95% Complete??? Registration questions
darinh
PostPosted: Wed Mar 26, 2008 2:03 pm    Post subject: 95% Complete??? Registration questions Reply with quote
First off...why is it that the last 5% of the project takes 95% of the time? Seems like progress has slowed to a snails pace!
Now the questions: For those of you who have done this before, when does one get the FAA involved for registration? Does the plane have to be "ready to fly" before starting the paperwork? Obviously, the plane needs to be ready to go when the DAR inspection is scheduled but can I get started on other paperwork before this? If so, anybody care to give me some pointers?
Just FYI, I would like to be flying the Phase 1 hours by mid summer or earlier if possible.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
avidfox
PostPosted: Wed Mar 26, 2008 2:19 pm    Post subject: 95% Complete??? Registration questions Reply with quote
".....when does one get the FAA involved for registration? "
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/0ca2845e2aafffbb86256dbf00640cb2/$FILE/AC20-27F.pdf
henrysfork1(at)msn.com
PostPosted: Wed Mar 26, 2008 2:26 pm    Post subject: 95% Complete??? Registration questions Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I am going to answer you Darin as I had inspectors from SLC come to Idaho to do mine. I would suggest you start your paper work now. The plane should be pretty well done but it take quit a bit of time to get them there to do the inspection. When they did get there they were not concerned to find mine lacking a couple of things. They were very good to work with and quit helpful. They set up my test flight restrictions and the items left unfinished were completed. I was permitted begin testing with no further inspections. That is the last I heard from them.
Dee Young
Model II
N345DY
avidfox
PostPosted: Wed Mar 26, 2008 2:32 pm    Post subject: 95% Complete??? Registration questions Reply with quote
Hmm...bad link?
try..
http://www.faa.gov/aircraft/gen_av/ultralights/amateur_built/amateur_regs/
And again... http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/0ca2845e2aafffbb86256dbf00640cb2/$FILE/AC20-27F.pdf
Edited to clarify links....
No substitution for 1st hand experience, but a good time line will be found at
Then click on
20-27, Certification and Operation of Amateur-Built Aircraft.
which should take you to:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/0CA2845E2AAFFFBB86256DBF00640CB2?OpenDocument
which will give a PDF link to the original intended reply
Hopes this works...
Steve
84KF
KF5\912UL
fredshiple(at)sbcglobal.n
PostPosted: Wed Mar 26, 2008 5:13 pm    Post subject: 95% Complete??? Registration questions Reply with quote
The EAA will supply an info pack that includes all the necessary papers and clear instructions on when and how to get them to the FAA. The best $12 I spent when building my Kitfox and now registering the RV7.
You need to allow 12 weeks to get your registration completed by the FAA, so should get your registration form, bill of sale and notarized builder form to them now.
Fred
Guy Buchanan
PostPosted: Wed Mar 26, 2008 9:07 pm    Post subject: 95% Complete??? Registration questions Reply with quote
You can do the registration anytime. If you are an EAA
member their membership pages walk you through it nicely. The FAA
also has a nice pamphlet on registration. Working from memory you:
1. Reserve an N number on-line. (You can let the FAA pick it, but why?)
2. Make sure you've got a complete bill of sale trace from the
original manufacturer to you. For some reason the FAA has gotten anal
about this.
3. Fill out and mail in your registration with the bill of sale information.
4. Get your registration back.
5. Put on your N numbers. (I wouldn't do it until after registration,
just in case.)
6. Finish the plane, including a complete "conditional inspection".
7. Make an appointment with a convenient DAR. Take out a 3rd mortgage
to pay his fee. (You already took out a 2nd to finish the plane, right?)
8. MAKE SURE THE INFORMATION ON THE DATA PLATE IS EXACTLY WHAT IS ON
THE FAA FORMS. My DAR was seriously anal about this. I don't know
why. I had to redo the forms before his arrival to exactly match my data plate.
9. The DAR comes and verifies that yes, your's looks like an
airplane, helps you fill out the forms, takes your home in payment,
then leaves.
10. You go flying.
11. If you want to do your own conditional inspections you go to your
local FSDO and fill out another form and they'll issue a Repairman's
Certificate. They might even ask if you built it.
Mea culpa if I missed a few steps, it's been a while and I
worked from memory.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
DanM
PostPosted: Thu Mar 27, 2008 4:57 am    Post subject: Re: 95% Complete??? Registration questions Reply with quote
I'm curious, what is the average cost of the FAA or DAR inspection these days?
Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM
msm_9949(at)yahoo.com
PostPosted: Thu Mar 27, 2008 5:23 am    Post subject: 95% Complete??? Registration questions Reply with quote
Darin,
You can get your N number anytime, reserve it on line on FAA site. Just before the FAA or private DAR does the airworthiness inspection, have an EAA technical advisor do a pre-inspection. You can find the nearest TA on EAA's website.
darinh <gerns25(at)netscape.net> wrote:
[quote]--> Kitfox-List message posted by: "darinh"
Now the questions: For those of you who have done this before, when does one get the FAA involved for registration? Does the plane have to be "ready to fly" before starting the paperwork? Obviously, the plane needs to be ready to go when the DAR inspection is scheduled but can I get started on other Be a better friend, newshound, and [quote][b]
dcsfoto
PostPosted: Thu Mar 27, 2008 6:30 am    Post subject: Re: 95% Complete??? Registration questions Reply with quote
1 as a DAR I have never taken a home as payment,in fact the last homebuilt I did for free since it was at my home airport.
you can register any time. do it soon as OKC is in the process of going all digital and seems to be loosing a lot of paperwork.
make sure to keep a unsigned copy and a copy of what you sent.
most DARs in Arkansas charge $450.00 plus expenses if long distance travel is required.
David Model 7 912s Model 3 912
kitfox(at)ida.net
PostPosted: Fri Mar 28, 2008 6:27 am    Post subject: 95% Complete??? Registration questions Reply with quote
I got my paper work from the FAA out of SLC. You should be talking to them
now. The paperwork took quite awhile on both of my planes. They were great
to work with and the inspector was very helpful even before he came to
Idaho. He let me know what he expected before he showed up. That was a
couple of years back so a phone call would be your best bet to get things
started I think.
Albert Smith
MudLake, Idaho
5TD, NSI T, CAP
darinh
PostPosted: Fri Mar 28, 2008 9:00 am    Post subject: Re: 95% Complete??? Registration questions Reply with quote
Thank for the info guys! I have my n-number reserved and have since read the AC on registration of homebuilt aircraft. This document has provided everything I need so I am sending the paperwork in today.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
