jdm(at)wideworld.net Guest
Posted: Thu May 25, 2006 5:16 pm Post subject: Nose Repairs Needed |
Question for the group. I cracked the gel coat and..... er.... ah.... well,
a little more on a nose up landing. It repairable but I can't tell if it's
polyester or epoxy. Any help would be appreciated. Thank you in advance!
John Murr
Original Firestar
John Bickham
Joined: 10 Jan 2006 Posts: 170 Location: St. Francisville, LA
Posted: Thu May 25, 2006 11:06 pm Post subject: Re: Nose Repairs Needed |
Hey John M.
I can help a little on this. Just went through the same thing. I had a freind who helped me. Some may know him from MV 2004 - Bruce Williams (Kitfox). He loves to play with fiberglass. He has built a couple of glass planes. He basically worked on this while I worked on some other stuff.
This is what I ordered from Aircraft Spruce. Not sure if you are talking about just a few small cracks or worse. I deformed mine to where it lost it's original shape. If your job is smaller, may not need all this. We had some material left over. It wasn't cheap and it was a lot of labor (sanding). Think I spent about $100.00 plus sandpaper. New cone was over $400.
Need to epoxy prime, sand smooth to fill and blend and if necessary prime one more time before final finish coats.
09-00100 DACRON FABRC 1.8 OZ X 64" #611 (release fabric)
4533-60 S-GLASS-STYLE 4533 5.8 OZ. 60" (Bi-directional)
01-07355 VINYL ESTER 411-350PA 1G KIT
If you need more help, Bruce would be the one to really talk to. Contact me off-list.
Check the before and after pictures to see what I was up against. Hope this was helpful. Got to remember to put thee attactments in backwards order!
Description: |
Filesize: |
825.12 KB |
Viewed: |
498 Time(s) |
Description: |
Filesize: |
27.25 KB |
Viewed: |
476 Time(s) |
_________________ Thanks too much,
John Bickham
Mark III-C w/ 912UL
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for. |
jindoguy(at)gmail.com Guest
Posted: Fri May 26, 2006 4:24 am Post subject: Nose Repairs Needed |
John, The rule is that you can put epoxy over polyester, but not the other
way around. Prep the area with 220 grit sandpaper tapering out 2" either
side of the crack, use peel ply over the patch so it won't lift the edges
and also to save a lot of time filling the weave for finish.
On 5/25/06, John Murr <jdm(at)wideworld.net> wrote:
well,
it's
polyester or epoxy. Any help would be appreciated. Thank you in advance=
Quote: |
John Murr
Original Firestar
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
--=20
Rick Girard
"Pining for a home on the Range"
planecrazzzy Guest
Posted: Fri May 26, 2006 4:36 am Post subject: Re: Nose Repairs Needed |
I notice that it had a nose skid "hoop" on it....
was it just too small ?
Mines been called a Monster but it works like it should... and until I'm satisfied that I don't need it any more....It'll stay on...
The nose is off the ground 5" when the hoop touches...
Here's some pictures of it...
http://wingsforum.com/viewtopic.php?t=174
Gotta Fly...
Mike in MN
Posted: Fri May 26, 2006 8:57 am Post subject: Nose Repairs Needed |
I don't have a hoop. You must have me confused with someone else. I
picture of my plane is on Frappr (South Central PA)
thanks!
Thanks!
planecrazzzy Guest
Posted: Fri May 26, 2006 5:10 pm Post subject: Re: Nose Repairs Needed |
I was looking at the "BEFORE" picture......It has a "hoop" but yet the nose was damaged.... ( Bickham's )
Gotta Fly...
Mike / N381PM
wcm(at)tampabay.rr.com Guest
Posted: Sat May 27, 2006 4:19 am Post subject: Nose Repairs Needed |
That's because his "hoop" wasn't the same diameter as a 55 gal. oil drum.
John Bickham
Posted: Sat May 27, 2006 5:53 am Post subject: Re: Nose Repairs Needed |
Just in case there is some confusion. I think we are talking about two different incidents. The damage to my nose cone (before & after pics) was the result of an engine out, off-field landing in a hayfield. Due to bad pilot decision making. It dropped in from 8 -10 feet. Not a simple nose over.
I was lucky nothing hurt me. First thing I checked for while the dust was settling was if a broken piece of tubing was sticking in me somewhere. No hoop would have minimized the damage in my case. I concede that my situation was my own fault. However, engine outs are part of the business. I'm not sure I would want that long piece of tubing down there aimed at my nasal cavity - like a pungee stick.
Not being critical of the large hoop idea. Think it may be good for taxi test. Just sharing my perspective and limited bad experience. To each his own.
Be safe. It just takes a few small wrong decisions to put you in a terrible spot. The first mistake is usually "nothing like that will ever happen to me".
John Bickham
Mark III-C w/ 912UL
planecrazzzy Guest
Posted: Sat May 27, 2006 7:45 am Post subject: Re: Nose Repairs Needed |
wcm(at)tampabay.rr.com wrote: | That's because his "hoop" wasn't the same diameter as a 55 gal. oil drum.
My Hoop isn't that big , But THANKS for being a "SMART" Azz
Gotta go now.....
planecrazzzy Guest
Posted: Sat May 27, 2006 7:50 am Post subject: Re: Nose Repairs Needed |
John Bickham wrote: | Just in case there is some confusion. I think we are talking about two different incidents. The damage to my nose cone (before & after pics) was the result of an engine out, off-field landing in a hayfield. Due to bad pilot decision making. It dropped in from 8 -10 feet. Not a simple nose over.
Oouch ! I hope that was all that was damaged.... Well, it probly bent the
gear too...
Gotta Fly...
Mike in MN
PS Yesterday was the first day that I could fly my plane without a coat...
