mind , here is a couple of more questions for you. 1.Has any one built a stretch wing Piet? (i know, stick to the plans) 2. Do builders use AN hardware or is the grade 8 nuts and bolts at the hardware store sufficient? (i believe it is same grade steel, usually courser threading though at hardware store) 3. I saw Keri Anns webpage, beautiful bird. any nonbias opinions on the removable wing option ? would love to have option of removing or even folding the wings to bring home. 4. are there any piet builders / owners near me? 5. how about opinions on building out of poplar? Thanks again; seems like a tight knit group Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370982#370982 ________________________________________________________________________________
Date: Apr 16, 2012
Paul, I can only answer one of those: Mine is almost all Poplar (not yet flying); but when it does fly, it won't be the only Poplar Piet. Oh...stay away from that non-A/C hardware stuff! Welcome! Gary from Cool ------Original Message------ From: nightmare Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Re: considering a piet build Sent: Apr 16, 2012 1:02 PM Wow , you guys are great. thanks for all the quick responses. My name is Paul Donahue and i live in royal palm beach florida (5 miles west of west palm beach int'l). If you don't mind , here is a couple of more questions for you. 1.Has any one built a stretch wing Piet? (i know, stick to the plans) 2. Do builders use AN hardware or is the grade 8 nuts and bolts at the hardware store sufficient? (i believe it is same grade steel, usually courser threading though at hardware store) 3. I saw Keri Anns webpage, beautiful bird. any nonbias opinions on the removable wing option ? would love to have option of removing or even folding the wings to bring home. 4. are there any piet builders / owners near me? 5. how about opinions on building out of poplar? Thanks again; seems like a tight knit group Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370982#370982 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Apr 16, 2012
1. I know of at least one "stretched wing" Piet that was up in the Jacksonville area (Pat Green's) 2. You can't easily buy Grade 8 bolts in 3/16 size, and judging by my trip to the hardware store yesterday, I'm not sure they dould be any cheaper. In Florida you can get anything from Aircraft Spruce out of Atlanta in 2 days. 4, I'm located in Titusville, just 150 miles north of you. 5. I built my Pietenpol out of Douglas Fir that I bought locally, and used Okoume plywood that I bought in Palm Beach County. This really is a good group and they were all a great help during my build. Ben Charvet Titusville, Fl NX866BC, 125 hrs so far On 4/16/2012 4:02 PM, nightmare wrote: > --> Pietenpol-List message posted by: "nightmare" > > Wow , you guys are great. thanks for all the quick responses. My name is Paul Donahue and i live in royal palm beach florida (5 miles west of west palm beach int'l). If you don't mind , here is a couple of more questions for you. > 1.Has any one built a stretch wing Piet? (i know, stick to the plans) > 2. Do builders use AN hardware or is the grade 8 nuts and bolts at the hardware store sufficient? (i believe it is same grade steel, usually courser threading though at hardware store) > 3. I saw Keri Anns webpage, beautiful bird. any nonbias opinions on the removable wing option ? would love to have option of removing or even folding the wings to bring home. > 4. are there any piet builders / owners near me? > 5. how about opinions on building out of poplar? > > Thanks again; seems like a tight knit group > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=370982#370982 > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Apr 16, 2012
Paul, Bill Rewey was always talking about building a "Super Pietenpol" with a longer wing, to approximate the wing loading of a Cub. I don't know if any have ever been built. Mine has a 6" longer than normal wingspan, but that was done to increase the volume in the centersection to give more fuel capacity. I will say that making such a change has dramatic ripple effects running through the entire airplane. The best flying Pietenpols seem to be the ones that were built closest to the plans. As Gary said - use aircraft hardware. It is not that much more expensive (maybe less than Grade 8 hardware), and the fine threads will be much more effective for getting accurate torques and for preventing loosening due to vibration. Besides, when you are getting bounced around by turbulence, it is reassuring to not have to wonder if your hardware is going to fail. Opinions on folding wings for a Piet? While that is always an attractive option for people thinking of building an airplane, I've never seen it done in practice. With a Pietenpol, I think it would be a pain due to having to tighten and safety wire the turnbuckles on the bracing wires between the struts every time you wanted to go flying. Also, many Pietenpols use simple bronze bushings on their axles, and while that is more than adequate for the amount of taxiing done at an airport, I wouldn't take any bets on how long a bushing would last being towed at highway speeds. Of course you could load it on a trailer, but that too is expensive. Weight is critical with these airplanes, and any wing folding mechanism is going to add weight that you can ill afford to add. As Walt evans used to say on this list "Simplicate and add Lightness". A wing folding mechanism does neither. There are severl Pietenpol builders/flyers in Florida. I'll leave it to them to contact you. As Gary said, there have been several Piets built of poplar. It is a good light wood. Not as light as spruce (Poplar is 16% heavier than sitka spruce), but somewhat stronger (Poplar's numbers generally run about 20% higher than spruce), so it has about the same strength to weight ratio. It works easily (nearly as easy as spruce, and much better than Douglas Fir, the other common choiceof non-aircraft grade woods). So all in all it is not a bad choice, particularly if you have a lot of experience in grading and selecting wood. Bear in mind that if you are choosing a wood other than aircraft grade spruce just to save money, the cost of the wood in a Pietenpol is something around 10% of the total price of the airplane, using aircraft spruce. You will spend so much more money on other things (primarily the engine) that the cost of wood is insignificant. Good luck with all your choices. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of nightmare Sent: Monday, April 16, 2012 4:03 PM Subject: Pietenpol-List: Re: considering a piet build Wow , you guys are great. thanks for all the quick responses. My name is Paul Donahue and i live in royal palm beach florida (5 miles west of west palm beach int'l). If you don't mind , here is a couple of more questions for you. 1.Has any one built a stretch wing Piet? (i know, stick to the plans) 2. Do builders use AN hardware or is the grade 8 nuts and bolts at the hardware store sufficient? (i believe it is same grade steel, usually courser threading though at hardware store) 3. I saw Keri Anns webpage, beautiful bird. any nonbias opinions on the removable wing option ? would love to have option of removing or even folding the wings to bring home. 4. are there any piet builders / owners near me? 5. how about opinions on building out of poplar? Thanks again; seems like a tight knit group Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370982#370982 ________________________________________________________________________________
Date: Apr 16, 2012
Hi Paul - Welcome. This group is a family, and like all families you'll find some dysfunction. Spend some time here and you'll figure out whose advice you really want. There are a lot of smart, talented people in the group. I personally seek guidance from builders who have completed a plane and fly it a lot. There's something about "flight proven" that you just can't beat. You'll get a lot of advice from fellows who haven't finished their planes and who don't have their pilot's license. They're not necessarily wrong, but they're strictly theoretical. Your questions: 1) Jack Phillips built a stretch wing and says he regrets it. 2) AN Hardware. 3) If you need removable/folding wings you may want to consider another design. 4) There are builders in FL. 5) Gary Boothe has built an entire airplane from poplar. His workmanship is superb. I'm flying wooden wing struts Gary built for me. Anyway, it's up to you. Spruce is the standard, and the spruce from Aircraft Spruce & Specialty has been graded. In the grand scheme of things there's not that much price advantage. My comments: 1) Get familiar with searching the list archives. 2) Get the 4 Tony Bingelis books from EAA. EAA's wood and welding books are also good. Finally, the FAA AC 43-13...whatever is the bible. 3) Plan on attending Brodhead. Again, welcome. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370988#370988 ________________________________________________________________________________
Date: Apr 16, 2012
Just wanted to say welcome, Paul! I'm still building, so can't offer a lot of practical advice. As Jack said, "Good luck with your choices"... there are plenty to consider. -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370989#370989 ________________________________________________________________________________
Subject: For Our New Friends - Who Builds and Flies
Date: Apr 16, 2012
I encourage our new members to pay particular attention to people on the list who have built their own airplanes and who fly them a lot. Please add names of active builder/flyers to the list so they know who I'm talking about. I did not include people I have not seen on the list. List members who built their planes and actively fly: Mike Cuy, Jack Phillips, Larry Williams, Don Emch, Shad & Gary Bell, Randy Bush, Ben Charvet, Greg Cardinal, Lowell Frank, Dan Helsper, Hans van der Voort, Tim Mickel, PF Beck, Kevin Purtee. Cuy, Phillips, Williams, Emch, the Bells, Bush and Purtee fly several hundred mile cross-country flights. Please feel free to add on. I know I didn't get everyone. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370992#370992 ________________________________________________________________________________
Subject: Re: For Our New Friends - Who Builds and Flies
Date: Apr 16, 2012
Kevin, As a relatively new member, I am aware of these people and seek them out when I travel to Brodhead. Many on this list, including you, have met me but just don't remember it. Although I greatly appreciate everyones suggestions and comments, those builders and flyers you've named carry more weight when I make my decisions. Thanks to all for your help. John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370994#370994 ________________________________________________________________________________
Date: Apr 16, 2012
thank you for all the info. i'll search previous entries and order some books to verify this is the plane for me. thanks; Paul Donahue Read this topic online here: http://forums.matronics.com/viewtopic.php?p=370998#370998 ________________________________________________________________________________
Date: Apr 16, 2012
Another option (if not mentioned earlier) that many airplane designs do is use 1/4 inch plates (doublers)-on the c/s spars, and 1/8 inch plates on t he outboard wing spars.- this way the outboard -wing spar fittings fit inside the c/s spar fittings.- The plywood spar doublers act to prevent t he spars from splitting.- As you can see there are many ways to skin-th is cat. - Shad- - From: Jack Phillips <pietflyr(at)bellsouth.net> Subject: RE: Pietenpol-List: Wing Hinge Strap Date: Monday, April 16, 2012, 10:52 AM One of those little areas in the plans that simply can't be built as drawn. -Vi Kapler put those in just to see if you were paying attention. - The straps are .090" thick, or nearly the same as a piece of 3/32" plywood. - You'll have to figure out how to arrange the doublers so the straps can overlap each other.- I chose to just put the plywood doublers on the win g spars and omit them on the centersection spars, allowing the wing straps to just slip over the centersection straps as shown in the photo below: - - Jack Phillips NX899JP Smith Mountain Lake, Virginia - -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of Kringle Sent: Monday, April 16, 2012 10:36 AM Subject: Pietenpol-List: Wing Hinge Strap - - Since the center section wing straps go on the inside of the wing straps I am assuming the plywood on the wing must be cut out for clearance?- Looks like I missed this on the plans- :( - John - -------- John - - - - Read this topic online here: - http://forums.matronics.com/viewtopic.php?p=370941#370941 - - - - Attachments: - http://forums.matronics.com//files/ws1_700.jpg - - - - - - ________________________________________________________________________________
Date: Apr 16, 2012
Bill Church wrote: > Ralph, > > The plans don't list deflections for any of the control surfaces, but in the UK, the LAA has documented the recommended travels, and shows typical aileron deflection to be 15 Up and 20 Down (that translates to about 3" up and 3 1/2" down. > http://www.lightaircraftassociation.co.uk/engineering/TADs/047%20PIETENPOL%20AIRCAMPER.pdf > > Bill C. If there is going to be any aileron differential at all, wouldn't a sane person want more Up than Down? -------- Bill Frank Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371004#371004 ________________________________________________________________________________
Date: Apr 16, 2012
Welcome to the group Paul. I live about 50 miles east of Pensacola,Fl. I extended the wingspan on my 1 piece wing. It is 32' 6". The reason I did is my runway is only 1300 feet long and hope to shorten the take off run some and maybe climb a little bit better. I have not flown it yet but hope to have it ready in a couple of months. As to the AN bolts and washers they are cheaper at Aircraft Spruce than my local Lowes. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 now covering and painting 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371005#371005 ________________________________________________________________________________
Date: Apr 16, 2012
Add Dick Navratil and Bob Poore. Lots of good, relevant experience. Greg Cardinal ----- Original Message ----- From: "kevinpurtee" <kevin.purtee(at)us.army.mil> Sent: Monday, April 16, 2012 4:54 PM Subject: Pietenpol-List: For Our New Friends - Who Builds and Flies > > > I encourage our new members to pay particular attention to people on the > list who have built their own airplanes and who fly them a lot. Please > add names of active builder/flyers to the list so they know who I'm > talking about. I did not include people I have not seen on the list. > > List members who built their planes and actively fly: Mike Cuy, Jack > Phillips, Larry Williams, Don Emch, Shad & Gary Bell, Randy Bush, Ben > Charvet, Greg Cardinal, Lowell Frank, Dan Helsper, Hans van der Voort, Tim > Mickel, PF Beck, Kevin Purtee. > > Cuy, Phillips, Williams, Emch, the Bells, Bush and Purtee fly several > hundred mile cross-country flights. > > Please feel free to add on. I know I didn't get everyone. > > -------- > Kevin "Axel" Purtee > NX899KP > Austin/San Marcos, TX > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=370992#370992 > > > ________________________________________________________________________________
From: "Dortch, Steven D MAJ NG NG NGB" <steven.d.dortch(at)us.army.mil>
Date: Apr 16, 2012
Subject: OT The other end of the performance envelope. 787
>From the Beech list. Thot y'all might like the other perspective: >From a friend of my friend the retired AA Captain Pete. _____ Hi All, I just completed the first pilot training class on the 787 at United Airlines, an airplane which is destined to replace the 767 and live for many years after I retire. Here's what I've learned in 787 training so far. By the way, last night we passed our MV (maneuvers validation) check ride, with emergency after emergency, and the FAA observing. Tonight was our LOE (line-oriented evaluation), again with FAA - this time 2 FAA observers. It's 0200 and I just got back to the hotel and poured a well-earned glass of wine to celebrate. I now have a type rating in the 787. Phew. I'm pretty confident this will be the last one for me. I've summarized some of the major differences and unique features of the 787 versus more traditional "old school" airplanes like the 777 (not kidding) - from the pilot's viewpoint. Our "Differences" course takes 11 days to gain an FAA type rating, which is a "common" type rating with the 777. The course has been like drinking from a fire hose, but has finally come together. Some of our pilots attended Boeing's 5-day differences course, and deemed it unacceptable. The FAA approved the Boeing 5-day course, but our guys decided it lacked too much information. FAA is observing our checkrides now, and taking our course as well, to certify the training. We're just the guinea pigs. A computer nerd would describe the 787 as 17 computer servers packaged in a kevlar frame. The central brains is the Common Core System (CCS). Two Common Computing Resources (CCRs) coordinate the communications of all the computer systems, isolating faults and covering failed systems with working systems. When battery power is first applied to the airplane in the morning, it takes about 50 seconds for the L CCR to boot up. After this, a few displays light up and you can start the APU. If there is a major loss of cockpit displays, this may require a CCR reboot, which would take about a minute. Here are a few of the major features and differences from the 777. Electrics - Though a smaller plane, the 787 has 4 times the electric generating power of the 777 - 1.4 gigawatts. Generators produce 235 VAC for the big power users. Other systems use the traditional 115 VAC and 28 VDC. There are 17 scattered Remote Power Distribution Units which power about 900 loads throughout the plane. The big power distribution system is in the aft belly, along with a Power Electronics Cooling System (PECS). This is a liquid cooling system for the large motor power distribution system. There's also an Integrated Cooling System (ICS), which provides refrigerated air for the galley carts and cabin air, and a Miscellaneous Equipment Cooling System for Inflight Entertainment Equipment. If 3 of the 4 engine generators fail, the APU starts itself. The APU drives two generators, and can be operated up to the airplane's max altitude of 43,000 feet. If you lose all 4 engine generators, the RAT (ram air turbine) drops out (like a windmill), powering essential buses. (It also provides hydraulic power to flight controls if needed). If you lose all 4 engine generators and the two APU generators (a really bad day), you are down to Standby Power. The RAT will drop out and provide power, but even if it fails, you still have the autopilot and captain's flight director and instruments, FMC, 2 IRSs, VHF radios, etc. If you're down to batteries only, with no RAT, you'd better get it on the ground, as battery time is limited. Brakes and antiskid are electric - 28V - so you don't lose brakes or antiskid even when you're down to just standby power. Normal flight controls are hydraulic with a couple exceptions. Engine driven and electric hydraulic pumps operate at 5000 psi (versus normal 3000 psi) to allow for smaller tubing sizes and actuators, thus saving weight. If you lose all 3 hydraulic systems (another bad day), you still have two spoiler panels on each wing which are electrically powered all the time, as is the stabilizer trim. You can still fly the airplane (no flaps, though). If you're having an even worse day and you lose all hydraulics and all generators, flight control power is still coming from separate Permanent Magnet Generators (PMGs) which produce power even if both engines quit and are windmilling. If the PMGs fail, too, your flight controls will be powered by the 28 V standby bus. If you lose all 3 pitot/static systems or air data computers, the airplane reverts to angle of attack speed (converts AOA to IAS), and this is displayed on the normal PFDs (primary flight displays) airspeed indicator tapes. GPS altitude is substituted for air data altitude and displayed on the PFD altimeter tapes. Very convenient. If you lose both Attitude and Heading Reference Units (AHRUs), it reverts to the standby instrument built-in attitude & heading gyro, but displays this on both pilot's PFDs for convenience. If you lose both Inertial Reference Units, it will substitute GPS position, and nothing is lost. If someone turns one or both IRSs off in flight (I hate it when they do that), you can realign them - as long as one of the GPSs is working! There is no pneumatic system. The only engine bleed is used for that engine's anti-ice. Wing anti-ice is electric. Each of two air conditioning packs control two CACs, which are electric cabin air compressors. The four CACs share two air inlets on the belly. Each pack controller controls two CACs, but if a pack controller fails, the remaining pack controller takes over control of all 4 CACs. There are no circuit breakers in the cockpit. To check on them, or if you get a message that one has opened (more likely), you select the CBIC (circuit breaker indication and control) display on one of the MFDs (multi function displays). There you can reset the virtual C/B if it is an "electronic" circuit breaker. You can't reset a popped "thermal" circuit breaker. If you have an APU fire on the ground or inflight, the fire extinguishing bottle is automatically discharged. If there is a cargo fire, the first two of seven bottles will automatically discharge also. There's a Nitrogen Generation System which provides automatic full-time flammability protection by displacing fuel vapors in the fuel tanks with nitrogen (Remember TWA 800?). Like the 767 and 777, the 787 also has full CPDLC capability (controller-to-pilot datalink communications). In addition, its full FANS capability includes ADS-B in & out. The controller can uplink speed, heading, and altitude changes to the airplane. These show up on a second line right under the speed, heading and altitude displays on the mode control panel. If you pilot wants to use them, he can press a XFR button next to each window. The controller can even uplink a conditional clearance, like - After passing point XYZ, climb to FL390. If you accept this, it will do it automatically. Fuel system - like the 777, the 787 has a fuel dump system which automatically dumps down to your maximum landing weight, if that is what you want. In addition, it has a Fuel Balance switch which automatically balances your L & R main tanks for you. No more opening crossfeed valves and turning off fuel pumps in flight. No more forgetting to turn them back on, either. Flight Controls - An "Autodrag" function operates when the airplane is high on approach and landing flaps have been selected. It extends the ailerons and two most outboard spoilers, while maintaining airspeed, to assist in glidepath capture from above, if you are high on the glideslope. The feature removes itself below 500 feet. Cruise flaps is an automated function when level at cruise. It symmetrically moves the flaps, ailerons, flaperons, and spoilers based on weight, airspeed and altitude to optimize cruise performance by varying the wing camber, thus reducing drag. Gust suppression - Vertical gust suppression enhances ride quality when in vertical gusts and turbulence. It uses symmetric deflection of flaperons and elevators to smooth the bumps. This should result in fewer whitecaps in passengers' coffee and cocktails. Lateral gust suppression improves the ride when on approach by making yaw commands in response to lateral gusts and turbulence. Instrument Approaches - The airplane is actually approved for autoland based not only on ILS but on GLS approaches - GPS with Ground based augmentation system, which corrects the GPS signals. GLS minimums are the same as CAT I ILSs - 200' and 1/2 mile visibility. Our airline is not yet approved for GLS autolandings yet, though we will be doing GLS approaches. Special Cat I & II HUD approaches - These allow lower than normal minimums when the Heads Up Devices are used at certain approved airports (HUDs). The HUDs include runway centerline guidance which helps you stay on the centerline on takeoff when visibility is greatly reduced. It uses either ILS or GLS for this. Cabin - Pressurization differential pressure maximum is 9.4 psid, so the cabin altitude is only 6000 feet when at the max cruising altitude of 43,000 feet. There is a cockpit humidifier switch, and cabin air humidification is fully automatic. Cabin windows are larger than other airplanes, and window shading is electronic. The passenger can select 5 levels of shading, from clear to black. The flight attendants can control the cabin lighting temperature - mood lighting - to aid in dealing with changing time zones (evening light after dinner, morning light to wake up, etc.). Much of the cockpit seems like it was designed by Apple. The Control Display Units (CDUs) are virtual, so you can move them from one MFD to another. In fact, you can configure the displays in 48 different ways, I think, though we have found a few favorites we will use to keep it simple. To move the cursor from one MFD to another, you can either use a button, or you can "flick" your finger across the trackpad (Cursor Control Device) to fling the cursor from one screen to the next - much like an iPad. I'm going home this morning, and will return for a 777 simulator ride before I go back to work. They want to make sure we've still got the old-fashioned legacy airplane in our brain before we fly the 777 again, even though it shares a "common type rating". We won't get the first 787 until October, and begin operations in November or December. At that time I'll return for at least 4 days refresher training before beginning IOE - initial operating experience in the airplane - with passengers. What a ride. It may be "fuel efficient", but I'm glad someone else is paying for the gas. Bill ________________________________________________________________________________
Date: Apr 17, 2012
Hi Paul I completely agree with Jack and I built my last Piet with a center swction a foot wider than plans to accomidate larger fuel tanks, then I built the wings to plans. I notice the difference and have flight tested this plane to 1300 lbs. Dick N. ----- Original Message ----- From: "Jack Phillips" <pietflyr(at)bellsouth.net> Sent: Monday, April 16, 2012 3:56 PM Subject: RE: Pietenpol-List: Re: considering a piet build > > > Paul, > > Bill Rewey was always talking about building a "Super Pietenpol" with a > longer wing, to approximate the wing loading of a Cub. I don't know if > any > have ever been built. Mine has a 6" longer than normal wingspan, but that > was done to increase the volume in the centersection to give more fuel > capacity. I will say that making such a change has dramatic ripple > effects > running through the entire airplane. The best flying Pietenpols seem to > be > the ones that were built closest to the plans. > > As Gary said - use aircraft hardware. It is not that much more expensive > (maybe less than Grade 8 hardware), and the fine threads will be much more > effective for getting accurate torques and for preventing loosening due to > vibration. Besides, when you are getting bounced around by turbulence, it > is reassuring to not have to wonder if your hardware is going to fail. > > Opinions on folding wings for a Piet? While that is always an attractive > option for people thinking of building an airplane, I've never seen it > done > in practice. With a Pietenpol, I think it would be a pain due to having > to > tighten and safety wire the turnbuckles on the bracing wires between the > struts every time you wanted to go flying. Also, many Pietenpols use > simple > bronze bushings on their axles, and while that is more than adequate for > the > amount of taxiing done at an airport, I wouldn't take any bets on how long > a > bushing would last being towed at highway speeds. Of course you could > load > it on a trailer, but that too is expensive. Weight is critical with these > airplanes, and any wing folding mechanism is going to add weight that you > can ill afford to add. As Walt evans used to say on this list "Simplicate > and add Lightness". A wing folding mechanism does neither. > > There are severl Pietenpol builders/flyers in Florida. I'll leave it to > them to contact you. > > As Gary said, there have been several Piets built of poplar. It is a good > light wood. Not as light as spruce (Poplar is 16% heavier than sitka > spruce), but somewhat stronger (Poplar's numbers generally run about 20% > higher than spruce), so it has about the same strength to weight ratio. > It > works easily (nearly as easy as spruce, and much better than Douglas Fir, > the other common choiceof non-aircraft grade woods). So all in all it is > not a bad choice, particularly if you have a lot of experience in grading > and selecting wood. Bear in mind that if you are choosing a wood other > than > aircraft grade spruce just to save money, the cost of the wood in a > Pietenpol is something around 10% of the total price of the airplane, > using > aircraft spruce. You will spend so much more money on other things > (primarily the engine) that the cost of wood is insignificant. > > Good luck with all your choices. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > -----Original Message----- > From: owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of nightmare > Sent: Monday, April 16, 2012 4:03 PM > To: pietenpol-list(at)matronics.com > Subject: Pietenpol-List: Re: considering a piet build > > > > Wow , you guys are great. thanks for all the quick responses. My name is > Paul Donahue and i live in royal palm beach florida (5 miles west of west > palm beach int'l). If you don't mind , here is a couple of more questions > for you. > 1.Has any one built a stretch wing Piet? (i know, stick to the plans) > 2. Do builders use AN hardware or is the grade 8 nuts and bolts at the > hardware store sufficient? (i believe it is same grade steel, usually > courser threading though at hardware store) > 3. I saw Keri Anns webpage, beautiful bird. any nonbias opinions on the > removable wing option ? would love to have option of removing or even > folding the wings to bring home. > 4. are there any piet builders / owners near me? > 5. how about opinions on building out of poplar? > > Thanks again; seems like a tight knit group > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=370982#370982 > > > ________________________________________________________________________________
Date: Apr 17, 2012
Jerry, my wife and I are driving down to Destin on the 27th and I would like to come up to see you sometime that weekend. What is your phone number.? Gardiner ----- Original Message ---- From: Jerry Dotson <jdotson(at)centurylink.net> Sent: Mon, April 16, 2012 8:35:19 PM Subject: Pietenpol-List: Re: considering a piet build Welcome to the group Paul. I live about 50 miles east of Pensacola,Fl. I extended the wingspan on my 1 piece wing. It is 32' 6". The reason I did is my runway is only 1300 feet long and hope to shorten the take off run some and maybe climb a little bit better. I have not flown it yet but hope to have it ready in a couple of months. As to the AN bolts and washers they are cheaper at Aircraft Spruce than my local Lowes. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 now covering and painting 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371005#371005 ________________________________________________________________________________
Subject: Re: Cost of inspections
Date: Apr 17, 2012
Hi Malcom, I do all the maintenance myself on the one I bought. My A&P charges me $225 to do the annual condition inspection. He likes to supervise me pull the plugs and clean/rotate them (Cont A-75), checks timing on both mags, checks the oil screen, checks fuel screens, and then eyeballs everything really good. Before the inspection I pull all the cowling, observation pannels and the seat backs, lube all bearings and pulleys, pull the wheel pants and lube wheel bearings. Then just take my time going over every nut and bolt. My personal pre-inspection takes me about 3 or 4 hours. The A&P portion takes about 2 - 2.5 hours. This year he wants to pull my metal prop and just make sure all is okay. Lesson learned - you don't save money on annuals by building a plane like I thought you would. I just doesn't cost that much in comparison to the rest of the years expenses (mostly fuel). Lorin -------- Lorin Miller Waiex N81YX GN-1 N30PP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371037#371037 ________________________________________________________________________________
Subject: Inspection rings
Date: Apr 17, 2012
Hello, I am not putting any ring by the moment, I just want to understand, or know better about the inspection rings. As I saw in lots of pictures and drawings there are 2 kinds of them, ones have an aluminium (I think Al) hatch to close them, and others have just a rounf piece of fabric over the a plastic ring. The procedure to inspect with the ones with the fabric cover ( I want to understand ) is: cut the fabric inside the hole, inpect, and put a nuew piece of fabric... isn't it? thank you -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371041#371041 ________________________________________________________________________________
Date: Apr 17, 2012
Those rings hold the aluminum insp covers. Doug Dever In beautiful Stow Ohio > Subject: Pietenpol-List: Inspection rings > From: mario.giacummo(at)gmail.com > Date: Tue=2C 17 Apr 2012 06:48:54 -0700 > To: pietenpol-list(at)matronics.com > m> > > Hello=2C > > I am not putting any ring by the moment=2C I just want to understand=2C o r know better about the inspection rings. > As I saw in lots of pictures and drawings there are 2 kinds of them=2C on es have an aluminium (I think Al) hatch to close them=2C and others have ju st a rounf piece of fabric over the a plastic ring. > The procedure to inspect with the ones with the fabric cover ( I want to understand ) is: cut the fabric inside the hole=2C inpect=2C and put a nuew piece of fabric... isn't it? > > thank you > > -------- > Mario Giacummo > http://vgmk1.blogspot.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371041#371041 > > > > > > > =========== =========== =========== =========== > > > ________________________________________________________________________________
Date: Apr 17, 2012
Subject: Re: Inspection rings
Understand. thanks Mario Giacummo ... .. .-.. .- .- ...- . -. - ..- .-. .- . ... .--. . .-.. .. --. .-. --- ... .- --..-- .--. .-. --- -... .- .-.. .- .-. ..- - .. -. .- --..-- . ... -- --- .-. - .- .-.. !!!!! 2012/4/17 Doug Dever > Those rings hold the aluminum insp covers. > > Doug Dever > In beautiful Stow Ohio > > > > Subject: Pietenpol-List: Inspection rings > > From: mario.giacummo(at)gmail.com > > Date: Tue, 17 Apr 2012 06:48:54 -0700 > > To: pietenpol-list(at)matronics.com > > > mario.giacummo(at)gmail.com> > > > > Hello, > > > > I am not putting any ring by the moment, I just want to understand, or > know better about the inspection rings. > > As I saw in lots of pictures and drawings there are 2 kinds of them, > ones have an aluminium (I think Al) hatch to close them, and others have > just a rounf piece of fabric over the a plastic ring. > > The procedure to inspect with the ones with the fabric cover ( I want to > understand ) is: cut the fabric inside the hole, inpect, and put a nuew > piece of fabric... isn't it? > > > > thank you > > > > -------- > > Mario Giacummo > > http://vgmk1.blogspot.com > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=371041#371041 > > > >====================== > &g====== > > > > > > > > * > > * > > ________________________________________________________________________________
Date: Apr 17, 2012
" I really think that 110 hp made a difference but the longer wing also made a difference. " --- when you say " made a difference" , i assume in a good way, right? also , is there much of a weight difference between a corvair 100 hp and a c-65 , c-85. thanks; Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371064#371064 ________________________________________________________________________________
Date: Apr 17, 2012
Mario, The plastic rings are initially captured in the covering process. These the n remain in that state until the first inspection, at which time they are c ut inside the ring and then covered with the aluminum cap. I think that is what your question is. Dan Helsper Puryear, TN -----Original Message----- From: giacummo <mario.giacummo(at)gmail.com> Sent: Tue, Apr 17, 2012 8:49 am Subject: Pietenpol-List: Inspection rings Hello, I am not putting any ring by the moment, I just want to understand, or know etter about the inspection rings. s I saw in lots of pictures and drawings there are 2 kinds of them, ones ha ve n aluminium (I think Al) hatch to close them, and others have just a rounf iece of fabric over the a plastic ring. he procedure to inspect with the ones with the fabric cover ( I want to nderstand ) is: cut the fabric inside the hole, inpect, and put a nuew piec e of abric... isn't it? thank you -------- ario Giacummo ttp://vgmk1.blogspot.com ead this topic online here: http://forums.matronics.com/viewtopic.php?p=371041#371041 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Subject: Re: 787 differences training
Date: Apr 17, 2012
I have been working on the 787 since it was a product development study in 1994 and I STILL would not post a story like that on the Pietenpol site. This site is an escape from that complex world...! Sometimes I tell people that during the day I work at the "world's largest airplane factory" and at night I work at "the world's smallest airplane factory" - my one car condo garage. Don't get me wrong, I love my job, yet find the Pietenpol to be extremely personally gratifying... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371071#371071 ________________________________________________________________________________
Date: Apr 17, 2012
"My whole perspective has changed a bit since my trip home from Brodhead last year where I had 2 near misses on disaster, too much for one trip. Dick N" I was curious about this statement so with a little internet snooping found this. http://www.eaa25.org/wp-content/uploads/2011/08/eaa251108.pdf -------- Chris Sacramento, CA WestCoastPiet.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371072#371072 ________________________________________________________________________________
Date: Apr 17, 2012
Right now, 47 views on the aviation related post, 35 views on the rant... I guess even some Piet folks find it interesting. Why not just prohibit off topic posting? Tools, wondering if that would make this post illegal as well... Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371073#371073 ________________________________________________________________________________
Date: Apr 17, 2012
Yes, that was what i try the understand... and now another one.... how is the aluminium cover attached to the ring?.. do not worry, something is going to come to my mind..... Thank you very much Dan. Regards. -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371074#371074 ________________________________________________________________________________
Date: Apr 17, 2012
Mario, They are made to fit the inspection ring and are held by spring pressure. The round ones are a standard size. http://www.aircraftspruce.com/catalog/cspages/de-nonslipcovers.php -john- John Hofmann Vice-President, Information Technology The Rees Group, Inc. 2424 American Lane Madison, WI 53704 Phone: 608.443.2468 ext 150 Fax: 608.443.2474 Email: jhofmann(at)reesgroupinc.com On Apr 17, 2012, at 1:24 PM, giacummo wrote: > > Yes, that was what i try the understand... and now another one.... how is the aluminium cover attached to the ring?.. do not worry, something is going to come to my mind..... > > Thank you very much Dan. > > Regards. > > -------- > Mario Giacummo > http://vgmk1.blogspot.com > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371074#371074 > > > > > > > > > > ________________________________________________________________________________
Subject: Re: OT The other end of the performance envelope. 787
Date: Apr 17, 2012
I did the type of checkride he mentions in an Airbus A330 on the SAME DAY I soloed a Pietenpol for the first time, which was also my first solo in a taildragger and the first time I soloed a light civil airplane since 1983... That definitely highlighted the differences. Probably not surprisingly, I found the Piet solo to be a lot more challenging. All the important decisions are left up to to your own lonesome self in the light civil arena. No load control to help make sure it's legal, no dispatch checking the weather, route, etc., no maintenance control and monster technical operations center to help you decide if the plane is ready or not. I even had to decide for myself if I was ready to fly it! No battery of instructors, check airmen and feds making that decision for me. Interesting reading. As incredible as it sounds (and is), that arena STILL doesn't have all the resources available to a Piet pilot and a well equipped iPad... Havn't been able to find the picture to save my soul, but my favorite Pietenpol pic of all times was a picture of a classic Piet next to a B2 bomber. The caption read something like: "next to the Piet I built my son, is the B2 my son built..." I guess he was an engineer on the project and they managed to set up the photo op when he delivered it to him. Again, both ends of the spectrum sitting right next to each other. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371078#371078 ________________________________________________________________________________
Date: Apr 17, 2012
I thought they where different things..... thank you. -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371081#371081 ________________________________________________________________________________
Subject: Temperature Gauges W/O Electrical System
Date: Apr 17, 2012
Guys, I am trying to figure out which temperature gauges (CHT & Oil) I can use that do not require electricity to operate since I am using an A-65F without an electrical system. I see a VDO CHT gauge advertised in Aircraft Spruce that says it does not need electricity unless you want the unit lighted. I do not see a similar note under any of the oil temp gauges. They all just say that they need 12VDC. The VDO web site did not help any since it seems to indicate that all their gauges need voltage to operate. Any recommendations on particular gauges or brands that have worked well? Thanks, -------- David Gallagher Zodiac 601 XL-B: flying, 200+ hours now Next project under construction: Aircamper Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371082#371082 ________________________________________________________________________________
From: Gerry Holland <gholland@content-stream.co.uk>
Subject: Re: Temperature Gauges W/O Electrical System
Date: Apr 17, 2012
David I have a non electric A75-8. The Oil Temperature is some form of capillary to Oil Pressure mount at rear of engine. Works well. Gerry ________________________________________________________________________________
Date: Apr 17, 2012
I have gauges from AS on my A-65. I think they are Mitchell. Look closely a t the AS cataloge. You will find a page or two of thier guages. But only tw o are for none electric Dave Dave Nielsen sentuchows(at)aol.com -----Original Message----- From: Gerry Holland <gholland@content-stream.co.uk> Sent: Tue, Apr 17, 2012 2:57 pm Subject: Re: Pietenpol-List: Temperature Gauges W/O Electrical System m.co.uk> David have a non electric A75-8. The Oil Temperature is some form of capillary t o il Pressure mount at rear of engine. Works well. erry -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Apr 17, 2012
David I think I have this Oil Pressure Gauge. http://www.aircraftspruce.com/catalog/inpages/oilpress3.php You need to ensure it comes with capillary tube and bulb to fit into rear of engine. Gerry ________________________________________________________________________________
Date: Apr 17, 2012
I just faced this problem on the 1920'ish Standard J1 biplane I'm helping to restore in Oshkosh. It runs an old water cooled V8 without an electrical system, a Hisso I think. Anyway, was was installed during a 1970's restore was a old Stewart Warner oil temp gage that had that capillary tube arrangement. I see them in A/C Spruce. While it says oil temp, it will work and the temp range is about correct. However, years ago I found a company in Albuquerque NM called MoMa. They restore ALL SORTS of gages and know about everything about them. If you want them to fix a tach gage, they want the tach cable sent along so it can be properly fit, etc. Also, their prices were about half of everywhere else. So I called them up about this water temp gage. The owner of the company usually answers the phone, a very nice lady Ms. Lucas. I explained what we wanted and she found a perfect vintage Stewart Warner WATER temp gage and fit the length of capillary tube to it we needed for the J1. Did this in under a week. If you have ANY gage stuff you need done, they are clearly worth checking with. The weirder the problem (like fixing a neat old auto speedometer to make a airplane tach), the better they will sound. They'll even do custom silkscreening of the gage face if you want. Just google MoMa and Albuquerque and you'll find them. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371089#371089 ________________________________________________________________________________
Date: Apr 17, 2012
Subject: Stitch question...
Would it be generally accepted as "ok" to go ahead and stitch around the diagonal in the attached? And leave the cord laying against the diagonal? This is one of the middle ribs on the horiz stab. And it doesn't move like a cable would. Shouldn't be any movement between the diagonal brace and the cord. So can I get by with just running the waxed cord around it and tightening up? There's just not much clearance in that area but I can just stich around the rib if needed.... (Hope this makes sense....) Jim in Pryor ________________________________________________________________________________
Date: Apr 17, 2012
Subject: Thank you....: Need some help....off topic...
Wow, I got a HUGE response (mostly offline, thank you!) from my request. Not sure if this is actually going to happen or not but I sure do appreciate all the great feedback. I am in a MUCH better position know how to proceed and some important things to watch out for. And all this time I was thinking I could just "prop it and go fly"!! (just kidding) I've tried to respond directly to all the offers of help but probably forgot someone....so THANK you all! Jim in Pryor.... -----Forwarded Message----- >From: Jim Markle <jim_markle(at)mindspring.com> >Sent: Apr 14, 2012 6:13 PM >To: Pietenpol List >Subject: Need some help....off topic... > >A pilot friend passed on about a year (or two) ago and his Champ has just been sitting...his daughter owns it now....it's on a grass strip about a mile from us. > >I've recommended to her that we at least pull it out of the hangar and start it from time to time. And she's fine with me taking it up if I want. (Of course I'm fine with that!). Mainly I hate to see it waste away...and it will if we don't do something. > >So do we just start propping to get it started or is there some process we need to follow for an aircraft that's been sitting for so long? > >Sorry for such an "off topic" request but....well....maybe this could lead to me getting some tailwheel time (yes, I know, ONLY after getting some tailwheel training...) but that might make me a better Piet pilot, right? :-) > >If someone has experience with such and could tell me what to watch for and give some pointers it would be appreciated. > >Offlist please. > >Thanks, >Jim in Pryor (where the storms might pass us by this time....) > ________________________________________________________________________________
Date: Apr 17, 2012
Subject: never mind.... Stitch question...
Just answered my own question. Went out to the shop and bent/hammered/drilled a small curved needle. Worked just fine. And didn't have to lay the cord up against the diagonal brace...didn't want to do that anyway. (And yes, I know, the holes don't line up with the lines...those were the original lines and somehow they didn't line up with each other, I'm still not sure why. So I made a template and punched the holes from the template...all in line with each other.) Next time I'll think about it some more before firing off an email...(no, I probably won't). JM -----Original Message----- >From: Jim Markle <jim_markle(at)mindspring.com> >Sent: Apr 17, 2012 2:37 PM >To: Pietenpol List >Subject: Stitch question... > >Would it be generally accepted as "ok" to go ahead and stitch around the diagonal in the attached? And leave the cord laying against the diagonal? This is one of the middle ribs on the horiz stab. And it doesn't move like a cable would. Shouldn't be any movement between the diagonal brace and the cord. So can I get by with just running the waxed cord around it and tightening up? > >There's just not much clearance in that area but I can just stich around the rib if needed.... > >(Hope this makes sense....) > >Jim in Pryor > ________________________________________________________________________________
Date: Apr 17, 2012
The Mitchell mechanical gauge is part # 10-02706 A.S. catalogue. Westach GH T part# is 2A1. part number for the sender is 712-5W AHHHH I think. Dave Dave Nielsen sentuchows(at)aol.com -----Original Message----- From: DaveG601XL <david.m.gallagher(at)ge.com> Sent: Tue, Apr 17, 2012 2:49 pm Subject: Pietenpol-List: Temperature Gauges W/O Electrical System m> Guys, I am trying to figure out which temperature gauges (CHT & Oil) I can use th at do ot require electricity to operate since I am using an A-65F without an lectrical system. I see a VDO CHT gauge advertised in Aircraft Spruce that ays it does not need electricity unless you want the unit lighted. I do no t ee a similar note under any of the oil temp gauges. They all just say that hey need 12VDC. The VDO web site did not help any since it seems to indica te hat all their gauges need voltage to operate. Any recommendations on particular gauges or brands that have worked well? Thanks, -------- avid Gallagher odiac 601 XL-B: flying, 200+ hours now ext project under construction: Aircamper ead this topic online here: http://forums.matronics.com/viewtopic.php?p=371082#371082 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Apr 17, 2012
Oil temp gauge as follows: Aircraft Spruce # 10-00954 http://www.aircraftspruce.com/catalog/inpages/scottoiltemp.php -------- Adrian M Winnipeg, MB Canada Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371105#371105 Attachments: http://forums.matronics.com//files/oil_temp_sensor_145.jpg ________________________________________________________________________________ ________________________________________________________________________________
Date: Apr 17, 2012
Subject: spins
Off topic, but has anyone done spins in the pietenpol? Just in case I get caught in an overcast.. Who knows. I might go into rolls and loops. I haven't heard of any G limits for the bernie planes. Gardiner Mason ________________________________________________________________________________
Subject: Re: to post or not to post....that is the question
Date: Apr 17, 2012
Thumbs up! That is all Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371111#371111 ________________________________________________________________________________
Subject: Horizontal stab end pieces
Date: Apr 17, 2012
Hey guys, I will try to keep this short. Trying to determine if the plans are telling me to put main beam or leading edge on the horizontal stab end pieces. I am probably over thinking this. Just wondering what others did. Thanks Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371112#371112 ________________________________________________________________________________
Subject: Re: Horizontal stab end pieces
Date: Apr 18, 2012
Kyle, I used the leading edge dimensions on the ends, but downsized toward the trailing edge, for a smooth transition. Gary from Cool Happy building! ------Original Message------ From: Kyle85 Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: Horizontal stab end pieces Sent: Apr 17, 2012 7:34 PM Hey guys, I will try to keep this short. Trying to determine if the plans are telling me to put main beam or leading edge on the horizontal stab end pieces. I am probably over thinking this. Just wondering what others did. Thanks Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371112#371112 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: Apr 17, 2012
This is what I used http://westcoastpiet.com/images/Chris%20Tracy/images/Tail_Wood_Piece_Locatio n.jpg But what the heck do I know, my plane is not finished Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kyle85 Sent: Tuesday, April 17, 2012 7:35 PM Subject: Pietenpol-List: Horizontal stab end pieces Hey guys, I will try to keep this short. Trying to determine if the plans are telling me to put main beam or leading edge on the horizontal stab end pieces. I am probably over thinking this. Just wondering what others did. Thanks Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371112#371112 ________________________________________________________________________________
Subject: considering a piet build
Date: Apr 17, 2012
I don't really have much to add in the Cub-vs-Air Camper thread except to slightly modify what someone (Jack-?) said about the "glide". I consider this to be a plus for the Piet. I always found that my most tense moments flying the Cub (and Super Cub) were those last few seconds (felt like hours) waiting for the mains to touch, riding the float down the runway, endlessly. I know, I know- it's all about airspeed control and that meant I was carrying a little too much airspeed- but still, I like the fact that I can bring the Piet down on a straight-line final all the way to the numbers and then plunk it down with minimal float. It's a nice short field performer, in my book. I also agree that adding wingspan also adds weight... not a good thing for Piets. Closing comment: pay no attention to posts from one "Kevin Purtee", a questionable guy that we put up with here out of kindness. He says his family is dysfunctional, but he's referring to himself, not his better half or any of us. And he belittles those of us who did not build our own Piets, but who fly them anyway. I think of Scout (my Air Camper) as an adopted child, one that I love by choice. "Fat Bottom Girl", Kevin's airplane by birth and upbringing, has no choice but to live in a dysfunctional household. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford/Ashland, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 18, 2012
Thanks guys, this is exactly what I was looking for. -------- David Gallagher Zodiac 601 XL-B: flying, 200+ hours now Next project under construction: Aircamper Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371136#371136 ________________________________________________________________________________
From: "Douwe Blumberg" <douweblumberg(at)earthlink.net>
Subject: spinning a Piet
Date: Apr 18, 2012
Always use Marvel Mystery Oil before you attempt to spin your Pietenpol, and make sure your handheld has enough range to clear the area by using a proper ground plane. Douwe ________________________________________________________________________________
Subject: Re: spins
Date: Apr 18, 2012
DO NOT spin a Pietenpol, even if you have a parachute (by-the-way would not fit in the cockpit with a pilot anyway). If you have a catastrophic failure, you could not get out of the plane if you had to. -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371139#371139 ________________________________________________________________________________
Subject: Re: considering a piet build
Date: Apr 18, 2012
Why would you want a Pietenpol if you have a Cub? Fly the Cub! -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371140#371140 ________________________________________________________________________________
Subject: Re: spins
Date: Apr 18, 2012
I think spinning a Pietenpol or on that matter any of the early homebuilts needs VERY careful consideration. My Corben Junior is 50+ years old and with a 4130 fuselage frame should be ok. The wings are still wood though! When I learnt to fly in the 60's spinning was an important part of the mid point syllabus and had to be demonstrated left and right during flight test. It gained an air of trepidation but in fact once mastered and demonstrated on test felt very worthwhile. Spinning for the sake of it.... no thanks. Knowing how to respond in such a flight condition is worth it. The one point to make though is that many who knew how to recover still came to grief because when it happened for real they were often to low, probably on that base leg section or steep climb out. Go spin in something aerobatic! Regards Gerry do no archive ________________________________________________________________________________
Date: Apr 18, 2012
had a cub, sold it 10 years ago when lost previous flying job. actually won it in the usaerobatic foundation raffle. flew it from oshkosh to south florida. your gonna make me cry now. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371162#371162 ________________________________________________________________________________
Subject: piet pics
Date: Apr 18, 2012
just looking for maybe a link for a bunch of piet pics in one place. or maybe whoever reads this can include their Piet pic. thanks; Paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371164#371164 ________________________________________________________________________________
Date: Apr 18, 2012
Subject: Re: piet pics
The West Coast Piet. website has a ton of pictures. For my personal in work photos, see the link below. I can send pictures of specific part/components if interested. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 18, 2012
http://textors.com/PietProject.html Jack Textor Sent from my iPad On Apr 18, 2012, at 11:39 AM, "nightmare" wrote: > > just looking for maybe a link for a bunch of piet pics in one place. or maybe whoever reads this can include their Piet pic. thanks; Paul > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371164#371164 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 18, 2012
If you wait till July you can get all the pics you want of any and every part you want in any power configuration you want. All you need to do is go to the Brodhead fly in. A field filled with Piets, Piet builders, wanna be fliers and liars. A veritable morgishgoard of Piets and Piets peoples Do not achieve this big secret This is flying weather, I can see by the number of people here today I'm gonna need lots of gas! Who would like a free ride? John ________________________________________________________________________________
From: "Sanders, Andrew P" <andrew.p.sanders(at)boeing.com>
Date: Apr 18, 2012
Subject: Re: RE: 2. 04:23 AM - Re: Pietenpol-List Digest: 46 Msgs -
04/16/12 (Sutton, Mark) To paraphrase Dennis Farina in "Big Trouble": With all due respect, I ask in the nicest possible way, PLEASE don't reply and send the entire digest back to the digest! Thanks, Andrew ________________________________ Message 2 _____________________________________ From: "Sutton, Mark" <msutton(at)unitedwayatlanta.org> Subject: Pietenpol-List: Re: Pietenpol-List Digest: 46 Msgs - 04/16/12 Sent from my Verizon Wireless Phone ----- Reply message ----- From: "Pietenpol-List Digest Server" <pietenpol-list(at)matronics.com> Subject: Pietenpol-List Digest: 46 Msgs - 04/16/12 * ________________________________________________________________________________
Date: Apr 18, 2012
thanks jack, paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371198#371198 ________________________________________________________________________________
Subject: Re: spins
Date: Apr 18, 2012
Terry, I think Ryan's comment was in regards to sand bag testing a wing rib to the point of destruction, as opposed to the discussion about spins. There was a lively and fairly entertaining discussion about this same topic (rib testing) a few years ago - that's where the reference to tractor weights comes from. There may have also been an elephant involved. The Pietenpol wing rib is a robust little structure. I don't think anyone has to worry about the ribs failing (if properly constructed). I'm not sure what knowledge would be gained from testing a rib to the point of destruction. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371199#371199 ________________________________________________________________________________
Subject: Re: spins
Date: Apr 18, 2012
Terry, If you just want to confirm the soundness of your construction abilities, why don't you just glue up a simple "T" made up of 2 pieces of 1/4" x 1/2" Sitka (or whatever wood you are building with), and gussets the same as you will use on your ribs. Allow the glue to fully cure, and then do a destructive test on that. Put it in a vise, and squeeze until it cracks. If the wood fails, you're "good to go". If the glue joints fail, you have reason to be concerned, since it's either your methods, or the adhesive that would be the reason for the glue joint to be the cause of failure. It's just that there's quite a bit of work involved in building an actual rib, and then you'd have to devise some sort of apparatus to hold and support the rib, and a method to distribute the weight, and acquire a bunch of sandbags, and on and on... so that, in the end, you'll be able to say that your rib supported "X" pounds (under the specific conditions that you tested it) before failing. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371207#371207 ________________________________________________________________________________
Date: Apr 18, 2012
Subject: Cub Style Wheel Option
What are the options to the Cub style wheels? I can find wheels but the-e xpander-tubes and master cyls are hard to come by and the Grove conversio n is very expensive. - I like the "balloon" look of the Cubs 10x4's, what are my other options?=0A=0ARyan M ________________________________________________________________________________
Date: Apr 18, 2012
Subject: Re: Cub Style Wheel Option
8x4=0A=0A=0A________________________________=0A From: Ryan M <aircamperace@ yahoo.com>=0ATo: "pietenpol-list(at)matronics.com" =0ASent: Wednesday, April 18, 2012 6:31 PM=0ASubject: Pietenpol-List: C ub Style Wheel Option=0A =0A=0AWhat are the options to the Cub style wheels ? I can find wheels but the-expander-tubes and master cyls are hard to come by and the Grove conversion is very expensive. - I like the "balloon ============== ________________________________________________________________________________
Date: Apr 18, 2012
Jim, I know you resolved this, but, you know that you are allowed to move the stitch to avoid framing members...right? Gary from Cool NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle Sent: Tuesday, April 17, 2012 12:38 PM Subject: Pietenpol-List: Stitch question... Would it be generally accepted as "ok" to go ahead and stitch around the diagonal in the attached? And leave the cord laying against the diagonal? This is one of the middle ribs on the horiz stab. And it doesn't move like a cable would. Shouldn't be any movement between the diagonal brace and the cord. So can I get by with just running the waxed cord around it and tightening up? There's just not much clearance in that area but I can just stich around the rib if needed.... (Hope this makes sense....) Jim in Pryor ________________________________________________________________________________
Date: Apr 18, 2012
Has any one tried the8 x 6 carlisle turf glide experimental?=0A=0Ahttp://ww w.desser.com/store/products/800%252d6-4-PLY-CARLISLE-TURF-GLIDE-EXPERIMENTA L-TIRE-.html-=0A=0A=0ARyan M=0A=0A________________________________=0A Fro m: Ryan M =0ATo: "pietenpol-list(at)matronics.com" =0ASent: Wednesday, April 18, 2012 6:31 PM=0ASu bject: Pietenpol-List: Cub Style Wheel Option=0A =0A=0AWhat are the options to the Cub style wheels? I can find wheels but the-expander-tubes and master cyls are hard to come by and the Grove conversion is very expensive. - I like the "balloon" look of the Cubs 10x4's, what are my other option ====================== ________________________________________________________________________________
Subject: adhesive question
Date: Apr 18, 2012
I connected the cables to the rudder and elevators and all works good. I cut leather pieces to cover the openings in the fabric where the cables exit and now what adhesive is best for this attachment.Thanks for any information. Bob ________________________________________________________________________________
Date: Apr 18, 2012
Subject: Re: adhesive question
Barge cement in a tube from Ace hardware ________________________________ From: Bob edson <robertse(at)centurytel.net> Sent: Wed, April 18, 2012 7:18:06 PM Subject: Pietenpol-List: adhesive question I connected the cables to the rudder and elevators and all works good. I cut leather pieces to cover the openings in the fabric where the cables exit and now what adhesive is best for this attachment.Thanks for any information. Bob ________________________________________________________________________________
Date: Apr 18, 2012
I used PolyTak. I used the Poly Fiber system fro my fabric work and PolyTak is their standard fabric adheasive. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bob edson Sent: Wednesday, April 18, 2012 7:18 PM Subject: Pietenpol-List: adhesive question I connected the cables to the rudder and elevators and all works good. I cut leather pieces to cover the openings in the fabric where the cables exit and now what adhesive is best for this attachment.Thanks for any information. Bob ________________________________________________________________________________
Date: Apr 18, 2012
Subject: Don't know
Since I am rebuilding my piet after the tornado damage do I have to get another FAA inspection? Gardiner ________________________________________________________________________________
Subject: looks awesome!
Date: Apr 18, 2012
I like it! :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371220#371220 ________________________________________________________________________________
Subject: Re: Overkill...
Date: Apr 18, 2012
I like it, i think it looks awesome! :D Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371221#371221 ________________________________________________________________________________
Date: Apr 18, 2012
Yeah, I figure if I can maintain minimum spacing I can probably move the stitches. Got it resolved thanks. That stitch has been smoothed over and 20 more made! :-) This evening my oldest son and my youngest son sat with me on the couch taking turns rib stitching. The oldest is an A&P at American Airlines and hadn't done a rib stitch in 15 or so years....so Ben (the 12 year old) helped him. It was one of my best Pietenpol experiences yet (and to think this project ALMOST ended up disappering from my shop a couple years ago!).... JM -----Original Message----- >From: Gary Boothe <gboothe5(at)comcast.net> >Sent: Apr 18, 2012 5:48 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: Stitch question... > > >Jim, > >I know you resolved this, but, you know that you are allowed to move the stitch to avoid framing members...right? > >Gary from Cool >NX308MB > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Jim Markle >Sent: Tuesday, April 17, 2012 12:38 PM >To: Pietenpol List >Subject: Pietenpol-List: Stitch question... > >Would it be generally accepted as "ok" to go ahead and stitch around the diagonal in the attached? And leave the cord laying against the diagonal? This is one of the middle ribs on the horiz stab. And it doesn't move like a cable would. Shouldn't be any movement between the diagonal brace and the cord. So can I get by with just running the waxed cord around it and tightening up? > >There's just not much clearance in that area but I can just stich around the rib if needed.... > >(Hope this makes sense....) > >Jim in Pryor > > ________________________________________________________________________________
Subject: Re: spins
Date: Apr 18, 2012
Gardiner, Getting back to your original question... The answer is YES, someone (not me) has spun a Pietenpol. I recall reading a story in Chet Peek's book "The Pietenpol Story" about a flight that BHP took, that was very nearly his last. As I recall, BHP was in the front seat, and a larger gentleman was in the pilot's seat, and the guy wanted to see how the plane would spin, so BHP threw it into a spin, but found that the extra weight in the rear wouldn't allow him to exit the spin. The stick travel was limited by hitting the panel, and BHP eventually ended up forcing the stick far to one side to get under the panel, in order to get the additional forward travel, and managed to exit the spin, just in the nick of time. If I have the time, I'll see if I can find the story. While it isn't recommended, from what I've read, I believe that spinning and looping occurred fairly frequently in the "old days". But then, so did crashes. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371232#371232 ________________________________________________________________________________
Date: Apr 18, 2012
Subject: Re: spins
Thanks Bill, A while back I visited Pat Green in Hilliard Fl, and he said that he let his friend take his Piet up for some acro. He got into a spin at about 4500 ft and did not get out of it untill 700 ft. It seems that his friend was very tall and his upper body blocked all airflow to the rudder. Pat then redesigned his rudder and added 10 inches to the height. I think he is still flying his Piet which he built about 30 years ago. He also added more wingspan to get over the pine trees at his field. He is a very nice man to talk to but I don't know his phone. Talk to him. Gardiner Mason ----- Original Message ---- From: Bill Church <billspiet(at)sympatico.ca> Sent: Wed, April 18, 2012 9:16:13 PM Subject: Pietenpol-List: Re: spins Gardiner, Getting back to your original question... The answer is YES, someone (not me) has spun a Pietenpol. I recall reading a story in Chet Peek's book "The Pietenpol Story" about a flight that BHP took, that was very nearly his last. As I recall, BHP was in the front seat, and a larger gentleman was in the pilot's seat, and the guy wanted to see how the plane would spin, so BHP threw it into a spin, but found that the extra weight in the rear wouldn't allow him to exit the spin. The stick travel was limited by hitting the panel, and BHP eventually ended up forcing the stick far to one side to get under the panel, in order to get the additional forward travel, and managed to exit the spin, just in the nick of time. If I have the time, I'll see if I can find the story. While it isn't recommended, from what I've read, I believe that spinning and looping occurred fairly frequently in the "old days". But then, so did crashes. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371232#371232 ________________________________________________________________________________
Date: Apr 18, 2012
Thanks guys, got the peace of mind I was looking for! - Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371239#371239 ________________________________________________________________________________
Subject: Don't know
Date: Apr 18, 2012
No, not unless you make substantial changes (different engine, different prop, etc.). Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of airlion Sent: Wednesday, April 18, 2012 7:56 PM Subject: Pietenpol-List: Don't know Since I am rebuilding my piet after the tornado damage do I have to get another FAA inspection? Gardiner ________________________________________________________________________________
Subject: Re: Don't know
Date: Apr 18, 2012
See, now that's what I love about this group! A very practical, responsible answer. If this were the "V-Tail Bonanza Group" or the "Mooney Owners Association" list, you'd be getting post after post about which FAA, NTSB, EAA, AOPA, GSA, TSA, or FCC form or license or fee you should be dealing with. You bend your Piet, you fix it. When it's fixed, you dust yourself off and you go fly it again. This is why we love these old airplanes! Ask me how I know ;o) PS- Gardiner, that little truck you babysat for me brought me 2500 miles from TX to OR towing a UHaul trailer in the heat of summer and mostly in 3rd gear, and it never missed a beat. Temp gauge never moved off the peg. Thanks again to you and Susan for treating me and my little Ranger like family, and I hope to do the same for you some day. Oh, and I'll buy you coffee and a piece of Georgia peach pie. -------- Oscar Zuniga Medford, OR Air Camper NX41CC "Scout" A75 power Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371243#371243 ________________________________________________________________________________
Date: Apr 18, 2012
Well, for what it's worth mine is here; http://www.clifdawson.ca/Homepage4-10-06/Pietenpol.html If that doesn't work; http://www.clifdawson.ca/ Clif A mile of road will take you a mile, but a mile of runway will take you anywhere > just looking for maybe a link for a bunch of piet pics in one place. or > maybe whoever reads this can include their Piet pic. thanks; Paul > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371164#371164 > > > ----- > No virus found in this message. > Checked by AVG - www.avg.com > ________________________________________________________________________________
Date: Apr 19, 2012
I asked this same question to my FSDO Inspector a few years ago. He said to use the paragraph in my flight limitations that deals with major changes as a guideline for returning to flight. He said it was not necessary to contact him, but recommended that you essentially place yourself back into "phase I" and fly off 5 hours in your flight test area and afterwards write the same statement in the logbook that you wrote after your initial Phase I was complete "I certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of.... yada yada yada." Straight from the horses mouth. -------- David Gallagher Zodiac 601 XL-B: flying, 200+ hours now Next project under construction: Aircamper Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371256#371256 ________________________________________________________________________________
Subject: post-rebuild inspection and adhesive question
Date: Apr 19, 2012
Gardiner, My FAA guy told me I did not have to do another inspection after my rebuild, EVEN with a new engine, he said just log what I did. You should be fine to go fly. On the adhesive question for leather, I love that yellow weatherstrip adhesive glue you can guy at auto parts stores. Permetax and 3M make them and they stick like gangbusters and stay flexible over time. Douwe ________________________________________________________________________________
Subject: Re: spins
Date: Apr 19, 2012
Okay, I found the story in Chet Peek's great book "The Pietenpol Story", which can be ordered from Chet here: http://www.threepeakspub.com/ or you can also get it from Aircraft Spruce: http://www.aircraftspruce.ca/catalog/bvpages/pietenpolStory.php Scary stuff. "Golly", indeed. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371259#371259 Attachments: http://forums.matronics.com//files/spins_226.pdf ________________________________________________________________________________
Subject: put your cards on the table Gents and Ladies!
Date: Apr 19, 2012
Here's an idea, With so many of us sharing, I realized that I'm unfamiliar with what most people are building (IF they're building.) so. How 'bout we all send in what we're building (Pietenpol, I know) like what engine, gear, wood or steel fuse, long or short fuse, how long into it and maybe how long to go? and additions/changes of note that we might find interesting and colors would be fun if you're not too secretive about such vital information. I'll start. Short fuselage Continental C-90 with starter Two piece wing Wood struts Bumped up "tiger moth" type center section tank "Jenny" gear "faux" doped/aged translucent linen finish with a beautiful "baby poop" green trim and "Re-PIET" huge across the wing and down each fuse side. Aiming to be done in two or three months. Marvel Mystery Oil in fuel, pre-mixed-sloshed, pre-warmed and perfumed! Douwe ________________________________________________________________________________
Subject: Re: put your cards on the table Gents and Ladies!
Date: Apr 19, 2012
Started in 1997 with plans purchase from Don Pietenpol. Sold in divorce at "on the gear" stage. Purchased back by V2.0 wife for wedding gift. Short fuse all Sitka Western red cedar ribs. Stock airfoil. Offset "flop" for entry. lengthened cabanes 2". 26" wide 27" deep in rear pit lofted to "print"at tailpost and firewall. Model A(60hp) Sensenich 76-42 wood prop. 3-pc wing(33 1/2' span) aluminum fuel tank in center section split gear 21" wheels with Faux "Bendix" style wheel covers. aluminum struts(to be wrapped and doped) Ceconite and dope finish. Wings finished and ready for pre-cover assembly this month. Goal to have in the air before Christmas. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371263#371263 ________________________________________________________________________________
Subject: Re: post-rebuild inspection and adhesive question
Date: Apr 19, 2012
Hey Douwe, Quick question about new engine. New type of engine, or same type, but new? Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371264#371264 ________________________________________________________________________________
Date: Apr 19, 2012
Good idea Douwe, here's mine: Long fuselage (spruce) 3-piece wing with fiberglass center section fuel tank (oh the horror) cub style gear with 19" motorcycle wheels on Ken Perkins hub and die spring shock struts Corvair power (100 HP "Airvair") with lots of WW parts and 5th bearing RAC electric elevator trim (WHAT! How does this guy get off calling that a Pietenpol) Ken Perkins steerable tail wheel assembly Turtledeck and upper formers stretched 1" per Mike Cuy Cabanes stretched 2 inches per LOTS of suggestions X-Com radio mounted in panel (the handheld stock prices just crashed) Reserved N328X in honor of SpaceShipOne (N328KF) To be named SpaceShip0.1 ( No boring "all about my kids" stories at this time - Thank You!) Uncovered fuselage & tail group ready for firewall forward Complete engine in parts boxes awaiting assembly All wing parts ready and awaiting assembly Estimated completion - 2 years - faster if I get fired first or win the lottery. Tom Stinemetze McPherson, KS. (4-19-12) >>> "Douwe Blumberg" 4/19/2012 8:14 AM >>> Heres an idea, With so many of us sharing, I realized that Im unfamiliar with what most people are building (IF theyre building) so How bout we all send in what were building (Pietenpol, I know) like what engine, gear, wood or steel fuse, long or short fuse, how long into it and maybe how long to go? and additions/changes of note that we might find interesting and colors would be fun if youre not too secretive about such vital information. ________________________________________________________________________________
Date: Apr 19, 2012
V2.0 Wife seems a good un! Started in 1997 with plans purchase from Don Pietenpol. Sold in divorce at "on the gear" stage. Purchased back by V2.0 wife for wedding gift. Regards Gerry ________________________________________________________________________________
Date: Apr 19, 2012
1932 F&G manual wood gear A engine 21" HD spoke wheels wings and horizontal creamy tan fuselage green so dark that it looks black chainsaw built prop....thanks for the info Dan jeff faith NX1929F Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371271#371271 ________________________________________________________________________________
Date: Apr 19, 2012
Hi Douwe, That sounds like a good idea. So to encourage anyone who=99s building, like mine, is =98rather slow=99, I will be the first of the =98slowbies=99 to post my, errr =98progress. Started: 2004 Plans form Don Pietenpol Wing ribs all done =93 made from douglas fir Fin & rudder woodwork done =93 mixed douglas fir and spruce Stabilizer & elevators started Hinges for both (abaove) from Vi Kapler Hope to finish and fly sometime before I kick the bucket Mark Stanley Japan From: Douwe Blumberg Sent: Thursday, April 19, 2012 10:14 PM Subject: Pietenpol-List: put your cards on the table Gents and Ladies! Here=99s an idea, With so many of us sharing, I realized that I=99m unfamiliar with what most people are building (IF they=99re building) so How =98bout we all send in what we=99re building (Pietenpol, I know) like what engine, gear, wood or steel fuse, long or short fuse, how long into it and maybe how long to go? and additions/changes of note that we might find interesting and colors would be fun if you=99re not too secretive about such vital information. I=99ll start. Short fuselage Continental C-90 with starter Two piece wing Wood struts Bumped up =9Ctiger moth=9D type center section tank =9CJenny=9D gear =9Cfaux=9D doped/aged translucent linen finish with a beautiful =9Cbaby poop=9D green trim and =9CRe-PIET=9D huge across the wing and down each fuse side. Aiming to be done in two or three months. Marvel Mystery Oil in fuel, pre-mixed-sloshed, pre-warmed and perfumed! Douwe ________________________________________________________________________________
Date: Apr 19, 2012
1937 Pietenpol Aircamper, NX308MB Started March of '08 Will probably fly this summer Long Fuselage - 3 pc wing Turtle decks raised 1.5", but cabanes held to plans Corvair Mostly Poplar Wood gear w/21" Harley Sportster wheels and tires, barely functional go-cart brakes ALL Hickory struts "Tiger Moth" 16 gallon fuel tank Latex paint Gary Boothe NX308MB From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Thursday, April 19, 2012 6:14 AM Subject: Pietenpol-List: put your cards on the table Gents and Ladies! Here's an idea, With so many of us sharing, I realized that I'm unfamiliar with what most people are building (IF they're building.) so. How 'bout we all send in what we're building (Pietenpol, I know) like what engine, gear, wood or steel fuse, long or short fuse, how long into it and maybe how long to go? and additions/changes of note that we might find interesting and colors would be fun if you're not too secretive about such vital information. I'll start. Short fuselage Continental C-90 with starter Two piece wing Wood struts Bumped up "tiger moth" type center section tank "Jenny" gear "faux" doped/aged translucent linen finish with a beautiful "baby poop" green trim and "Re-PIET" huge across the wing and down each fuse side. Aiming to be done in two or three months. Marvel Mystery Oil in fuel, pre-mixed-sloshed, pre-warmed and perfumed! Douwe ________________________________________________________________________________
Date: Apr 19, 2012
Started in 1993 with a "project" plane - fuselage and wing only One-piece wing Douwe's "old" Model A engine 76 x 44 Hegy wood prop External aileron cables Jenny gear 18" spoke wheels Everything all assembled, covered, painted, except: 90% done, 90% to go Larry Morlock ________________________________________________________________________________
Subject: Re: Destructive Testing
Date: Apr 19, 2012
When I first started building, I was intrigued with Charlie Rubeck's Western Red Cedar ribs. At Brodhead '98 Charlie convinced me to build one and test it. I built a test fixture utilizing engineering grade compression springs of known rate. I pulled the loading spacing out of an old NACA document. I still have the fixture. If memory serves, I tested a single WRC rib mounted on stub spars to 267 pounds before I heard a crack somewhere. Never did find the crack. I can load a rib in the fixture and take a pic if anyone is interested? If in doubt about the strength of the Piet ribs, start looking at some of the ribs that certified aircraft have used in the past. I have a Porterfield CP-65 rib that is under 1/4" square stock. It scares me to just look at it. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371285#371285 ________________________________________________________________________________
Date: Apr 19, 2012
Ok... here goes... Pietenpol build by myself, Mike Groah and my dad Vic Groah Long spruce fuselage with Keri Ann door mod. Three piece wing Turtle deck and panels raised one inch wing raised one inch Straight axle gear-wire wheels-mechanical drum brakes Aluminum Fuselage tank Center section wing storage like Mike Cuy's Corvair powered- Culver 66-30 prop Fuselage covered and painted a dark green(polyfiber) horizontal and wings are cream (one wing and ailerons still need their paint) Panel crowded with what most would say is too much stuff. (Garmin Aera and XCOM radio mounted in the panel) Smoke system (tank in wing center compartment) need to finish painting the wings and get a hangar to keep this thing in. Hope to fly this summer. http://www.youtube.com/watch?v=S5hYe_RYzkM&context=C3db22b9ADOEgsToPDskKC6YORoerna4k_SGQfI1lU ________________________________________________________________________________
Date: Apr 19, 2012
My concern is that this type of conversation will lead to improper test methods, and useless info. Imagine if a number of NEW builders decided that there must be some concern about rib strength, just because of these posts, that causes them to start sand bagging their ribs. Suddenly, numbers start coming in....the normal reaction is going to be that, if my rib crushes at a lesser weight than yours, then mine must be substandard; a completely incorrect conclusion since the testing methods must be correct - and there are proper testing methods. Not speaking to you, directly, Mike, but to everyone else: Forget about testing the rib design! YOU DON'T KNOW HOW! Just follow the previous good practices, as stated by Ryan M, and others, and test your first glue joints (if you have never worked with wood before), and trust empirical evidence. Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of 899PM Sent: Thursday, April 19, 2012 8:45 AM Subject: Pietenpol-List: Re: Destructive Testing --> When I first started building, I was intrigued with Charlie Rubeck's Western Red Cedar ribs. At Brodhead '98 Charlie convinced me to build one and test it. I built a test fixture utilizing engineering grade compression springs of known rate. I pulled the loading spacing out of an old NACA document. I still have the fixture. If memory serves, I tested a single WRC rib mounted on stub spars to 267 pounds before I heard a crack somewhere. Never did find the crack. I can load a rib in the fixture and take a pic if anyone is interested? If in doubt about the strength of the Piet ribs, start looking at some of the ribs that certified aircraft have used in the past. I have a Porterfield CP-65 rib that is under 1/4" square stock. It scares me to just look at it. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371285#371285 ________________________________________________________________________________
Date: Apr 19, 2012
From: Andrew Eldredge <andrew.eldredge(at)gmail.com>
NX7229R Continental A-65 6" exension on Fuselage, Douglas Fir Construction 3pc Wing (Center section wider, 1 extray bay each side, Correspondingly Shorter Wings) Split Axle Gear, Matco Wheels and brakes w/ turf-glide lawn tractor tires. (turf-glide sounds cool, though) Latex Paint, complete with runs. About 300hrs TTAF, originally flew Nov. 1997 About to come out of Repairs, I'm spam-canning this weekend Or I'd be taking it to the airport this Saturday Andrew Eldredge On Thu, Apr 19, 2012 at 9:26 AM, Gary Boothe wrote: > 1937 Pietenpol Aircamper, NX308MB**** > > Started March of =9108**** > > Will probably fly this summer**** > > ** ** > > Long Fuselage ' 3 pc wing**** > > Turtle decks raised 1.5=94, but cabanes held to plans**** > > Corvair**** > > Mostly Poplar**** > > Wood gear w/21=94 Harley Sportster wheels and tires, barely functional > go-cart brakes**** > > ALL Hickory struts**** > > =93Tiger Moth=94 16 gallon fuel tank**** > > Latex paint**** > > **** > > ** ** > > ** ** > > Gary Boothe**** > > NX308MB**** > > ** ** > > *From:* owner-pietenpol-list-server(at)matronics.com [mailto: > owner-pietenpol-list-server(at)matronics.com] *On Behalf Of *Douwe Blumberg > *Sent:* Thursday, April 19, 2012 6:14 AM > > *To:* pietenpolgroup > *Subject:* Pietenpol-List: put your cards on the table Gents and Ladies!* * > ** > > ** ** > > Here=92s an idea,**** > > ** ** > > With so many of us sharing, I realized that I=92m unfamiliar with what mo st > people are building (IF they=92re building=85) so=85**** > > ** ** > > How =91bout we all send in what we=92re building (Pietenpol, I know) like what > engine, gear, wood or steel fuse, long or short fuse, how long into it an d > maybe how long to go? and additions/changes of note that we might find > interesting and colors would be fun if you=92re not too secretive about s uch > vital information.**** > > ** ** > > I=92ll start.**** > > ** ** > > *Short fuselage* > > *Continental C-90 with starter* > > *Two piece wing* > > *Wood struts* > > *Bumped up =93tiger moth=94 type center section tank* > > *=93Jenny=94 gear* > > *=93faux=94 doped/aged translucent linen finish with a beautiful =93baby poop=94 > green trim and =93Re-PIET=94 huge across the wing and down each fuse side .* > > *Aiming to be done in two or three months.* > > *Marvel Mystery Oil in fuel, pre-mixed-sloshed, pre-warmed and perfumed!* > > ** ** > > Douwe**** > > ** ** > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?Pietenpol-List* > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > -- Andrew Eldredge Provo, UT ________________________________________________________________________________
From: "Cuy, Michael D. (GRC-RXD0)[ASRC AEROSPACE CORP]" <michael.d.cuy(at)nasa.gov>
Date: Apr 19, 2012
Subject: back to wood basics with Tony Bingelis
http://members.eaa.org/home/homebuilders/building/wood/4Aircraft%20Woodwork %20Basics.html What a great, simple, easy to understand article WITH sketches! Great To ny B's sketches. Scroll down to learn a lot in just a few photos. It's pretty entertaining watching p eople try dancing on the heads of pins when building an airplane like the Pietenpol. Mike C. ________________________________________________________________________________
Date: Apr 19, 2012
I will add to that-.LONG FUSE CORVAIR ENGINE, TWO PIECE WING WITH 36in wide CENTER SECTION. SPLIT AXLE GE AR, BRUSHED ON LATEX, POWDER BLUE WITH BURNT ORANGE TRIM. Should be flying in 3 months with NEW TAIL FEATHERS, TWO NEW WINGS, REPAIR TO THE COWLING,LA NDING GEAR,AND TAIL CONE. MY PLANE HAD 70 HOURS ON it PLUS 10 seconds in th e tornado. How about adding an=C2- address to the list in case of travel to that area. Gardiner Mason, 840 Woodley Dr. Atlanta Ga. 30318=C2- Ph 40 4 367 9453 --- On Thu, 4/19/12, Douwe Blumberg wrote: From: Douwe Blumberg <douweblumberg(at)earthlink.net> Subject: Pietenpol-List: put your cards on the table Gents and Ladies! Date: Thursday, April 19, 2012, 9:14 AM =0A=0A=0A =0A =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0AHere=99s an idea, =0A =0A =C2- =0A=0AWith so many of us sharing, I realized that I=99m un familiar=0Awith what most people are building (IF they=99re building ) so =0A=0A =C2- =0A=0AHow =98bout we all send in what we=99re building=0A(Pietenpol, I know) like what engine, gear, wood or steel fuse, long or short=0Afuse, how long into it and maybe how lo ng to go? and additions/changes of note=0Athat we might find interesting an d colors would be fun if you=99re not too=0Asecretive about such vita l information. =0A=0A =C2- =0A=0AI=99ll start. =0A=0A =C2- =0A=0A Short fuselage =0A=0AContinental C-90 with starter =0A=0ATwo piece wing =0A =0AWood struts =0A=0ABumped up =9Ctiger moth=9D type=0Acenter s ection tank =0A=0A=9CJenny=9D gear =0A=0A=9Cfaux=9D doped/aged translucent=0Alinen finish with a beautiful =9Cbaby poop =9D green trim and =9CRe-PIET=9D=0Ahuge across the wing a nd down each fuse side. =0A=0AAiming to be done in two or three months. =0A =0AMarvel Mystery Oil in fuel,=0Apre-mixed-sloshed, pre-warmed and perfumed ! =0A=0A =C2- =0A=0ADouwe =0A=0A =C2- =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A ==================0A=0A ________________________________________________________________________________
Date: Apr 19, 2012
Bought original plans in 2008 while I was in Iraq to drool over. Started making parts in 2011. Prospective airplane: Poplar wing ribs Douglas fir everything else. Fuel tank up front, storage up top. Gear tbd Engine cont. A65 Long fuse +2 on cabanes Going toTry my hand at making a prop via homemade duplicator Dacron med. weight. Stuart system covering. Ribs done. Center section done (minus install) Fittings started. Tail group jigs and beam sections done. All wood bought rough and milled in my shop. Fuse wood gathered. And other misc. parts (seems like I should be further along now that a write it down, bummer) -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371300#371300 ________________________________________________________________________________
Date: Apr 19, 2012
Purchased plans in Feb 2009... Long fuse 3-piece wing Split gear 21" wire wheels - just got these back from Buchanan's yesterday! Tee Hee! Mighty Corvair power Everything is spruce except where otherwise called for. Planning for fuel up front, storage up top. +2 on cabanes Black and Yellow latex... LOL! -------- Mark Chouinard Wings, Center Section and Empannage and Fuse framed up - Working on Landing Gear Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371301#371301 ________________________________________________________________________________
Date: Apr 19, 2012
"...put your cards on the table Gents and Ladies!" (Poker face) Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 19, 2012
Gary, I agree. I am a Mfg Engineer by trade and have as much fun building fixtures as I do the actual projects. The heated forum discussions of the "inferior" Western Red Cedar ribs nearly 15 years ago intrigued me enough to build the test fixture to convince myself that WRC was indeed a perfectly acceptable wood for Piet ribs. I am sure there are plenty of Charlies rib sets in flying Piets today. The Piet rib as designed, is built like the proverbial brick sh%$ house. Zero reason to change it. Just bought a 500' spool of 7x19 aircraft cable of E-Bay. Was disappointed as hell to see the big "MADE IN CHINA" label on the spool when it arrived. The engineer in me again kicked into high gear. I made up 3 nico'd cable assemblies last night to pull to destruction on certified load cells tomorrow. If it breaks within 10% of rated load.....I'm ok with it. Done deal. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371303#371303 ________________________________________________________________________________
Date: Apr 19, 2012
Mike Danford, Chickamauga GA (Chattanooga TN area), 423 580 1383. Bought plans from Mr Pietenpol around 96. Got some supplemental drawings directly from Orrin Hoopman. I've not made a lot of progress! Mostly because I was never around any aviation types (light civil or homebuilders) and could never come to a conclusion on how to do this or that. However, that's all getting fixed right now. My intentions are: All wood, short fuse, wood gear, make my own prop, rebuild a Model A myself, wood struts all around, probably no brakes or tailwheel, build my own wheel hubs. Really want a basic plane. However, I bought Dick Navratil's NX2RN and have come to the conclusion a reliable A-65 is good. ANYTHING lighter is gooder (considering a steel fuse). A steerable tailwheel and simple brakes worth the weight. I'm near Chattanooga TN and have the following available to local builders should they need it. Completely equipped wood shop, I can basically turn a tree into dimensioned lumber. If you have some wood you need milled into wing rib material, spars (dimensioning, routing) worked on, longeron milling from larger stock, etc, I can help. Leading edge and trailing edge shaping. I have a complete machine shop. Several lathes, mills, shapers, grinders (surface, tool and cutter, run of the mill). All sorts of drilling and boring capability. My larger lathe has a 1 1/2" headstock bore so I can work on axles. Lots of welding capability, oxy/acet (std victor torch and a Henrob), MIG and TIG. I'm JUST finally figuring out how to weld decently... you're mostly on your own here, but welcome to come use the stuff. I also have a decent selection of things to lift things with. I can lift wings onto planes, engines, etc. I'm close enough to several private fields that we can trailer a mini excavator to one of them to assemble a plane if you need help with that. I've got a number of large cast iron workbenches (about 8 ft, dead flat) that are great for scarfing together spars, laminating struts, ect. If anyone's willing to travel, you're welcome to come use what you need. Always a room available as well. Beer and food supplied as needed! The catch is that I'm not here a lot, but someone usually is. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371306#371306 ________________________________________________________________________________
Date: Apr 19, 2012
First year was 2008 - "preparation" things like a total overhaul of my shop. (new workbench, shelves, storage drawers, sawdust vacuum system, new table saw, etc...) 2008 Bought a "complete" project with all wood parts done (wings fuselage tails)... Sold the fuselage as I am choosing to build a steel-tube (short fuselage) version... Building a "modern recreation/interpretation" of Bernard Pietenpol's 1931 Velie radial-powered Piet. (even though that one was wood fuselage, mine will be steel.) Most of the primary fuselage structure complete. Many, many, many, many details to go... having a great time...... Steel-tube 1931 Pietenpol per 1932 F&GM drawings, plans from Don, & two photo of Bernard's Velie Piet. (two inches wider than plans - short fuselage dimensions - exactly F&GM dimensions in side view) Hand built/custom 4130 steel/wicker seats... Rotec R2800 radial engine... Wider center section (for larger fuel tank) shape of an S.E.5a center section... Hatz/cub/split style gear... Plan on using 16" wire rims and 4" Harley 24" diameter tires... A few "carefully hidden" electronics such as radio, transponder... (heaven forbid...!) Red/black paint scheme... N507N Three years done - no idea how much left - maybe halfway...?!?!!?? Welder comes tomorrow to do more welding on the flight controls. Plan to take a "summer off" and fly the Piet around America... http://www.rotecengines.com/Projects/JakeSchultz.html -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371310#371310 ________________________________________________________________________________
Subject: Wood Available
Date: Apr 19, 2012
Hi All If anyone is in need of some rib cap strip, tail feathers, or a Model A engine mount, I have the following douglas fir "kits": Ribs -- 700 running feet of 1/4 x 1/2 cap strip in 6 ft lengths Tail Feathers -- all pieces needed. L/E, T/E and main beam formed, 3/16 cap strip, everything except plywood. Also have the 3 ash pieces for a model A engine mount. I will be driving my truck up I 95 from Florida to Maine in May and could deliver anywhere on the way. Let me know off line if you're interested. Dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371311#371311 ________________________________________________________________________________
Date: Apr 19, 2012
Plans ordered from Don Pietenpol June 2004. First wood cut November 2005. Using Sitka Spruce throughout - purchased as rough sawn planks. Built parts (to date): Ribs done. Standard Pietenpol FC-10 airfoil. Empennage done. Long fuselage 80% done. 1" longer than plans, 1" taller than plans, standard width. Control horns 90% done. Continental C-75-12 Intentions (but not built yet): 3-pc wing with UK-style built-up spars "Jenny" gear + tall skinny wheels + mechanical brakes Tailwheel Nosewheel... :) Paint scheme: yes, it will have one Goal to have in the air before Christmas. Just not sure which one. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371316#371316 ________________________________________________________________________________
Date: Apr 19, 2012
.... like this test: -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371317#371317 ________________________________________________________________________________
Date: Apr 19, 2012
Subject: Re: Pietenpol list Re: Put your cards on the table
Hello-- Bought plans in 1968 but been bogged down with Army time, finishing my college degree, jobs, and building homes when I had to move. So far it's all framed up: long fuselage, standard 3-piece wing w/4' center section so I can have a cutout for visibility. Ribs Western Hemlock, all else spruce. Model A with some of Ken Perkins' stuff and Wico Mag. Split gear w/springs Most metal made except landing gear and struts Instruments in hand, no radio yet Will use latex paint Now I'm (finally) building a shop large enough to assemble it all into an airplane. --Mac in Oregon ________________________________________________________________________________
Subject: EAA Meet
Date: Apr 19, 2012
I invited my local EAA group up to my place for our monthly meeting. Grilled out some brats and mets with refreshments. This is a photo of my EAA Technical Advisor showing the group (and me) the proper way to trammel a wing in my shop. These are good times and invaluable teaching moments for me. I love building this Pietenpol! -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371323#371323 Attachments: http://forums.matronics.com//files/brianm_167.jpg ________________________________________________________________________________
Date: Apr 19, 2012
Acquired three "Flying and Glider" manuals in ninety something. Plans bought 2001. Built tail parts in winter 99/200,.W. Hemlock. Short fuse with an extra 6" at the rear, 1" wider. Seat back tilted back an inch. All Hemlock. Jenny gear with 19" wheels& 3.90 tires and my own disk brakes. Oh, Fir legs (Not Douglas). 36" wide center section with 22 gal. Moth style tank. Cabanes Fir and straight up, not angled. O-290 up front, zero hrs top end 800hrs bottom,$2500! Hemlock ribs done, 13' 6" X 1" spar material in rafters. Working on heel brake parts now. A few hrs of detail work left before beginning wings. I'll make own prop. Plan on latex-dark red fuse, cream wings, tail & wheels. Clif. Vancouver, BC, Canada http://www.clifdawson.ca/ Here's an idea, How 'bout we all send in what we're building (Pietenpol, I know) like what engine, gear, wood or steel fuse, long or short fuse, how long into it and maybe how long to go? Douwe ________________________________________________________________________________
Subject: tools' question re Douwe's engine
Date: Apr 20, 2012
Replaced the Ford with a C-90. loved the Ford, but a Colorado move MIGHT be on our horizon so. Douwe ________________________________________________________________________________
Subject: a question for "women2 fly"
Date: Apr 20, 2012
Hey Ladies, I've always wondered about the details of your project. Are you guys building a Piet? Douwe ________________________________________________________________________________
Date: Apr 20, 2012
Long fuselage. Corvair engine. 21" Rims with wooden gear. Will cover and paint with Stewart Systems. Riblett 612 Ribs and tail done. Just ordered Spruce for Fuselage. Progress at www.scottyspietenpol.com Tamworth, NSW Australia Scotty -------- Tamworth, Australia Building a Corvair Powered Pietenpol Air Camper www.scottyspietenpol.com Rudder, Vert stab, Elevators, Hor Stab and Ribs built...About to start fuselage...Corvair engine at Roy's Garage waiting to be modified. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371339#371339 ________________________________________________________________________________
Subject: Re: a question for "women2 fly"
Date: Apr 20, 2012
I have built a Pietenpol, flown it, and sold it. Click on my link below. Presently building a Wag Aero J3 Cub, with some modification on my own. Cheers, Wf2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371340#371340 Attachments: http://forums.matronics.com//files/nov18_08_copy_116.jpg ________________________________________________________________________________
Date: Apr 20, 2012
I'll sneak out of the woodwork and reply on this topic. Mostly I keep my eyes glued to the goal of "Brodhead in '13". Plans purchased in 2008 Purchased set of wings from a Sky Scout project Started gluing in 2009 3-piece wing complete Fuselage, tailfeathers, - on split axle gear, 6" wheels 3' center section with 15 gal. Al tank mounted on taller cabanes Corvair run at CC 21 Working on plumbing and wiring Plan to cover using Stewart System - Latex paint - scheme TBD I seem to fit the 90 percent rule at this point. Location: Holly Lake Ranch, TX (northeast TX), planes at 3F9 (hopefully a pic is attached of fuse on wheels outside of hangar) -------- Robert Caldwell Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371341#371341 Attachments: http://forums.matronics.com//files/dsc01334_919.jpg ________________________________________________________________________________
Date: Apr 20, 2012
Here is mine All wood short fuse, Model A,self made maple propeller,straight axle gear, 3 piece wing back 2 in. Blue and Yellow latex,rolled on. No brakes or tailwheel, but am researching, installing both. 5 hours into phase one testing. Flies great, but is tough to get around on the ground. NX110DL Don Lane Minnesott Beach NC ________________________________________________________________________________
From: "John Nauerth III" <proplock(at)federatedwildblue.com>
Subject: hose fittings
Date: Apr 20, 2012
long story short; have a master brake cylinder,has an =934 an 833 elbow on it, what fittings,hose do I need to match up with 1/8 pipe thread? Picture taken at Broadhead, on another Piet, I know something is available, but what? am frustrated at trying to find fittings. Thanks, Regards, John III ________________________________________________________________________________
Date: Apr 20, 2012
Here is what i have: Started with a fusalage my dad build in 1976 Originally he had a 1928 Chevrolet 4 cylinder. I Built a custom Mitsubishi engine with a bearing housing for the prop Harley Davidson starter Riblett 612 airfoil 3pc wing all spruce, 1" routed spars Aluminum airfoil tube struts 21" stainless spoke wheels jenny gear Fully assembled, all controls hooked up and working Starting the covering stage, all Stewart Systems Going to be all Olive Drab. http://youtu.be/sp24Odus-oU -------- NX321LR Fully Assembled less covering Mistubishi Powered Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371347#371347 ________________________________________________________________________________
From: Kip and Beth Gardner <kipandbeth(at)earthlink.net>
Subject: Put your cards on the table Gents and Ladies!
Date: Apr 20, 2012
Purchased project plane in 2001 - long fuse, cub gear - fuse & tailfeathers mostly complete. Project been too dormant most of the years since then - work, young family, etc. Just last year bought & now bringing a small farm back to life ... Time? Corvair torn down & partially rebuilt Removed original trurtledeck, rebuilding & raising 2" to accommodate shoulder straps. Rib jig built, but thinking about switching to Riblett 612. Lots of rib gussets cut. Kip Gardner, NE Ohio ________________________________________________________________________________
Date: Apr 20, 2012
Try =BC=94 Nylaflow tubing. You can get it and the fittings from ACS. It=92s what Vans uses on all the RV=92s. I used it on my master cylinders on my Pietenpol. I used regular AeroQuip hoses at the brake calipers. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Nauerth III Sent: Friday, April 20, 2012 8:48 AM Subject: Pietenpol-List: hose fittings long story short; have a master brake cylinder,has an '4 an 833 elbow on it, what fittings,hose do I need to match up with 1/8 pipe thread? Picture taken at Broadhead, on another Piet, I know something is available, but what? am frustrated at trying to find fittings. Thanks, Regards, John III ________________________________________________________________________________
Date: Apr 20, 2012
Bought plans in 2005 and rough cut spruce and douglas fir. Completed Riblett 612 ribs out of spruce, the remainder of airframe will be douglas fir. Working on tail sections with beams cut to section and in process of laying out. Plan to build long fuse with split undercarriage and spring leaf tail wheel. Wing will be 3 piece with tank in centre section. The spars will be built up, similar to UK construction method. Fabric will be attached with water based adhesive similar to Stewart System but acquired here in Australia and finished with latex. Basic steam powered instruments and radio. Corvair powered as per WW conversion. Have most parts to start engine assembly. Progress is slow due to work and family, but I keep chipping away.... I live in Perth, Western Australia, so if any of you find yourselves down this way, drop me a line, you'll always be welcome. Best regards, John Woods ________________________________________________________________________________
Date: Apr 20, 2012
WOW, always wondered who built this beauty. Barry NX973BP -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of womenfly2 Sent: Friday, April 20, 2012 7:25 AM Subject: Pietenpol-List: Re: a question for "women2 fly" --> I have built a Pietenpol, flown it, and sold it. Click on my link below. Presently building a Wag Aero J3 Cub, with some modification on my own. Cheers, Wf2 -------- Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371340#371340 Attachments: http://forums.matronics.com//files/nov18_08_copy_116.jpg ________________________________________________________________________________
Date: Apr 20, 2012
Subject: What I am doing
1. I bought glider manual and plans in the early nineties=0A2. bought and f inished a Grega project in the 90's=0A3. sold project in 99 lost medical=0A 4. flew powered parachute from 2001 to 2011=0A5. passed medical in 2011.=0A 6. sold powered parachute 2011=0A7. 2011 started building 1928 Model A moto r, bored 125 over, insert main bearings, new babbitt rod bearings=0A8. rece ntly bought 172-3/8" longest fuselage about 75% completed-now must make one of the following decisions:=0A----A. Finish my A motor and hang it on the longest fuselage=0A----B. Cut down the longest fuselage to 163" and use my A motor=0A----C. Stop building my A motor and look for a continental motor.=0AAny feedback is appreciated.=0AThanks=0A-Walte r Allen Owensboro Kentucky ________________________________________________________________________________
Date: Apr 20, 2012
Builder: John N Recine Lancaster Aeroplane Works 330 Knightsbridge Way Lititz, Pennsylvania 17543 Cell 215-208-8309 Hangared 5-5 at Lancaster airport, Lancaster , PA Pronounced locally Amish inflection: Lankester Airport identifier LNS Construction: February 21, 2007 to date Estimated completion: 2 years Tail number reserved : NX895JR Tail # origin: Plans number builders initials Plans Issued by: Don Pietenpol Date of issuance: 05/22/2006 Long Fuse Pietenpol Air Camper Powered by: Lycoming 0235 C1 D 108 hp internal combustion Aircraft engine Engine Statue: Disassembled, inspected and awaiting consumable parts, paint and assembly Straight axle Jenny type Landing Gear, laminated white ash & black walnut Wheels: Spoke Wheels Cabane struts: laminated white ash and black walnut Wing struts: laminated white ash and black walnut with embedded steel at all 3 major attachment points Instrument boards: white ash and black walnut veneered Tail wheel: Maule steerable on single spring Fuse: 172" long and 29" wide to the outside of the longerons Construction: Poplar Adhesive: West Systems Epoxy Wings: 3 piece, major wing panels 15' 7 " roughly Spars: Routed yellow poplar 1" Ribs: Spruce, purchased from Jack Textor 2007 Center section: 34" Poplar Spars and spruce ribs Wingspan overall: 35' estimated tip to tip Firewall: Stainless over fiberfrax sheeting Tail Feather: Poplar Fittings: Stainless and mild steel Skin: TBD Paint: TBD Paint Scheme: TBD Status: fuse in preparation for varnish coat progressed slowed significantly due to factors both within and beyond my control. Visitors to the Lancaster Aeroplane Works are welcome wear work cloths and Bring Beer and Pizza! all of which will satisfy the Aeroplane Gods John ________________________________________________________________________________
Date: Apr 20, 2012
Subject: Re: What I am doing
Hello Walter. It seems that your questions really come down to personal preference. To save some time and money, use what you currently have and see how it flies. Although I am not familiar with the Model A, so I can't comment on W&B issues with it and the long fuse...if there are any. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: hose fittings
Date: Apr 20, 2012
Hi, the problem is; master cylinders are from a wrecked Cessna, the fitting on the master is a =934, with o ring, so pipe thread cannot be used on master. I need an aircraft hose with a 37 degree flair fitting on master end, the outer end needs a male 1/8 pipe fitting, all 1/4 internal hose diameter,12 inches long. Nyla flow fittings are pipe thread,will screw into Matco brake cylinders. Any thoughts? thanks From: Jack Phillips Sent: Friday, April 20, 2012 8:40 AM Subject: RE: Pietenpol-List: hose fittings Try =C2=BC=9D Nylaflow tubing. You can get it and the fittings from ACS. It=99s what Vans uses on all the RV=99s. I used it on my master cylinders on my Pietenpol. I used regular AeroQuip hoses at the brake calipers. Jack Phillips NX899JP Smith Mountain Lake, Virginia ------------------------------------------------------------------------- ------- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of John Nauerth III Sent: Friday, April 20, 2012 8:48 AM Subject: Pietenpol-List: hose fittings long story short; have a master brake cylinder,has an =934 an 833 elbow on it, what fittings,hose do I need to match up with 1/8 pipe thread? Picture taken at Broadhead, on another Piet, I know something is available, but what? am frustrated at trying to find fittings. Thanks, Regards, John III ________________________________________________________________________________
Subject: Re: calling for a Rick Holland update---come in Rick....do
you r
Date: Apr 20, 2012
Hey Mikey (and rest of Piet gang) Yes I am still alive, just haven't been on the forum for a while. As many of you guys have said you don't make much sawdust sitting in front of a computer. Anyhow after seven years I had everything done but the paperwork, renting a hanger and finding a trailer to drag everything to Meadow Lake airport (East of Colorado Springs). But as you know I have one of those crank snappin Vairs and I kept thinking about Randy telling me about his crank snapping episode and decided to pull the engine off and install a Weseman 5th bearing and higher capacity oil pump, (I can almost hear Jack snickering in the background). Am almost done with that so I can soon do a final W&B and start looking for that hanger (and take a couple lessons in a tail dragger of some sort). rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371375#371375 ________________________________________________________________________________
you r
Date: Apr 20, 2012
Way to go, Rick! Will we be seeing this one at Brodhead this summer? Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of at7000ft Sent: Friday, April 20, 2012 3:27 PM Subject: Pietenpol-List: Re: calling for a Rick Holland update---come in Rick....do you r Hey Mikey (and rest of Piet gang) Yes I am still alive, just haven't been on the forum for a while. As many of you guys have said you don't make much sawdust sitting in front of a computer. Anyhow after seven years I had everything done but the paperwork, renting a hanger and finding a trailer to drag everything to Meadow Lake airport (East of Colorado Springs). But as you know I have one of those crank snappin Vairs and I kept thinking about Randy telling me about his crank snapping episode and decided to pull the engine off and install a Weseman 5th bearing and higher capacity oil pump, (I can almost hear Jack snickering in the background). Am almost done with that so I can soon do a final W&B and start looking for that hanger (and take a couple lessons in a tail dragger of some sort). rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371375#371375 ________________________________________________________________________________
Date: Apr 20, 2012
Started building NX510JD July, 2009 Sitka spruce and certified plywood Long fuselage Wingspan 32.5 feet one piece All control surfaces hinged gap-less with piano hinge 16.5 gallon airfoil shaped wing tank Covered with 2.7 oz Dacron using Stewart systems adhesive Painted with Rustoleum oil base Regal Red fuselage, v fin and rudder. The wing,horizontal stabilizer, and elevators are painted with Rustoleum oil base Safety Yellow. now in final assembly Jenny style gear with Kawasaki dirt bike forged aluminum 21" wheels, mechanical disc brakes Lycoming O-235 C2C 115 HP @ 2800 rpm Jay Anderson CloudCars prop 76 X 44 -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371382#371382 ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Subject: Re: Inspection rings
Date: Apr 20, 2012
I've never heard of putting on a new piece of fabric. Leave the hole uncut until you need to look inside where the ring is, cut the fabric out inside the ring, after inspection replace the cutout piece with an alluminum cover which is specially made for just that. C ----- Original Message ----- From: "giacummo" <mario.giacummo(at)gmail.com> Sent: Tuesday, April 17, 2012 9:48 AM Subject: Pietenpol-List: Inspection rings > > > Hello, > > I am not putting any ring by the moment, I just want to understand, or > know better about the inspection rings. > As I saw in lots of pictures and drawings there are 2 kinds of them, ones > have an aluminium (I think Al) hatch to close them, and others have just a > rounf piece of fabric over the a plastic ring. > The procedure to inspect with the ones with the fabric cover ( I want to > understand ) is: cut the fabric inside the hole, inpect, and put a nuew > piece of fabric... isn't it? > > thank you > > -------- > Mario Giacummo > http://vgmk1.blogspot.com > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371041#371041 > > > ________________________________________________________________________________
Date: Apr 20, 2012
John, Why is your wingspan so huge? Was this this intentional? Dan Helsper Puryear, TN -----Original Message----- From: AMsafetyC <AMsafetyC(at)aol.com> Sent: Fri, Apr 20, 2012 10:28 am Subject: Re: Pietenpol-List: put your cards on the table Gents and Ladies! Builder: John N Recine Lancaster Aeroplane Works 330 Knightsbridge Way Lititz, Pennsylvania 17543 Cell 215-208-8309 Hangared 5-5 at Lancaster airport, Lancaster , PA Pronounced locally Amish inflection: Lankester Airport identifier LNS Construction: February 21, 2007 to date Estimated completion: 2 years Tail number reserved : NX895JR Tail # origin: Plans number builders initials Plans Issued by: Don Pietenpol Date of issuance: 05/22/2006 Long Fuse Pietenpol Air Camper Powered by: Lycoming 0235 C1 D 108 hp internal combustion Aircraft engine Engine Statue: Disassembled, inspected and awaiting consumable parts, paint and assembly Straight axle Jenny type Landing Gear, laminated white ash & black walnut Wheels: Spoke Wheels Cabane struts: laminated white ash and black walnut Wing struts: laminated white ash and black walnut with embedded steel at al l 3 major attachment points Instrument boards: white ash and black walnut veneered Tail wheel: Maule steerable on single spring Fuse: 172" long and 29" wide to the outside of the longerons Construction: Poplar Adhesive: West Systems Epoxy Wings: 3 piece, major wing panels 15' 7 " roughly Spars: Routed yellow poplar 1" Ribs: Spruce, purchased from Jack Textor 2007 Center section: 34" Poplar Spars and spruce ribs Wingspan overall: 35' estimated tip to tip Firewall: Stainless over fiberfrax sheeting Tail Feather: Poplar Fittings: Stainless and mild steel Skin: TBD Paint: TBD Paint Scheme: TBD Status: fuse in preparation for varnish coat progressed slowed significantl y due to factors both within and beyond my control. Visitors to the Lancast er Aeroplane Works are welcome wear work cloths and Bring Beer and Pizza! a ll of which will satisfy the Aeroplane Gods John -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Apr 20, 2012
Dan, its been a while since I measured the wing panels however I believe the spars were cut from 16 foot poplar planks to 15 '7" from the joint hinge strap fitting to the bow of the wing tips, as i recall. Even then I thought more wing the better so I didn't mind the length. I believe the plans for the 3 piece wing are larger any way. All of which is speculation at the moment until I get good solid measurements from the wing panels. If my numbers are incorrect I will correct them Ill let ya know John ________________________________________________________________________________
Subject: apologies to Axel
Date: Apr 20, 2012
Having not seen any response to my post about Kevin, it occurredto me that I may have offended him with some of the content. Nosuch effect was intended. Kevin is the sort that we need more ofhere, and there, and everywhere. I am honored to be among his aviationcohort, and I am very honored to call him my friend. >From all that I see and hear about her, is wife is every bit his equal, too. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 20, 2012
Oscar, I know Kevin well enough to know that it would take a lot more than that to offend him. He's busy learning to fly a new helicopter. Jack Phillips NX899JP Smith Mountain lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Oscar Zuniga Sent: Friday, April 20, 2012 9:16 PM Subject: Pietenpol-List: apologies to Axel Having not seen any response to my post about Kevin, it occurredto me that I may have offended him with some of the content. Nosuch effect was intended. Kevin is the sort that we need more ofhere, and there, and everywhere. I am honored to be among his aviationcohort, and I am very honored to call him my friend. >From all that I see and hear about her, is wife is every bit his equal, too. Oscar Zuniga Air Camper NX41CC "Scout" Flying Squirrel N2069Z "Rocket" Medford, OR website at http://www.flysquirrel.net ________________________________________________________________________________
Date: Apr 20, 2012
Subject: Busy busy busy
Hello guys, hope you all are getting some flying in.- I have been busy do ing house work for the past 4 weeks, and the piet is still tore apart.- I started the annual about a month ago, and took all the tail hardware, tail wire fittings to repaint them, and had to replace the carb heat box due to cracks (didnt feel like taking the time to repair them right now).- Dad wants to replace all the lift strut hardware for piece of mind, and recoat the inside of the struts with corrosion prevention compound (AV-30).- No big items on the annual except lack of time to get it done.- I am putting in a brick patio that started with tearing out a deck, tearing out a chimn ey, patching in the vinal siding, patching in the roof,-regrading aroung the house with 20 tons of stone, and 7 yards of topsoil, and the poor Piet is sitting out in the hangar with its pants down.- Hopefully I will have it back up within 3-4 weeks and get some flying in before 100LL hits $27/gal.- As far as having my fly-in it is still in the planning phase, not sure when to do it, probably late summer, or early fall.- I am also t rying to work an angle to get time off work, and permission from "The Boss" to squeeze in 3 days to go to Brodhead.- If she lets me I will try to fl y up friday, and come home sunday.- I might need to order 48 feet of vort alator tape to get the required speed I will need to get there and back-o n that tight scedule.- - Happy flights, and restfull nights to Y'all - Shad - - P.S.- I will not be atempting any spins without a pith helmet, or marvel mys. oil ________________________________________________________________________________
Date: Apr 21, 2012
Great idea Douwe! Plans purchased from Pietenpol family 2003 Hiatus to build RV8 Re-started in 2009 with ribs Rough cut all wood except capstrips Currently all wood work finished, empennage and wings varnished Controls done Split gear about =BE done, 25 inch wire wheels redoing C85 -0- time done To complete=85 engine mount, cover, rigging, instruments, plumbing, etc NX1929T reserved Pictures here www.textors.com Jack Textor DSM NX1929T _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Douwe Blumberg Sent: Thursday, April 19, 2012 8:14 AM Subject: Pietenpol-List: put your cards on the table Gents and Ladies! Here=92s an idea, With so many of us sharing, I realized that I=92m unfamiliar with what most people are building (IF they=92re building=85) so=85 How =91bout we all send in what we=92re building (Pietenpol, I know) like what engine, gear, wood or steel fuse, long or short fuse, how long into it and maybe how long to go? and additions/changes of note that we might find interesting and colors would be fun if you=92re not too secretive about such vital information. I=92ll start. Short fuselage Continental C-90 with starter Two piece wing Wood struts Bumped up =93tiger moth=94 type center section tank =93Jenny=94 gear =93faux=94 doped/aged translucent linen finish with a beautiful =93baby poop=94 green trim and =93Re-PIET=94 huge across the wing and down each fuse side. Aiming to be done in two or three months. Marvel Mystery Oil in fuel, pre-mixed-sloshed, pre-warmed and perfumed! Douwe ________________________________________________________________________________
Subject: Fuse question
Date: Apr 21, 2012
I THOUGHT I had my mind made up on this but I have started having doubts on fuse length. My emp is days from completion and I was planning on starting the fuse shortly after. I have plans for both the long and the short fuse along with the materials to build either, so that is not a factor. Here is my scenario; It is important to me that my dad be able to fly with me. He is about 6'2 and 230 lbs. I am 5'10 180 lbs. My initial thought was long fuse because I was planning on running a cont. A-65. But then i realized my fuel tank is set up to be placed in the nose. So, I would think I could go with the short and be fine with the added fuel weight that far forward. But the problem with that logic is I will develop an aft CG as my fuel burns. If I do decide to go with the short will my dad fit with that fuel tank up there? I need some real world guidance here I know a few of you have built and flown planes close to this configuration. Any regrets or thoughts you would like to pass along would be appreciated. Thanks, Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371455#371455 ________________________________________________________________________________
Subject: Re: Fuse question
Date: Apr 21, 2012
Your 6' 2" Dad will not be happy in the front cockpit of a short fuselage Pietenpol, regardless of fuel tank location. I am 5' 11" and had a ride in the short fuselage version. It was a tight fit. Greg Cardinal Minneapolis ----- Original Message ----- From: "Kyle85" <boschkyle(at)hotmail.com> Sent: Saturday, April 21, 2012 9:59 PM Subject: Pietenpol-List: Fuse question > > I THOUGHT I had my mind made up on this but I have started having doubts > on fuse length. My emp is days from completion and I was planning on > starting the fuse shortly after. I have plans for both the long and the > short fuse along with the materials to build either, so that is not a > factor. Here is my scenario; It is important to me that my dad be able to > fly with me. He is about 6'2 and 230 lbs. I am 5'10 180 lbs. My initial > thought was long fuse because I was planning on running a cont. A-65. But > then i realized my fuel tank is set up to be placed in the nose. So, I > would think I could go with the short and be fine with the added fuel > weight that far forward. But the problem with that logic is I will develop > an aft CG as my fuel burns. If I do decide to go with the short will my > dad fit with that fuel tank up there? I need some real world guidance here > I know a few of you have built and flown planes close to this > configuration. Any regrets or thoughts you would like to ! > pass along would be appreciated. > Thanks, > Kyle > > -------- > Airspeed, altitude or brains: Two are always needed to successfully > complete the flight. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371455#371455 > > > ________________________________________________________________________________
Date: Apr 22, 2012
Kyle, I'm 6' 2" and about 195 lbs. I have the long fuselage, with the fuel in the centersection. I can just barely manage to get into the front cockpit (rear cockpit is fine) and would not want to sit in it for any extended period. My cabane struts are 2-1/2" longer than plans and even with that it's a bear to fold myself into the front seat. If I were you, I'd build the short fuselage (because it's lighter, and you'll need all the lightness you can get to haul both of you aloft) and put your Dad on a diet. He'll thank you for it (as will his Doctor), he'll fit better in the airplane, and the plane will perform better. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Greg Cardinal Sent: Saturday, April 21, 2012 11:31 PM Subject: Re: Pietenpol-List: Fuse question Your 6' 2" Dad will not be happy in the front cockpit of a short fuselage Pietenpol, regardless of fuel tank location. I am 5' 11" and had a ride in the short fuselage version. It was a tight fit. Greg Cardinal Minneapolis ----- Original Message ----- From: "Kyle85" <boschkyle(at)hotmail.com> Sent: Saturday, April 21, 2012 9:59 PM Subject: Pietenpol-List: Fuse question > > I THOUGHT I had my mind made up on this but I have started having doubts > on fuse length. My emp is days from completion and I was planning on > starting the fuse shortly after. I have plans for both the long and the > short fuse along with the materials to build either, so that is not a > factor. Here is my scenario; It is important to me that my dad be able to > fly with me. He is about 6'2 and 230 lbs. I am 5'10 180 lbs. My initial > thought was long fuse because I was planning on running a cont. A-65. But > then i realized my fuel tank is set up to be placed in the nose. So, I > would think I could go with the short and be fine with the added fuel > weight that far forward. But the problem with that logic is I will develop > an aft CG as my fuel burns. If I do decide to go with the short will my > dad fit with that fuel tank up there? I need some real world guidance here > I know a few of you have built and flown planes close to this > configuration. Any regrets or thoughts you would like to ! > pass along would be appreciated. > Thanks, > Kyle > > -------- > Airspeed, altitude or brains: Two are always needed to successfully > complete the flight. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371455#371455 > > > ________________________________________________________________________________
Subject: Pietenpols Unstable?
Date: Apr 22, 2012
A pilot told me that all the piets she flew were unstable. She said, If you let go of the stick they would just fall off one way or the other. Say it aint so! John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371466#371466 ________________________________________________________________________________
Date: Apr 22, 2012
Kyle - I have a long fuselage, no tank up front and standard length cabanes. Not your setup but you may still find the information valuable: I've had people close to your Dad's size up there and, 1) they don't want to stay very long, 2) they tear up the airplane getting in and out - the person and the plane cannot exist in the same space at the same time. Extended cabanes would alleviate ingress/egress issues a little but it would still be a tight fit. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371467#371467 ________________________________________________________________________________
Subject: Re: Pietenpols Unstable?
Date: Apr 22, 2012
Perhaps she meant to say that all Piet pilots are unstable? How many has she flown? Here's what I know: if the air is calm my airplane will fly hands off for 20-30 seconds. If there are any bumps I have to monitor the airplane much more closely. The nose wants to drop at low speeds, but that has nothing to do with aerodynamics and everything to do with those big heavy elevators hanging back there being subject to gravity. I have the East Texas Trim System in the form of a bungee cord that keeps the nose where it belongs. Here's what I've been told. I'm darn sure no aerodynamics expert so take it for what it's worth: if the CG is jacked up, common in a Piet, an airplane can be unstable. The experts can chime in. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371469#371469 ________________________________________________________________________________
Date: Apr 22, 2012
Only in turbulence. The only time I found it bothersome is when trying to fold a chart. Then I learned to have my charts pepared prior to takeoff to minimize folding them in the air. It is part of the charm. Greg Cardinal Minneapolis ----- Original Message ----- From: "Kringle" <Mrkringles(at)msn.com> Sent: Sunday, April 22, 2012 7:01 AM Subject: Pietenpol-List: Pietenpols Unstable? > > A pilot told me that all the piets she flew were unstable. She said, > ?oIf you let go of the stick they would just fall off one way or the > other?. Say it ain?Tt so! > > John > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371466#371466 > > > ________________________________________________________________________________
Date: Apr 22, 2012
Has anyone ever built a "flying" tail Piet? In my model years I did so with a couple of Sig Seniors and it worked well. Jack Textor Sent from my iPad On Apr 22, 2012, at 7:15 AM, "kevinpurtee" wrote: > > Perhaps she meant to say that all Piet pilots are unstable? How many has she flown? > > Here's what I know: if the air is calm my airplane will fly hands off for 20-30 seconds. If there are any bumps I have to monitor the airplane much more closely. > > The nose wants to drop at low speeds, but that has nothing to do with aerodynamics and everything to do with those big heavy elevators hanging back there being subject to gravity. I have the East Texas Trim System in the form of a bungee cord that keeps the nose where it belongs. > > Here's what I've been told. I'm darn sure no aerodynamics expert so take it for what it's worth: if the CG is jacked up, common in a Piet, an airplane can be unstable. The experts can chime in. > > -------- > Kevin "Axel" Purtee > NX899KP > Austin/San Marcos, TX > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371469#371469 > > > > > > > > > > ________________________________________________________________________________
Date: Apr 22, 2012
John,=0A=0ABecause=C2-Piets have no =C2-dihedral and generally have an aft cg, it will be less stable than a 172 or whatever else she is used to f lying. That doesn't necessarily make it a bad thing, just has more=C2-cha racter, but may take a little more skill to fly it.=C2-=0A=0AI am a pilot but only a Piet builder so take it for what it's worth.=0A=0ARyan Michals =0A=0AStability=C2-is the tendency of an airplane in flight to remain in straight, level, upright flight and to return to this attitude, if displace d, without corrective action by the pilot.=0AStatic stability=C2-is the =C2-initial=C2-tendency of an airplane, when disturbed, to return to th e original position.=0ADynamic stability=C2-is the=C2-overall=C2-tend ency of an airplane to return to its original position, following a series of damped out oscillations.=0A=0AStability may be (a)=C2-positive,=C2-m eaning the airplane will develop forces or moments which tend to restore it to its original position; (b)=C2-neutral,=C2-meaning the restoring for ces are absent and the airplane will neither return from its disturbed posi tion, nor move further away; (c)=C2-negative,=C2-meaning it will develo p forces or moments which tend to move it further away. Negative stability is, in other words, the condition of=C2-instability.=0AA stable airplane is one that will fly "hands off" and is pleasant and easy to handle. An exc eedingly stable airplane, on the other hand, may lack maneuverability.=0AAn airplane which, following a disturbance, oscillates with increasing up and down movements until it eventually stalls or enters a dangerous dive would be said to be unstable, or to have negative dynamic stability.=0AAn airpla ne that has positive dynamic stability does not automatically have positive =C2-static=C2-stability. The designers may have elected to build in, fo r example, negative static stability and positive dynamic stability in orde r to achieve their objective in maneuverability. In other words, negative a nd positive dynamic and static stability may be incorporated in any combina tion in any particular design of airplane.=0AAn airplane may be=C2-inhere ntly stable,=C2-that is, stable due to features incorporated in the desig n, but may become=C2-unstable=C2-due to changes in the position of the center of gravity (caused by consumption of fuel, improper disposition of t he disposable load, etc.).=0AStability may be (a)=C2-longitudinal,=C2-( b)=C2-lateral,=C2-or (c)=C2-directional,=C2-depending on whether th e disturbance has affected the airframe in the (a)=C2-pitching,=C2-(b) =C2-rolling, or (c)=C2-yawing=C2-plane. copied from :http://www.allst ar.fiu.edu/aero/axes33.htm=C2-=0A=0A________________________________=0A F rom: Kringle =0ATo: pietenpol-list(at)matronics.com =0ASen t: Sunday, April 22, 2012 8:01 AM=0ASubject: Pietenpol-List: Pietenpols Uns n.com>=0A=0AA pilot told me that all the piets she flew were unstable.=C2 - She said, =9CIf you let go of the stick they would just fall off one way or the other=9D.=C2- Say it ain=99t so!=0A=0AJohn=0A =0A--------=0AJohn=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://f orums.matronics.com/viewtopic.php?p=371466#371466=0A=0A=0A=0A=0A=0A=0A=0A == ________________________________________________________________________________
Date: Apr 22, 2012
Ill ask her more the next time I see her but it may be several months. She is a retired FAA inspector and has over 100 hours piloting Pietenpols. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371477#371477 ________________________________________________________________________________
Date: Apr 22, 2012
Sorry folks but I must say something here... The Piet's design is basically stable. If the CG is within limits and the plane is well rigged. I have no adjustable elevator trim on 58TL but I can trim it using the throttle. Just for grins the other night I took my hands off the stick and using only the throttle and rudders entered downwind at 45 deg and turned to base. Banks were 15 deg or so. I was seeing if I might be able to land it without stick input. My conclusion is with 'luck' and a long approach/field one could fly it on. I used to fly a 1978 PA28-181 and wouldn't fly more than 5-10 seconds without dropping a wing until we FIXED the aileron rigging! Then you could fly it with the throttle and rudder... Piet design Inherently unstable? - Simply No Steve On Sun, Apr 22, 2012 at 8:01 AM, Kringle wrote: > > A pilot told me that all the piets she flew were unstable. She said, =93 If > you let go of the stick they would just fall off one way or the other=94. > Say it ain=92t so! > > John > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371466#371466 > > =========== =========== =========== =========== > > ________________________________________________________________________________
Date: Apr 22, 2012
The stability of the Piet is totally affected by the lack of trim tabs. That needs to be controlled by engine power instead. Or as BHP said, you can stick your arm out to one side or the other and make it turn. Dont try that with a 172. Dick N. ----- Original Message ----- From: "Kringle" <Mrkringles(at)msn.com> Sent: Sunday, April 22, 2012 7:01 AM Subject: Pietenpol-List: Pietenpols Unstable? > > A pilot told me that all the piets she flew were unstable. She said, > ?oIf you let go of the stick they would just fall off one way or the > other?. Say it ain?Tt so! > > John > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371466#371466 > > > ________________________________________________________________________________
Date: Apr 22, 2012
All flying Piets are stable. What that means is that when disturbed from a steady state, they tend to return to that state, rather than diverge from it. If the CG is within limits, it's pretty much guaranteed... (barring weird stuff). However, probably due to the reasonably small control surfaces, Piets tend to get better pilot reports when flown in the aft region of acceptable CG limits. There, the plane is LESS stable, but still stable. When disturbed from a steady state, it's pretty slow and not aggressive about returning to that state, also, it takes less force to disturb it. Stability and maneuverability are the mutually exclusive things here. You can only have one, and how an airplane flies is a compromise between the two. The general inability to remain trimmed and simply fly hands off however is probably what's being discussed, rather than stability. A highly stable airplane will have the ability to stay trimmed up better than one that is not as stable, or more maneuverable. As mentioned, many piets don't even have a way to trim them, so for hands off flight, you find the airspeed the airplane is trimmed for. Dicks's NX2RN is a classic example. It's hands off at 2K rpm and a pilot only. Fly at a higher rpm and it needs some rudder input and it climbs (or needs constant down stick and will therefore fly faster). At 1900 rpm, the opposite. So the broad sweeping statement that Piets are unstable really suffers from misuse of the term stable. For it's class, it's a relatively maneuverable, less stable airplane. If you want it more stable, move the CG forward. Then, rig the plane to fly hands off in the regime you'll be flying in the most. By the way, if the plane was unstable, when it is disturbed from steady state, that movement would continue until something bad happens, like a ground loop, but in the air. All taildraggers are unstable while moving on the ground. Directionality can be achieved by overcoming the unstable force either with sufficient rudder authority or tailwheel authority, or brakes, or something. But the configuration is unstable. The one caveat is unstable airplanes like F-18's, that have computers keeping them in control. They are maneuvable and have forced stability. Tools Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371490#371490 ________________________________________________________________________________
Date: Apr 22, 2012
With 100hrs, her=C2-experience=C2-couldn't have been all that bad, she got back in one, several times.=0A=0ARyan=0A=0A____________________________ ____=0A From: Kringle <Mrkringles(at)msn.com>=0ATo: pietenpol-list(at)matronics.c om =0ASent: Sunday, April 22, 2012 10:24 AM=0ASubject: Pietenpol-List: Re: =0A=0AI=C3=A2=82=AC=84=A2ll ask her more the next time I see her but it may be several months.=C2- She is a retired FAA in spector and has over 100 hours piloting Pietenpols.=0A=0A--------=0AJohn=0A =0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matronics.com/v - =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- =C2- ==================== ________________________________________________________________________________
Date: Apr 22, 2012
John, have you found the hose fittings you need? If not, email me off list and we'll talk...I believe I can help you out. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 22, 2012
Subject: long fuze Piet?
Go long. Period. Piets are still tight fits for many. I have a short Piet fuze hanging in my garage as unusable by me, and a long fuselage Piet requires bigger "shin holes" for me in the bulkhead at the passenger seat back frame. I am just under 6 ft. 2in. Others may well correct me on this, but I suspect both the pilot and passenger make out with more room in a long fuze version. Not only you and your dad, but other passengers and maybe the guy you sell it to or your kids may appreciate the longer leg room and ease of entry. Tim in central TX ________________________________________________________________________________
Date: Apr 22, 2012
Subject: Cards on the Table x 2
Hello Fella's=0A=0AI'm involved in two Piet builds. My Piet started in 1992 when I bought the GN-1 plans from John Grega. At that time I didn't even k now about Bernard, Hoopman and Cherry Grove.- But I was just too busy wit h Career- and family so the plans sat in my file drawer along with all my other info packets for other kits and plans for the dream of flight.=0AThe n in 2010, with my youngest of 3 finally graduated from college, I started getting the itch again. I looked through all the info packets and plans for several different aircraft and came across the Grega plans. An EAA member since 1992, I was not involved in a Chapter so it was time to get to know s ome guys and get started building. When I went to the Chapter meeting for t he first time I carried the GN-1 plans with me. I had written GN-1 in large red letters on the outside of the manilla envelope and as soon as I walked in the room the chapter president Brian Kissinger, saw it and said "We've been looking for those". It turns out that about a half a year before the c hapter had received a Piet that had been crashed nearly 15 years before. It was a Grega built in the early 70's by a retired airline pilot, Art Hollim an. The construction was A+. Well done and over built at just over 800 poun ds. The crash did very little damage to the plane but unfortunately Art Holliman did not fair so well. He is still with us but a head injury left him blind. The plane was scavenged for the engine and ins truments but the rest was in remarkable shape.=0ASo about a dozen chapter 6 4 members are working a few hours a week to rebuild it. About half the tail feathers have been covered and one wing panel should be done soon. Another crew is working on the fuse and cowl to enclose the 0-200. Cub style gear with springs and 6 inch wheels.=0AWe were hoping to make Brodhead this year but 2013 is more realistic.=0AThis is our Logo (copyrighted)=0A=0ABelow is the Scrounge Dawg Piet (GN-1) at Historic Hangar 2, built by Curtis Wright in 1927and used to build the Curtis Robin, at CPS St. Louis Downtown.=0A =0A=0A=0ANow back to my Piet. I started researching Pietenpol on the intern et and found the Brodhead Pietenpol Association and this Matronics list. I sent away for the plans and picked up a project consisting of basic fuse an d ribs and spars. I already have the Bingellis books, bought way back $45 f or all 4.=0ASo I'm building to plans, long fuse, using Tony's books as the construction manual.=0A=0AFuse is mostly done now except for Jenny style ge ar which won't be put on till I get it in my new (new to me that is) hangar at H49. Hangar needs a lot of work yet. Hope to be in by June.=0ARibs on s pars with leading and trailing edges. Have not yet cut out ailerons.=0AI ha ve a beautiful little A-65 200 hrs SMOH and chrome cylinders and complete e xhaust, airbox, carb etc.- Engine is ready to mount.=0A=0ARay Hegy 72x42 prop previously flight tested by Oscar Z. on Scout.=0AWith the three piece wing, the span will be 31 ft. Cross bracing in wings will be hard wire, no turnbuckles.=0A=0A15 gal tank in center section. No nose tank.=0A19 inch ri ms will be cross laced to a home made 6inch hub and covered with fabric. =0A=0ASmall go-cart style strap brakes, heel pedals.=0A=0ABelow pic is not very current=0A=0A=0AJeff Wilson=0ASt. Louis, MO=0APrivate Pilot ________________________________________________________________________________
Date: Apr 22, 2012
Subject: new
Douwe, you have really started something. If all these new builders get their planes flying then we are going to have a hell of a squadron. Cheers, Gardiner ________________________________________________________________________________
Subject: Re: long fuze Piet?
Date: Apr 22, 2012
Thanks Tim! Looks like I will be making the long one work for me. Just be building a class E and G airspace basic VFR airplane with no extra electrical and split axle landing gear with spoke wheels. The end product hopefully will be light enough for us. Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371521#371521 ________________________________________________________________________________
Date: Apr 22, 2012
Thanks guys! Looks like I am going to build long and as light as I can! -Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371522#371522 ________________________________________________________________________________
Date: Apr 22, 2012
Kevin, what do you mean by "jacked up"? C ----- Original Message ----- From: "kevinpurtee" <kevin.purtee(at)us.army.mil> Sent: Sunday, April 22, 2012 8:15 AM Subject: Pietenpol-List: Re: Pietenpols Unstable? > > > Perhaps she meant to say that all Piet pilots are unstable? How many has > she flown? > > Here's what I know: if the air is calm my airplane will fly hands off for > 20-30 seconds. If there are any bumps I have to monitor the airplane much > more closely. > > The nose wants to drop at low speeds, but that has nothing to do with > aerodynamics and everything to do with those big heavy elevators hanging > back there being subject to gravity. I have the East Texas Trim System in > the form of a bungee cord that keeps the nose where it belongs. > > Here's what I've been told. I'm darn sure no aerodynamics expert so take > it for what it's worth: if the CG is jacked up, common in a Piet, an > airplane can be unstable. The experts can chime in. > > -------- > Kevin "Axel" Purtee > NX899KP > Austin/San Marcos, TX > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371469#371469 > > > ________________________________________________________________________________
Date: Apr 23, 2012
Subject: Latex Paint Forum
Just an FYI for anyone in the Suffolk , VA area. I will be at the VA Festiv al of flight this coming weekend presenting a forum on painting your airpla ne with inexpensive latex paint. The forum is currently scheduled to run fr om 11:15 to 12:15 on Saturday (maybe Sunday too). I will talk about finishi ng my Kolb MKII, Titan Tornado, and Pietenpol Aircamper. Weather permitting I will have the Titan with me. Stop by and say hi if you get the chance. B elow is a link to the festival=99s web site. http://virginiaflyin.org/ Malcolm Morrison http://home.comcast.net/~mmorrison123/Airplanes.htm ________________________________________________________________________________
Date: Apr 22, 2012
Chuck, Jacked up is a term that you would hear a lot in the military. It means something that is not correct or blatantly wrong. You will hear drill instructors tell someone their uniform is "Jacked Up" if it is wrinkled or items not pinned(or in today's military velcro) in its place. Sorry to cut in, but I am pretty sure that is what he was getting at. Kyle -------- Airspeed, altitude or brains: Two are always needed to successfully complete the flight. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371540#371540 ________________________________________________________________________________
Date: Apr 22, 2012
Too far aft, Chuck. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371549#371549 ________________________________________________________________________________
Date: Apr 23, 2012
Subject: FW: Corvair CHT
From: Rod Wooller [mailto:rodwooller(at)gmail.com] Sent: Monday, 23 April 2012 8:19 PM Subject: Fwd: Corvair CHT ---------- Forwarded message ---------- From: Rod Wooller <rodwooller(at)gmail.com> Date: Sat, Apr 21, 2012 at 9:29 PM Subject: Corvair CHT Pietenpol-List Digest List I have a CHT gauge on my Pietenpol with sensors under the rear spark plugs of each cylinder head. Can anyone tell me the maximum temperature that the Corvair heads should be run at ? Thanks, Rod Wooller ZK-PAC ________________________________________________________________________________
Subject: Re: Corvair CHT
Date: Apr 23, 2012
My book on the Lycoming O-235 C2C says: Cylinder head Maximum temp 525 F for spark plug thermocouple preferred max 425 F continuous. I would think most engines would have similar maximums. I hope mine will be in the 375 area for longevity. -------- Jerry Dotson 59 Daniel Johnson Rd Baker, FL 32531 Started building NX510JD July, 2009 thru covering and painting, now in final assembly 21" wheels Lycoming O-235 C2C Jay Anderson CloudCars prop 76 X 44 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371572#371572 ________________________________________________________________________________
Date: Apr 23, 2012
Subject: Re: FW: Corvair CHT
Rod,there is a good discussion of CHT and cooling issues at the following link: http://flycorvair.com/pietengineissue.html Lots of info there... Regards, John Franklin Prairie Aire 4TA0 Needville, TX GN-1 / Corvair 164CID I have a CHT gauge on my Pietenpol with sensors under the rear spark plugs of each cylinder head. Can anyone tell me the maximum temperature that the Corvair heads should be run at ? Thanks, Rod Wooller ZK-PAC ________________________________________ ________________________________________________________________________________
Date: Apr 23, 2012
WW says, ".....I would try and keep the motor below 450F peak and 400F cruise......" ----- Original Message ----- From: Rod Wooller To: pietenpol-list(at)matronics.com Sent: Monday, April 23, 2012 4:22 AM Subject: Pietenpol-List: FW: Corvair CHT From: Rod Wooller [mailto:rodwooller(at)gmail.com] Sent: Monday, 23 April 2012 8:19 PM To: rmwo(at)clear.net.nz Subject: Fwd: Corvair CHT ---------- Forwarded message ---------- From: Rod Wooller <rodwooller(at)gmail.com> Date: Sat, Apr 21, 2012 at 9:29 PM Subject: Corvair CHT To: Pietenpol-List Digest Server , Pietenpol-List Digest List I have a CHT gauge on my Pietenpol with sensors under the rear spark plugs of each cylinder head. Can anyone tell me the maximum temperature that the Corvair heads should be run at ? Thanks, Rod Wooller ZK-PAC ________________________________________________________________________________
Date: Apr 23, 2012
Rod,=0A-=0AThe max is over well 400F, however I see a constant 350 F on b oth sides on mine even on a hot Texas day.=0A-=0AHans=0A-=0ANX 15KV=0AW aller, TX=0A =0A=0A________________________________=0A From: Rod Wooller <r mwo(at)clear.net.nz>=0ATo: pietenpol-list(at)matronics.com =0ASent: Monday, April 23, 2012 3:22 AM=0ASubject: Pietenpol-List: FW: Corvair CHT=0A =0A=0A- =0A-=0AFrom:Rod Wooller [mailto:rodwooller(at)gmail.com] =0ASent: Monday, 23 April 2012 8:19 PM=0ATo: rmwo(at)clear.net.nz=0ASubject: Fwd: Corvair CHT=0A -=0A-=0A---------- Forwarded message ----------=0AFrom: Rod Wooller <ro dwooller(at)gmail.com>=0ADate: Sat, Apr 21, 2012 at 9:29 PM=0ASubject: Corvair CHT=0ATo: Pietenpol-List Digest Server , Pie tenpol-List Digest List =0A=0A=0AI hav e a CHT gauge on my Pietenpol with sensors under the rear spark plugs of ea ch cylinder head.=0ACan anyone tell me the maximum temperature that the Cor vair heads should be run at ?=0A=0AThanks,=0ARod Wooller=0AZK-PAC=0A- =0A ================ ________________________________________________________________________________
Subject: Cards on the table
Date: Apr 23, 2012
Now since most of us have put our cards on the table to meet the request, is someone planning to take the information arrange it into a consolidated universally formatted spread sheet and publish and send it out to all members? Was there or is there a purpose to all of that information being published? Having taken the time to participate, what was the purpose? Thanks John Archive at your own risk Sent from my iPhone ________________________________________________________________________________
Date: Apr 23, 2012
Subject: Re: Va. Festival of Flight
I'm flying my Piet down for the Va Festival of Flight. We're planning on flyin Friday evening and making a weekend of it, along with me, 3 buddies with a 182, a Piper Colt and a TriPacer. Malcomb, I'll look out for your talk. I didn't use latex but I did investigate it and gave it serious consideration. My familiarity with the PolyFiber system, and it's repairability made me go that way with my finish. Matt Paxton NX629ML ________________________________________________________________________________
Date: Apr 23, 2012
>From the '09 Corvair Flight Ops manual WW sells, Chapter 7 "Operational Limits" written by Woody Harris: "The Corvair has a factory limit of 575F. The engine will tolerate this for very brief periods in automotive applications. For aircraft, the target is much lower." "400F should be the upper limit for stock heads. 450F is the limit for Falcon heads." A good read if you are going to be operating a Corvair in an aircraft, good info, interesting writing.... Ryan On Mon, Apr 23, 2012 at 9:07 AM, Hans van der Voort wrote: > Rod, > > The max is over well 400F, however I see a constant 350 F on both sides on > mine even on a hot Texas day. > > Hans > > NX 15KV > Waller, TX > > *From:* Rod Wooller > > *To:* pietenpol-list(at)matronics.com > *Sent:* Monday, April 23, 2012 3:22 AM > *Subject:* Pietenpol-List: FW: Corvair CHT > > > *From:* Rod Wooller [mailto:rodwooller(at)gmail.com] > *Sent:* Monday, 23 April 2012 8:19 PM > *To:* rmwo(at)clear.net.nz > *Subject:* Fwd: Corvair CHT > > > ---------- Forwarded message ---------- > From: *Rod Wooller* <rodwooller(at)gmail.com> > Date: Sat, Apr 21, 2012 at 9:29 PM > Subject: Corvair CHT > To: Pietenpol-List Digest Server , > Pietenpol-List Digest List > > > I have a CHT gauge on my Pietenpol with sensors under the rear spark plugs > of each cylinder head. > Can anyone tell me the maximum temperature that the Corvair heads should > be run at ? > > Thanks, > Rod Wooller > ZK-PAC > > > *http://www.matronics.com/Navigator?Piete===================== > * > > > * > > * > > ________________________________________________________________________________
Subject: Control sticks in position...
Date: Apr 23, 2012
Hello good Piet-ple, My welder (Mike, who's company is "Ready Weld") came over and finished up welding the control assembly on Friday. I then cleaned up the parts, positioned, drilled, and temporarily bolted the assembly where it goes in the plane. (Note: I am using "Home Depot" fasteners until final assembly so don't fret about the cheap carriage bolts holding it all together until then...!) Now I can sit in the plane and make airplane noises - while practicing takeoff's and gradual turns (ha!) Regards... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371635#371635 Attachments: http://forums.matronics.com//files/pilot_stick_477.jpg http://forums.matronics.com//files/passenger_stick_164.jpg http://forums.matronics.com//files/pandp_control_sticks_170.jpg ________________________________________________________________________________
Subject: Aileron Cable Routing
Date: Apr 23, 2012
Have any of you had to run a set of "idler" pulleys to route the aileron control cables around instruments when moving the cabanes back? I am eyballing the cable locations with the cabanes still vertical and see interference. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371634#371634 ________________________________________________________________________________
Date: Apr 23, 2012
Subject: Re: Aileron Cable Routing
I had to add some on mine. I added a tubular frame to mount the passenger shoulder harnesses, a design I copied off the British Piet site. Had to add some idlers to keep cables from rubbing. Something else to consider is where the cross braces pass through the cowls, as those move aft also. Ben On 4/23/2012 2:28 PM, 899PM wrote: > --> Pietenpol-List message posted by: "899PM" > > Have any of you had to run a set of "idler" pulleys to route the aileron control cables around instruments when moving the cabanes back? I am eyballing the cable locations with the cabanes still vertical and see interference. > > -------- > PAPA MIKE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371634#371634 > > -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Apr 23, 2012
From: Douwe Blumberg <douweblumberg(at)earthlink.net>
Subject: new piets
Hey all! Wow, I really enjoyed reading the details of everyone's projects. I too am encouraged that the design seems alive and well and can't wait for a few years down the road when they're all up and flying! Sounds like some very interesting ones coming along. Am excited to hear from Rick Holland and can't wait to hear a flight report soon. Keep at it everyone! Douwe ________________________________________________________________________________
Date: Apr 23, 2012
Looks really nice, Jake. Seems so odd to see a steel tube framework instead of wood, but very nice workmanship. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of aerocarjake Sent: Monday, April 23, 2012 2:29 PM Subject: Pietenpol-List: Control sticks in position... Hello good Piet-ple, My welder (Mike, who's company is "Ready Weld") came over and finished up welding the control assembly on Friday. I then cleaned up the parts, positioned, drilled, and temporarily bolted the assembly where it goes in the plane. (Note: I am using "Home Depot" fasteners until final assembly so don't fret about the cheap carriage bolts holding it all together until then...!) Now I can sit in the plane and make airplane noises - while practicing takeoff's and gradual turns (ha!) Regards... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371635#371635 Attachments: http://forums.matronics.com//files/pilot_stick_477.jpg http://forums.matronics.com//files/passenger_stick_164.jpg http://forums.matronics.com//files/pandp_control_sticks_170.jpg ________________________________________________________________________________
Date: Apr 23, 2012
I've got all 6 instrumented. #3 is typically the warmest and it hasn't gone above ~360. Like Hans, I'm in Texas. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371683#371683 ________________________________________________________________________________
Date: Apr 24, 2012
Subject: progress info thread
Hey John, As stated in my initial email that started that thread, I thought it be would be 1. interesting 2. encouraging and 3. educational to hear what everybody is doing. I had no idea what most of us were building until now and it also gives us an idea of when some of these new ones might "come on line". As stated before, it is interesting to see the subtle and not so subtle "nuances" builders are incorporating. Douwe ________________________________________________________________________________
Date: Apr 25, 2012
Thanks for all the helpful replies. My cooling eyebrows are as per Hans van der Voort's design, but I may need to do some work with high temp silicon to minimise air leakage as my test pilot recorded CHT's of 450F during climb-out on a 72F day. A flat nose probably doesn't help the airflow either. Still a lot of testing to do before I get the controls. Thanks again guys. Rod Wooller ZK-PAC From: Rod Wooller [mailto:rodwooller(at)gmail.com] Sent: Monday, 23 April 2012 8:19 PM Subject: Fwd: Corvair CHT ---------- Forwarded message ---------- From: Rod Wooller <rodwooller(at)gmail.com> Date: Sat, Apr 21, 2012 at 9:29 PM Subject: Corvair CHT Pietenpol-List Digest List I have a CHT gauge on my Pietenpol with sensors under the rear spark plugs of each cylinder head. Can anyone tell me the maximum temperature that the Corvair heads should be run at ? Thanks, Rod Wooller ZK-PAC ________________________________________________________________________________
Subject: Wing Tip Transition
Date: Apr 24, 2012
I would like to see pictures of how some of you transitioned the wing tip to the leading and trailing edge. Thanks John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371737#371737 ________________________________________________________________________________
Date: Apr 24, 2012
You can see the corner of the wingtip in the foregroud of this picture (ignore me sitting in my fuselage making airplane noises). I mixed microballoons with epoxy to make a thick slurry and globbed it in place, then sanded it smooth. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Tuesday, April 24, 2012 7:34 PM Subject: Pietenpol-List: Wing Tip Transition I would like to see pictures of how some of you transitioned the wing tip to the leading and trailing edge. Thanks John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371737#371737 ________________________________________________________________________________
Subject: Re: Wing Tip Transition
Date: Apr 24, 2012
May be this help?.. -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371744#371744 Attachments: http://forums.matronics.com//files/dsc04443_105.jpg http://forums.matronics.com//files/dsc04445_837.jpg ________________________________________________________________________________
Date: Apr 24, 2012
#2. John, as you will notice in some of my pictures, I didn't take the aileron all the way to the tip. I used what some call an "encapsulated" aileron. C ----- Original Message ----- From: "Kringle" <Mrkringles(at)msn.com> Sent: Tuesday, April 24, 2012 7:34 PM Subject: Pietenpol-List: Wing Tip Transition > > I would like to see pictures of how some of you transitioned the wing tip > to the leading and trailing edge. > > Thanks > John > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371737#371737 > > > ________________________________________________________________________________
From: "skellytown flyer" <skellflyer1(at)yahoo.com>
Date: Apr 24, 2012
do you have the bottom air baffles under the cylinders? also I made some close fitting plates to fit against the rear of the heads to prevent air escaping at the back and force it all down through the cylinder/ head fins with the exception of the oil cooler and tried to close any areas around the outside of that also.my single temp pickup is under one head bolt nut- when checked on the ground runs with a good quality heat gun the readings were within 15 to 20 degrees of the surrounding head surfaces. and mine never climbed over 290 in early testing. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371746#371746 ________________________________________________________________________________
Date: Apr 24, 2012
John I made the top of the wing tip bow to be flush with the top of the leading edge. The bottom of the leading edge was tapered from the last wing rib up to the bottom of wing tip bow. I also added a filler block behind the joint so I could radius the corner. http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_5559.JPG You didn't ask but you will also need to taper the wing tip bow to the thickness of the aileron trailing edge. My taper starts just past the rear spar. I made the top of the bow equal to the top of the trailing edge so all I had to do was make one cut off the bottom of the bow. http://westcoastpiet.com/images/Chris%20Tracy/images/IMG_5560.JPG Chris Sacramento, Ca Westcoastpiet.com -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Tuesday, April 24, 2012 4:34 PM Subject: Pietenpol-List: Wing Tip Transition I would like to see pictures of how some of you transitioned the wing tip to the leading and trailing edge. Thanks John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371737#371737 ________________________________________________________________________________
Date: Apr 24, 2012
Rod,=0A=C2-=0AClean up the heads, remove all casting flashing.=0AThat thi n film of aluminum left behind by GM on their mass produced heads.=0A=C2- =0AJust make sure air flows over those fins it makes a BIG difference.=0A =C2-=0AA simple fix that often gets ignored=0A=C2-=0ARegards=0A=C2- =0AHans=0A=C2-=0ANX15KV=0AWaller, TX=0A=0AFrom: Rod Wooller <rmwo(at)clear.n et.nz>=0ATo: pietenpol-list(at)matronics.com =0ASent: Tuesday, April 24, 2012 4:47 PM=0ASubject: Pietenpol-List: FW: Corvair CHT=0A=0A=0AThanks for all t he helpful replies. My cooling eyebrows are as per Hans van der Voort =99s design, but I may need to do some work with high temp silicon to minim ise air leakage as my test pilot recorded CHT=99s of 450F during clim b-out on a 72F day. A flat nose probably doesn=99t help the airflow e ither. Still a lot of testing to do before I get the controls.=0A=C2-=0AT hanks again guys.=0ARod Wooller=0AZK-PAC=0A=C2-=0AFrom:Rod Wooller [mailt o:rodwooller(at)gmail.com] =0ASent: Monday, 23 April 2012 8:19 PM=0ATo: rmwo@c lear.net.nz=0ASubject: Fwd: Corvair CHT=0A=C2-=0A=C2-=0A---------- Forw arded message ----------=0AFrom: Rod Wooller <rodwooller(at)gmail.com>=0ADate: Sat, Apr 21, 2012 at 9:29 PM=0ASubject: Corvair CHT=0ATo: Pietenpol-List D igest Server , Pietenpol-List Digest List =0A=0A=0AI have a CHT gauge on my Pietenp ol with sensors under the rear spark plugs of each cylinder head.=0ACan any one tell me the maximum temperature that the Corvair heads should be run at ======== ________________________________________________________________________________
Date: Apr 25, 2012
Some more pics John http://textors.com/8-31-08_012.jpg Jack Textor DSM NX1929T -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Kringle Sent: Tuesday, April 24, 2012 6:34 PM Subject: Pietenpol-List: Wing Tip Transition I would like to see pictures of how some of you transitioned the wing tip to the leading and trailing edge. Thanks John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371737#371737 ________________________________________________________________________________
Date: Apr 25, 2012
Date: Apr 25, 2012
Thanks all for pictures. Ive saved them to my iPad for future reference. John -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371770#371770 ________________________________________________________________________________
Date: Apr 25, 2012
Michael, Perhaps the photo you attached is an older photo, and this has already been addressed, but it looks like you would need some additional bracing at your wing tip. There was a recent discussion here on the List that brought up the point that the wing tip bow actually acts as a compression strut. Your photo appears to show a wing tip bow that is even slimmer than the "plans" version. The structure shown in your photo likely will not be stout enough. It would be prudent to introduce a compression strut similar to those at the wing root and mid-wing. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371771#371771 ________________________________________________________________________________
Date: Apr 25, 2012
Correct Bill, that is an "in work" picture and the most current one I have at this time. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 25, 2012
Subject: Engine "Screw, Dowel"
There are, I believe, three of these "screw, dowel" bolts to hold the engine case halves together. I could not find these at ACS. If anyone has an idea who might carry them or what nomenclature I should use to search with, I would appreciate it. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 25, 2012
I assume you are talking about a Continental A65? Try Fresno Airparts (559) 237-4863 email fresnoairparts(at)att.net . They have an ad on the first page of every Trade-a-Plane and carry every part for the small Continentals. They list "Crankcase clamping dowel bolt, nut set for $47.50. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez Sent: Wednesday, April 25, 2012 9:44 AM Subject: Pietenpol-List: Engine "Screw, Dowel" There are, I believe, three of these "screw, dowel" bolts to hold the engine case halves together. I could not find these at ACS. If anyone has an idea who might carry them or what nomenclature I should use to search with, I would appreciate it. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 25, 2012
John, the first time I sent some pictures it was rejected by the list for being too large. Maybe this one will go through. The wing is upside down in both pictures. I didn't run my aileron all the way to the tip. C ----- Original Message ----- From: "Kringle" <Mrkringles(at)msn.com> Sent: Tuesday, April 24, 2012 7:34 PM Subject: Pietenpol-List: Wing Tip Transition > > I would like to see pictures of how some of you transitioned the wing tip > to the leading and trailing edge. > > Thanks > John > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371737#371737 > > > ________________________________________________________________________________
Date: Apr 25, 2012
Ok Jack. I'll give them a call. Mike C. seems to think that kit is all the nuts, bolts, etc for the entire engine. (A65)=C2- Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com --- On Wed, 4/25/12, Jack Phillips wrote: From: Jack Phillips <pietflyr(at)bellsouth.net> Subject: RE: Pietenpol-List: Engine "Screw, Dowel" Date: Wednesday, April 25, 2012, 10:35 AM =0A=0A=0A =0A =0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0A=0AI assume you are talking about a=0AContinental A65?=C2- Try Fresno Airparts (559) 237-4863=C2- e mail fresnoairparts(at)att.net .=C2- They=0Ahave an ad on the first page of every Trade-a-Plane and carry every part for=0Athe small Continentals.=C2 - They list =9CCrankcase clamping dowel bolt,=0Anut set for $47.50. =0A=0A =C2- =0A=0AJack Phillips =0A=0ANX899JP =0A=0ASmith Mountain Lake, Virginia =0A=0A =C2- =0A=0A=0A=0A=0A=0A=0A=0A=0A=0AFrom: owner-pietenpol -list-server(at)matronics.com=0A[mailto:owner-pietenpol-list-server(at)matronics. com] On Behalf Of Michael Perez =0ASent: Wednesday, April 25, 2012=0A9:44 AM =0ATo: pietenpol-list(at)matronics.com =0ASubject: Pietenpol-List: Engine=0A"Screw, Dowel" =0A=0A=0A=0A =C2- =0A =0A=0A =0A =0A There are, I believe, three of these "screw,=0A dowel" bo lts to hold the engine case halves together. I could not find=0A these at ACS. If anyone has an idea who might carry them or what nomenclature=0A I should use to search with, I would appreciate it. =0A =0A Michael Perez =0A Pietenpol HINT Videos =0A Karetaker Aero =0A www.karetakeraero.com =0A =0A =0A=0A=0A =C2- =C2-http://www.matro nics.com/Navigator?Pietenpol-Listhttp://forums.matronics.comhttp://www.matr -======================== ============0A=0A ________________________________________________________________________________
Date: Apr 25, 2012
Thanks Bill, those are the kind of pictures I was looking for. -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371793#371793 ________________________________________________________________________________
Subject: Re: calling for a Rick Holland update---come in Rick....do
you r
Date: Apr 25, 2012
I doubt that I will have the 40 hours flown off for Brodhead this year Jack but hopefully 2013. Rick -------- Rick Holland Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371795#371795 ________________________________________________________________________________
Date: Apr 25, 2012
I am learning english with you ;o) -------- Mario Giacummo http://vgmk1.blogspot.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371797#371797 ________________________________________________________________________________
Date: Apr 25, 2012
Mario, Your English is much better than my Spanish! Do no archive -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371798#371798 ________________________________________________________________________________
Date: Apr 25, 2012
Subject: Re: put your cards on the table Gents and Ladies!
Bill Princell - Noblesville, IN Started a complete rebuild and design upgrade of N10837 on 6-05 which had been severally damaged in a central Texas landing accident. My project is a Piet/Grega hybrid with an oversize fuselage (plus 2" wide and 3" deep) and a 44" wide wing center section. Removed and sold original Subaru EA81 engine - Rebuilt a 1965 Corvair Engine w/William Wynne conversion parts and a Dan's 5th Bearing. Engine ran at CC #20 held in Michigan on weekend of June 3, 2011. New wings and center section build and completed using Riblett 612 airfoil with continuous aileron hinges. Made 4 new Cabane struts w/support cables. New fin/rudder and elevator/stabilizer w/push/pull rod control system and a continuous (no gap) hinge system. Made 8 new support cables w/turnbuckles. Cockpit interiors completed. New aluminum instrument panel completed w/new steam gauges installed. All new electrical system and wiring installed. New Cub type gear w/6:00x6 wheels and tires and disc type brakes. New engine mount for Corvair engine built and installed. All metal surfaces have been powder coated. Will start fabric covering this fall using Stewart Systems process w/Latex paint. Using light weight fabric and w/medium weight fabric on upper surface of wings. Hope to complete and first flight in 2014. ________________________________________________________________________________
Date: Apr 25, 2012
Hey Bill, you might want to consider putting a supercharger on that engine. From what I can see of your photos, Your plane looks great. Cheers, Gardiner ________________________________ From: Bill Princell <weprincell(at)gmail.com> Sent: Wed, April 25, 2012 1:38:47 PM Subject: Pietenpol-List: Re: put your cards on the table Gents and Ladies! Bill Princell - Noblesville, IN Started a complete rebuild and design upgrade of N10837 on 6-05 which had been severally damaged in a central Texas landing accident. My project is a Piet/Grega hybrid with an oversize fuselage (plus 2" wide and 3" deep) and a 44" wide wing center section. Removed and sold original Subaru EA81 engine - Rebuilt a 1965 Corvair Engine w/William Wynne conversion parts and a Dan's 5th Bearing. Engine ran at CC #20 held in Michigan on weekend of June 3, 2011. New wings and center section build and completed using Riblett 612 airfoil with continuous aileron hinges. Made 4 new Cabane struts w/support cables. New fin/rudder and elevator/stabilizer w/push/pull rod control system and a continuous (no gap) hinge system. Made 8 new support cables w/turnbuckles. Cockpit interiors completed. New aluminum instrument panel completed w/new steam gauges installed. All new electrical system and wiring installed. New Cub type gear w/6:00x6 wheels and tires and disc type brakes. New engine mount for Corvair engine built and installed. All metal surfaces have been powder coated. Will start fabric covering this fall using Stewart Systems process w/Latex paint. Using light weight fabric and w/medium weight fabric on upper surface of wings. Hope to complete and first flight in 2014. ________________________________________________________________________________
Date: Apr 25, 2012
Subject: Re: Engine "Screw, Dowel"
I also replaced all my crankcase bolts on reassembly. May have some old ones laying around if you are looking to save the $50. Ben On 4/25/2012 10:35 AM, Jack Phillips wrote: > > I assume you are talking about a Continental A65? Try Fresno Airparts > (559) 237-4863 email fresnoairparts(at)att.net > . They have an ad on the first page > of every Trade-a-Plane and carry every part for the small > Continentals. They list "Crankcase clamping dowel bolt, nut set for > $47.50. > > Jack Phillips > > NX899JP > > Smith Mountain Lake, Virginia > > ------------------------------------------------------------------------ > > *From:*owner-pietenpol-list-server(at)matronics.com > [mailto:owner-pietenpol-list-server(at)matronics.com] *On Behalf Of > *Michael Perez > *Sent:* Wednesday, April 25, 2012 9:44 AM > *To:* pietenpol-list(at)matronics.com > *Subject:* Pietenpol-List: Engine "Screw, Dowel" > > There are, I believe, three of these "screw, dowel" bolts to hold the > engine case halves together. I could not find these at ACS. If anyone > has an idea who might carry them or what nomenclature I should use to > search with, I would appreciate it. > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > * * > * * > ** > ** > ** > *http://www.matronics.com/Navigator?Pietenpol-List* > ** > ** > *http://forums.matronics.com* > ** > ** > *http://www.matronics.com/contribution* > * * > * > > > * -- Ben Charvet, PharmD Staff Pharmacist Parrish Medical center ________________________________________________________________________________
Date: Apr 25, 2012
But, which ones do you need? [image: Inline image 1] [image: Inline image 2] On Wed, Apr 25, 2012 at 8:44 AM, Michael Perez wrote: > There are, I believe, three of these "screw, dowel" bolts to hold the > engine case halves together. I could not find these at ACS. If anyone has > an idea who might carry them or what nomenclature I should use to search > with, I would appreciate it. > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > * > > * > > ________________________________________________________________________________
Date: Apr 25, 2012
Thanks Ben, I have all the old bolts, some are not worth keeping.- I figu re going through the engine like I am, I should buy new bolts. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 25, 2012
In your attached picture, they would be #14A. In mine, they are #22, Screw, Dowel, (hence the subject line)-part number 24252, quantity 3.- Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 25, 2012
Good plan Sent from my iPhone On Apr 25, 2012, at 7:19 PM, Michael Perez wrote: > Thanks Ben, I have all the old bolts, some are not worth keeping. I figur e going through the engine like I am, I should buy new bolts. > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > > ========================== ========= ========================== ========= ========================== ========= ========================== ========= > ________________________________________________________________________________
Date: Apr 26, 2012
Subject: dinner w Markle off topic no building relevence just a
great piet friend visit Had a great dinner out with Jim Markle tonight, so good to see him. My son in law cooked and Markle appeared happy. We sent him on his way back to Harrisburg with left over lasagna from dinner and Gelato from GDB for TV time at the Harrisburg Hampton Inn be for returning to Tulsa. I hope he gets a chance to enjoy it all! It was great seeing him again as we talked about Brodhead in July!, cant wait for that trip. It was great to see him again we, okay I enjoyed the visit we had a good time for the short time available. Safe trip back to the Hotel tonight and Tulsa tomorrow. John ________________________________________________________________________________
Subject: How much Aluminum?
Date: Apr 27, 2012
Would one 4 X 8 sheet of .025 2024-T3 be enough to complete the sheet metal requirements of a Pietenpol? -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371903#371903 ________________________________________________________________________________
From: "C N Campbell" <cncampbell(at)windstream.net>
Subject: Re: How much Aluminum?
Date: Apr 27, 2012
I would like to know the same thing! I'm just about to the point of making the aluminum parts and need to know how much to order -- certainly don't want to order too much. Chuck ----- Original Message ----- From: "Kringle" <Mrkringles(at)msn.com> Sent: Friday, April 27, 2012 2:21 PM Subject: Pietenpol-List: How much Aluminum? > > Would one 4 X 8 sheet of .025 2024-T3 be enough to complete the sheet > metal requirements of a Pietenpol? > > -------- > John > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371903#371903 > > > ________________________________________________________________________________
Subject: progress report NX53WE
Date: Apr 27, 2012
Painting completed and starting to reassemble.Here are some pictures. Bob ________________________________________________________________________________
Date: Apr 27, 2012
Really looking nice, Bob. Can't wait to see it. Jack Phillips NX899JP Smith Mountain Lake, Virginia _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Bob edson Sent: Friday, April 27, 2012 3:31 PM Subject: Pietenpol-List: progress report NX53WE Painting completed and starting to reassemble.Here are some pictures. Bob ________________________________________________________________________________
Date: Apr 27, 2012
John,=0A-=0AMore than enough. for cowling and top of fuse.=0A-=0AIf you order one whole sheet have it shipped rolled.=0AIt saves a lot in shipping that way.=0A-=0AHans=0A-=0ANX15KV=0AWaller- =0A=0A__________________ ______________=0A From: Kringle <Mrkringles(at)msn.com>=0ATo: pietenpol-list@m atronics.com =0ASent: Friday, April 27, 2012 1:21 PM=0ASubject: Pietenpol-L le" =0A=0AWould one 4 X 8 sheet of .025 2024-T3 be enou gh to complete the sheet metal requirements of a Pietenpol?=0A=0A-------- =0AJohn=0A=0A=0A=0A=0ARead this topic online here:=0A=0Ahttp://forums.matro ============= ________________________________________________________________________________
Date: Apr 27, 2012
Im also ordering some plywood so the sheet of aluminum should add minimal if any cost to the shipment. Thanks -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371924#371924 ________________________________________________________________________________
Date: Apr 27, 2012
DQogDQoNCkZyb206IEphY2sgUGhpbGxpcHMgW21haWx0bzpwaWV0Zmx5ckBiZWxsc291dGgubmV0 XSANClNlbnQ6IFR1ZXNkYXksIEFwcmlsIDI0LCAyMDEyIDA1OjQ0IFBNDQpUbzogcGlldGVucG9s LWxpc3RAbWF0cm9uaWNzLmNvbSA8cGlldGVucG9sLWxpc3RAbWF0cm9uaWNzLmNvbT4gDQpTdWJq ZWN0OiBSRTogUGlldGVucG9sLUxpc3Q6IFdpbmcgVGlwIFRyYW5zaXRpb24gDQogDQoNCg0KIA0K DQogDQoNCllvdSBjYW4gc2VlIHRoZSBjb3JuZXIgb2YgdGhlIHdpbmd0aXAgaW4gdGhlIGZvcmVn cm91ZCBvZiB0aGlzIHBpY3R1cmUgKGlnbm9yZSBtZSBzaXR0aW5nIGluIG15IGZ1c2VsYWdlIG1h a2luZyBhaXJwbGFuZSBub2lzZXMpLiAgSSBtaXhlZCBtaWNyb2JhbGxvb25zIHdpdGggZXBveHkg dG8gbWFrZSBhIHRoaWNrIHNsdXJyeSBhbmQgZ2xvYmJlZCBpdCBpbiBwbGFjZSwgdGhlbiBzYW5k ZWQgaXQgc21vb3RoLg0KDQogDQoNCkphY2sgUGhpbGxpcHMNCg0KTlg4OTlKUA0KDQpTbWl0aCBN b3VudGFpbiBMYWtlLCBWaXJnaW5pYQ0KDQogDQoNCi0tLS0tT3JpZ2luYWwgTWVzc2FnZS0tLS0t DQpGcm9tOiBvd25lci1waWV0ZW5wb2wtbGlzdC1zZXJ2ZXJAbWF0cm9uaWNzLmNvbSBbbWFpbHRv Om93bmVyLXBpZXRlbnBvbC1saXN0LXNlcnZlckBtYXRyb25pY3MuY29tXSBPbiBCZWhhbGYgT2Yg S3JpbmdsZQ0KU2VudDogVHVlc2RheSwgQXByaWwgMjQsIDIwMTIgNzozNCBQTQ0KVG86IHBpZXRl bnBvbC1saXN0QG1hdHJvbmljcy5jb20NClN1YmplY3Q6IFBpZXRlbnBvbC1MaXN0OiBXaW5nIFRp cCBUcmFuc2l0aW9uDQoNCiANCg0KLS0+IFBpZXRlbnBvbC1MaXN0IG1lc3NhZ2UgcG9zdGVkIGJ5 OiAiS3JpbmdsZSIgPE1ya3JpbmdsZXNAbXNuLmNvbT4NCg0KIA0KDQpJIHdvdWxkIGxpa2UgdG8g c2VlIHBpY3R1cmVzIG9mIGhvdyBzb21lIG9mIHlvdSB0cmFuc2l0aW9uZWQgdGhlIHdpbmcgdGlw IHRvIHRoZSBsZWFkaW5nIGFuZCB0cmFpbGluZyBlZGdlLg0KDQogDQoNClRoYW5rcw0KDQpKb2hu DQoNCiANCg0KLS0tLS0tLS0NCg0KSm9obg0KDQogDQoNCiANCg0KIA0KDQogDQoNClJlYWQgdGhp cyB0b3BpYyBvbmxpbmUgaGVyZToNCg0KIA0KDQpodHRwOi8vZm9ydW1zLm1hdHJvbmljcy5jb20v dmlld3RvcGljLnBocD9wPTM3MTczNyMzNzE3MzcNCg0KIA0KDQogDQoNCiANCg0KIA0KDQogDQoN CiANCg0KIA0KDQogDQoNCiANCg0K ________________________________________________________________________________
Date: Apr 28, 2012
Chuck and Michael, Just out of curiosity... why did you decide not to run the ailerons all the way to the tip? Just curious, that's all... Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371983#371983 ________________________________________________________________________________
Date: Apr 28, 2012
Don, This has always been one of my favorite pictures. I believe it is you and Frank Pavliga? Could you send me a high res copy so I can get it printed and hung in my shop? Thanks, John email mrkringles(at)msn.com -------- John Read this topic online here: http://forums.matronics.com/viewtopic.php?p=371986#371986 Attachments: http://forums.matronics.com//files/img_0288_151.jpg ________________________________________________________________________________
Date: Apr 28, 2012
Subject: Re: dinner w Markle off topic no building relevence just
a great piet friend visit
Sm9obiwgaXQgd2FzIG15IHBsZWFzdXJlIQoKSmltIGluIFByeW9yLi4uLgpOWDE5MjlKIMKgOi0p CgpEbyBub3QgYXJjaGl2ZQoKU2VudCB2aWEgc21hcnRwaG9uZS4KCi0tLS0tLS0tIE9yaWdpbmFs IG1lc3NhZ2UgLS0tLS0tLS0KU3ViamVjdDogUGlldGVucG9sLUxpc3Q6IGRpbm5lciB3IE1hcmts ZSBvZmYgdG9waWMgbm8gYnVpbGRpbmcgcmVsZXZlbmNlIGp1c3QgYSBncmVhdCAgcGlldCBmcmll bmQgdmlzaXQgCkZyb206IEFNc2FmZXR5Q0Bhb2wuY29tIApUbzogcGlldGVucG9sLWxpc3RAbWF0 cm9uaWNzLmNvbSAKQ0M6ICAKCkhhZCBhIGdyZWF0IGRpbm5lciBvdXQgd2l0aCBKaW0gTWFya2xl IHRvbmlnaHQsIHNvIGdvb2QgdG8gc2VlIGhpbS4gTXkgc29uIGluIGxhd8KgIGNvb2tlZCBhbmQg TWFya2xlIGFwcGVhcmVkIGhhcHB5LiBXZSBzZW50IGhpbSBvbiBoaXMgd2F5IGJhY2sgdG8gSGFy cmlzYnVyZyB3aXRoIGxlZnQgb3ZlciBsYXNhZ25hIGZyb20gZGlubmVyIGFuZCBHZWxhdG8gZnJv bSBHREIgZm9yIFRWIHRpbWUgYXQgdGhlIEhhcnJpc2J1cmcgSGFtcHRvbiBJbm4gYmUgZm9yIHJl dHVybmluZyB0byBUdWxzYS4KwqBJIGhvcGUgaGUgZ2V0cyBhIGNoYW5jZSB0byBlbmpveSBpdCBh bGwhIEl0IHdhcyBncmVhdCBzZWVpbmcgaGltIGFnYWluIGFzIHdlIHRhbGtlZCBhYm91dCBCcm9k aGVhZCBpbiBKdWx5ISwgY2FudCB3YWl0IGZvciB0aGF0IHRyaXAuCsKgCkl0IHdhcyBncmVhdCB0 byBzZWUgaGltIGFnYWluIHdlLCBva2F5IEkgZW5qb3llZCB0aGUgdmlzaXQgd2UgaGFkIGEgZ29v ZCB0aW1lIGZvciB0aGUgc2hvcnQgdGltZSBhdmFpbGFibGUuCsKgClNhZmUgdHJpcCBiYWNrIHRv IHRoZSBIb3RlbMKgdG9uaWdodCBhbmQgVHVsc2EgdG9tb3Jyb3cuCsKgCkpvaG7CoAogCgpfLT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PQpfLT0gICAgICAgICAgLSBUaGUgUGlldGVucG9sLUxpc3QgRW1haWwgRm9ydW0gLQpfLT0gVXNl IHRoZSBNYXRyb25pY3MgTGlzdCBGZWF0dXJlcyBOYXZpZ2F0b3IgdG8gYnJvd3NlCl8tPSB0aGUg bWFueSBMaXN0IHV0aWxpdGllcyBzdWNoIGFzIExpc3QgVW4vU3Vic2NyaXB0aW9uLApfLT0gQXJj aGl2ZSBTZWFyY2ggJiBEb3dubG9hZCwgNy1EYXkgQnJvd3NlLCBDaGF0LCBGQVEsCl8tPSBQaG90 b3NoYXJlLCBhbmQgbXVjaCBtdWNoIG1vcmU6Cl8tPQpfLT0gICAtLT4gaHR0cDovL3d3dy5tYXRy b25pY3MuY29tL05hdmlnYXRvcj9QaWV0ZW5wb2wtTGlzdApfLT0KXy09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAg ICAgICAgLSBNQVRST05JQ1MgV0VCIEZPUlVNUyAtCl8tPSBTYW1lIGdyZWF0IGNvbnRlbnQgYWxz byBhdmFpbGFibGUgdmlhIHRoZSBXZWIgRm9ydW1zIQpfLT0KXy09ICAgLS0+IGh0dHA6Ly9mb3J1 bXMubWF0cm9uaWNzLmNvbQpfLT0KXy09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 PT09PT09PT09PT09PT09PT09PT09PT09PT0KXy09ICAgICAgICAgICAgIC0gTGlzdCBDb250cmli dXRpb24gV2ViIFNpdGUgLQpfLT0gIFRoYW5rIHlvdSBmb3IgeW91ciBnZW5lcm91cyBzdXBwb3J0 IQpfLT0gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAtTWF0dCBEcmFsbGUsIExpc3QgQWRt aW4uCl8tPSAgIC0tPiBodHRwOi8vd3d3Lm1hdHJvbmljcy5jb20vY29udHJpYnV0aW9uCl8tPT09 PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09PT09 Cgo ________________________________________________________________________________
Date: Apr 28, 2012
John, Absolutely! When I get home later I will send some to you. I have others too. From different angles. It was during the Brodhead Piet Fly-in in '07. The photographer, if I remember correctly worked for USA Today and flew with Andrew King in his T-craft. I think he was on his way to Oshkosh and asked if he could get some aerial shots. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372018#372018 ________________________________________________________________________________
Date: Apr 28, 2012
Don, I think it was more for asthetics than anything else. I just have never flown an airplane (and I have flown a bunch of them) where the aileron went all the way to the wing tip. If I lose any aileron effectiveness by losing that 5-inches of aileron, then I'll just have to be careful. Do what you think best. Chuck ----- Original Message ----- From: "Don Emch" <EmchAir(at)aol.com> Sent: Saturday, April 28, 2012 9:19 AM Subject: Pietenpol-List: Re: Wing Tip Transition > > Chuck and Michael, > > Just out of curiosity... why did you decide not to run the ailerons all > the way to the tip? Just curious, that's all... > > Don Emch > NX899DE > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=371983#371983 > > > ________________________________________________________________________________
Subject: Re: progress report NX53WE
Date: Apr 28, 2012
What is the diameter of your wheels, and tires if you don't mind me asking...? Looks wonderful assembled....!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372030#372030 ________________________________________________________________________________
Subject: Re: piet pics
Date: Apr 28, 2012
thanks cliff; great work and very helpful pics. paul Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372033#372033 ________________________________________________________________________________
Date: Apr 28, 2012
You're welcome. Clif > > > thanks cliff; great work and very helpful pics. paul ________________________________________________________________________________
Date: Apr 29, 2012
Subject: fabric shrink temperature
I've just started covering my Piet and I need a consensus of opinion. I have heard that on a light wooden structure that one needs to be careful to not over shrink the fabric. What has everyone done? Do I stop at 250 degrees? Go to 300 or even full shrink at 350. At this stage I sure don't want to warp or break anything. As a side note, never having covered before I was sweating the process a little. As everyone has said, its easy, fun and even magical. Rick Schreiber Valparaiso IN ________________________________________________________________________________
Date: Apr 29, 2012
I went to 350 on mine. No problem as long as the structure is right. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Schreiber Sent: Sunday, April 29, 2012 10:30 AM Subject: Pietenpol-List: fabric shrink temperature I've just started covering my Piet and I need a consensus of opinion. I have heard that on a light wooden structure that one needs to be careful to not over shrink the fabric. What has everyone done? Do I stop at 250 degrees? Go to 300 or even full shrink at 350. At this stage I sure don't want to warp or break anything. As a side note, never having covered before I was sweating the process a little. As everyone has said, its easy, fun and even magical. Rick Schreiber Valparaiso IN ________________________________________________________________________________
Date: Apr 29, 2012
Rick, Glad to hear that you are at that stage...my favorite! I used 1.7 oz fabric and stopped at 300....call me chicken.... Gary Boothe NX308MB -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Schreiber Sent: Sunday, April 29, 2012 7:30 AM Subject: Pietenpol-List: fabric shrink temperature --> I've just started covering my Piet and I need a consensus of opinion. I have heard that on a light wooden structure that one needs to be careful to not over shrink the fabric. What has everyone done? Do I stop at 250 degrees? Go to 300 or even full shrink at 350. At this stage I sure don't want to warp or break anything. As a side note, never having covered before I was sweating the process a little. As everyone has said, its easy, fun and even magical. Rick Schreiber Valparaiso IN ________________________________________________________________________________
Date: Apr 29, 2012
>From the limited fabric work I have done, (aileron, both elevators, vertica l stab. and rudder) I went to the full temp.- Everything seemed more the strong enough and I never once heard anything creek, snap or pop! Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: Apr 29, 2012
Don,- I had the wing tip shape in mind soon after I started building the wings. As the process started coming together, things fell into place as yo u see them in my pictures.- Like Chuck had mentioned, I personally like t he looks of having the elevators stop short of the tip. - Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: Re: fabric shrink temperature
Date: Apr 29, 2012
Rick - I went to whatever Polyfiber said to go to. 350? I had one problem with the fabric on the top of the wing deforming the structure around the fuel tank hole. Hurt my feelings a little bit but I reinforced the woodwork and drove on. Jack's right: if the structure is sound you won't have a problem. I thought the structure around the wing tank was sufficient but it obviously wasn't. The rest of the shrinking process was trouble-free, and was actually my absolute favorite part of the build. The piet's really stout and there should be no problem with tearing up a plans-built airplane when shrinking the fabric to the manufacturer's standard. -------- Kevin "Axel" Purtee NX899KP Austin/San Marcos, TX Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372080#372080 ________________________________________________________________________________
Date: Apr 29, 2012
Michael and Chuck, Personal preference is as good a reason as any I guess. I think the ailerons extending all the way to the end was more popular in the 20's and early 30's. Later on as they developed more effective ailerons I think they started to end them before the end of the wing. Some of the early Travel Airs, Wacos, etc. had "elephant ears" or ailerons that actually extended past the wingtip. So I guess it was the thing to do back then. Don Emch NX899DE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372092#372092 ________________________________________________________________________________
Date: Apr 29, 2012
Hey fellow listers. I had a great visit with Jerry Dotson and hie wife Bobbie. You should listen to him when he talks about how do things. His workmanship is superb== Metal wise and woodworking. Cabanes and struts are outstanding.. He has a nice 1300 ft strip way out in the boonies. It is kind of hard to get to so I spent a half a day going Boonie Hopping. Gardiner ________________________________________________________________________________
Date: Apr 29, 2012
Rick, I went with 350, BUT make sure you reinforce the end ribs. In my case (one- piece wing) the rib adjacent to the tank (center) was pulled out of positio n a little. Not good. Dan Helsper Puryear, TN -----Original Message----- From: Rick Schreiber <lmforge(at)earthlink.net> Sent: Sun, Apr 29, 2012 9:31 am Subject: Pietenpol-List: fabric shrink temperature > I've just started covering my Piet and I need a consensus of opinion. I ave heard that on a light wooden structure that one needs to be careful o not over shrink the fabric. What has everyone done? Do I stop at 250 egrees? Go to 300 or even full shrink at 350. At this stage I sure on't want to warp or break anything. As a side note, never having covered before I was sweating the process a ittle. As everyone has said, its easy, fun and even magical. Rick Schreiber alparaiso IN -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: Apr 29, 2012
Bellanca tips. :-) Long and distinquished history. Clif To most people the sky is the limit. To a pilot, the sky is home. Don, I had the wing tip shape in mind soon after I started building the wings. Michael Perez ________________________________________________________________________________
Date: Apr 30, 2012
Congrats to Bellanca, I don't recall them building Pietenpols.. Ryan On Sun, Apr 29, 2012 at 10:15 PM, Clif Dawson wrote: > ** > Bellanca tips. :-) > Long and distinquished history. > > Clif > > To most people the sky is the limit. > To a pilot, the sky is home. > > > Don, I had the wing tip shape in mind soon after I started building > the wings. Michael Perez > > * > * > > * > > * > > ________________________________________________________________________________
Date: Apr 30, 2012
Pietenpols with wings to the plans.....long and distinguished history On Sun, Apr 29, 2012 at 10:15 PM, Clif Dawson wrote: > ** > Bellanca tips. :-) > Long and distinquished history. > > Clif > > To most people the sky is the limit. > To a pilot, the sky is home. > > > Don, I had the wing tip shape in mind soon after I started building > the wings. Michael Perez > > * > * > > * > > * > > ________________________________________________________________________________
Date: Apr 30, 2012
Subject: Right angle tach drive
It looks like I'm having to replace the right angle drive for the tach on my Piet, after only about 75 hours of operation. The first drive never worked well - the needle would jump and the male square drive end from the tach cable seems to have been loose enough in the female fitting on the drive that it wallowed out the female end quite a bit. The replacement failed on a flight back from Suffolk, Va. yesterday. The female recepticle for the cable was completely rounded out inside, and there is a lot of resistance in the drive gears. I greased both these drives with white lithium grease before I installed them. I've also lubricated the cable with a NAPA speedometer cabe lube which is a light machine oil with graphite in it. Dirty stuff but good cable lube, I'm told. Both of these right angle drives were from Aircraft Spruce. Wicks has a different model drive, a bit more expensive, but if I keep replacing these ACS drives, I'd rather pay once and be done for a while. Anyone have experience like this, and anyone using the Wicks angle tach drive? Any thoughts on lubricating the angle drive itself. I wondered if the grease is getting too firm at low temperatures. It was in the 50s in flight yesterday and it failed when I started it up after a fuel stop. I'd been flying for about 1.7 hours prior to the fuel stop. I'm wondering if I should try the oil and graphite lube in the angle drive. I notice that the Wicks angle drive has a zerk fitting to allow it to be greased. Any ideas what type grease is recommended? Matt Paxton NX629ML ________________________________________________________________________________
Date: Apr 30, 2012
Subject: another covering question
I'm now starting the cover of my elevators. I have the lower cover on one side. In order to attach the cover, I made a small slit in the fabric just long enough to allow the control horn to protrude. I did a preliminary shrink at 250 degrees, trying to not over shrink near the horn. I still got some gaping around the horn plus the fabric still has some looseness in this area. My question is how do I finish this area off to eliminate the gaps? I am using the Stewarts system. In their video they only cover minor fitting protrusions under the fabric, such as lift strut attachments. In the video, they just covered over the fitting and then slit the fabric after the first shrink. Next they cut a patch that was glued over the fitting. After the patch is glued in place, the area of the patch is not shrunk again. Attached is a photo of what I have now. Rick Schreiber Valparaiso In ________________________________________________________________________________
Date: Apr 30, 2012
Subject: Re: another covering question
I had the same issue. (I'm shrinking to 300deg and using the lightweight fabric.) You can see from the attached pic that the gap (below the patch) had opened up after shrinking. Then I made that "patch" and just cut one slit for the patch to fit over the horn. that allowed me to leave a bit of material up onto the side of the horn to help seal it up. (And yes, I cleaned it up a bit so it doesn't still look so messy!) Hope this helps.... Jim in Pryor NX1929J -----Original Message----- >From: Rick Schreiber <lmforge(at)earthlink.net> >Sent: Apr 30, 2012 1:05 PM >To: pietenpol-list(at)matronics.com >Subject: Pietenpol-List: another covering question > >I'm now starting the cover of my elevators. I have the lower cover on >one side. In order to attach the cover, I made a small slit in the >fabric just long enough to allow the control horn to protrude. I did a >preliminary shrink at 250 degrees, trying to not over shrink near the >horn. I still got some gaping around the horn plus the fabric still has >some looseness in this area. My question is how do I finish this area >off to eliminate the gaps? > >I am using the Stewarts system. In their video they only cover minor >fitting protrusions under the fabric, such as lift strut attachments. In >the video, they just covered over the fitting and then slit the fabric >after the first shrink. Next they cut a patch that was glued over the >fitting. After the patch is glued in place, the area of the patch is not >shrunk again. > >Attached is a photo of what I have now. > >Rick Schreiber >Valparaiso In ________________________________________________________________________________
Date: Apr 30, 2012
Rick, Pre-Shrink the patch material, then cut the patch to the exact cross section of the control horn at the level of the fabric. Slip it over the horn and glue it in place. It might still gap a little, but should be a pretty good fit. See photo below: Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Schreiber Sent: Monday, April 30, 2012 2:06 PM Subject: Pietenpol-List: another covering question I'm now starting the cover of my elevators. I have the lower cover on one side. In order to attach the cover, I made a small slit in the fabric just long enough to allow the control horn to protrude. I did a preliminary shrink at 250 degrees, trying to not over shrink near the horn. I still got some gaping around the horn plus the fabric still has some looseness in this area. My question is how do I finish this area off to eliminate the gaps? I am using the Stewarts system. In their video they only cover minor fitting protrusions under the fabric, such as lift strut attachments. In the video, they just covered over the fitting and then slit the fabric after the first shrink. Next they cut a patch that was glued over the fitting. After the patch is glued in place, the area of the patch is not shrunk again. Attached is a photo of what I have now. Rick Schreiber Valparaiso In ________________________________________________________________________________
Date: Apr 30, 2012
In your picture, where the fabric is still loose near the fitting, make sure you heat that like the rest of the fabric to shrink it tight prior to putting on the patch. After my patch was on, I heated it some to make sure the edges laid nice and the patch had a small amount of shrink/tension on it. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: wheels
Date: Apr 30, 2012
Jake Schultz In answer to your question the wheels are 21 inch stainless steel with stainless spokes. My son made the hubs 6 inches wide stainless steel with stainless rotors. The overall diameter of the tires is 27 inches.Things are starting to come together and look like a pietenpol. It's beem about 20 months since we started. Bob ________________________________________________________________________________
Date: Apr 30, 2012
On 4/30/2012 2:21 PM, Michael Perez wrote: > In your picture, where the fabric is still loose near the fitting, > make sure you heat that like the rest of the fabric to shrink it tight > prior to putting on the patch. After my patch was on, I heated it some > to make sure the edges laid nice and the patch had a small amount of > shrink/tension on it. > > Michael Perez > Pietenpol HINT Videos > Karetaker Aero > www.karetakeraero.com > > * > * Mike: I did shrink around the fitting. Part of the problem is my control horns are made from flat sheet and so have little thickness when compared to the formed control horns. When I shrunk the cover near the horn it gapped a fair amount. I was afraid to shrink it till the surface was perfectly level. Rick Schreiber Valparaiso In ________________________________________________________________________________
Subject: Re: Right angle tach drive
Date: Apr 30, 2012
IMHO, the best all around grease for an item like the right angle drive is moly. You can wash all the old lube out with solvent and re pack with moly from any autozone, etc. If you're concerned about extremely lw temps, you can mix the moly grease with some 10 wt oil to make a really light wt grease; just make sure you mix very thoroughly. I've done this on speedo heads and small mechanisms for years and never had one seize as yours has. Just make sure you're wearing old clothes, as moly cannot be removed from anything. -------- Tom Kreiner Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372175#372175 ________________________________________________________________________________
Date: Apr 30, 2012
I am in the process of covering my wings now and I glued a small piece of 1/16 in ply around the horn. Now the fabric can be glued down. Cheers, Gardiner Mason ----- Original Message ---- From: Rick Schreiber <lmforge(at)earthlink.net> Sent: Mon, April 30, 2012 2:05:57 PM Subject: Pietenpol-List: another covering question I'm now starting the cover of my elevators. I have the lower cover on one side. In order to attach the cover, I made a small slit in the fabric just long enough to allow the control horn to protrude. I did a preliminary shrink at 250 degrees, trying to not over shrink near the horn. I still got some gaping around the horn plus the fabric still has some looseness in this area. My question is how do I finish this area off to eliminate the gaps? I am using the Stewarts system. In their video they only cover minor fitting protrusions under the fabric, such as lift strut attachments. In the video, they just covered over the fitting and then slit the fabric after the first shrink. Next they cut a patch that was glued over the fitting. After the patch is glued in place, the area of the patch is not shrunk again. Attached is a photo of what I have now. Rick Schreiber Valparaiso In ________________________________________________________________________________
Date: Apr 30, 2012
Jim Markle and Jack Phillips thanks for the response, but I was wondering did you shrink the fabric until it was flat as Mike Perez has suggested. I was just afraid if I did it would gap a hideous amount. Rick Schreiber ________________________________________________________________________________
Date: Apr 30, 2012
You can shrink the fabric on the wing as much as you want, and let it gap. Then glue down the pre-shrunk patch and don't shrink it any further. Jack Phillips NX899JP Smith Mountain Lake, Virginia -----Original Message----- From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick Schreiber Sent: Monday, April 30, 2012 7:04 PM Subject: Re: Pietenpol-List: another covering question Jim Markle and Jack Phillips thanks for the response, but I was wondering did you shrink the fabric until it was flat as Mike Perez has suggested. I was just afraid if I did it would gap a hideous amount. Rick Schreiber ________________________________________________________________________________
Date: Apr 30, 2012
On 4/30/2012 6:25 PM, Jack Phillips wrote: > --> Pietenpol-List message posted by: "Jack Phillips" > > You can shrink the fabric on the wing as much as you want, and let it gap. > Then glue down the pre-shrunk patch and don't shrink it any further. > > Jack Phillips > NX899JP > Smith Mountain Lake, Virginia > > That's what I will do, thanks! Rick Schreiber Valparaiso, In ________________________________________________________________________________
Date: Apr 30, 2012
What Jack said... :-) Jim in Pryor NX1929J -----Original Message----- >From: Jack Phillips <pietflyr(at)bellsouth.net> >Sent: Apr 30, 2012 6:25 PM >To: pietenpol-list(at)matronics.com >Subject: RE: Pietenpol-List: another covering question > > >You can shrink the fabric on the wing as much as you want, and let it gap. >Then glue down the pre-shrunk patch and don't shrink it any further. > >Jack Phillips >NX899JP >Smith Mountain Lake, Virginia > >-----Original Message----- >From: owner-pietenpol-list-server(at)matronics.com >[mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Rick >Schreiber >Sent: Monday, April 30, 2012 7:04 PM >To: pietenpol-list(at)matronics.com >Subject: Re: Pietenpol-List: another covering question > > >Jim Markle and Jack Phillips thanks for the response, but I was >wondering did you shrink the fabric until it was flat as Mike Perez has >suggested. I was just afraid if I did it would gap a hideous amount. > >Rick Schreiber > > ________________________________________________________________________________
Subject: Re: wheels
Date: Apr 30, 2012
Thanks...... Your bird looks great............ (I am leaning towards a 24" tire based on the 1931 Piet that Bernard built. Your Piet wheels look a bit bigger than that and I wanted to check.... ) I love the way ANY big/spoked tires look on a Piet....!!! Great job..... -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372185#372185 ________________________________________________________________________________
Subject: LATEX PRIMER?
Date: May 01, 2012
For those who have applied latex paint over the Stewart System.....did you prime after taping? If so, latex primer? Having done a couple Ceconite and dope jobs, I am sure intrigued with this method and would like to try it. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372209#372209 ________________________________________________________________________________
Subject: Re: LATEX PRIMER?
Date: May 01, 2012
Primed with latex, but not flight tested. Gary from Cool ------Original Message------ From: 899PM Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: LATEX PRIMER? Sent: May 1, 2012 7:59 AM For those who have applied latex paint over the Stewart System.....did you prime after taping? If so, latex primer? Having done a couple Ceconite and dope jobs, I am sure intrigued with this method and would like to try it. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372209#372209 Sent on the Sprint Now Network from my BlackBerry ________________________________________________________________________________
Date: May 01, 2012
I did no priming at all. I went straight to the paint. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Subject: 3M Fastbond
Date: May 01, 2012
About a year ago there was discussion regarding using Fastbond instead of Ecobond. I believe Jon Coxwell mentioned he was going to do some comparisons. Was wondering if the Fastbond could be heat activated, anybody try it yet? Thanks, Jack Textor Sent from my iPad ________________________________________________________________________________
Date: May 01, 2012
Dad just used white latex paint for his base coat, it sticks just fine.- He used warm water and dawn dish soap to wash the fabric before painting. - Shad --- On Tue, 5/1/12, gboothe5(at)comcast.net wrote: From: gboothe5(at)comcast.net <gboothe5(at)comcast.net> Subject: Re: Pietenpol-List: LATEX PRIMER? Date: Tuesday, May 1, 2012, 11:22 AM Primed with latex, but not flight tested. Gary from Cool ------Original Message------ From: 899PM Sender: owner-pietenpol-list-server(at)matronics.com ReplyTo: pietenpol-list(at)matronics.com Subject: Pietenpol-List: LATEX PRIMER? Sent: May 1, 2012 7:59 AM For those who have applied latex paint over the Stewart System.....did you prime after taping? If so, latex primer? Having done a couple Ceconite and dope jobs, I am sure intrigued with this method and would like to try it. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372209#372209 Sent on the Sprint=AE Now Network from my BlackBerry=AE le, List Admin. ________________________________________________________________________________
Date: May 02, 2012
I used Gliddon grey latex primer, thinned a little with water, applied with a foam brush, and sanded with 320 grit dry between coats (3 coats). Been flying for a year and no problems. Malcolm Morrison http://home.comcast.net/~mmorrison123/Airplanes.htm ----- Original Message ----- From: "899PM" <rockriverrifle(at)hotmail.com> Sent: Tuesday, May 1, 2012 10:59:36 AM Subject: Pietenpol-List: LATEX PRIMER? For those who have applied latex paint over the Stewart System.....did you prime after taping? If so, latex primer? Having done a couple Ceconite and dope jobs, I am sure intrigued with this method and would like to try it. -------- PAPA MIKE Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372209#372209 ________________________________________________________________________________
Subject: French Valley Visit EAA 1279
From: "AircamperN11MS" <Scott.liefeld(at)lacity.org>
Date: May 02, 2012
Good morning Lister's, I had the good fortune of being invited to the French Valley EAA meeting last Sunday 4-29-12. It was a show and tell meeting for the Piets. It was about a 1.5 hour flight each way for me with good weather both ways. Their piet looks outstanding. They are currently waiting for an FAA inspection while tying up some loose ends on the plane. I am very impressed. If you remember, this is the plane they brought to Brodhead a few years ago. Attached are three pics. I apologize ahead of time if the sizing is incorrect. The Blue and Silver plane is theirs. I'll try and keep the list updated as progress moves on. -------- Scott Liefeld Flying N11MS since March 1972 Steel Tube C-85-12 Wire Wheels Brodhead in 1996 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372264#372264 Attachments: http://forums.matronics.com//files/fvpietimg_0422_197.jpg http://forums.matronics.com//files/fvpietimg_0421_157.jpg http://forums.matronics.com//files/fvpietimg_0420_113.jpg ________________________________________________________________________________
Date: May 02, 2012
Malcolm, Your Piet is done and flying? How did the wing pivot mechanism work out? Dan On 05/01/2012 07:49 PM, gliderx5(at)comcast.net wrote: > I used Gliddon grey latex primer, thinned a little with water, applied > with a foam brush, and sanded with 320 grit dry between coats (3 coats). > Been flying for a year and no problems. > > Malcolm Morrison > http://home.comcast.net/~mmorrison123/Airplanes.htm ________________________________________________________________________________
Subject: aluminum struts
Date: May 02, 2012
Hello I was wondering about using streamlined aluminum for the wing struts on my pietenpol, any comments, pros or cons. Thanks Larry V Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372312#372312 ________________________________________________________________________________
Subject: Re: aluminum struts
Date: May 03, 2012
Larry, Many builders have successfully used aluminum struts on their Pietenpols. There's lots of discussion and info in the archives. The aluminum extrusions are definitely less expensive than new 4130 streamline tubing, but different attachment details need to be used, since welding aluminum can greatly reduce it's strength. Bill C. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372326#372326 ________________________________________________________________________________
Date: May 03, 2012
I am using aluminum on mine. I believe there are a few flying Pietenpols th at use them as well.- The aluminum struts will save you some weight. Here is where I bought them: http://carlsonaircraft.com/struts.html Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
From: Gerry Holland <gholland@content-stream.co.uk>
Date: May 03, 2012
Michael Hi. Regarding Aluminium against 4130 profile and strength. Is their any rule of thumb about comparative strengths. I would like to change my round 1/2" 4130 Jury Struts for streamlined and wondered whether aluminium would be suitable. Regards Gerry ________________________________________________________________________________
Date: May 03, 2012
From: "bradandlinda tds.net" <bradandlinda(at)tds.net>
The pre war Aeronca Chiefs used alum struts, but they were wider than J-3 struts. On Thu, May 3, 2012 at 7:38 AM, Gerry Holland <gholland@content-stream.co.uk > wrote: > gholland@content-stream.co.uk> > > Michael Hi. > Regarding Aluminium against 4130 profile and strength. > Is their any rule of thumb about comparative strengths. > I would like to change my round 1/2" 4130 Jury Struts for streamlined and > wondered whether aluminium would be suitable. > Regards > Gerry > > ________________________________________________________________________________
Date: May 03, 2012
Gerry, replacing round with streamline is a good idea. I can't comment on c omparative strengths, however I will say that my jury struts will be stream line aluminum.- I don't believe these small struts see much stress, but t hose that know will chime in. Michael Perez =0APietenpol HINT Videos =0AKaretaker Aero =0Awww.karetakeraero.com ________________________________________________________________________________
Date: May 03, 2012
Hi Gerry I have a set of Aluminum struts and jury struts, I picked them up from Carlson Aircraft in East Palastine, Ohio. I also picked up aluminum ends for the struts. I think the total for everything was about $700. It was worth every penny. They are for my new Piet, under construction at this point. Dick N. ----- Original Message ----- From: "Gerry Holland" <gholland@content-stream.co.uk> Sent: Thursday, May 03, 2012 7:38 AM Subject: Re: Pietenpol-List: aluminum struts <gholland@content-stream.co.uk> Michael Hi. Regarding Aluminium against 4130 profile and strength. Is their any rule of thumb about comparative strengths. I would like to change my round 1/2" 4130 Jury Struts for streamlined and wondered whether aluminium would be suitable. Regards Gerry ________________________________________________________________________________
Date: May 03, 2012
Thanks everyone for your replies. Dick I was wondering what size of aluminum struts you would recommend. Larry V Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372377#372377 ________________________________________________________________________________
Date: May 03, 2012
My struts are 2.44" x 1.00". See them at carlsonaircraft.com .The struts are actually pretty cheap $63 each, its the fitting that are pretty expensive. I am going to polish mine and try to make them look like chrome. Dick N ----- Original Message ----- From: "Larry V" <larryvangerven(at)hotmail.com> Sent: Thursday, May 03, 2012 8:11 PM Subject: Pietenpol-List: Re: aluminum struts > > > Thanks everyone for your replies. > Dick I was wondering what size of aluminum struts you would recommend. > Larry V > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=372377#372377 > > > ________________________________________________________________________________
Date: May 04, 2012
Hi Larry, Used 4 of these, with 7075 aluminum inserts purchased from Mcmaster-Carr, u sing two AN4 bolts to hold them in. Dan Helsper Puryear, TN ________________________________________________________________________________
Date: May 04, 2012
Polishing aluminum works great. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: May 04, 2012
Thanks for posting that Michael. I was wondering how they are going to look. I should also point out that these lift struts come in 10" lengths enough to make lift struts and cabanes.. Dick N. ----- Original Message ----- From: Michael Perez To: pietenpol-list(at)matronics.com Sent: Friday, May 04, 2012 8:33 AM Subject: Re: Pietenpol-List: aluminum struts Polishing aluminum works great. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: May 04, 2012
Dan Thanks for the images of the struts and inserts, I am wondering did Mcmaster-Carr have those inserts or did you make those from their aluminum stock? Dick Thanks for the info on the sizes of the struts and price Larry V Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372426#372426 ________________________________________________________________________________
Date: May 05, 2012
Larry, I bought the aluminum stock, McMaster Carr part number 9055K3 (3/4" x 1"). Just shave off the four corners and it will slide in quite nicely. I can't recall how log I cut the inserts now (my airplane is in IL.) Dan Helsper Puryear, TN -----Original Message----- From: Larry V <larryvangerven(at)hotmail.com> Sent: Fri, May 4, 2012 11:08 pm Subject: Pietenpol-List: Re: aluminum struts > Dan hanks for the images of the struts and inserts, am wondering did Mcmaster-Carr have those inserts or did you make those fr om heir aluminum stock? Dick hanks for the info on the sizes of the struts and price arry V ead this topic online here: http://forums.matronics.com/viewtopic.php?p=372426#372426 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: May 05, 2012
Dan, Did you use the same fittings on both the upper and lower ends....? Thanks for all the info everyone. it is the way I am planning to go with mine.... Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372457#372457 ________________________________________________________________________________
Date: May 05, 2012
Jake, Yes, I used the same 7075 insert in both ends. In the bottom you can see it was drilled and tapped to fit the J-3 forks I bought, then locked in place with the jam nut. In the top (I have a photo but can't find it at the mome nt) I rounded the end of the insert and drilled a hole for the (5/16"?) bol t that holds it to the wing spar fitting. I'll keep looking for it :O) Dan Helsper Puryear, TN -----Original Message----- From: aerocarjake <flight.jake(at)gmail.com> Sent: Sat, May 5, 2012 10:46 am Subject: Pietenpol-List: Re: aluminum struts Dan, Did you use the same fittings on both the upper and lower ends....? Thanks for all the info everyone. it is the way I am planning to go with ine.... Jake -------- ake Schultz - curator, ewport Way Air Museum (OK, it's just my home) ead this topic online here: http://forums.matronics.com/viewtopic.php?p=372457#372457 -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: May 05, 2012
You mean these? http://westcoastpiet.com/images/Dan%20Helsper/images/2-10-09_034.JPG http://westcoastpiet.com/images/Dan%20Helsper/images/2-10-09_034.JPG Chris Sacramento, Ca Westcoastpiet.com _____ From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Saturday, May 05, 2012 11:02 AM Subject: Re: Pietenpol-List: Re: aluminum struts Jake, Yes, I used the same 7075 insert in both ends. In the bottom you can see it was drilled and tapped to fit the J-3 forks I bought, then locked in place with the jam nut. In the top (I have a photo but can't find it at the moment) I rounded the end of the insert and drilled a hole for the (5/16"?) bolt that holds it to the wing spar fitting. I'll keep looking for it :O) Dan Helsper Puryear, TN -----Original Message----- From: aerocarjake <flight.jake(at)gmail.com> Sent: Sat, May 5, 2012 10:46 am Subject: Pietenpol-List: Re: aluminum struts Dan, Did you use the same fittings on both the upper and lower ends....? Thanks for all the info everyone. it is the way I am planning to go with mine.... Jake -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372457#372457 " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List p://forums.matronics.com blank>http://www.matronics.com/contribution ________________________________________________________________________________
Date: May 05, 2012
Chris.... Those would be the ones. Thank you for finding those. Please note: There is a bit of an angle between the strut and the wing spar fitting. This can be easily accounted for as you see. Don't drill the AN4 holes until the wing is mounted and everything is all lined-up. Dan Helsper Puryear, TN -----Original Message----- From: Chris <catdesigns(at)att.net> Sent: Sat, May 5, 2012 3:19 pm Subject: RE: Pietenpol-List: Re: aluminum struts You mean these? http://westcoastpiet.com/images/Dan%20Helsper/images/2-10-09_034.JPG http://westcoastpiet.com/images/Dan%20Helsper/images/2-10-09_034.JPG Chris Sacramento, Ca Westcoastpiet.com From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-lis t-server(at)matronics.com] On Behalf Of helspersew(at)aol.com Sent: Saturday, May 05, 2012 11:02 AM Subject: Re: Pietenpol-List: Re: aluminum struts Jake, Yes, I used the same 7075 insert in both ends. In the bottom you can see it was drilled and tapped to fit the J-3 forks I bought, then locked in place with the jam nut. In the top (I have a photo but can't find it at the mome nt) I rounded the end of the insert and drilled a hole for the (5/16"?) bol t that holds it to the wing spar fitting. I'll keep looking for it :O) Dan Helsper Puryear, TN -----Original Message----- From: aerocarjake <flight.jake(at)gmail.com> Sent: Sat, May 5, 2012 10:46 am Subject: Pietenpol-List: Re: aluminum struts Dan, Did you use the same fittings on both the upper and lower ends....? Thanks for all the info everyone. it is the way I am planning to go with ine.... Jake -------- ake Schultz - curator, ewport Way Air Museum (OK, it's just my home) ead this topic online here: http://forums.matronics.com/viewtopic.php?p=372457#372457 " target=_blank>http://www.matronics.com/Navigator?Pietenpol-List ://forums.matronics.com lank>http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Pietenpol-List">http://www.matro nics.com/Navigator?Pietenpol-List ref="http://forums.matronics.com">http://forums.matronics.com ref="http://www.matronics.com/contribution">http://www.matronics.com/c -= - The Pietenpol-List Email Forum - -= Use the Matronics List Features Navigator to browse -= the many List utilities such as List Un/Subscription, -= Archive Search & Download, 7-Day Browse, Chat, FAQ, -= Photoshare, and much much more: - -= --> http://www.matronics.com/Navigator?Pietenpol-List - -======================== -= - MATRONICS WEB FORUMS - -= Same great content also available via the Web Forums! - -= --> http://forums.matronics.com - -======================== -= - List Contribution Web Site - -= Thank you for your generous support! -= -Matt Dralle, List Admin. -= --> http://www.matronics.com/contribution -======================== ________________________________________________________________________________
Date: May 05, 2012
Awesome, thanks....!! -------- Jake Schultz - curator, Newport Way Air Museum (OK, it's just my home) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=372483#372483 ________________________________________________________________________________
Date: May 06, 2012
It takes some work, but they do look great polished. I polished all of my wing and cabane struts at one time and my arms were quite sore the next day or two. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: May 06, 2012
Dan makes a good point about the angle and holes. I drilled the rear most h ole in the inserts/struts first, (I believe) then once the wings were on an d adjusted, I marked and drilled the other insert/strut hole(s). - There may also be a gap between the strut insert and the wing attach bracke ts as shown in Dan's pictures. I made a spacer to fill in.- Just some FYI . - I wonder if the wing support cable fitting can be inserted between the inse rt and wing attach fitting to help take up the gap? Just some FYI. Michael Perez Pietenpol HINT Videos Karetaker Aero www.karetakeraero.com ________________________________________________________________________________
Date: May 06, 2012
Subject: Re: on beating dead horses...But smaller horses
Videos like this are great! No stones thrown from me! Michael Perez Pietenpol HINT Videos
April 15, 2012 - May 06, 2012
Pietenpol-Archive.digest.vol-le
