alfolavf(at)online.no Guest
Posted: Sun Feb 19, 2006 11:43 am Post subject: Defroster-system? |
Hi all!
Thanks for the inputs on the new wing tip landing lights! I'll go for the LE landing lights then.
I've another one for you:
In addition to the cabin heat, I also need a way to send warm air to the windshield, in other words a defrost system.
I was thinking that maybe I could mount an "Y" coupling on the hose supplying cabin heat and route warm air from the "Y" intersection to the windshield, if I cut out some long slots in the area just below the windshield. (almost like a car)
How has other builders living in cold areas solved this?
While I'm at it:
I saw that there's some "hatches" for extra fresh air that can be installed in the forward portion of the fuselage which can be used on warm days.
Anyone have any experience with this?
Is the fresh air intakes which comes with the kit inadequate?
Here I'm asking RV-operaters who's flying in weather conditions like Norway: summer temps mostly around 20-25 degrees celcius (approx 65-75 fahrenheit)
Best regards Alf Olav Frog / Norway
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
N67BT(at)aol.com Guest
Posted: Sun Feb 19, 2006 5:05 pm Post subject: Defroster-system? |
| Quote: | I used a small computer type fan mounted to the louvered cabin heat panel. Not flying yet so I don't know how well it will work. I used round aluminum flanges at both ends of the SCAT duct. See: http://users.aol.com/n67bt/defrostfan.htm
Bob Trumpfheller
<<I've another one for you:
How has other builders living in cold areas solved this?>>
shaun-s(at)sbcglobal.net Guest
Posted: Sun Feb 19, 2006 5:54 pm Post subject: Defroster-system? |
i wish to opt out
N67BT(at)aol.com wrote: | Quote: | | Quote: | I used a small computer type fan mounted to the louvered cabin heat panel. Not flying yet so I don't know how well it will work. I used round aluminum flanges at both ends of the SCAT duct. See: http://users.aol.com/n67bt/defrostfan.htm
Bob Trumpfheller
rv6capt(at)pacificcoast.n Guest
Posted: Mon Feb 20, 2006 7:36 am Post subject: Defroster-system? |
I live in Canada and have no problems with heat or need for a defroster.
The coldest that I have flown in has only been -23c.
Cheers
Norman
Shaun Smith wrote:
| Quote: | i wish to opt out
duct.
Bob Trumpfheller
rv-9a-online(at)telus.net Guest
Posted: Mon Feb 20, 2006 9:28 am Post subject: Defroster-system? |
Norman Younie wrote:
Cheers
Norman
Geez, Norman, Victoria doesn't really count as a cold climate! Your
lucky if you get frost for a week a year.
I assume, though that you make trips to the interior where it's colder.
By the way, are your daffodils blooming yet ?
Vern Little
9A (White Rock)
Posted: Mon Feb 20, 2006 10:00 am Post subject: Defroster-system? |
My daffodils are all done for the year, although there are still lots of
them around. The trees in town are all in full bloom. I saw a bunch of
roses in full bloom yesterday and the tulips are blooming. Yes I fly
across to Alberta and as you know it gets cold there.
Cheers
Vern Little wrote:
> defroster. The coldest that I have flown in has only been -23c.
> Cheers
> Norman
Vern Little
9A (White Rock)
cgreimer(at)mts.net Guest
Posted: Sun Feb 26, 2006 12:39 pm Post subject: Defroster-system? |
| Quote: | I've another one for you:
I regularly fly in cold temps with my RV-6. I have the dual muffin fan
defroster setup with no hot air feed. I run the fans at anything below 10C
0C and above - canopy and windshield stay relativly clear at all times.
0C to -10C - canopy will fog up during startup and taxi but fans keep the
windshield clear. Once in the air the rest of the canopy will quickly clear
and stay that way until on the ground
-10 to -20C - canopy and windshield will fog up during startup but usually
the fans will keep a small viewing area clear. I need to rub the frost off
the side windows to see adequately during taxi and takeoff. Once in the air
the canopy gradually clears.
-30C and below - the heating/defrost system has a hard time coping but with
cruise power the windshield will become mostly clear. The side windows
require constant manual clearing.
This is all with one person on board as I don't carry a lot of passengers in
winter.
One critical thing is not to overheat yourself and start sweating before
entering the cockpit. If I need to clear snow from the hangar or anything
physical, I'll cool down for awhile before getting in. I usually keep the
canopy cracked until the engine is running, then I open the air vents to
keep the air flowing until I'm ready for takeoff. You dont get any engine
heat at idle anyway.
Curt
RV-6 C-GACR
375 hours
Winnipeg, Canada
