rv10free2fly(at)yahoo.com Guest
Posted: Tue Jun 10, 2014 1:06 am Post subject: Mounting External Plane Power Voltage Regulator |
I'd like to hear from other builders please regarding the mounting of their external Plane a Power (or similar) voltage regulator.
I was thinking of mounting my external voltage regulator in the sub panel behind the main panel.
My only concern is accessibility to the regulator in the mounted position, without having to be a contortionist to gain access to the sub panel once all is completed.
I'd be interested to hear from anyone (and see pictures) who has devised a 'drop down' mounting panel which can provide easy access.
Your thoughts would be greatly appreciated please.
Warm regards
Patrick
South Australia
rleffler
Posted: Tue Jun 10, 2014 1:29 am Post subject: Mounting External Plane Power Voltage Regulator |
I put the voltage regulator for my backup alternator behind the sub panel. I ran out of room to mount it on the main panel. I've had to get behind the sub panel for other reasons several times. Once you take the stick out, it isn't too bad getting back there.
Bob
Sent from my iPad
Quote: | On Jun 10, 2014, at 5:05 AM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Warm regards
Patrick
South Australia
_________________ Bob Leffler
N410BL - Phase I
Posted: Tue Jun 10, 2014 3:20 am Post subject: Mounting External Plane Power Voltage Regulator |
Bob
Thanks for the reassurance
Warm regards
Patrick
Quote: | On 10 Jun 2014, at 18:58, Bob Leffler <rv(at)thelefflers.com> wrote:
Bob
Sent from my iPad
> Warm regards
> Patrick
> South Australia
flying-nut(at)cfl.rr.com Guest
Posted: Tue Jun 10, 2014 7:47 am Post subject: Mounting External Plane Power Voltage Regulator |
I wouldn't mount it on the sub-panel just for the reasons you gave. And
there's accessibility problems in case you have to troubleshoot a
charging issue. I'd mount it on the firewall or on a bracket near the
alternator.
However, I'm curious why you want to mount the regulator inside the
cabin instead of on the engine side of the firewall.
Linn
Warm regards
Patrick
South Australia
Checked by AVG - www.avg.com
Posted: Tue Jun 10, 2014 8:16 am Post subject: Mounting External Plane Power Voltage Regulator |
I'm just curious as to why you are using an alternator with an external
regular? As we know this charging system design went out in the mid 60s on
cars and for good reason. The Plane Power alternator like Van's sells has
an internal regulator. I have several years using this alternator on two
RVs and they have been trouble free.
Carl
Posted: Tue Jun 10, 2014 8:58 am Post subject: Mounting External Plane Power Voltage Regulator |
Linn
That's probably because there are recommendations to mount the regulator on
the cabin side of the firewall.
Carlos
Posted: Tue Jun 10, 2014 10:20 am Post subject: Mounting External Plane Power Voltage Regulator |
Where did those recommendations come from???
I've never seen a voltage regulator installed inside the cabin on
certified A/C nor all the homebuilts I've ever looked at. I seriously
doubt that the cabin-side recommendations came from Plane Power.
Linn
On 6/10/2014 12:59 PM, Carlos Trigo wrote:
Linn
Carlos
bcondrey
Posted: Tue Jun 10, 2014 10:37 am Post subject: Mounting External Plane Power Voltage Regulator |
Here's one recommendation to mount on the cabin side of the firewall from
the B&C regulator instructions in the first paragraph:
http://www.bandc.biz/pdfs/LR3C_Wiring_and_Installation_RevC.pdf
Bob
On Tue, Jun 10, 2014 at 1:19 PM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
Linn
> Linn
> on
> Carlos
Posted: Tue Jun 10, 2014 11:11 am Post subject: Mounting External Plane Power Voltage Regulator |
Thank you Bob! I'm a better educated consumer.
I've seen temps inside the cabin (closed up, of course) higher than the engine compartment a few times but that's not a great statistical sample.
For that very reason I would not buy the B&C, but wouldn't know about that suggestion until I had already purchased it.
The Plane Power regulator doesn't have that particular suggestion ...... I checked.
Linn
On 6/10/2014 2:37 PM, Bob Condrey wrote:
[quote] Here's one recommendation to mount on the cabin side of the firewall from the B&C regulator instructions in the first paragraph:
Bob
On Tue, Jun 10, 2014 at 1:19 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote]--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
I've never seen a voltage regulator installed inside the cabin on certified A/C nor all the homebuilts I've ever looked at. I seriously doubt that the cabin-side recommendations came from Plane Power.
Linn
[quote]--> RV10-List message posted by: "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
Linn
Carlos
bcondrey
Posted: Tue Jun 10, 2014 11:22 am Post subject: Mounting External Plane Power Voltage Regulator |
Lancair actually mounts them on the engine side of the firewall from the factory for those that chose quick build firewall stuff. Here's also a comment from Bob Nuckolls on the subject:
"EVERY manufacturer would like to have you place THEIR product
in the most benign environment possible. But the bottom line is
that short of bolting the LR3 to an engine or exhaust part,
it will be fine on the forward side of the firewall also."
Bob
On Tue, Jun 10, 2014 at 2:10 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote] Thank you Bob! I'm a better educated consumer.
Linn
Bob
Linn
Linn
Carlos
bobw
Both of the regulators on my C310 were under the right front passengers seat.
Bob Wilson
_________________ Bob Wilson
bob@rjw.cc |
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Tue Jun 10, 2014 4:52 pm Post subject: Mounting External Plane Power Voltage Regulator |
Mine is mounted on the left sidewall just forward of the door.
Been there since 2006 and works just fine there.
Hid it behind one of Abbey's side panels. Easy to get to if needed.
grumpy
N184JM
do not archivie
On Jun 10, 2014, at 1:37 PM, Bob Condrey <condreyb(at)gmail.com (condreyb(at)gmail.com)> wrote:
[quote]Here's one recommendation to mount on the cabin side of the firewall from the B&C regulator instructions in the first paragraph:
Bob
Linn
Linn
Carlos
