		cs(at)charlesstringham.co Guest
				 Posted: Sun Aug 22, 2010 4:38 pm    Post subject: Floor Covering |
				Greetings Fellow RVers,
 Quick Build RV-8 wings and fuselage are coming next week, so I'm finishing up on the hangar. I got this new Rustoleum Epoxyshield garage floor 2-part epoxy. The contractor used a cure/sealer on the concrete slab. Instructions from Rustoleum say the product can't be applied over a sealer--must be to bare concrete. The contractor said use muriatic acid to remove the cure/sealer. Rustoleum instructions say not to use muriatic acid, instead to use the citric acid provided with the kit. But the citric acid doesn't seem to remove the cure/sealer. I will probably call Rustoleum tomorrow, but does anyone have suggestions?
 Thanks, Chet
  |  | - The Matronics RV8-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sun Aug 22, 2010 6:42 pm    Post subject: Floor Covering |
				I rented a floor surface grinder/concrete shaver and ran it all over the floor of my hangar prior to paint.  Mine too was sealed and it seems to have worked great.  3 years do far and no paint lifting.
 -Mike
 On Aug 22, 2010, at 8:34 PM, "cs(at)charlesstringham.com" <cs(at)charlesstringham.com> wrote:
  Thanks, Chet
				 Posted: Sun Aug 22, 2010 8:01 pm    Post subject: Floor Covering |
				Cool, thanks Mike.
		wpaulin(at)usa.net Guest
				 Posted: Sun Aug 22, 2010 8:29 pm    Post subject: Floor Covering |
				Yes,
 Do not use Rustoleum.   It will chip and peal and come off from oil or fuel or even just time.  I know, I tried it in a garage.
 Hire a professional you find on line to put on an industrial grade product.  If you search on line, you will find pilot / hangar horror stories as I did after my first try.  My second try with a pro worked fine.
 Thanks, Chet
 William L. Paulin, Ph.D.
 1575 South Forest Drive
 Prescott, AZ 86303
 Cell         +1 858 722 2905
 Office      +1 760 720 2905
 Europe  +358 40 720 4047
 wpaulin(at)usa.net
		Terry Watson
  Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
				 Posted: Sun Aug 22, 2010 9:14 pm    Post subject: Floor Covering |
				Aviation Consumer did a comparison and report on hanger (garage) floor paint
 a year or two ago.
 Terry
				 Posted: Sun Aug 22, 2010 10:36 pm    Post subject: Floor Covering |
				yes , thanks.  That is where I got sent to the pros.
  bill
 a year or two ago.
 Terry
				 Posted: Mon Aug 23, 2010 2:18 am    Post subject: Floor Covering |
				I used this stuff:
 http://www.epoxy-coat.com/
 A buddy and I did it ourselves in about 8 hours.  44x62' hangar floor.  One guy mixes and pours, the other squeegies and rolls.
 I was pleased with the results after 3 years.  I too was told to stay away from the Rust Oleum stuff (although I like their other paint products)
 -Mike Kraus
 On Aug 23, 2010, at 12:28 AM, "William L. Paulin" <wpaulin(at)usa.net> wrote:
  Yes,
  Thanks, Chet
  Prescott, AZ 86303
  wpaulin(at)usa.net
		geezer02(at)windstream.ne Guest
				I used Rustoleum on my hanger floor more than 10 years ago and it is still great. I did sand the floor first, using a rental floor polisher with an open grit. then applied two coats.
 Louis Someday RV-8
  a year or two ago.
  Terry
