cs(at)charlesstringham.co Guest
Posted: Sun Aug 22, 2010 4:38 pm Post subject: Floor Covering |
Greetings Fellow RVers,
Quick Build RV-8 wings and fuselage are coming next week, so I'm finishing up on the hangar. I got this new Rustoleum Epoxyshield garage floor 2-part epoxy. The contractor used a cure/sealer on the concrete slab. Instructions from Rustoleum say the product can't be applied over a sealer--must be to bare concrete. The contractor said use muriatic acid to remove the cure/sealer. Rustoleum instructions say not to use muriatic acid, instead to use the citric acid provided with the kit. But the citric acid doesn't seem to remove the cure/sealer. I will probably call Rustoleum tomorrow, but does anyone have suggestions?
Thanks, Chet
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
n223rv(at)wolflakeairport Guest
Posted: Sun Aug 22, 2010 6:42 pm Post subject: Floor Covering |
I rented a floor surface grinder/concrete shaver and ran it all over the floor of my hangar prior to paint. Mine too was sealed and it seems to have worked great. 3 years do far and no paint lifting.
-Mike
On Aug 22, 2010, at 8:34 PM, "cs(at)charlesstringham.com" <cs(at)charlesstringham.com> wrote:
Thanks, Chet
Posted: Sun Aug 22, 2010 8:01 pm Post subject: Floor Covering |
Cool, thanks Mike.
wpaulin(at)usa.net Guest
Posted: Sun Aug 22, 2010 8:29 pm Post subject: Floor Covering |
Yes,
Do not use Rustoleum. It will chip and peal and come off from oil or fuel or even just time. I know, I tried it in a garage.
Hire a professional you find on line to put on an industrial grade product. If you search on line, you will find pilot / hangar horror stories as I did after my first try. My second try with a pro worked fine.
Bill
Thanks, Chet
William L. Paulin, Ph.D.
1575 South Forest Drive
Prescott, AZ 86303
Cell +1 858 722 2905
Office +1 760 720 2905
Europe +358 40 720 4047
wpaulin(at)usa.net
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Sun Aug 22, 2010 9:14 pm Post subject: Floor Covering |
Aviation Consumer did a comparison and report on hanger (garage) floor paint
a year or two ago.
Terry
Posted: Sun Aug 22, 2010 10:36 pm Post subject: Floor Covering |
yes , thanks. That is where I got sent to the pros.
bill
a year or two ago.
Terry
Posted: Mon Aug 23, 2010 2:18 am Post subject: Floor Covering |
I used this stuff:
http://www.epoxy-coat.com/
A buddy and I did it ourselves in about 8 hours. 44x62' hangar floor. One guy mixes and pours, the other squeegies and rolls.
I was pleased with the results after 3 years. I too was told to stay away from the Rust Oleum stuff (although I like their other paint products)
-Mike Kraus
On Aug 23, 2010, at 12:28 AM, "William L. Paulin" <wpaulin(at)usa.net> wrote:
Yes,
Bill
Thanks, Chet
Prescott, AZ 86303
wpaulin(at)usa.net
geezer02(at)windstream.ne Guest
I used Rustoleum on my hanger floor more than 10 years ago and it is still great. I did sand the floor first, using a rental floor polisher with an open grit. then applied two coats.
Louis Someday RV-8
a year or two ago.
Terry
