		cakeykev(at)gmail.com Guest
				 Posted: Mon May 14, 2018 8:01 am    Post subject: Orientation of NAV/VOR antenna compared to COM antenna |
				My aerial is inside the fuselage, keeps clean doesn’t get knocked works fine.
 Kevin Challis
 G ODJG
  	  | Quote: | 	 		   On 14 May 2018, at 16:40, carlp101 <cparkinson(at)cisc-uk.com> wrote:
  Hi Christoph,
  I've just fitted a VOR/GS antenna on the belly of my Europa Tri-Gear just aft of the hatch for the central tunnel on the underside (see attached pic). It works a treat and it's all signed-off by the LAA inspector! It's a CI 157P antenna. You can either have the V of the antenna pointing forwards or backwards.
  Carl
  G-URMS
  http://forums.matronics.com/viewtopic.php?p=480114#480114
  http://forums.matronics.com//files/antenna_fitted_812.jpg
		rampil
				 Posted: Tue May 15, 2018 11:56 am    Post subject: Re: Orientation of NAV/VOR antenna compared to COM antenna |
				Just because metal fused aircraft needs external vhf antennae, does
 not mean it is required for glass aircraft.  It only adds drag.
		AirEupora
