		rv10free2fly(at)yahoo.com Guest
				 Posted: Tue Jun 10, 2014 1:06 am    Post subject: Mounting External Plane Power Voltage Regulator |
				I'd like to hear from other builders please regarding the mounting of their external Plane a Power (or similar) voltage regulator.
 I was thinking of mounting my external voltage regulator in the sub panel behind the main panel.
 My only concern is accessibility to the regulator in the mounted position, without having to be a contortionist to gain access to the sub panel once all is completed.
 I'd be interested to hear from anyone (and see pictures) who has devised a 'drop down' mounting panel which can provide easy access.
 Your thoughts would be greatly appreciated please.
 Warm regards
 Patrick
 South Australia
		rleffler
				 Posted: Tue Jun 10, 2014 1:29 am    Post subject: Mounting External Plane Power Voltage Regulator |
				I put the voltage regulator for my backup alternator behind the sub panel.   I ran out of room to mount it on the main panel.   I've had to get behind the sub panel for other reasons several times. Once you take the stick out, it isn't too bad getting back there.
 Bob
 Sent from my iPad
  	  | Quote: | 	 		   On Jun 10, 2014, at 5:05 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
  Warm regards
  Patrick
  South Australia
  _________________ Bob Leffler
N410BL - Phase I
				 Posted: Tue Jun 10, 2014 3:20 am    Post subject: Mounting External Plane Power Voltage Regulator |
				Bob
 Thanks for the reassurance
 Warm regards
 Patrick
  	  | Quote: | 	 		   On 10 Jun 2014, at 18:58, Bob Leffler <rv(at)thelefflers.com> wrote:
  Bob
  Sent from my iPad
 > Warm regards
 > Patrick
 > South Australia
		flying-nut(at)cfl.rr.com Guest
				 Posted: Tue Jun 10, 2014 7:47 am    Post subject: Mounting External Plane Power Voltage Regulator |
				I wouldn't mount it on the sub-panel just for the reasons you gave.  And
 there's accessibility problems in case you have to troubleshoot a
 charging issue.  I'd mount it on the firewall or on a bracket near the
 alternator.
 However, I'm curious why you want to mount the regulator inside the
 cabin instead of on the engine side of the firewall.
 Linn
 On 6/10/2014 5:05 AM, Patrick Pulis wrote:
  Warm regards
  Patrick
  South Australia
  Checked by AVG - www.avg.com
				 Posted: Tue Jun 10, 2014 8:16 am    Post subject: Mounting External Plane Power Voltage Regulator |
				I'm just curious as to why you are using an alternator with an external
 regular?  As we know this charging system design went out in the mid 60s on
 cars and for good reason.  The Plane Power alternator like Van's sells has
 an internal regulator.  I have several years using this alternator on two
 RVs and they have been trouble free.
 Carl
				 Posted: Tue Jun 10, 2014 8:58 am    Post subject: Mounting External Plane Power Voltage Regulator |
				Linn
 That's probably because there are recommendations to mount the regulator on
 the cabin side of the firewall.
 Carlos
				 Posted: Tue Jun 10, 2014 10:20 am    Post subject: Mounting External Plane Power Voltage Regulator |
				Where did those recommendations come from???
 I've never seen a voltage regulator installed inside the cabin on
 certified A/C nor all the homebuilts I've ever looked at.  I seriously
 doubt that the cabin-side recommendations came from Plane Power.
 Linn
 On 6/10/2014 12:59 PM, Carlos Trigo wrote:
  Linn
  Carlos
		bcondrey
				 Posted: Tue Jun 10, 2014 10:37 am    Post subject: Mounting External Plane Power Voltage Regulator |
				Here's one recommendation to mount on the cabin side of the firewall from
 the B&C regulator instructions in the first paragraph:
 http://www.bandc.biz/pdfs/LR3C_Wiring_and_Installation_RevC.pdf
 Bob
 On Tue, Jun 10, 2014 at 1:19 PM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
  Linn
 > Linn
 > on
 > Carlos
				 Posted: Tue Jun 10, 2014 11:11 am    Post subject: Mounting External Plane Power Voltage Regulator |
				Thank you Bob!  I'm a better educated       consumer.
        I've seen temps inside the cabin (closed up, of course) higher       than the engine compartment a few times but that's not a great       statistical sample.
        For that very reason I would not buy the B&C, but wouldn't       know about that suggestion until I had already purchased it.
        The Plane Power regulator doesn't have that particular suggestion       ...... I checked.
        Linn
        On 6/10/2014 2:37 PM, Bob Condrey wrote:
      [quote]       Here's one recommendation to mount on the cabin side of the         firewall from the B&C regulator instructions in the first         paragraph:
        Bob
        On Tue, Jun 10, 2014 at 1:19 PM, Linn         Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>         wrote:
          [quote]--> RV10-List           message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
            I've never seen a voltage regulator installed inside the cabin           on certified A/C nor all the homebuilts I've ever looked at.            I seriously doubt that the cabin-side recommendations came           from Plane Power.
            Linn
            [quote]-->             RV10-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
              Linn
              Carlos
		bcondrey
				 Posted: Tue Jun 10, 2014 11:22 am    Post subject: Mounting External Plane Power Voltage Regulator |
				Lancair actually mounts them on the engine side of the firewall from the factory for those that chose quick build firewall stuff.   Here's also a comment from Bob Nuckolls on the subject:
  "EVERY manufacturer would like to have you place THEIR product
 in the most benign environment possible. But the bottom line is
 that short of bolting the LR3 to an engine or exhaust part,
  it will be fine on the forward side of the firewall also."
 Bob
  On Tue, Jun 10, 2014 at 2:10 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
  [quote]  Thank you Bob!  I'm a better educated consumer.
  Linn
  Bob
  Linn
 Linn
 Carlos
		bobw
				Both of the regulators on my C310 were under the right front passengers seat.
 Bob Wilson
  _________________ Bob Wilson
bob@rjw.cc |
		gengrumpy
  Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
				 Posted: Tue Jun 10, 2014 4:52 pm    Post subject: Mounting External Plane Power Voltage Regulator |
				Mine is mounted on the left sidewall just forward of the door.
 Been there since 2006 and works just fine there.
 Hid it behind one of Abbey's side panels.  Easy to get to if needed.
 grumpy
 N184JM
 do not archivie
 On Jun 10, 2014, at 1:37 PM, Bob Condrey <condreyb(at)gmail.com (condreyb(at)gmail.com)> wrote:
 [quote]Here's one recommendation to mount on the cabin side of the firewall from the B&C regulator instructions in the first paragraph:
  Bob
  Linn
 Linn
 Carlos
