RV10-Archive.digest.vol-cm
August 02, 2007 - August 23, 2007
> option is to swap the oil cooler out, but that a $500 cost.
> Thank You
> Ray Doerr
> 40250
> N519RV
> -----Original Message-----
> From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-
> server(at)matronics.com] On Behalf Of Rob Kermanj
> Sent: Thursday, August 02, 2007 4:53 AM
> To: rv10-list(at)matronics.com
> Subject: RV10-List: high oil temp
> Hello everyone. I just flew from Florida to California and had a
> serious oil temp issue. The temperatures are very hot across
> southern part of the country so I am not sure if this is to be
> expected.
> I am seeing 220 climbing through 5000 and need to lower the nose and
> climb only at 300 fpm to keep the temp from climbing higher. This is
> even worse after a fuel stop when the engine gets soaked with heat.
> I used to have to watch my CHT but now it is the oil temp limiting my
> performance.
> Does anyone else have similar issues at this time of the year?
> I have no modifications to the cowl and have Vans FWF stuff.
> Thanks,
> Rob Kermanj
Subject: | Re: high oil temp |
It was a direct replacement-simple install-I bought louvres but did not feel I
needed them after the new oil cooler.I did remove the dams on 1 and two.
Sent: Thu, 2 Aug 2007 8:04 am
Subject: Re: RV10-List: high oil temp
Does this oil cooler fit or did you have to modify things?
Thanks, Rob.
On Aug 2, 2007, at 10:58 AM, pilotdds(at)aol.com wrote:
I had similar problems that disapeared with the oil cooler made by the air-conditioning
folks and marketed by Alex De dominicis.10 degree reduction and much
quicker cooling after climb.Temps have been well over 100 in our valley.
Sent: Thu, 2 Aug 2007 2:52 am
Hello everyone. I just flew from Florida to California and had a serious oil temp
issue. The temperatures are very hot across southern part of the country so
I am not sure if this is to be expected.?
I am seeing 220 climbing through 5000 and need to lower the nose and climb only
at 300 fpm to keep the temp from climbing higher. This is even worse after a
fuel stop when the engine gets soaked with heat.?
I used to have to watch my CHT but now it is the oil temp limiting my performance.?
Does anyone else have similar issues at this time of the year??
I have no modifications to the cowl and have Vans FWF stuff.?
Thanks,?
Rob Kermanj?
Subject: | Re: TT Pitch Servo Install Directions |
I spoke with Zach at TT. They are working on AutoCAD diagrams, but do not have
them ready at present...
The bellcrank hole position is not critical, but should be located 2.25" up and
.5" aft from the center hole.
The TT bracket supplied by Vans in the -10 kit should be discarded. Instead, use
the one supplied with the servo.
Jay
http://forums.matronics.com/viewtopic.php?p=127234#127234
From: | "ddddsp1(at)juno.com" <ddddsp1(at)juno.com> |
I have the louvers on the bottom of the cowl..........they do work. If
you just install the SW cooler and do NOT put in the louvers don't expec
t much of a change. AMF when I talked to the people selling the "better
" oil cooler for $500 they would not promise cooler oil temps without ad
ding the louvers. Airflow over the cooler is the issue in the RV10.....
......NOT the cooler itself.
IMHO Dean 805HL
Get Juno DSL - the easier, safer broadband!
32
ork. If you just install the SW cooler and do NOT put in the louve
rs don't expect much of a change. AMF when I talked to the people
selling the "better" oil cooler for $500 they would not promise cooler o
il temps without adding the louvers. Airflow over the cooler is th
e issue in the RV10...........NOT the cooler itself.
IMHO Dean 805HL
/2-2125045-32">Get Juno DSL - the easier, safer broadband!
font>
