EFIS Comparisons
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
gmvouga(at)hotmail.com
PostPosted: Thu Jan 12, 2006 8:03 pm    Post subject: EFIS Comparisons Reply with quote
Hi all,
I've been muddling through all the different EFIS's trying to decide which
one to put in my RV-7A. I'm leaning toward the Blue Mountain E-1, but
frankly, the company scares the hell out of me. I've even heard of several
new systems that have come to market (or are about to) over the last year.
I'd like to put together a comparison of features to help me with my
decision. Has anyone already done this? If you already have a spreadsheet
that you wouldn't mind sharing I would appreciate it.
Greg
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
jan.de.jong(at)xs4all.nl
PostPosted: Fri Jan 13, 2006 3:07 am    Post subject: EFIS Comparisons Reply with quote
I'm not at that stage yet and don't have a spreadsheet.
I would like to mention what I think is the most important feature of
all: is it failsafe.
Will it tell you when a function is not working? Or will it lie to you?
The more useful a function the more you rely on it. The more you rely on
it the greater the danger.
The failsafe feature involves the crosschecking of built-in redundancy
and must have been designed in from the beginning.
The alternative is to supply both the redundancy and the monitoring
externally yourself - increasing cost, workload.and insecurity.
Good luck.
Jan de Jong
Greg Vouga wrote:
Hi all,
Greg
PostPosted: Fri Jan 13, 2006 6:30 am    Post subject: EFIS Comparisons Reply with quote
I agree, reliability is definitely going to weigh in on my decision.
Reply-To: avionics-list(at)matronics.com
Subject: Re: EFIS Comparisons
Date: Fri, 13 Jan 2006 12:08:52 +0100
Good luck.
Jan de Jong
Greg Vouga wrote:
>Hi all,
which
several
year.
spreadsheet
>Thanks,
>Greg
mlas(at)cox.net
PostPosted: Fri Jan 13, 2006 7:55 am    Post subject: EFIS Comparisons Reply with quote
Greg,
I have used most of the systems out there from the Dynon up to the
Honeywell systems. The system I settled on was the Chilton EFIS with a
Blue Mountain EFIS G-3 Lite as a backup. I also incorporated the
Trutrak Gyro stabilized Sorcerer autopilot as a standalone gyro
platform.
The reason for the Chilton was all the functions with the history of
reliability and customer satisfaction. I can't understate the number of
functions in the Chilton; here are a few that I thought were very
important. First the Chilton has full flight management including
Stars, Sid, Jet airways and Victor airways. It has every runway
approach and is very easy to use. For the VFR pilot this may not be
very important but for the IFR pilot no other EFIS comes close in the
price range. Another function is the ground mapping with obstacles,
these days more and more EFIS systems are offering this function but the
Chilton offers an additional feature, it has a terrain warning system
like the ground proximity on the airliners and transport aircraft. So
if you are running around and something pops up in front of you, you
will get a voice and visual command to pull up. This function is worth
its weight in gold if you fly in poor weather or at night. The Chilton
also offers full flight director function, full digital autopilot
integration with the Trutrak line, satellite weather, TIS traffic
warning, Storm Scope function, a performance gliding function which give
you information for gliding distance in the event of an engine failure.
This function is dynamic in that it corrects for wind, direction of
travel and height above terrain. The Chilton is also scaleable, you can
add as much redundancy as you can afford. You could have up to four
gyros, GPS's, and Air Data Computer if you wanted making it a standalone
system. The down side is cost. The basic two screen system with most
of the function listed above is around $27,000.
On to the Dynon, I have flown behind this unit in several aircraft. At
face value for the price it is a good unit. I have not had a failure
and it seems to perform good to fair. Sometimes it does strange things
in Yaw and Roll but seems to be stable overall. As far as the engine
monitor system I think it is a waste of money, there are many other
unites out their that are better and more readable such as the Grand
Rapids, Advanced Flight Systems AF-2500 (great unit), or the I-K
Technologies AIM-3000 or 4000. I would not consider the Dynon as a
primary for IFR but it would make a good backup or VFR unit.
The unit that I liked better then the Dynon for simple operations was
the Blue Mountain EFIS. On function that put the BM above the Dynon is
it's intergraded Nav GPS function. For a few hundred bucks you also get
a GPS with map and also a Nav interface for LOC/GS interface. The
performance of the small G3 over the old Lite is much improved. It is
on par with the Dynon for rates and stability, whereas the older unit
was a boat anchor. The EFIS one from BM is nice but it is pricey for
what you get. You have a unit that is not stand alone and never well be
with no flight management function. So it is a VFR navigator only. One
other thing to mention is that bigger is not always better, I fly an
Airbus to fund my small airplane interests and it has a smaller screen
then the BM. What I'm trying to say is that the BM looks good but
wastes precious panel space with the very large screen.
On to OP Technologies, from what I have seen this is a good unit that
has many functions of the Chilton for less money and they put it on your
choice of different size screens. I have briefly flown behind this unit
and find that it seems to work very well. The only issues I have heard
from owners is they are still teething with the software.
The Grand Rapids Technologies units are also a good choice for the
money. They have a little less on the function and the glitter but work
very well. I would say the GRT stability and reliability is almost on
par with the Chilton. The GRT is a little cruder but works very well.
A little note is that GRT has been making units for different companies
and has been in the business of Avionics for a long time, so they have a
good track record.
And lastly is Avidyne, very pricey but works well and like the Chilton
has a certified version. My personal opinion is that like Gamin the
Avidyne is not very ergonomic and can be difficult to use intuitively,
all and all very stable and reliable.
Mike
cjensen(at)dts9000.com
PostPosted: Fri Jan 13, 2006 8:37 am    Post subject: EFIS Comparisons Reply with quote
Greg,
Chuck Jensen
Greg,
Mike's summary of the features and relative merits of the individual
company's (a VERY important instrument feature) as well as the dollar
value of each seems reasonably accurate and comprehensive.
I too canvassed the features of each of the listed units, though I did
not have the same operating experience as Mike. I came to the
conclusion that GRT EFIS represented the best value for high
reliability, excellent feature set and unquestioned company credibility.
After a few hundred hours of flying the dual GRT EFIS and TruTrak GSVS
A/P, I have nothing but satisfaction to report. Yes, the resolution on
the GRT screen is a bit low, but for PFD and engine information
purposes, its more than accurate. Depicting weather and terrain may
suffer a little, but unless you're a Freight Dog or fly a lot of heavy
IFR in heavy traffic area (i.e. if you flight plan Newark, NJ) you will
find it very satisfactory. Not quite as polished as the Chilton, but
then, you can buy a lot of avgas with the $17,000 difference.
Chuck
Velocity XLRG
Greg,
platform.
good track record.
Mike
Tim(at)MyRV10.com
PostPosted: Fri Jan 13, 2006 9:05 am    Post subject: EFIS Comparisons Reply with quote
You guys and you're "Chiltons". I use those for fixing
my truck. But for flying, I'm planning instead to use
my "Cheltons".
http://www.chelton.com/comp/company_profile.asp?companyid=12
http://www.d2av.com/
<all in good fun...and to help keep the archives full of
proper search terms>
Tim Olson -- RV-10 #40170
DO NOT ARCHIVE
Chuck Jensen wrote:
Greg,
Chuck Jensen
Greg,
Chuck
Velocity XLRG
Greg,
platform.
good track record.
Mike
LarryRosen(at)comcast.net
PostPosted: Fri Jan 13, 2006 9:21 am    Post subject: EFIS Comparisons Reply with quote
But not when you put Do No Archive in the post.
Larry Rosen
All in Good fun Smile
DO NOT ARCHIVE
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
